NOTES:
1. CRIMP CONTACTS SUPPLIED UNASSEMBLED AND WITHOUT
EPOXY BACKING.
2. REFER TO DRAWING HPSFMISTD FOR CONTACT PATTERNS.
3. HEX-NUT TORQUE: 10-12 IN-LB.
4. DIMENSIONS ARE REFERENCE ONLY, IN INCHES [mm],
WITHIN ±0.015 UNLESS OTHERWISE NOTED.
O-RING
MAT'L: ELASTOMER,
BLACK
PANEL-MOUNT CONNECTOR PART NUMBERS:
.117 3 REF
(WHEN ASSEMBLED)
S F 7 9 8 X - X P G - 3XX
CONTACTS, CRIMP
MAT'L: COPPER ALLOY,
GOLD PLATED
EPOXY BACKING:
3ES = WITH EPOXY
300 = WITHOUT EPOXY
# OF CONTACTS: 9 - 18
CONTACTS STYLE:
0 = CRIMP
2 = SOLDER
4 = PC TAIL
HOUSING
MAT'L: COPPER ALLOY, NICKEL PLATED
HEX-NUT
CRIMP CONTACTS
CUSTOMER PRINT
SF7980-18PG-300 SHOWN
.812 20.6 REF
ACROSS FLATS
KEY
.870 22.1 REF
.826 21
.574 14.6 REF
D-FLAT
KEY
.142 3.6 REF
CONTACTS, SOLDER
GOLD PLATED
.938 23.8 REF
FACE VIEW
SF7982-18PG-300 SHOWN
.188 4.8
MAXIMUM PANEL THICKNESS
WIRING END
SOLDER CONTACTS
PART
NUMBER:
SF798X-XPG-3XX
.205 5.2 REF
.137 3.5 REF
.582±.003 14.8±0.1
CONTACTS, CRIMP
GOLD PLATED
CUSTOMER APPROVAL
.020±.001 0.5±0
TYP
.610±.003 15.5±0.1
RECOMMENTED PANEL CUT-OUT
PC TAIL CONTACTS
SF7984-18PG-3ES SHOWN
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
RoHS COMPLIANT
0A
PNK
REV. INIT.
1-30-18
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
DRAWING CREATED PER PDR17011
DESCRIPTION
ORIG. DRAWN BY:
PNK
DATE:
1-30-18
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
NTS
SIZE
B
FILE:
SF798X-XPG-3XX_CD
SHEET
1 OF 1
CUSTOMER:
DIRECTORY:
PART
NUMBER:
SLW
(9-18) #26 PIN CONTACTS
SHIELDED MINI-CON-X
STANDARD PRODUCT
SF798X-XPG-3XX
REV
0A
很抱歉,暂时无法提供与“SF7984-18PG-3ES”相匹配的价格&库存,您可以联系我们找货
