UTS710D6S32
UTS710D6S32
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT FMALE 6POS GOLD SOLDER
UTS710D6S32 数据手册
MALE CONNECTOR C A B B (Without marking) 8 3.2 Maxi (Panel thickness) 4±0,2 SHELL C 17,93+0,15 -0,10 D E F G H d ; 1 ; RL 19,2+0,35 -0,10 FEMALE CONNECTOR PIN SOCKET 8 7 F 6 THREAD 1"20 UNEF CLASS 2A marking thickness 0.2 Ø0,6±0.05 for contact #20 Ø1±0.05 for contact #16 ØA marking thickness 0.2 7 NUT (see tightening torque) INSERT I 6 O' RING PANEL CUT OUT B ±0.20 (without marking) C ±0.20 3.8/6 for layout 8-2/8-3/8-4 3.75/5.8 for layout 8-2/8-3/8-4 4.7/7.25 for layout 8-3A/8-98/8-33 4.8/6.9 for layout 8-3A/8-98/8-33 10 4.9/7 4.9/7 3.1 9/16 24 UNEF CLASS 2A 2 Nm 12 4.8/7 3.85/5.9 for layout 12-14 5.2/7 3.85/5.9 for layout 12-14 14 4.8/7 5.3/7 Thread 13.75 ± 0.20 14.60 ± 0.20 E 5 08 11.90 24.00 19.05 ±0.37 10 14.90 26.90 22.15 16.40 0/+0.2 17.30 0/+0.25 3.1 11/16 24 UNEF CLASS 2A 3 Nm 12 18.95 31.75 27.15 20.85 0/+0.3 22.10 0/+0.3 3.1 7/8 20 UNEF CLASS 2A 4 Nm 14 22.15 34.90 30.20 24.00 0/+0.3 25.40 0/+0.3 3 ± 0.1 1"20 UNEF CLASS 2A 5 Nm UTS7 14 4 3 3,1 ± 0,1 Drill diameter for hold down clip (x2) 5 32 4 D= Dipsolder contacts Insert arrangement (See table) P = Male contact S = Female contact Orientations Normal (no digit), W,X,Y,Z = different orientations PERFORMANCE CHARACTERISTICS : - Operating temperature:-40°C up to 105°C - Insulation resistance:5000 M min - Test potential:2000 Vrms for #16 layout and 1500Vrms for #20 layout - Corrosion salt spray:500 hours - Durability:250 matings and unmatings 2,3 3 Specification CUSTOMER DRAWING B 8,57 7,5 A . Shell size MATERIAL : - Shell:Polyamid UL94 V-0 - Insert:Polychloropren (CR) - Seal gasket : Sealing IP68/69K : Silicone - O'ring:nitril - Nut:Aluminium alloy black anodized - Contact: Brass + gold plated SHELL 10/12/14 D 19 P Jam nut receptacle UTS ØE DRILLING PATTERN FOR HOLD DOWN PINS SHELL 8 J (female connector) Tightening torque (Nut) F ± 0.3 D D A ±0.15 I (male connector) Shell size 8 SHELL SIZE J 2,3 8,57 D 2 Sealing in mated and unmated conditions: -IP68 : 1 bar during 1 week : immersion under 10 m of water (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) 1 3,1 Drill diameter for hold down clip (x2) H G Contact area of receptacle on PCB F E d Perçage 1 Perçage 2 A B C D T10 3.98 9.85 5.31 9.20 T12 4.92 12.17 6.56 11.37 T14 5.29 13.10 7.06 12.23 D 05/12/13 ISS DATE Designed by: TITLE NOTE : Insert arrangements : refer to C144-UTS1-A TAILLE C DRILLING PATTERN: Modification of view and cotation -- -Latest modification - by: SORIN V. Date:19/05/10 LANDAIS.P MOD N° 2 CUSTOMER DRAWING JAM NUT WITH DIPSOLDER CONTACTS UTS HI SEAL SPECIF.32 Scale 2/1 General linear Tolerances: ± 0.2 WWW.SOURIAU.COM FORMAT C A2 NPRDS / PROJECT UTS-HI SEAL This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° C121-UTS1-A B SHEET 1/1 A 1
UTS710D6S32
物料型号:文档中没有明确提供物料型号,但提到了SOURIAU品牌。
器件简介:文档描述了一种高密封性的连接器,适用于恶劣环境,具有多种尺寸和布局选项。
引脚分配:提供了不同尺寸(8、10、12、14)的连接器的引脚分配信息,包括公头和母头的布局。
参数特性:包括操作温度范围(-40°C至105°C)、绝缘电阻(5000 MΩ min)、测试电压(#16布局2000 Vrms,#20布局1500Vrms)、耐腐蚀性(盐雾测试500小时)和耐用性(250次插拔)。
功能详解:文档详细说明了连接器的密封性能,包括IP68和IP69K标准,以及在连接和未连接状态下的密封要求。
应用信息:适用于需要高密封性和耐用性的工业环境。
封装信息:提供了外壳材料(聚酰胺UL94 V-0)、插入材料(聚氯丁橡胶CR)、密封垫圈材料(硅胶,符合IP68/69K)、O型圈材料(丁腈橡胶)、螺母材料(黑色阳极氧化铝合金)和接触材料(黄铜镀金)。
UTS710D6S32 价格&库存
很抱歉,暂时无法提供与“UTS710D6S32”相匹配的价格&库存,您可以联系我们找货
