Ø
B±0.20
F
D±0.30
2.50±0.10
G
10
1.
7.00±0.20
D
H
2.54
3.00±0.20
A ±0.50
Recommended PCB Layout
(Tolerance:±0.05mm)
Specifications
E
Plating
Underplating: 30µ”-50µ” Nickel
Contact Area: Gold Flash
2.50±0.10
D
Material
Insulator: LCP, UL94V-0, Natural
Contact: Brass
Ordering Grid
0.64 sq. Pin
BG305
2.54±0.10
No. of
Contacts
2
3
4
5
6
7
8
9
10
11
12
C
B
A
XX
X
0500
L
X
No. of Contacts
02 to 12
Packing Options
G = Plastic Box (Standard packing for 2 contacts)
D = Tube (Standard packing for 3-6 contacts)
Contact Plating
A = Gold Flash All Over
Dimensions
A
B
5.08
2.54
7.62
5.08
10.16
7.62
12.70
10.16
15.24
12.70
17.78
15.24
20.32
17.78
22.86
20.32
25.40
22.86
27.94
25.40
30.48
27.94
Request Samples
and Quotation
Insulator Material
L = LCP (Natural)
(Other plating options
available on request)
e.g. 1000 = 10.00mm
(Maximum 2500=25.00mm)
(Minimum 0500=5.00mm)
Mates with:
BG306 or Direct solder to PCB
Part Number
Product Description
BG305
2.54mm Pitch Pin Header, Single Row, U-Shaped,
Thru-Hole, Dual Insulator, Natural LCP
Drawing Date
7th December 2011
By
2
Mechanical & Environmental
Operating Temperature: -40°C to +105°C
Soldering Process:
Wave : 250°C for 5-10 sec.
Manual Solder: 350°C for 3-5 sec
Dimension D (Footprint width)
0500 = 5.00mm (Standard)
Or specify custom Footprint Width
Detail
1
Electrical
Current Rating: 3A per pin
Contact Resistance: 20 mΩ max.
Insulating Resistance: 1000 MΩ min.
Dielectric Withstand Voltage: 500V AC
3
4
Revision
Date
5
CC
Drawing
Release
A4
01/11/17
Tolerances (Except as Noted)
Length
Angle
Units:
Metric (mm)
X.X ± 0.30
X.XX ± 0.20
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CM
8
Sheet No.
1/1
BG305-06-A-0500-L-D 价格&库存
很抱歉,暂时无法提供与“BG305-06-A-0500-L-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3002+2.658723002+0.34415
