NOTES:
1. CRIMP CONTACTS SUPPLIED UNASSEMBLED.
2. REFER TO DRAWING HPSFMISTD FOR CONTACT PATTERNS.
3. DIMENSIONS ARE REFERENCE ONLY, IN INCHES [mm], WITHIN ±0.015 UNLESS OTHERWISE NOTED.
CABLE-END CONNECTOR PART NUMBERS:
S F 6 9 8 X - X S G - 5XX
BACKSHELL KIT:
520 = BACKSHELL
0.220 [5.6]
530 = BACKSHELL
0.330 [8.4]
MAT'L: THERMOPLASTIC INSERT
COPPER ALLOY,GOLD PLATED CONTACTS
ELASTOMERIC SEAL O-RING
CUSTOMER PRINT
# OF CONTACTS: 9 - 18
SOLDER CONTACTS INSERT KIT OPTION,
SEE CONNECTOR PART NUMBERS
PLUG INSERT KIT
0.763 19.4
REF
WITH
GROMMET I.D.
WITH
GROMMET I.D.
CONTACTS STYLE:
0 = CRIMP
2 = SOLDER
CONDUCTIVE
TAPE
1.429 36.3 REF
KEYWAY
KEYWAY
GROMMET
FACE VIEW
SF6982-18SG-520 SHOWN
0.114 2.9
REF
0.789 20.0
REF
WIRING VIEW
WITHOUT BACKSHELL
COUPLING RING
HOUSING
INSULATING TUBE
BACKSHELL KIT
MAT'L: THERMOPLASTIC SHELL & STRAP,
ELASTOMERIC GROMMET,
STAINLESS STEEL SCREWS
PLUG ASSEMBLY KIT
SF698X-XSG-5XX
MAT'L: COPPER ALLOY, NICKEL PLATED HOUSING & COUPLING RING,
NICKEL/COPPER/POLYESTER FABRIC WITH CONDUCTIVE ADHESIVE TAPE,
MYLAR INSULATING TUBE
CRIMP CONTACTS INSERT KIT OPTION,
PART
NUMBER:
CUSTOMER APPROVAL
0.699 17.8
REF
0.024 0.6 REF
(WHEN ASSEMBLED)
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
RoHS COMPLIANT
0A
PNK
REV. INIT.
2-8-18
DRAWING CREATED PER PDR17006
DATE
DESCRIPTION
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
ORIG. DRAWN BY:
PNK
DATE:
2-8-18
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
NTS
SIZE
B
FILE:
SF698X-XSG-5XX_CD
SHEET
1 OF 1
CUSTOMER:
DIRECTORY:
PART
NUMBER:
SLW
CABLE-END CONNECTOR
9-18 #26 SOCKET CONTACTS
SHIELDED MINI-CON-X
STANDARD PRODUCT
SF698X-XSG-5XX
REV
0A
很抱歉,暂时无法提供与“SF6980-18SG-530”相匹配的价格&库存,您可以联系我们找货
