NRPN371PAEN-RC
NRPN371PAEN-RC
    SULLINS
    插件,P=2mm
    排针 间距:2mm 1x37P 直插
NRPN371PAEN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY E 2673 9/14/2012 LH F 2828 04/09/2015 LH H 3714 UPDATE NOTE 4(WAS 1 AMP) UPDATE PROCESSING TEMPERATURE FOR NYLON 6T MATERIAL ADD 01-POSITION ON DIMENSION TABLE 07/27/2017 LH F E E B .020[0.50] .079±.008 2.00±0.20 A±.008[0.20] D D .079±.002 2.00±0.05 .142±.008 3.60±0.20 .079 2.00 C C .110±.008 2.80±0.20 .020±.002 0.50±0.05 A±.004 [ .10] 02-20, .008[0.20] MAX. 21-30, .012[0.30] MAX. 31-40, .016[0.40] MAX. .079±.002 2.00±0.05 .031±.002 0.80±0.05 B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: .000030" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL. 4. CURRENT RATING: 2.0 AMPS. 5. VOLTAGE RATING: 150V AC/DC. 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 500V AC. 9. OPERATING TEMPERATURE: -40° C TO +105° C. 10. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY. 8 7 6 5 RECOMMENDED PCB LAYOUT Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 1 DECIMALS .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 09/17/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER MALE 2mm CC, 1 ROW, ST PART NUMBER SIZE C CAGE CODE 54453 SCALE: 16:1 3 A 2 NRPNxx1PAEN-RC DWG. NO. 10531 SHEET 1 OF 1 1 REV H FILE NAME: 10531, NRPN_ _1PAEN-RC
NRPN371PAEN-RC 价格&库存
很抱歉,暂时无法提供与“NRPN371PAEN-RC”相匹配的价格&库存,您可以联系我们找货
