PCB Mount Dura-Pull® & Dura-Twist® Connectors
Dura-Pull®
NEW
Option
NPB 653
Dura-Twist®
REAR-MOUNT RECEPTACLES WITH PC-TAIL CONTACTS The Dura-Pull®
and Dura-Twist® series are the first push-pull connectors to offer the harshenvironment reliability Switchcraft/Conxall is known for. These new options
feature “PC-tail” type contacts which are suitable for mounting directly on a
PCB for quick and reliable installation. Visit Switchcraft.com to learn more
about the Dura-Pull® and Dura-Twist series!
IP68
REAR-Mount
Connector Design
Optional Sealed
Unmated
Switchcraft
Quality
Rear-mountable receptacles make it easy
to solder the connectors to a PCB prior to
mounting on a panel.
High
quality,
silicon-based
potting
compound ensures the connector remains
sealed to IP68 - even when unmated!
Built to the same high quality-level and
specifications that the Dura-Pull® and DuraTwist® connector series are known for.
Specifications
Life: 5,000 insert/withdrawals min
Ingress Protection: IP68
Temp. Limits: -40°C to 135°C
Electrical: 10A, 125V AC (2-pin)
Housing: Copper Alloy, Ni Plated
Contacts: Copper Alloy, Au Plated
Insulator: LCP, Natural
O-Rings: Thermoplastic Elastomer
P
- BP
CONNECTOR:
HS2 - Dura-Pull Push-Pull
TS2 - Dura-Twist Threaded
# OF CONTACT PINS:
2 thru 9
GENDER:
M - Male Pins
F - Female Sockets
CONTACT SIZE:
20 - #20 (2-5 contacts)
26 - #26 (6-9 contacts)
EPOXY SEAL:
E - Optional potting compound sealed
VISIT WWW.SWITCHCRAFT.COM FOR DRAWINGS AND DETAILED SPECIFICATIONS
很抱歉,暂时无法提供与“HS2P2M20-BPE”相匹配的价格&库存,您可以联系我们找货
