AMC36SAAN
AMC36SAAN
    SULLINS
    CONN HEADER VERT 36POS 2.54MM
AMC36SAAN 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY E 2763 ADDED 'G' PLATING & UPDATED OPERATING TEMPERATURE FOR 'R' MATERIAL 4/17/2013 KV F 2855 G 2995 CHANGED DEFAULT PPS FROM BLACK COLOR TO GREEN COLOR, REMOVED 'R' MATERIAL OPTION (OFFERED 'A' ONLY FOR 200C APPLICATION), ADD "Y" & "L" MATERIAL / COLOR OPTION ADD 'R' MATERIAL OPTION FOR 175 C APPLICATION H 3134 UPDATE BOM FOR P MATERIAL CODE F F 2/25/2014 JH 6/11/2014 JH 1/14/2015 JHSU E E D D .100 2.54 B A C C .050 1.27 A HEAD DIMENSION .100 2.54 TAIL DIMENSION B B .100 2.54 TYP. A .025 0.64 FITS .040 MIN. HOLE SECTION A-A A CUSTOMER COPY NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. UL FLAMMABILITY RATING: 94V-0 5. DIELECTRIC WITHSTANDING VOLTAGE: 1800 VAC 6. CURRENT RATING: 3 AMPS 7. CONTACT RESISTANCE: 30 MILLIOHMS MAX. 8. INSULATION RESISTANCE: 5000 MEGOHMS MIN. 8 7 Pb RoHS COMPLIANT 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 9/9/2011 JH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 2 _ _C_ _S_ _N - (M500) CAGE CODE 54453 SCALE: 4:1 3 A .100" CC, HEADER, STRAIGHT DWG. NO. C10436 SHEET 1 OF 1 1 REV H FILE NAME: C10436, _ _C_ _S_ _N-OMIT, M500, STRAIGHT
AMC36SAAN 价格&库存
很抱歉,暂时无法提供与“AMC36SAAN”相匹配的价格&库存,您可以联系我们找货
