DF51K-30DP-2DSA(800) 数据手册
2mm Pitch, Positive lock, Wire-to-Board Connector (UL, C-UL Listed)
DF51K Series
Secure mating with clear tactile click
Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Insertion force
to lock
Matches the peak
■ Features
1. Positive lock provides clear tactile click
and secures reliable connection
The locking mechanism delivers a clear tactile click, which
prevents incomplete mating. (Fig.1)
2. Wide variation
Insertion force
to contact
Matching peak insertion forces provides
a clear click sound and tactile click
Straight and right angle types are available in single row and
double row contact arrangements for flexible board design.
Gold and Tin plating options support various application needs.
Fig.1
3. Easy Lock Release
The width of the center lock lever increases as the pin count
increases for easy extraction.
Additionally, the center lock design does not need side-to-side
spacing to un-mate the connector, which enables high density
mounting. (Fig.2)
4. Prevents incorrect mating
Visually and mechanically polarized design prevents reverse
mating and incorrect mating between different number of
positions. (Fig.3)
5. Suitable for potting
Capable of being potted up to 3mm. (Fig.3)
6. Uses the same crimp tools as DF11 Series
Wide applicable cable range : 22 to 30 AWG.
(However, the crimp contact of DF51K and DF11 are not
compatible with each other.)
7. UL, C-UL certified
■ Applications
Office equipment, Industrial machinery,
Industrial robots, Amusement equipment,
Medical equipment.
Center lock width gets wider as the pin count increases
for easy operation.
Extra spacing not
required
High workability and high density mounting
due to center lock design
Fig.2
Secure
Center Lock Design
Guide Key
Prevents
Incorrect Mating
Resin Sealing
3mm Max.
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2020.08 ①
1
DF51K Series ● 2mm Pitch, Positive lock, Wire-to-Board Connector (UL, C-UL Listed)
■ Product Specifications
Ratings
Rated
Single
Current
Row
(Note 1)
Rated
Voltage
Ratings
Number of
Contacts
22
AWG
24
AWG
26
AWG
3-6
2A
2A
2A
2A
1.5A
2
4
Double
Row
Rated
Current
(Note 1)
6-30
22 AWG
2A
Rated
Voltage
3A
3A
2A
2.5A
2.5A
250V AC/DC
24 to 28 AWG
1A
28
AWG
1A
30
AWG
0.5A
30 AWG
0.5A
30V AC/DC
Items
Operating Temperature
-55 to +105°C (Note 2)
Operating Humidity Range
20 to 80% (Note 3)
Storage Temperature
-10 to +60°C (Note 4)
Storage Humidity Range
40 to 70% (Note 4)
UL/C-UL File No., and Recognition No.
UL, C-UL : E132750
Specifications
Conditions
1. Insulation Resistance
No less than 1,000MΩ
Measured at 500V DC
3. Contact Resistance
No more than 30mΩ
Measured at 1mA and no higher than 20mV
2. Withstanding Voltage
No flashover or breakdown
4. Vibration Resistance
650V AC is applied for 1 minute
Frequency : 10 to 55Hz, half amplitude 0.75mm,
10 times in each of the 3 directions
No electrical discontinuity of 1μs or greater
5. Shock Resistance
Acceleration velocity : 490m/s2 for 11ms, half-sine
wave in 3 directions, 3 times for each directions
Contact resistance : no more than 30mΩ
Insulation resistance : no less than 500MΩ
6. Moisture Resistance
Temperature : 40±2°C, humidity : 90 to 95%,
left as it is for 96 hours
Insulation resistance : no less than 1,000MΩ
7. Temperature Cycles
8. Mating Durability
-55℃: 30 minutes → 105℃ : 30 minutes 5 cycles
Contact resistance: no more than 30mΩ
9. Soldering Heat Resistance
The resin parts should withstand the temperature
and resist melting.
Tin plated : 30 mating cycles,
Gold plated : 50 mating cycles
Flow : 260℃, 5 sec.
Hand soldering : temperature of soldering
iron at 270℃ for 3 seconds
Note 1 : The rated current varies based on the cable size used.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : Use without condensation on parts.
Note 4 : The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating
temperature for temporary storage such as pre-assembly and during shipping.
■ Material / Finish
Product
Header
Crimp Socket
Socket Contact
2
Part
Material
Finish
Brass
Tin Plated or Gold Plated
Phosphor bronze
Insulator
Straight : PA66
Right Angle : PBT (glass-reinforced)
Insulator
Contact
Contact
Black
Black
UL Regulation
UL94V-0
UL94V-0
■ Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
● Connector
DF51K # 1
2
● Crimp Contact
3
P - 2 DSA
4
5
6
DF51K - 2428 SCF A
1
7
8
9
1
Series Name : DF51K
3
Number of Contacts
Single-row : 2 to 6
Double-row : 4 to 30
2
4
5
Form Type
Blank : Without guide-boss
B
: Guide-boss type
Connector type
P : Single-row pin header
S : Single-row crimp socket
DP : Double-row pin header
DS : Double-row crimp socket
Contact Pitch : 2mm
6
7
8
9
Type of Housing
DSA : Straight header
DS : Right angle header
C : Crimp socket
Applicable Conductor
22 : 22 AWG
2428 : 24 to 28 AWG
30 : 30 AWG
Packaging
SC : Socket contacts/pack
SCF : Socket contacts/reel
Plating Specifications
Blank : Tin plated
A
: Gold plated
■ Diagram of Connector Mating Combinations
● Single-row
Crimp Socket
DF51K-*S-2C
Socket Contact
DF51K-22SC(F)(A)
DF51K-2428SC(F)(A)
Straight Header
DF51K-*P-2DSA
DF51K-30SC(F)(A)
Right Angle Header
DF51K(B)-*P-2DS
● Double-row
Crimp Socket
DF51K-*DS-2C
Socket Contact
DF51K-22SC(F)(A)
DF51K-2428SC(F)(A)
Straight Header
DF51K-*DP-2DSA
DF51K-30SC(F)(A)
Right Angle Header
DF51K(B)-*DP-2DS
3
■ Single-row Straight Header
Part No.
HRS No.
No. of Contacts
480-0543-0 **
3
480-0545-0 **
5
DF51K-2P-2DSA(8**)
480-0542-0 **
DF51K-4P-2DSA(8**)
480-0544-0 **
DF51K-3P-2DSA(8**)
DF51K-5P-2DSA(8**)
DF51K-6P-2DSA(8**)
Recommended PCB Layout (t=1.6mm)
A
2
480-0546-0 **
2.0
4
11.2
6.0
6
15.2
9.2
No. of
Contacts
480-0548-0 **
6
DF51K-4DP-2DSA(8**)
480-0547-0 **
DF51K-8DP-2DSA(8**)
480-0549-0 **
DF51K-6DP-2DSA(8**)
DF51K-10DP-2DSA(8**)
DF51K-12DP-2DSA(8**)
DF51K-14DP-2DSA(8**)
DF51K-16DP-2DSA(8**)
B
Part No.
[Specification number] - **, (8**)
00 : Tin plated
05 : Gold plated
HRS No.
No. of
Contacts
480-0555-0 **
DF51K-18DP-2DSA(8**)
480-0554-0 **
8
11.2
6.0
DF51K-22DP-2DSA(8**)
480-0556-0 **
12
15.2 10.0
480-0552-0 **
14
16
9.2
13.2
4.0
8.0
17.2 12.0
19.2 14.0
DF51K-20DP-2DSA(8**)
DF51K-24DP-2DSA(8**)
DF51K-26DP-2DSA(8**)
DF51K-28DP-2DSA(8**)
DF51K-30DP-2DSA(8**)
Note : The sales unit is one pack (100pcs/pack). Order by number of packs.
4
10.0
7.2
10
480-0553-0 **
8.0
4
480-0550-0 **
480-0551-0 **
A
4.0
13.2
■ Double-row Straight Header
HRS No.
B
7.2
Note : The sales unit is one pack(100pcs/pack). Order by number of packs.
Part No.
00 : Tin plated
05 : Gold plated
480-0557-0 **
480-0558-0 **
480-0559-0 **
480-0560-0 **
A
B
18
21.2 16.0
22
25.2 20.0
24
26
28
30
23.2 18.0
27.2 22.0
29.2 24.0
31.2 26.0
33.2 28.0
■ Single-row Right Angle Header
*The above drawing is of guide-boss type.
Part No.
HRS No.
Guide-Boss
No. of
Contacts
480-0588-0 **
With boss
3
DF51KB-2P-2DS(8**)
480-0587-0 **
DF51K-4P-2DS(8**)
480-0589-0 **
Without boss
480-0591-0 **
Without boss
DF51KB-3P-2DS(8**)
DF51K-5P-2DS(8**)
DF51K-6P-2DS(8**)
480-0590-0 **
Note : The sales unit is one tray. Order by number of trays.
With boss
Without boss
A
00 : Tin plated, tray packaging
05 : Gold plated, tray packaging
B
2
7.2
2.0
4
11.2
6.0
6
15.2
5
9.2
13.2
4.0
8.0
10.0
C
Quantity per
Package
7.14
330
5.14
420
270
230
200
5
■ Double-row Right Angle Header
Part No.
HRS No.
Guide-Boss
No. of
Contacts
480-0593-0 **
With boss
6
Without boss
10
Without boss
14
DF51KB-4DP-2DS(8**)
480-0592-0 **
DF51K-8DP-2DS(8**)
480-0594-0 **
Without boss
DF51K-12DP-2DS(8**)
480-0596-0 **
Without boss
DF51KB-6DP-2DS(8**)
DF51K-10DP-2DS(8**)
DF51K-14DP-2DS(8**)
DF51K-16DP-2DS(8**)
DF51K-18DP-2DS(8**)
DF51K-20DP-2DS(8**)
DF51K-22DP-2DS(8**)
DF51K-24DP-2DS(8**)
DF51K-26DP-2DS(8**)
DF51K-28DP-2DS(8**)
DF51K-30DP-2DS(8**)
480-0595-0 **
480-0597-0 **
480-0598-0 **
480-0599-0 **
480-0600-0 **
480-0601-0 **
480-0602-0 **
480-0603-0 **
480-0604-0 **
480-0605-0 **
6
With boss
Without boss
Without boss
Without boss
Without boss
Without boss
Without boss
Without boss
Without boss
4
A
7.2
B
2.0
9.2
4.0
13.2
8.0
8
11.2
12
15.2
10.0
19.2
14.0
16
18
24
26
28
30
17.2
21.2
23.2
25.2
27.2
29.2
31.2
33.2
6.0
12.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
C
Quantity per
Package
7.14
330
5.14
420
270
230
200
170
150
140
130
120
110
100
90
90
■ Crimp Socket
● Single-row
Part No.
HRS No.
No. of Contacts
480-0562-0 00
3
DF51K-2S-2C(800)
480-0561-0 00
DF51K-4S-2C(800)
480-0563-0 00
DF51K-3S-2C(800)
DF51K-5S-2C(800)
DF51K-6S-2C(800)
480-0564-0 00
480-0565-0 00
A
B
2
6.8
2.0
4
10.8
6.0
6
14.8
5
8.8
12.8
4.0
8.0
10.0
● Double-row
Part No.
HRS No.
No. of Contacts
480-0568-0 00
6
DF51K-4DS-2C(800)
480-0567-0 00
DF51K-8DS-2C(800)
480-0569-0 00
DF51K-6DS-2C(800)
DF51K-10DS-2C(800)
DF51K-12DS-2C(800)
DF51K-14DS-2C(800)
DF51K-16DS-2C(800)
DF51K-18DS-2C(800)
DF51K-20DS-2C(800)
DF51K-22DS-2C(800)
DF51K-24DS-2C(800)
DF51K-26DS-2C(800)
DF51K-28DS-2C(800)
DF51K-30DS-2C(800)
2.0
8
10.8
6.0
12
14.8
10.0
18.8
14.0
10
480-0572-0 00
14
480-0573-0 00
480-0574-0 00
480-0575-0 00
480-0576-0 00
480-0577-0 00
480-0578-0 00
480-0579-0 00
480-0580-0 00
B
6.8
480-0570-0 00
480-0571-0 00
A
4
16
18
24
26
28
30
8.8
12.8
16.8
20.8
22.8
24.8
26.8
28.8
30.8
32.8
4.0
8.0
12.0
16.0
18.0
20.0
22.0
24.0
26.0
28.0
7
■ Socket Contact
Part No.
Packaging
DF51K-22SCF(800)
480-0581-0 00
10,000/reel
DF51K-2428SCF(800)
480-0583-0 00
10,000/reel
480-0585-0 00
10,000/reel
480-0612-0 00
10,000/reel
480-0614-0 00
10,000/reel
480-0616-0 00
10,000/reel
DF51K-22SC(800)
DF51K-2428SC(800)
DF51K-30SCF(800)
DF51K-30SC(800)
DF51K-22SCFA(800)
DF51K-22SCA(800)
DF51K-2428SCFA(800)
HRS No.
DF51K-2428SCA(800)
DF51K-30SCFA(800)
DF51K-30SCA(800)
480-0582-0 00
480-0584-0 00
480-0586-0 00
480-0613-0 00
480-0615-0 00
480-0617-0 00
Finish
100/pack
Tin plated
100/pack
100/pack
100/pack
Gold plated
100/pack
100/pack
● Applicable wire (Tinned, Annealed copper wire)
UL
1061
Wire Size (Stranded Wire Structure)
1007
1061
Jacket Diameter
22 AWG (17 pieces / 0.16mm)
Ø1.2 to Ø1.45mm
26 AWG (7 pieces / 0.16mm)
Ø0.9 to Ø1.45mm
30 AWG (7 pieces / 0.1mm)
Ø0.8mm
24 AWG (11 pieces / 0.16mm)
28 AWG (7 pieces / 0.127mm)
Note 1 : Applicable
Tool : Applicator
Note 2 : Contact
your Hirose representative when considering usage of
non-applicable wires.
Applicable Crimping Tool
Type
Applicator
Press Unit
Hand Tool
Contact Extraction Tool
Part No.
HRS No.
Wire Type
Applicable Contacts
AP105-DF11-22S
901-4529-7 00
UL1061 (22 AWG)
DF51K-22SCF/SCFA
AP105-DF11-30S
901-4532-1 00
UL1061 (30 AWG)
DF51K-30SCF/SCFA
AP105-DF11-2428S
CM-105C
HT801/DF11-22S(A)
HT801/DF11-2428S(A)
HT801/DF11-30S(A)
DF-C-PO(B)
901-4511-1 00
901-0001-0 00
UL1007 (24 to 28 AWG)
DF51K-2428SCF/SCFA
550-0407-5 00
UL1061 (22 AWG)
DF51K-22SC/SCA
550-0408-8 00
UL1061 (30 AWG)
DF51K-30SC/SCA
550-0403-4 00
550-0179-2 00
DF51K-2428SC/SCA
DF51K-*****SCF/SCFA
Note 3 : Please conduct crimping work according to the "Crimping work standards" and "Crimping condition table".
Note 4 : Any problems that occur from using tools other than those specified by Hirose are not covered by warranty.
Note 5 : Please contact Hirose for information about hand tooling.
8
Mated Dimensions
● Wire-to-Board connection using the straight header
[Single-row]
[Double-row]
DF51K-*DS-2C
DF51K-*S-2C
DF51K-*DP-2DSA
DF51K-*P-2DSA
● Wire-to-Board connection using the right angle header
[Single-row]
[Double-row]
DF51K(B)-*DP-2DS
DF51K(B)-*P-2DS
DF51K-*S-2C
Precautions for use
DF51K-*DS-2C
1. The connector could be damaged if pulled out forcibly. When it is hard to pull out, push it in slightly first and then depress
the lock and un-mate.
Please refer to “DF51K mating and unmating Procedure Document (DOC180208-010)” for points in handling regarding mating
operations.
2. When mating a crimped contact into a socket, please refrain from inserting it diagonally in order to maintain performance reliability.
Please refer to the "Harness procedure manual (DOC180330-002)" for points in harness operations.
Operating Environment
Please contact a Hirose representative if you are designing this connector into environmental conditions where high and low
temperatures are repeated.
While taking in consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non-specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure,
aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
9
MEMO
10
MEMO
11
[ JAPAN ]
[ GERMANY ]
[ TAIWAN ]
Headquarters
GERMAN Branch / STUTTGART Office
TAIWAN Office
HIROSE ELECTRIC EUROPE B.V.
HIROSE ELECTRIC (TAIWAN) CO., LTD.
Phone : +81-45-620-7410
http://www.hirose.com
Phone : +49-711-456002-1
http://www.hirose.com/eu/
Phone : +886-2-2555-7377
http://www.hirose.com/tw/
NUREMBERG Office
[ U.S.A ]
Phone : +49-911-326889-63
US Headquarters / CHICAGO Office
HIROSE ELECTRIC ( U.S.A.), INC.
HANOVER Office
Phone : +1-630-282-6700
http://www.hirose.com/us/
Phone : +49-511-978261-30
[ KOREA ]
KOREA Office
HIROSE KOREA CO.,LTD.
Phone : +82-31-496-7000
http://www.hirose.co.kr/
SAN JOSE Office
Phone : +1-408-253-9640
[ FRANCE ]
DETROIT Office (AUTOMOTIVE)
PARIS Office
Phone : +1-734-542-9963
Phone : +33-1-85764886
[ SINGAPORE ]
SINGAPORE Office
HIROSE ELECTRIC SINGAPORE PTE. LTD.
Phone : +65-6324-6113
http://www.hirose.com/sg/
BOSTON Office
[ ITALY ]
Phone : +1-978-655-9850
MILAN Office
DALLAS Office
Phone : +39-02-36636350
Phone : +1-972-324-3370
IRVINE Office
Phone : +1-949-930-3750
[ CHINA ]
CHINA Headquarters / SHANGHAI Branch
HIROSE ELECTRIC ( CHINA ) CO., LTD.
Phone : +86-21-6391-3355
http://www.hirose.com/cn/
[ THE NETHERLANDS ]
EU Headquarters / AMSTERDAM OFFICE
Phone : +31-20-6557460
[ UNITED KINGDOM ]
UK Branch
Phone : +44-1908-202050
[ THAILAND ]
BANGKOK Liaison Office
Phone : +66-2-686-1255
[ MALAYSIA ]
PENANG Representative Office
Phone : +60-4-648-5536
SHENZHEN Branch
Phone : +86-755-8207-0851
[ INDIA ]
BANGALORE Office
BEIJING Branch
HIROSE ELECTRIC INDIA PVT. LTD.
HIROSE ELECTRIC ( CHINA ) CO.,LTD.
Phone : +91-80-4120-1907
Phone : +86-10-5165-9332
GUANGZHOU Branch
Phone : +86-180-9895-1861
DELHI Office
Phone : +91-120-660-8018
[ HONG KONG ]
HONG KONG Office
HIROSE ELECTRIC
HONGKONG TRADING CO., LTD.
Phone : +852-2803-5338
http://www.hirose.com/hk/
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
12
The contents of this catalog are current as of date of 08/2020. Contents are subject to change without notice for the purpose of improvements.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
DF51K-10DP-2DS(800) DF51K-12DP-2DS(805) DF51K-12DP-2DSA(800) DF51K-12DP-2DSA(805) DF51K-14DP2DS(800) DF51KB-4DP-2DS(805) HT801/DF51K-22S(A) HT801/DF51K-2428S(A) HT801/DF51K-30S(A) DF51KB2P-2DS(800) DF51KB-2P-2DS(805) DF51KB-3P-2DS(800) DF51KB-4DP-2DS(800) DF51K-6P-2DSA(805) DF51K8DP-2DS(800) DF51K-5P-2DSA(805) DF51K-5S-2C(800) DF51K-6P-2DS(800) DF51K-4P-2DSA(805) DF51K-5P2DS(800) DF51K-5P-2DS(805) DF51K-4DP-2DSA(800) DF51K-4P-2DS(800) DF51K-4P-2DS(805) DF51K30SC(800) DF51K-30SCA(800) DF51K-30SCF(800) DF51K-30SCFA(800) DF51K-3P-2DSA(805) DF51K-2S2C(800) DF51K-30DP-2DS(800) DF51K-30DP-2DS(805) DF51K-30DP-2DSA(805) DF51K-30DS-2C(800) DF51K28DP-2DS(805) DF51K-28DS-2C(800) DF51K-2P-2DSA(805) DF51K-26DP-2DS(800) DF51K-26DP-2DS(805)
DF51K-26DS-2C(800) DF51K-28DP-2DS(800) DF51K-24DP-2DS(800) DF51K-24DP-2DS(805) DF51K-24DP2DSA(805) DF51K-24DS-2C(800) DF51K-2428SC(800) DF51K-2428SCF(800) DF51K-10DP-2DSA(800) DF51K12DP-2DS(800) DF51K-22DP-2DS(805) DF51K-20DP-2DS(800) DF51K-20DP-2DS(805) DF51K-22DP-2DS(800)
DF51K-18DP-2DS(800) DF51K-18DP-2DS(805) DF51K-18DS-2C(800) DF51K-14DP-2DS(805) DF51K-16DP2DS(800) DF51K-16DP-2DSA(805)
