FFA.1S.302.CLAC52
FFA.1S.302.CLAC52
    LEMO(雷莫)
    FFA.1S.302.CLAC52
FFA.1S.302.CLAC52 数据手册
FFA.1S.302.CLAC52 www.lemo.com SUMMARY # Wires Low voltage 2 Image is for illustrative purpose only Series 1S Termination type Male solder IP rating 50 AWG wire size 28.00 - 20.00 Cable Ø 4.20 - 5.20 mm Status active Matching parts ERA.1S.302.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Hermaphroditic keying (half moon insert) with male pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 17.25 g Performance Configuration 1S.302 : 2 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 15 Amps Specifications Contact Type: Solder Contact Dia.: 1.3 mm (0.051in) Bucket Dia.: 1 mm (0.039in) Max. Solid Conductor: 0.5 mm^2 (AWG 20) Max. Stranded Conductor: 0.5 mm^2 (AWG 20) R (max): 3.6 mOhm Vtest: 1200 V (AC), 1800 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 12 42.5 31.5 8.5 in. 0,47 1,67 1,24 0,33 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1S.015.PA085 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.02.T20.047PGZE Grey CMN.02.T20.047PNZE CMN.02.T20.048QGZE TPR (medical) Grey 120240 PVC Black 120250 PVC Grey 120501 PVC Grey 20260 PVC Black 2221 PVC Black 4082 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.1S.302.CLAC52
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
FFA.1S.302.CLAC52 价格&库存
很抱歉,暂时无法提供与“FFA.1S.302.CLAC52”相匹配的价格&库存,您可以联系我们找货
FFA.1S.302.CLAC52
    • 1+312.05063
    • 5+305.25040
    • 25+298.16899
    • 50+291.15006
    库存:38
