FX30B-3P-7.62DS
FX30B-3P-7.62DS
    HRS(广濑)
    CONN HEADER R/A 3POS 7.62MM
FX30B-3P-7.62DS 数据手册
13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections FX30B Series ■Features 1. Contact Pitch : 3.81mm ,7.62mm 2. Current Capacity : 13~25A/pin (Page 2.) *For details, see the derating curve.(Described on page 4.) (1)Reliable to mounting misalignment when using multiple connectors. (2)Other products without position misalignment absorption can be used together. 6. Effective Mating Length : 2mm Example of Connector Mounted Next to Another Connector The effective mating length is 2mm long, so it has an enough margin for the mating stroke. (3.0mm for longer contacts) 7. Multi-point Contact Structure It has superior contact reliability by employing an independent four-point contact spring structure. 8. Low Insertion / Extraction Force It offers low insertion/extraction force by employing a two-step contact timing sequence. 9. Robustness Reinforcement metal fittings that securely fix the connector to the PCB are added on both sides of the connector, providing excellent deformation resistance for up, down, left and right directions. FX18 Series FX30B Series (without position misalignment absorption function) (with position misalignment absorption function) 10. Large Guide Form Leads Superior Mating Ability A large induction form has been provided, allowing easy mating operations. (Induction amount : ±1.3 mm, with position misalignment absorption amount : ±1.6mm) 11. Protected structure Our proprietary protective wall prevents foreign materials from contacting the sensitive areas. (Compatible to JIS C 0922 Probes for verification B) 12. UL, C-UL and TÜV certifications have been achieved. ■Mating variations Coplanar connection type Receptacle side 11 Vertical connection type A Vertical connection type B Parallel connection type 11 FX30B-*P-3.81DS FX30B-*P-3.81DSA** 11 FX30B-*S-3.81DSA 20,25,30 0.5 min 0.5 min FX30B-*S-3.81DS 26 FX30B-*S-3.81DSA 20,25,30 0.5 min 0.5 min FX30B-*S-3.81DS 26 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. Connection Type:Coplanar / Vertical / Parallel 4. Number of Pos. : 2 / 3 / 4 / 5 Pos. 5. Position Misalignment Absorption Movable Amount: ±0.3mm FX30B-*P-3.81DS Header side In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 11 FX30B-*P-3.81DSA** 2019.6r 1 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections ■Product Specifications Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FULL CONTACT TYPE (P=3.81mm) Ambient temp 25ç Current rating UL/C-UL (Note 3) TÜV Ratings UL/C-UL Voltage rating TÜV SKIPPED CONTACT TYPE (P=7.62mm) Ambient temp 25ç Current rating UL/C-UL (Note 3) TÜV Ratings UL/C-UL Voltage rating TÜV UL/C-UL/TÜV File No. and Confirmation No. 2 pos. 3 pos. 4 pos. 5 pos. 23A 22A 20A 20A Operating temperature range : -55 to +105ç (Note 1) 16A 15A 13A 13A 17A 16A 15A 15A 250V AC/DC Operating humidity range : Relative humidity 85% max. 150V AC/DC (Not dewed) 2 pos. 3 pos. 25A 24A Storage temperature range : -10 to +60ç (Note 2) 18A 16A 19A 18A 600V AC/DC UL/C-UL TÜV Storage humidity range : 40% to 70% (Note 2) E52653 R50275872 Item 1. Contact resistance 2. Insulation resistance Specification 2mø or less 1000Mø or more 3. Withstanding voltage No flashover or breakdown 4. Insertion/extraction lifespan Contact resistance : 5 mø or less 5. Vibration resistance No electric outage of 1µs or greater 6. Shock resistance No electric outage of 1µs or greater (Acc. to UL1977 / CSA C22.2 No.182.3-M1987) (Acc. to EN61984 : 2009) Conditions Measured at 10 mA Measured at 250 V DC Conduct electricity by applying a voltage of 750 V AC for 1 minute Insert/extract 100 times Frequency : 10 to 55Hz, half amplitude : 0.75mm, 10 cycles in each of 3 axis directions for 5 minutes/cycle Acceleration of 490 m/s2, duration 11 ms, sine half-wave, 3 cycles in each of the 3 axes each in both directions Temperature : 40°C, humidity : 90 to 95%, left for 96 hours Temperature : -55 ➝ 105°C Time : 30 ➝ 30 min., 5 cycles Solder tank : solder tank temperature : 260°C, 10 seconds Manual soldering : soldering iron temperature : 380°C, 10 seconds Contact resistance : 5mø or less Insulation resistance : 1000Mø or more Contact resistance : 5mø or less 8. Temperature cycle Insulation resistance : 1000Mø or more No melting of resin part, which affects the 9. Solder heat resistance product performance Note 1 : Includes temperature rise caused by current flow. Note 2 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting. Note 3 : Current rating per 1 contact is used. 7. Humidity resistance ■Materials / Finish ●Receptacle/Header Common Part Insulator Material Polyamide resin Power supply contact Copper alloy Reinforcement metal fitting Phosphorous bronze Color/Finish Black Contact area : Gold plating Mounting area : Pure tin plating Whole body : Pure tin plating Specification UL94V-0 ------------------- ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle ❶ Series Name FX30B - 5 S - 3.81 DS ❶ ❷ ❸ ❹ ❷ Number of Contacts 2 to 5 ❺ ●Header FX30B - 5 P - 3.81 DSA 20 ❶ ❷ ❸ ❹ ❺ FX30B ❸ Connector Type S : Receptacle type P : Header type ❹ Contact Pitch 3.81mm ❺ Product Type DS : Right angle type DSA : Straight type ❻ ❻ Stacking Height Type ●Receptacle (One pin skipped type) FX30B - 3 S - 7.62 DS ❶ ❷ ❸ ❹ ❺ ●Header (One pin skipped type) FX30B - 3 P - 7.62 DSA 20 ❶ 2 ❷ ❸ ❹ ❺ ❻ FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections ■Functional diagram ●Right angle receptacle ● Right angle header 【FX30B-*P-3.81DS】 【FX30B-*P-7.62DS】 【FX30B-*S-3.81DS】 【FX30B-*S-7.62DS】 Coplanar connection Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Vertical connection ●Straight header ●Straight receptacle 【FX30B-*P-3.81DSA**】 【FX30B-*P-7.62DSA**】 【FX30B-*S-3.81DSA】 【FX30B-*S-7.62DSA】 Parallel connection ■Stacking height dimensions for parallel connection type Stacking height combinations table FX30B-*S-3.81DSA FX30B-*S-7.62DSA FX30B-*P-3.81DSA20 FX30B-*P-7.62DSA20 FX30B-*P-3.81DSA25 FX30B-*P-7.62DSA25 FX30B-*P-3.81DSA30 FX30B-*P-7.62DSA30 20mm 25mm 30mm Straight receptacle FX30B-*S-3.81DSA FX30B-*S-7.62DSA Straight header FX30B-*P-3.81DSA** FX30B-*P-7.62DSA** 3 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections BDerating curve ●Normal type (Electricity conducted through the 5 pins of 5-pin coplanar connection type connector) Temperature rise curve [5 cores] Derating curve [5 cores] Current [A] Current [A] :Base curve :Derating curve Temperature rise [ç] Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ambient temperature [ç] (Electricity conducted through the 4 pins of 4-pin coplanar connection type connector) Derating curve [4 cores] Temperature rise curve [4 cores] Current [A] Current [A] :Base curve :Derating curve Ambient temperature [ç] Temperature rise [ç] (Electricity conducted through the 3 pins of 3-pin coplanar connection type connector) Temperature rise curve [3 cores] Derating curve [3 cores] Current [A] Current [A] :Base curve :Derating curve Temperature rise [ç] Ambient temperature [ç] (Electricity conducted through the 2 pins of 2-pin coplanar connection type connector) Derating curve [2 cores] Temperature rise curve [2 cores] Current [A] Current [A] :Base curve :Derating curve Ambient temperature [ç] Temperature rise [ç] Note: The derating curve is created by multiplying a derating factor of 0.8 to the current value of the base curve. 4 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections BDerating curve ●One pin skipped type (Electricity conducted through the 3 pins of 3-pin coplanar connection type connector) Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Electricity conducted through the 2 pins of 2-pin coplanar connection type connector) Note: The derating curve is created by multiplying a derating factor of 0.8 to the current value of the base curve. 5 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections 1±0.1 3±0.3 2.1±0.3 ●Right angle receptacle (S-DS type) 16.6±0.3 9.3±0.3 A±0.3 B±0.3 Diagram of recommended PCB layout dimensions (Note) PCB thickness : t= 1.6mm 9.3±0.05 P=3.81±0.05 0.8±0.3 P=3.81±0.3 C±0.3 D±0.3 3.3±0.3 (3) Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3±0.05 C±0.05 No.N No.1 11±0.3 3.4±0.3 No.N No.1 0.5±0.1 Ø1.35+00.1 Ø2.3+00.1 (Through hole) (Through hole) D±0.05 External outline of the connector Unit : mm Part No. HRS No. A B C D N (No. of Contacts) FX30B-2S-3.81DS FX30B-3S-3.81DS FX30B-4S-3.81DS FX30B-5S-3.81DS 570-3600-6 00 570-3601-9 00 570-3602-1 00 570-3603-4 00 20.56 24.37 28.18 31.99 15.41 19.22 23.03 26.84 3.81 7.62 11.43 15.24 18.21 22.02 25.83 29.64 2 3 4 5 ●Straight receptacle (S-DSA type) 11±0.3 A±0.3 No.1 No.N 1.2±0.2 16.3±0.3 12.9±0.3 B±0.3 Diagram of recommended PCB layout dimensions Ø2+0.1 0 E±0.05 No.1 3.3±0.3 (3) (Note) PCB thickness : t= 1.6mm External outline of the connector (hole) No.N 0.8±0.3 P=3.81±0.3 C±0.3 E±0.2 D±0.3 Ø2.3+0.1 0 3±0.05 4±0.05 (Through hole) P=3.81±0.05 C±0.05 D±0.05 Ø1.35+0.1 0 (Through hole) Unit : mm 6 Part No. HRS No. A B C D E N (No. of Contacts) FX30B-2S-3.81DSA FX30B-3S-3.81DSA FX30B-4S-3.81DSA FX30B-5S-3.81DSA 570-3500-1 00 570-3501-4 00 570-3502-7 00 570-3503-0 00 20.56 24.37 28.18 31.99 15.41 19.22 23.03 26.84 3.81 7.62 11.43 15.24 18.21 22.02 25.83 29.64 13.21 17.02 20.83 24.64 2 3 4 5 0.5±0.1 1.5±0.2 1±0.1 1.5±0.3 3±0.3 4±0.3 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections ●Right angle header (P-DS type) 1±0.1 3±0.3 4.2±0.3 10.8±0.3 9.6±0.3 19±0.3 A±0.3 B±0.3 F±0.3 Diagram of recommended PCB layout dimensions (Note) PCB thickness : t= 1.6mm D±0.05 External outline of the connector No.1 3.3±0.3 (3) C±0.05 P=3.81±0.05 No.N 3±0.05 0.8±0.3 P=3.81±0.3 C±0.3 D±0.3 0.5±0.1 Ø2.3+0.1 0 Ø1.35+0.1 0 (Through hole) (Through hole) Unit : mm Part No. HRS No. A B C D F N (No. of Contacts) FX30B-2P-3.81DS FX30B-3P-3.81DS FX30B-4P-3.81DS FX30B-5P-3.81DS 570-3400-7 00 570-3401-0 00 570-3402-2 00 570-3403-5 00 20.56 24.37 28.18 31.99 15.41 19.22 23.03 26.84 3.81 7.62 11.43 15.24 18.21 22.02 25.83 29.64 12.81 16.62 20.43 24.24 2 3 4 5 ●Straight header - 20 (P-DSA20 type) 11±0.3 A±0.3 No.N No.1 F±0.3 13±0.3 9.6±0.3 10.8±0.3 1.2±0.2 8.5±0.3 Diagram of recommended PCB layout dimensions (Note) PCB thickness : t= 1.6mm Ø2+00.1 E±0.05 No.N (hole) No.1 +0.1 Ø2.3 0 0.8±0.3 P=3.81±0.3 C±0.3 E±0.2 D±0.3 3.3±0.3 (3) External outline of the connector (Through hole) 0.5±0.1 1.5±0.2 1±0.1 1.5±0.3 3±0.3 4±0.3 3±0.05 4±0.05 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No.N 11±0.3 3.4±0.3 No.1 8.5±0.3 P=3.81±0.05 C±0.05 D±0.05 Ø1.35+0.1 0 (Through hole) Unit : mm Part No. HRS No. A C D E F N (No. of Contacts) FX30B-2P-3.81DSA20 FX30B-3P-3.81DSA20 FX30B-4P-3.81DSA20 FX30B-5P-3.81DSA20 570-3100-3 00 570-3101-6 00 570-3102-9 00 570-3103-1 00 20.56 24.37 28.18 31.99 3.81 7.62 11.43 15.24 18.21 22.02 25.83 29.64 13.21 17.02 20.83 24.64 12.81 16.62 20.43 24.24 2 3 4 5 7 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections ●Straight header - 25 (P-DSA25 type) 11±0.3 A±0.3 No.N No.1 B±0.3 F±0.3 Diagram of recommended PCB layout dimensions 1.2±0.2 18±0.3 14.6±0.3 9.6±0.3 10.8±0.3 8.5±0.3 (Note) PCB thickness : t= 1.6mm Ø2+00.1 E±0.05 No.N (hole) No.1 3.3±0.3 (3) Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. External outline of the connector Ø2.3+0.1 0 0.8±0.3 P=3.81±0.3 C±0.3 E±0.2 D±0.3 3±0.05 4±0.05 (Through hole) P=3.81±0.05 C±0.05 D±0.05 0.5±0.1 1.5±0.2 1±0.1 1.5±0.3 3±0.3 4±0.3 Ø1.35+0.1 0 (Through hole) Unit : mm Part No. HRS No. A B C D E F N (No. of Contacts) FX30B-2P-3.81DSA25 FX30B-3P-3.81DSA25 FX30B-4P-3.81DSA25 FX30B-5P-3.81DSA25 570-3200-8 00 570-3201-0 00 570-3202-3 00 570-3203-6 00 20.56 24.37 28.18 31.99 15.41 19.22 23.03 26.84 3.81 7.62 11.43 15.24 18.21 22.02 25.83 29.64 13.21 17.02 20.83 24.64 12.81 16.62 20.43 24.24 2 3 4 5 ●Straight header - 30 (P-DSA30 type) 11±0.3 A±0.3 No.N No.1 B±0.3 F±0.3 10.8±0.3 23±0.3 19.6±0.3 9.6±0.3 Diagram of recommended PCB layout dimensions Ø2+00.1 E±0.05 No.N 1.2±0.2 (Note) PCB thickness : t= 1.6mm External outline of the connector (hole) No.1 Ø2.3+0.1 0 3±0.05 4±0.05 3.3±0.3 (3) (Through hole) P=3.81±0.05 C±0.05 D±0.05 8 8.5±0.3 0.8±0.3 P=3.81±0.3 C±0.3 E±0.2 D±0.3 Ø1.35+0.1 0 (Through hole) Unit : mm Part No. HRS No. A B C D E F N (No. of Contacts) FX30B-2P-3.81DSA30 FX30B-3P-3.81DSA30 FX30B-4P-3.81DSA30 FX30B-5P-3.81DSA30 570-3300-2 00 570-3301-5 00 570-3302-8 00 570-3303-0 00 20.56 24.37 28.18 31.99 15.41 19.22 23.03 26.84 3.81 7.62 11.43 15.24 18.21 22.02 25.83 29.64 13.21 17.02 20.83 24.64 12.81 16.62 20.43 24.24 2 3 4 5 0.5±0.1 1.5±0.2 1±0.1 1.5±0.3 3±0.3 4±0.3 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections 1±0.1 3±0.3 2.1±0.3 ●Right angle receptacle (S-DS type) One pin skipped type 16.6±0.3 9.3±0.3 A±0.3 B±0.3 11±0.3 3.4±0.3 Diagram of recommended PCB layout dimensions D±0.05 C±0.05 Contact No.N 3.3±0.3 (3) 3±0.05 P=7.62±0.05 Contact No.1 0.8±0.3 External outline of the connector 0.5±0.1 P=7.62±0.3 C±0.3 D±0.3 9.3±0.05 +0.1 Ø1.35 0 (Through hole) +0.1  0 Ø2.3 (Through hole) Unit : mm Part No. HRS No. FX30B-2S-7.62DS FX30B-3S-7.62DS 570-3604-7 00 570-3605-0 00 A B C D N (No. of Contacts) 24.37 19.22 7.62 22.02 31.99 26.84 15.24 29.64 2 3 ●Straight receptacle (S-DSA type) One pin skipped type 11±0.3 A±0.3 Contact No.1 Contact No.N Diagram of recommended PCB layout dimensions (Note) PCB thickness : t= 1.6mm E±0.05 Contact No.1 Contact No.N Ø2 +0.1 0 (hole) +0.1 0 (Through hole) Ø2.3 3.3±0.3 (3) External outline of the connector P=7.62±0.05 C±0.05 D±0.05 Part No. HRS No. FX30B-2S-7.62DSA FX30B-3S-7.62DSA 570-3504-2 00 570-3505-5 00 1.2±0.2 16.3±0.3 12.9±0.3 B±0.3 3±0.05 4±0.05 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Note) PCB thickness : t= 1.6mm 0.8±0.3 P=7.62±0.3 C±0.3 E±0.2 D±0.3 0.5±0.1 Ø1.5±0.2 1±0.1 1.5±0.3 3±0.3 4±0.3 +0.1 Ø1.35 0 (Through hole) Unit : mm A B C D E 24.37 19.22 7.62 22.02 17.02 31.99 26.84 15.24 29.64 24.64 N (No. of Contacts) 2 3 9 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections 1±0.1 3±0.3 4.2±0.3 ●Right angle header (P-DS type) One pin skipped type 10.8±0.3 19±0.3 9.6±0.3 A±0.3 B±0.3 F±0.3 8.5±0.3 Contact No.N Contact No.1 11±0.3 3.4±0.3 Diagram of recommended PCB layout dimensions (Note) PCB thickness : t= 1.6mm P=7.62±0.05 External outline of the connector Contact No.1 3.3±0.3 (3) Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D±0.05 C±0.05 Contact No.N 0.8±0.3 P=7.62±0.3 C±0.3 D±0.3 3±0.05 0.5±0.1 +0.1 Ø1.35  0 (Through hole) (Through hole) +0.1  0 Ø2.3 Unit : mm Part No. HRS No. FX30B-2P-7.62DS FX30B-3P-7.62DS 570-3404-8 00 570-3405-0 00 A B C D F N (No. of Contacts) 24.37 19.22 7.62 22.02 16.62 31.99 26.84 15.24 29.64 24.24 2 3 ●Straight header - 20 (P-DSA20 type) One pin skipped type 11±0.3 A±0.3 Contact No.N Contact No.1 8.5±0.3 13±0.3 9.6±0.3 Diagram of recommended PCB layout dimensions (Note) PCB thickness : t= 1.6mm Contact No.N Contact No.1 +0.1 0 Ø2 (hole) Ø2.3+0.1 0 (Through hole) 3.3±0.3 (3) E±0.05 3±0.05 4±0.05 External outline of the connector C±0.05 D±0.05 10 Part No. HRS No. FX30B-2P-7.62DSA20 FX30B-3P-7.62DSA20 570-3104-4 00 570-3105-7 00 10.8±0.3 1.2±0.2 F±0.3 0.8±0.3 C±0.3 E±0.2 D±0.3 P=7.62±0.05 +0.1 Ø1.35 0 (Through hole) Unit : mm A C D E F 24.37 7.62 22.02 17.02 16.62 31.99 15.24 29.64 24.64 24.24 N (No. of Contacts) 2 3 1±0.1 0.5±0.1 P=7.62±0.3 1.5±0.3 3±0.3 Ø1.5±0.2 4±0.3 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections ●Straight header - 25 (P-DSA25 type) One pin skipped type 11±0.3 A±0.3 Contact No.N Contact No.1 8.5±0.3 C±0.05 D±0.05 1.2±0.2 Ø2+0.1 0 (hole) Ø2.3+0.1 0 (Through hole) 3±0.05 4±0.05 No.1 3.3±0.3 (3) E±0.05 No.N 0.8±0.3 C±0.3 E±0.2 D±0.3 P=7.62±0.05 +0.1 Ø1.35 0 (Through hole) 0.5±0.1 P=7.62±0.3 Ø1.5±0.2 1±0.1 1.5±0.3 3±0.3 4±0.3 Unit : mm Part No. HRS No. FX30B-2P-7.62DSA25 FX30B-3P-7.62DSA25 570-3205-1 00 570-3206-4 00 A B C D E F N (No. of Contacts) 24.37 19.22 7.62 22.02 17.02 16.62 31.99 26.84 15.24 29.64 24.64 24.24 2 3 ●Straight header - 30 (P-DSA30 type) One pin skipped type 11±0.3 A±0.3 Contact No.1 Contact No.N 8.5±0.3 E±0.05 Contact No.N Contact No.1 Ø2+0.1 0 (hole) Ø2.3+0.1 0 (Through hole) C±0.05 D±0.05 P=7.62±0.05 +0.1 (Through hole) Ø1.35 0 1.2±0.2 External outline of the connector 23±0.3 19.6±0.3 9.6±0.3 (Note) PCB thickness : t= 1.6mm 3.3±0.3 (3) Diagram of recommended PCB layout dimensions 10.8±0.3 B±0.3 F±0.3 3±0.05 4±0.05 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (Note) PCB thickness : t= 1.6mm External outline of the connector 18±0.3 14.6±0.3 9.6±0.3 Diagram of recommended PCB layout dimensions 10.8±0.3 B±0.3 F±0.3 0.8±0.3 C±0.3 E±0.2 D±0.3 1±0.1 0.5±0.1 P=7.62±0.3 1.5±0.3 3±0.3 Ø1.5±0.2 4±0.3 Unit : mm Part No. HRS No. FX30B-2P-7.62DSA30 FX30B-3P-7.62DSA30 570-3304-3 00 570-3205-6 00 A B C D E F 24.37 19.22 7.62 22.02 17.02 16.62 31.99 26.84 15.24 29.64 24.64 24.24 N (No. of Contacts) 2 3 11 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections BTray Packaging State Diagram ●Right angle receptacle (S-DS type) ●Normal type (265) (B) (C) (175) (97.6) (30) (P=24.4) (P=A) A FX30B-5S-3.81DS Unit : mm Part No. A B C Quantity FX30B-2S-3.81DS FX30B-3S-3.81DS FX30B-4S-3.81DS FX30B-5S-3.81DS 30 180 42.5 35 35.5 177.5 43.75 30 42 168 48.5 ●One pin skipped type Part No. QTY.25 >PS< FX30B-2S-7.62DS FX30B-3S-7.62DS 25 Unit : mm A B C 35.5 177.5 43.75 42 168 48.5 Quantity 30 25 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Straight receptacle (S-DSA type) ●Normal type (265) (B) (P=A) A FX30B-5S-3.81DSA (175) (108) (P=18) (33.5) (C) Unit : mm Part No. A B C Quantity FX30B-2S-3.81DSA FX30B-3S-3.81DSA FX30B-4S-3.81DSA FX30B-5S-3.81DSA 31.5 38 189 190 38 37.5 49 42 45 180 42.5 35 ●One pin skipped type QTY.35 >PS< Unit : mm Part No. A B C Quantity FX30B-2S-7.62DSA FX30B-3S-7.62DSA 38 45 190 180 37.5 42.5 42 35 ●Right angle header (P-DS type) ●Normal type (265) (B) (C) (175) (93) (40.6) (P=31) (P=A) A FX30B-5P-3.81DS Unit : mm Part No. A B C Quantity FX30B-2P-3.81DS FX30B-3P-3.81DS FX30B-4P-3.81DS FX30B-5P-3.81DS 30 180 42.5 28 35.5 177.5 43.75 24 42 168 48.5 ●One pin skipped type Part No. QTY.20 >PS< FX30B-2P-7.62DS FX30B-3P-7.62DS 20 Unit : mm A B C 35.5 177.5 43.75 42 168 48.5 Quantity 24 20 ●Straight header - ** (P-DSA** type) ●Normal type (265) (B) (C) (33.5) (P=A) A (175) (108) (P=18) FX30B-5P-3.81DSA30 Unit : mm Part No. A B C Quantity FX30B-2P-3.81DSA** FX30B-3P-3.81DSA** FX30B-4P-3.81DSA** FX30B-5P-3.81DSA** 31.5 38 189 190 38 37.5 49 42 45 180 42.5 35 ●One pin skipped type QTY.35 >PS< Unit : mm Part No. A B C Quantity FX30B-2P-7.62DSA** FX30B-3P-7.62DSA** 38 45 190 180 37.5 42.5 42 35 Note : The above illustration shows a tray form example. Please refer to “delivery specifications” for official individual forms. 12 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections BCleaning conditions ●Organic Solvent Cleaning Solvent Room temperature cleaning Heated cleaning ○ ○ IPA (Isopropyl alcohol) ●Water Cleaning When using water cleaner (terpene, alkali saponifier, etc.), please select a cleaner according to the chart of effects to metal and resin issued by each cleaner manufacture. In addition, please make sure that the connectors are not left behind without removing moisture. ●Precautions for Cleaning BUsage precautions ●A position misalignment absorption function is provided in this product. Please use this product within the dimensions shown in the below diagram, while taking into account the connector mounting position misalignments and PCB mating position misalignments. Longitudinal direction (X direction) ●The purpose of the position misalignment absorption function provided on ±0.3 mm this product is to absorb the misalignments between the connector mounting positions and between the PCB mating positions. This function cannot be used for the purpose to absorb mating position misalignments due to vibrations. Please use the connectors after the PCBs have been fixed so that the connector positions are fixed securely. Avoid supporting PCBs by connectors only, and be sure to fix the PCBs using methods other than the connectors. Lateral direction (Y direction) ±0.3 mm ●This connector is designed to correct minor mating misalignments. This ability creates a structure that allows more for more movement and shifting between its pieces than with other similar connectors. The PCB boards need to be secured as well. If they are not, vibration or other external forces will cause the connectors to become unmated. ●This product has a structure to absorb position misalignments by the spring displacement of the contacts in pitch directions. Therefore, a spring reaction force will be generated in the pitch directions when absorbing the position misalignments (Approximately 4 N per 1 core) Please make sure that the structure bodies (positioning pins, screws, guiding rails, and other connectors, etc.) that will be used as the positioning base have enough strength against the spring reaction force. ●Allowable Mating Gap Receptacle side Within 1.3mm Within 1.3mm Within 1mm The effective mating length of this product is 2mm. Use the connectors so that the gap between the header and receptacle when they are mated is within 1.0 or 1.3mm. Particularly make sure the gap does not exceed the limits due to warping of PCB, etc. Within 1mm Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. If flax or cleaner remains in the connector after it was cleaned using organic solvent or water cleaner, the performance of the connector may deteriorate. Make sure that the connectors are cleaned thoroughly. Header side Coplanar connection type Vertical connection type A Vertical connection type B Parallel connection type 13 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections ●A reverse insertion prevention structure and an abnormal mating position prevention structure have been provided in this connector, however, if the connectors are mated with an excessive force, connector breakage may result. Avoid improper mating of connectors by applying an excessive force and connect them correctly while confirming the connector polarities shown below.shown below.tors by applying an excessive force and connect them correctly while confirming the connector polarities shown below. Receptacle side Δ mark (polarity mark) Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. *Prior to mating, make sure that the connector polarity marks match Header side Δ mark (polarity mark) ●A structure in which the contact deformation does not occur under normal mating operations has been provided on this connector, however, please make sure of the following; connector edge does not come to contact with the opening for mating, connectors are not mated diagonally in an abnormal manner, and foreign substances or hard objects, etc. do not touch the contacts. Pay attention so that contact deformation which causes a contact defect does not occur. ●If the connector is inserted/extracted forcibly in a wrong direction or it is rotated when inserting/extracting, a connector breakdown or contact defect may result. Please be careful. ●This product cannot be used for the purpose of current interruption application. (Prohibition of hot-swapping) 14 FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 15 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX30B Series●13~25A Compatible, Position Misalignment Absorption Type Power Supply Connector for PCB Connections USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 16 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 06/2019. Contents are subject to change without notice for the purpose of improvements.
FX30B-3P-7.62DS 价格&库存
很抱歉,暂时无法提供与“FX30B-3P-7.62DS”相匹配的价格&库存,您可以联系我们找货
