8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
2668
ADD 'LCP' MATERIAL AND REMOVE 'NYLON 9T'
09/06/2012
LH
E
2828
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL, UPDATE LCP OPERATING TEMP TO -40 C 04/09/2015
TO +125 C (WAS -40 C TO +105 C)
LH
F
E
E
B .012[ 0.30]
.197 5.00
D
D
A
.100 2.54
HEAD DIM.
C
TAIL DIM. .012[0.30]
.158 4.02
C
.098 2.50
.100 2.54
A
.100 2.54
.025 0.64
.100 2.54
B
.039 1.00
B
.100 2.54
RECOMMENDED PCB LAYOUT
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK.
2. CONTACT MATERIAL: SEE PAART NUMBER CODING.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 1000 VAC.
8. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
8
7
6
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
DECIMALS
.XX= .01 [.3]
.XXX= .008 [.20]
.XXXX= .0040 [.100]
DRAWN
DATE
NAME
03/21/2011 LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER .100"[2.54mm]PITCH, 2 ROWS, RA
PART NUMBER
SIZE
C
54453
SCALE: 4:1
3
2
_ R _C_ _ _-D_ _N-M71RC
CAGE CODE
DWG. NO.
11639
SHEET 1 OF 1
1
REV
E
FILE NAME: 11639, _ R_C_ _ _D_ _N-M71RC
A
很抱歉,暂时无法提供与“PREC018DGAN-M71RC”相匹配的价格&库存,您可以联系我们找货
