UTGX6JC-----P
8
7
Operating temperature: -40
C up to 105C
Insulation resistance: 5000 min
M
Corrosion salt spray: 500 hours
Durability: 500 matings and unmatings
Sealing conditions: SEE TABLE
WIRING AREA (between insert and backshell seal)
E4
E3
6
NOTA:
4
1- Contact to be ordered separately for version
UTGX6----- : refer to corresponding catalogue.
2- Insert arrangement refer to:
UTO-CONTACT-L-C02 (Female insulator)
UTO-DHP-003-C01 (Female insulator #20)
UTO-DHP-002-C01 (Female insulator #16)
5
UTO-CONTACT-L-C01 (Male insulator)
UTO-DHP-003-C01 (Male insulator #20)
UTO-DHP-001-C01 (Male insulator #16)
Sealing in MATED conditions with COUNTERPART:
Sealing in MATED conditions with COUNTERPART and UNMATED conditions:
C144-UTS1-A (HiSeal Version)
3- This part shall be used at the place of the
-IP68 1 bar during 1 week: immersion under 10 m of water. (IEC 60529)
-IP69K : exposure to high pressure water of cleaning equipement -IP69K : exposure to high pressure water of cleaning equipement
standard seal to accomodate with different cable
(DIN 40050)
(DIN 40050)
4- Plug, backshell and the reducing seal are delivered a
a kit. The backshell already includes the standard seal.
THREAD
COUPLING RING
BACKSHELL
BODY
3
HEXAGON D
(See tightening torque in table)
CONDITIONS
5
SEALING
SHELL :PA UL94 V0, UL746C F1 Black color
COUPLING RING: PA + Nickel-plated brass
BACKSHELLS : PA UL94 V0 F1 Black color
BACKSHELL Seal : CR
INSERT (UTGX0-----) : PA UL94 V0, UL746C F1
INSERT (UTGX0--E---) : Polychloroprene
O'RING : NITRIL
MATING SEAL : SILICON
CONTACTS: brass + coated depending on P/N
PERFORMANCE CHARACTERISTICS :
BACKSHELL
SEAL
BACKSHELL
NUT
CountryJurisdiction& Control List
FR
NOT LISTED
A MAX
INSERT
SHELL
PLUG
MATING
SEAL
O'RING
P/N : CROSS REF TABLE
SHELL TYPE
2
MAX
STANDARD
MAX
THREAD
CLASS 2A
10% (g.)
1
D
Tightening
torque (N.m)
E1
E2
E3
E4
1.5 / 5
18.5
1
21
34.1
29
33.5
9/16-24 UNEF
30
5 / 12
3 / 9
24
2
25
38.1
33
37.5
11/16-24 UNEF
40
7 / 14
5 / 12
26
2.5
29
42.1
36
40.5
13/16-20 UNEF
53
A
B
C
10
12
14
TYPE OF
CONTACTS
P: MALE
S: FEMALE
TYPE OF
LAYOUT
Standard layout (No digit)
E : HISEAL Handsolder contacts
INSERT
ARRANGEMENT
See NOTA 2
14/02/2020
10
26.2
66
2.5 / 8
12
29.7
69
14
34.6
75.5
Scale
3/2
G
F
E
D
-Update drawing
25253J
Latest modification - by:
J.FEURPRIER
PE.LANDAIS Date:10/05/19
C
A2
CUSTOMER DRAWING
MOD N
3
2
PLUG T6 WITH BACKSHELL JC - SIZE 10 12 & 14, Standard and Hiseal version
UTGX CONNECTOR
Dimensions in mm
General linear
Tolerances:
0.2
www.souriau.com
FORMAT
H
DATE
TITLE
MASS
Normal (no digit)
W,X,Y,Z
SHELL SIZE
Designed by:
HEXAGON backshell nut
Plug
JC
ISS
MAX
6
* P/N for example
BACKSHELL
B
SHELL
SIZE
UTGX 6 JC 14 E 19 P
BASIC SERIES
B MAX
REDUCING
SEAL (NOTA.3)
4
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
CAPACITY
C
6
UTGX6JC-----S
7
COMMON QUOTES FOR ALL VERSION
A
UTGX6JC--E--WIRING AREA (between insert and backshell seal)
E2
E1
B
C
D
E
F
G
H
UTGX6JC-----
MATERIAL :
8
B.3; Validé
SIDE VIEW FOR EACH VERSION
SOURIAU DRG N°
UTGX-0005A-C
B
NPRDS / PROJECT
GBB
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTGX6JC14E15P”相匹配的价格&库存,您可以联系我们找货
