EYG.0B.309.CLN
www.lemo.com
SUMMARY
# Wires
Low voltage
9
Image is for illustrative purpose only
Series
0B
Termination type
Female print PCB
IP rating
50
AWG wire size
34.00 - 28.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.0B.309.CLAD42
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EY*: Fixed receptacle for printed circuit, nut fixing (back panel mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
7.69 g
Performance
Configuration
0B.309 : 9 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.5 mm (0.02in)
R (max): 8.7 mOhm
Vtest (contact-shell): 500 V (AC), 710 V (DC)
Vtest (contact-contact): 600 V (AC), 850 V (DC)
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
C
D
E
M
N
P
S1
e
mm.
12
10
12.5
7.62
2.6
2.5
15
6
8.2
M9x0.6
in.
0,47
0,39
0,49
0,30
0,10
0,10
0,59
0,24
0,32
RECOMMENDED BY LEMO
Tools
2/3
3/3
很抱歉,暂时无法提供与“EYG.0B.309.CLN”相匹配的价格&库存,您可以联系我们找货
