HR30-6PA-6P(71)
HR30-6PA-6P(71)
    HRS(广濑)
    CONN_D12.6X30.3MM
    圆形连接器 插头 6Pin 2A
HR30-6PA-6P(71) 数据手册
Miniature Waterproof Plastic Connectors HR30 Series Mated dimensions 32.3 Ø12.6 3 and 6 pos. 10 and 12 pos. Ø15.5 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 42.1 Fig.1 Features Lock/release operation 1. Small-size with low profile 3, 6 contacts : Maximum outer diameter Ø12.6mm Mated length 32.3mm (from the panel surface) 10, 12 contacts : Maximum outer diameter Ø15.5mm Mated length 42.1mm (from the panel surface) These small, compact connectors offer unique features available only from Hirose. Push-pull- single action lock Fig.2 2. Waterproof construction IP67 and 68 waterproof construction in the mated state IP67 : Left submerged in water at a depth of 1m for 30 minutes IP68 : Left submerged in water at a depth of 2m for 14 days Alignment marks 3. Push/pull lock Push-pull locking collar Waterproof connectors feature an easy to operate push/pull locks developed with our exclusive technology. 4. Light weight 3 and 6 contacts: 6g (plug + receptacle) 10 and 12 contacts: 9g (plug + receptacle) 5. Clamp structure Our proprietary clamping method allows clamping the cable by simply tightening the cord ring. 6. Easy mating operation The plug can be securely locked while holding it in your hand while mating. (Fig.2) Polarized interface 7. Mis-insertion prevention Fig.3 Mating portions are polarized to avoid improper mating and connector damage. 8. Mating mark Both the plug and the receptacle feature a white index mark on them which is used to quickly align the two interfaces for proper mating.(Fig.3) 9. Complies with the RoHS requirements In consideration of environmental issues, we use only materials that comply with the RoHS Directive. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.7⑦ 1 HR30 Series●Miniature Waterproof Plastic Connectors Product Specifications 5A (3 pos.) 2A (6,10,12 pos.) 100V AC,140V DC(3,6 pos.) 30V AC,42V DC(10,12 pos.) Current rating Ratings Voltage rating Characteristic 1.Contact resistance 2.Insulation resistance 3.Withstanding voltage Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.Vibration Specification 5mø max. (3 pos.) 15mø max. (Solder type : 6, 10, and 12 pos.) 30mø max. (Through hole type: 6 and 12 pos.) Operation Temperature Range -25ç to +85ç StorageTemperature Range -10ç to +60ç Conditions 1A DC 1000Mø min. 100V DC No flashover or insulation breakdown 300V AC / 1minute No electrical discontinuity of 10µs or more Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 1 cycle= 5min, 10 cycles in each of the 3 directions. Contact resistance 10mø min.(3 pos.) 5.Durability Contact resistance 30mø min. (Solder type: 6, 10, and 12 pos.) (mating/un-mating) Contact resistance 100mø min. (Through hole type: 6 and 12 pos.) 1000 cycles 6.Temperature cycle Insulation resistance 100Mø min. (-55ç : 30 minutes → Room temperature : 10 to 15 minutes → +85ç : 30 minutes → Room temperature : 10 to 15 minutes) for 5 cycles 7.Humidity resistance Insulation resistance 10Mø min. (when humidity high) 100Mø min. (when dry) 96 hours at temperature of 40ç and humidity of 90% to 95% 8.Waterproof performance No water penetration inside. While mated with corresponding or protective cap submerged at depth of 1m for half hour. Material / Finish Assembly Component Material Hexagonal nut Washer Contacts Phosphor bronze Insulator Plug Gasket Contacts Spring Insulator Gasket Receptacles Crimp contact (male/female) Finish PPS PBT Polyacetal Silicone rubber, chloroprene rubber Brass, phosphor bronze, Copper compound metal Stainless steel PPS Chloroprene rubber Brass, phosphor bronze, Copper compound metal Zinc alloy Phosphor bronze Contacts Black Black Natural Remarks UL94V-0 UL94V-0 ---------- Red/Black ---------- Gold plated ---------- ---------Black Black ---------UL94V-0 ---------- Gold plated ---------- Chromate Nickel plated ------------------- Selective gold plated ---------- Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HR30 - 6 P A - 6 S C (* *) q w e r q Model name : HR30 w Shell size : Outside diameter/plug mating side e Connector type : P : Plug Connector type Connector type r Variation Blank A B, D 2 : R : Receptacle : J : Jack : Standard : Fine wire : Over mold type t y u i t Number of Contacts : 3, 6, 10 and 12 y Contact type S : Female contact P : Male contact u Contact wiring type Blank : Solder C : Crimping D : Through hole i Other specifications: A two-digit character is added to indicate other specifications as needed. HR30 Series●Miniature Waterproof Plastic Connectors Plugs Solder Type HR30-6P-6S (31) A(Fully tightened) Applicable cable diameter B 1 6 2 5 (Representative example) Part No. HR30-6P-3S(31) HR30-6P-6S(31) HR30-6P-6P(31) HR30-6PA-3S(71) HR30-6PA-6S(71) HR30-6PA-6P(71) HR30-7P-12S(71) HR30-8P-12P(71) HRS No. 130-0004-1 31 130-0010-4 31 130-0009-5 31 130-0021-0 71 130-0019-9 71 130-0020-8 71 130-0027-7 71 130-0026-4 71 A B 29.8 30.3 Applicable cable diameter range Solder pot inner diameter 1.1 mm 4.2 to 5 0.8 mm 12.6 29.8 0.8 mm 30.3 39.8 15.5 4g 1.1 mm 3.5 to 4.3 Weight 6.2 to 7 0.6 mm 6.7g Crimp Type HR30-7P-12SC (71) A(Fully tightened) Applicable cable diameter Ø15.5 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4 3 (Representative example) Shown with contacts installed. Part No. HR30-7P-10SC(71) HR30-7P-12SC(71) HR30-8P-12PC(71) HRS No. 130-0013-2 71 130-0014-5 71 130-0015-8 71 A Applicable cable diameter range 39.8 6.2 to 7 Crimp contact HR30-SC-211 Weight 6g HR30-PC-211 3 HR30 Series●Miniature Waterproof Plastic Connectors Plug for overmolds Solder Type HR30-6PB-6S Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HR30-6PB-3S HR30-6PB-6S HR30-6PD-6P HR30-7PB-12S HR30-8PB-12P HRS No. 130-0034-2 130-0032-7 130-0041-8 130-0035-5 130-0030-1 A 22.7 B C 12.6 5.2 15.5 6.4 Solder pot inner diameter 1.1 mm Weight 3.1g 0.8 mm 2.9g 0.6 mm 4.7g 4.5g 23.2 25.9 ØB ØC A Crimp Type HR30-8PB-12PC Part No. HR30-7PB-10SC HR30-7PB-12SC HR30-8PB-12PC 4 HRS No. 130-0036-8 130-0033-0 130-0031-4 Crimp contact Weight HR30-SC-211 4.1g HR30-PC-211 4.3g Ø15.5 Ø6.4 25.9 HR30 Series●Miniature Waterproof Plastic Connectors Receptacles Solder Type HR30-6R-6P (71) A Gasket 1 6 3 4 C 2 5 D B E(Thread) F(Hex nut) Part No. HR30-6R-3P(71) HR30-6R-6P(71) HR30-6R-6S(71) HR30-7R-12P(31) HR30-8R-12S(31) HRS No. 130-1003-4 71 130-1009-0 71 130-1008-8 71 130-1016-6 31 130-1018-1 31 A 16 B C D E F 8.3 12 8.9 M8∞0.75 10 9.3 15 11.5 M11∞1 13 18.4 18.6 Solder pot inner diameter Weight 1.1mm 2g 0.8mm 0.6mm 3.4g Crimp Type 15.5 HR30-7R-12PC (31) 9.3 Ø15 Ø11.5 Gasket M11X1(Thread) Shown with contacts installed. Part No. HR30-7R-10PC(31) HR30-7R-12PC(31) HR30-8R-12SC(31) 13(Hex nut) (Representative example) HRS No. 130-1012-5 31 130-1013-8 31 130-1014-0 31 Crimp contact Weight HR30-PC-211 3g HR30-SC-211 Through hole Type A HR30-8R-12SD (31) B 2 C D Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example) Through hole post (0.2∞0.5) E F(Hex nut) (Representative example) Part No. HR30-6R-6PD(71) HR30-6R-6SD(71) HR30-7R-12PD(31) HR30-8R-12SD(31) HRS No. 130-1020-3 71 130-1021-6 71 130-1017-9 31 130-1019-4 31 A 14.9 15.2 16 B C D E F Weight 8.3 12 8.9 M8∞0.75 10 2g 9.3 15 11.5 M11∞1 13 3.4g Gasket 5 HR30 Series●Miniature Waterproof Plastic Connectors Jacks Solder Type HR30-6J-6P (31) Applicable cable diameter A B(Fully tightened) 1 6 2 5 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3 4 (Representative example) Part No. HRS No. HR30-6J-6P(31) 130-2009-6 31 HR30-6JA-6P(71) 130-2018-7 71 HR30-7J-12P(71) 130-2020-9 71 HR30-8J-12S(71) 130-2019-0 71 A B 12 28.8 15 37.3 Applicable cable diameter range Solder pot inner diameter Weight 4.2 to 5 0.8 mm 3.5 to 4.3 6.2 to 7 0.6 mm 3g 5.7g 5.9g Crimp Type HR30-7J-12PC (71) Applicable cable diameter Ø15 37.3 (Fully tightened) (Representative example) Shown with contacts installed. 6 Part No. HRS No. HR30-7J-10PC(71) 130-2015-9 71 HR30-7J-12PC(71) 130-2017-4 71 HR30-8J-12SC(71) 130-2016-1 71 Applicable cable diameter range 6.2 to 7 Crimp contact HR30-PC-211 HR30-SC-211 Weight 5g HR30 Series●Miniature Waterproof Plastic Connectors Jack for overmolds Solder Type A HR30-6JB-6P Part No. HRS No. A HR30-6JB-3P 130-2029-0 12.7 HR30-6JB-6P 130-2021-1 12 HR30-6JB-6S 130-2028-0 12.7 HR30-7JB-12P 130-2023-7 HR30-8JB-12S 130-2024-0 15 B C Solder pot inner diameter Weight 1.1mm 21.7 23.7 5.2 2.3g 2.2g 0.8mm 6.4 2.3g 3.6g 0.6mm 4.1g Crimp Type 5 HR30-8JB-12SC 23.7 Ø6.4 Ø1 Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C B Part No. HRS No. HR30-7JB-10PC 130-2025-2 HR30-7JB-12PC 130-2022-4 HR30-8JB-12SC 130-2026-5 Crimp contact HR30-PC-211 Weight 3.1g HR30-SC-211 7 HR30 Series●Miniature Waterproof Plastic Connectors Caps For Plugs ØA ØB 1.4 HR30-6P-C (31) C 1 ØD Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ØE (Representative example) Part No. HR30-6P-C(31) HRS No. 130-3000-7 31 HR30-7P-C(31) 130-3004-8 31 HR30-8P-C(31) 130-3003-5 31 A 13 B 8.4 C 8.9 D 4 E 8.8 Applicable cable diameter Ø4.2 to 5 Weight 1g 16 10.4 10.5 6 11.4 Ø6.2 to 7 2g For Receptacle C 0.9 ØB ØA 1.4 HR30-6R-C (31) ØE ØD (Representative example) Part No. HR30-6R-C(31) HRS No. 130-3001-0 31 A 12.6 B 11.8 C 7.5 D 12.1 HR30-7R-C(31) 130-3002-2 31 15.5 14.8 8.5 15 E 9.1 Remarks This cap fits each size of 12.1 the HR30-7R and HR30-8R receptacles Note : When using these caps, do not use the gasket that is normally supplied with the receptacle. The “B” diameter end of the receptacle cap will serve as the gasket. 8 Weight 1g HR30 Series●Miniature Waterproof Plastic Connectors Crimp Contacts Male contact Female contact 1.2 1.2 A 0.82 1.15 0.82 1.15 A A 11 A 11 A-A cross-section Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Representative example) (Representative example) HRS No. Packaging type Weight Loose contact HR30-PC-111 130-0022-3 100pcs/pack Type Part No. Reel contact HR30-PC-211 130-0016-0 10,000pcs/reel A-A cross-section HRS No. Packaging type Weight 0.03g/1 pin Loose contact HR30-SC-111 130-0023-6 100pcs/pack 0.03g/1 pin 0.03g/1 pin Reel contact HR30-SC-211 130-0017-3 10,000pcs/reel 0.03g/1 pin Type Part No. Note : Use wire size 26 to 30 AWG with a jacket diameter of 1 mm max. Diagrams of Connectors in Combination Plugs HR30-*P-**(71) Receptacles HR30-*R-**(71) Jacks HR30-*J-**(71) Caps for Receptacle HR30-*R-C(71) Caps for Plug HR30-*P-C(71) Note 1 : Please use connectors with compatible shell size and number of contacts. If you are using a male contact plug, please also use a corresponding product with a female receptacle and a jack. Note 2 : Please install the applicable crimping contacts when using the crimping style connectors. (Please refer to the manual for wiring work.) Note 3 : When using the cap on the receptacle side, do not use the gasket that is normally supplied with the receptacle. The Hirose cap has the necessary gasket as part of the cap unit. Cap mounting diagram Panel Cable Cap Cap 9 HR30 Series●Miniature Waterproof Plastic Connectors Applicable Tools Cable Assembly Tools Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. HR30-6P-3S-T01 150-0220-1 HR30-6P-6S-T01 150-0214-9 HR30-6P-6P-T01 150-0221-4 HR30-7P-10SC-T01 150-0228-3 HR30-7P-12SC-T01 150-0223-0 HR30-8P-12PC-T01 150-0227-0 HR30-6R-3P-T01 150-0225-5 HR30-6R-6P-T01 150-0218-0 HR30-6R-6S-T01 150-0222-7 HR30-7J-10PC-T01 150-0231-8 HR30-7J-12PC-T01 150-0230-5 HR30-8J-12SC-T01 150-0226-8 Applicable Connectors Shell size 6 Connector type Plug 7 Plug 8 Plug Receptacle Jack 7 8 Contact type 3 Female 6 Receptacle Jack 6 No. of contacts Female Male 10 Female 12 Female 12 Male 3 Male Male Female Male Male Female 6 10 12 Note : Wiring for soldering or disassembly and assembly of plugs and jacks can be accomplished more efficiently when using the cable assembly tool. Tightening collar for back shell Part No. HRS No. Applicable Connectors HR30-6P-T02 150-0216-4 3 and 6 contacts HR30-8P-T02 150-0224-2 10 and 12 contacts Note : The code ring tightening collar is used to tighten the cord ring to the specified torque. (Please refer to the manual for assembly procedures.) Solder termination fixture HR30-6P-6S-T01 10 HR30-6R-6P-T01 Back shell tightening collar HR30-6P-T02 HR30 Series●Miniature Waterproof Plastic Connectors Applicable Tools Type Description Manual Part No. HRS No. Manual crimping tool HT-102/HR30-1 150-0229-6 Automatic crimping machine CM-105C 901-0001-0 Applicator AP105-HR30-1 901-2015-9 Automatic Applicable contact Applicable wire HR30-SC-111 AWG26 to 30 HR30-PC-111 –––––– –––––– HR30-SC-211 AWG26 to 30 HR30-PC-211 HR30-SC-111 Extraction tool HR30-TP 150-0219-2 –––––– HR30-SC-211 HR30-PC-111 –––––– Manual contact crimping tool HT-102/HR30-1 Automatic contact crimping machine CM-105C Contact extraction tool HR30-TP Receptacle, Board Mounting Through Hole Pattern 5 3 4 0.9 6 2 3 3 2.16 1.44 12-Ø0.65 1 7 1 4 10 12 2.16 1.44 3 4 7 8 8 11 12-Ø0.65 0.48 1.83 2.16 1.44 0.48 1.83 1 5 4 2.16 1.44 6-Ø0.65 10 11 12 0.87 2.22 2 0.9 0.87 2.22 6 1 0.9 6-Ø0.65 1.6 1.35 0.9 0.49 0.9 1.56 1.56 0.9 0.72 0.72 0.72 0.72 1.52 1.52 1.8 1.8 6R-6PD 6R-6SD 7R-12PD 8R-12SD Remark : 1.The receptacle through hole configuration depicts a view from the mating side of the connector. 2.The above Δ mark indicates the guide key position. 3.The recommended board maximum thickness :1.2mm. 4.Tolerance of +0.03mm is recommended for the plated through hole location. Tolerance of +0.02mm is recommended for the plated through hole diameter. Contact Position Arrangement Panel Cutout Alignment mark 6 2 3 2 HR30-6P-3S(**) 5 5 1 6 4 D +0.05 0 1 3 A +0.05 0 2 3 4 HR30-6P-6S(**) HR30-6P-6P(**) +0.05 0 1 Alignment mark B Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HR30-PC-211 ØC 3 7 2 6 10 1 5 9 4 8 2 3 7 6 10 1 1 5 9 12 11 4 8 4 2 5 8 6 9 +0 0 .05 3 7 10 11 12 HR30-7P-10SC(**) HR30-7P-12SC(**) HR30-8P-12PC(**) A 3,6 pos. 1.25 10,12 pos. 1.35 Panel Thishness 6.45 8.05 3.95 0.7 to 2 9.25 11.05 5.45 0.7 to 3 B C D Remarks : 1. The contact arrangement depicts a view from the wiring side. 2. Installation is accomplished by securing the receptacle from the back side of the panel using the supplied hexagon nut. The tightening torque of the hexagon nut should be 0.5 N·m for 3, 6 contacts, and 0.8 N·m for 10, 12 contacts. In addition, in order to prevent loosening, please apply Locktight 263 and Lockprimer 7649 manufactured by Henkel Japan Ltd., Tokyo. 11 HR30 Series●Miniature Waterproof Plastic Connectors Assembly Procedures Plug Assembly Sequence Push/pull locking collar Insulator/contact assembly Seal bushing Spring A Back shell Strain relief B Cable Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 A B Solder type : 3 and 6 Contacts. 2mm 5.5mm max. Solder type : 12 Contacts. 2mm 10mm max. Crimp type : 10 and 12 Contacts. -0 -0.5 15 to 20mm 2 mm Insert the cable in the following order : 1. Back shell, 2. cord clamp, 3. gasket, 4, spring and 5. locking collar. Prepare the cable end according to the dimensions shown in Table 1. Note : When preparing the cable, use caution not to damage the insulation and conductors of the lead wires. Block end face Insulator/contact assembly Solder termination fixture Solder type 2 Fix the P case block on the cable termination tool, and after preliminary soldering, solder for 3 to 4 seconds with the soldering iron at 350±10ç. Note 1 : Take care to avoid creating cold solder joints and solder joints with voids or air holes in it. Also check to make sure the solder joint is adequately fused between the lead wires and solder cup. Note 2 : The P case block is a precision unit. Please use caution when soldering the P case block so it does not become damaged. Any damage could result in loss of the waterproof performance. Crimp type After crimping the appropriate contact to the cable lead wire, insert the terminated wire into the correct contact position on the P case block. Note : After inserting the crimping wire/contact, slightly pull the lead wire and check if the crimping contact is properly seated into the P case block. 12 HR30 Series●Miniature Waterproof Plastic Connectors Fixation Cable Back shell Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Push/pull locking collar Cable Guide keys Tightening collar for back shell A (Refer to Table-2) Plug insulator body Solder termination fixture Cable View A (2:1) 3 Groove - sealing bushing Front edge of cable jacket Fig.B Fig.C Table-2 Back shell tightening collar size Torque 3 and 6 Contacts. 16mm 0.5N.m 10 and 12 Contacts. 18mm 0.5N.m Connector Insert the cable by fitting the coupling guide to the wire-connected P case block. Then, pass the cable through and assemble in the following order: 1. spring, gasket, 2 cord clamp, and 3. cord tube. Make sure when assembling it with the cord clamp and cord tube, to maintain the positional relations between the cable sheath end face and the concave area of the gasket as shown in Fig.B. Note : Please install the cord tube using the cord tube tightening tool with the cord ring tightening torque shown in Table-2. ln addition, in order to prevent loosening, please apply Locktight 263 and Lockprimer 7649 manufactured by Henkel Japan Ltd., Tokyo. When screwing in the cord tube, use your hand to hold the cable so that the cable will not rotate or twist and apply stress to the soldered wires. However, as the cable tends to be twisted slightly (just over one rotation), we recommend that you twist it in the opposite direction in advance. 13 HR30 Series●Miniature Waterproof Plastic Connectors Points to note when using Heat shrink tubing We recommend that you use shrink tubing over the solder connections in order to protect the soldered wires and to enhance insulation. However, please be careful when applying heat in this area when installing the shrink tube so excess heat does not bleed into or affect the resin parts as shown in the figure below. Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. If the product does become heated beyond the area shown and into the resin parts, please make sure to prevent the following. qDeformation of the C ring. This could result in prevention of locking during mating. wMelting of some parts. To prevent the deformation of the C rings of the receptacles and the jack, we recommend heat to be applied after mating with a compatible plug. Before heating, please mate the plug in the receptacle securely, then pull the back shell for checking whether it is locked properly. If it is heated with semi-fitting, C ring may be thermally deformed with shrinking condition and it may not be locked properly. C ring Receptacle Shrinkable tube Heat application area Mated dimensions Compatible plug Back shell Receptacle Heat application area Precautions after wiring (Solder type and Crimp type) After wiring, do not seal the connected portion with potting, etc. Potting may cause the O-ring to come off when the applicable plug is removed. If the connector is used with the O-ring removed, the waterproof performance will not be satisfied. Compatible plug O-ring Receptacle Potting non-compatible Lead wire Equipment housing 14 HR30 Series●Miniature Waterproof Plastic Connectors General usage notes 1. Mating 2. Un-mating Mounting panel Receptacle D Cable Plug Mounting panel C Push/pull locking collar Cable Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A Alignment marks D B C When mounting, smooth mating will be achieved by holding When removing the plug from its connected condition, hold plug in any are “A” and aligning the arrow of the plug with the plug by push/pull locking collar (area “B”) and pull that of the receptacle, then pushing the plug straight in. straight off. Precautions 1. Make sure the power is off before mating or un-mating the connector. 2. When mating the connector, push it on with a force of a least 30N. After mating, pull slightly on the connector to check for proper mating and to ensure the connector is firmly locked to the receptacle. 3. After mating the connector, do not apply a force over 30N to the cable in the directions shown by the arrows. An excessive load can lead to connector damage. 30N max. Panel 30N max. 30N max. 4. To maintain the waterproof performance, cable clamping force and cable stability, please use a cable within the recommended for cable diameters. Because the performance will differ depending on the cable structure, make sure to check all specifications of the cable assembly before use or production. 5. Please assemble and install the connector and components with the specified tightening torque. If the tightening torque is too weak or too strong, loosening or breakage can occur. 6. Please contact Hirose if your application requires compliance with the Electrical Appliance and Meterial Safety Act. 7. Please note that the white label on the connector may come off due to solvents such as alcohol. 15 HR30 Series●Miniature Waterproof Plastic Connectors Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 16 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2021. Contents are subject to change without notice for the purpose of improvements.
HR30-6PA-6P(71) 价格&库存
很抱歉,暂时无法提供与“HR30-6PA-6P(71)”相匹配的价格&库存,您可以联系我们找货
