UTS010D98P
UTS010D98P
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT MALE 6POS GOLD SOLDER
UTS010D98P 数据手册
0.25 C Maxi D A 0.25 B 0.25 I (male connector) Shell size 0.15 SOCKET 7 INSERT B 8 J I PIN 0.6 0.05 for contact #20 1 0.05 for contact #16 E 0.15 6 0.25 3,2 0.1 A 7 A B 4 Holes THREAD SHELL SIZE C 8 B 0.25 C MAXI FEMALE CONNECTOR MALE CONNECTOR A 0.25 D 0.15 SHELL D E F G H B.2; Validé F MAXI ØE 0.15 F Maxi 8 G 0.25 H 0.10 5 8 21.00 15.10 21.50 2.30 11.90 11.70 15.10 12.50 10 23.80 18.30 21.50 2.30 14.90 11.70 18.30 15.10 12 26.20 20.60 21.50 2.30 18.95 11.70 20.60 18.20 14 28.60 23.00 21.50 2.30 22.15 11.70 23.00 21.40 Thread 7/16 28 UNEF Class 2A J (female connector) 6 9.76/11.86 for layout 8-2/8-3/8-4 9.55/11.71 for layout 8-2/8-3/8-4 10.78/13.09 for layout 8-3A/8-98/8-33 10.82/12.79 for layout 8-3A/8-98/8-33 10 8.1/10.5 8.15/10.15 12 8.1/10.5 7.2/9.3 for layout 12-14 8.15/10.15 7.3/9.3 for layout 12-14 14 8.1/10.5 8.15/10.15 9/16 24 UNEF Class 2A 11/16 24 UNEF Class 2A UTS0 14 D 19 P . 5 XX Receptacle UTS0 13/16 20 UNEF Class 2A Shell size 4 4 D= Dipsolder contacts Insert arrangement (See table) P = Male contact S = Female contact CUT PANEL MATERIAL : Orientations Normal (no digit), W,X,Y,Z = different orientations G 0.25 3 3 Specification Shell:PBT UL94 V-0 Black color Insert:Polychloroprene Seal gasket :Sealing IP68/69K : Silicone O'seal : Nitril Contact: brass + gold plated Country FR H 0.1 Front panel mounting 2 Operating temperature:-40 C up to 105 C Insulation resistance:5000 M min Test potential:1500Vrms for #20 layout Corrosion salt spray:500 hours Durability:250 matings and unmatings Sealing in mated and unmated conditions: -IP68 1 bar during 1 week : immersion under 10 m of water. (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) NOT LISTED P/N : SEE TABLE G 0.25 PERFORMANCE CHARACTERISTICS : Jurisdiction & Control List B 02/11/2017 ISS DATE Designed by: 3,2 0.1 TITLE Scale 2/1 1 NOTE: Updating shell material 21774A Latest modification - by: J. FEURPRIER Date: COURTOIS L. 11/05/11 CUSTOMER DRAWING RECEPTACLE WITH DIPSOLDER CONTACTS UTS HI SEAL General linear Tolerances: 0.1 WWW.SOURIAU.COM Insert arrangements : refer to C144-UTS1-A H SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) G F E D FORMAT A2 C 2 MOD N NPRDS / PROJECT UTS This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° C143-UTS1-A B SHEET 1/1 A 1
UTS010D98P 价格&库存
很抱歉,暂时无法提供与“UTS010D98P”相匹配的价格&库存,您可以联系我们找货
