XX
X
X
U
D
X
X
X
Shell type : FH Plug IP68
Shell size
Keying : G, A, B, C, D, E
Contact layout : SEE INSULATOR DRAWING
PROTECTION INDEX:
Contact style: S (solder), C (Crimp)
[0.79]
2000 MATING CYCLES AS PER IEC
60512-5 test 9a
Dropping height 750 mm [29.53] per
IEC 60512 test 7b
Contact style
DURING 1 WEEK)
7
term +134°C / 273.2°F)
Connector color coding
(ASSEMBLED VIEW FOR INFORMATION ONLY)
Packaging :Nothing : single packaging, B(Bulk) : 100pcs
6
REFERENCE
PPP1-0036B
PPP1-0037B
5
PPP1-0038B
PPP1-0039B
PPP1-0040B
POSITION
Color
G
No color
A
Blue
A
B
Red
R
C
Green
V
D
Orange
O
E
Yellow
J
Optional color coding
Color
Code
U
Max tightening torque : 1.5 N.m
0.5
2 [0.079]
04, 05
0.9
3 [0.118]
1.3
04, 05
0.9
02, 03
1.3
14 on flats
1.35 [0.053] 5.5 [0.217]
1.60 [0.063] 5.5 [0.217]
2.10 [0.083] 5.5 [0.217]
Mark
Mark
7.5 [0.295]
A
6.15 [0.242]
B
4.8 [0.189]
C
3.5 [0.138]
D
CABLE GLAND AND COLLET SHOULD BE USED IN
ACCORDANCE WITH THE CABLE JACKET MATERIAL
5
FRONT VIEW
55 around
[2.16]
REFERENCE
MAIN KEY
POSITION
PPP1-0029B
4
PPP1-0030B
AR
PPP1-0031B
BR
7
PPP1-0032B
SCALE 1/1
PPP1-0033B
VARIABLE KEYS
3
PPP1-0034B
3
5
AR
BR
A
45 $ 180 $
B
135 $225 $
C
45 $ 225 $
D
135 $315 $
E
180 $315 $
G
165 $195 $
4
3
G : Default key
CountryJurisdiction
& Control List
FR
NOT LISTED
INSULATOR KEY
(ALIGN WITH HALF BUSH WINDOW)
P/N : SEE TABLE : CONNECTOR CODING
6
4
MASS
2
1
ITEM
NO.
1
2
3
1
VISUAL KEY
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
H
3.5 [0.138]
6
40 around
[1.57]
HALF BUSH KEY
(ALIGN WITH INTERNAL SLEEVE GROOVE)
3 [0.118]
BACK VIEW
18,5 0,5
[ n 0.71 - n 0.75]
C
10, 12
06, 07, 08 0.7
C (Crimp)
SIDE VIEW
Contact size
02, 03
Back nut : S (standard, cable gland), M (boot), O (overmolded)
See color/keying table
Layout
06, 07, 08 0.7
S (Solder)
-40°C +125°C (-40°F +257°F)
AUTOCLAVING
200 CYCLES AS ISO 17665-1 (Short
BIOCOMPATIBILITY: ALL SHELL PEI_ULTEM PARTS to USP Class VI / ISO 10993
Standard collet
C
8
IP 50 In unmated condition
ROHS & REACH COMPLIANT
OPERATING TEMPERATURE:
Material : (U) PEI_ULTEM
Stripping dimensions
METHOD 21
3.5mm MIN. TO 7.5mm MAX.
IP 68 AS PER IEC 60529 (1BAR
In mated condition
Contact type : M (Male), F (Female)
A
X
>500M ^
PER ANSI-EIA-364-D
B
1
ELECTRICAL:
INSULATION RESISTANCE :
MAX. CURRENT RATING :
CONNECTOR TESTING VOLTAGE :
CONNECTOR WORKING VOLTAGE :
PHYSICAL:
MAXIMUM WIRE SIZE USED :
CABLE DIAMETER
ENVIRONMENTAL:
ENDURANCE:
SHOCK:
C
FH
D
JMX
E
F
G
H
Basic type
8
E.15; Validé
Connector coding
G
4
2
5
SCALE 1/1
6
7
F
E
10%
12 g
PART LIST
MATERIAL
SLEEVE
PEI_ULTEM
HALF BUSH WITHOUT WINDOW
INSULATOR
(CHOOSE PER CABLE SIZE)
RUBBER WASHER
STANDARD BACK NUT
D
17/05/18
ISS
DATE
Designed by:
DESCRIPTION
HALF BUSH WITH WINDOW
E
TITLE
PEI_ULTEM
Scale
PEI_ULTEM
2/1
PEEK
Adding color/keying table and cable/claw table
Latest modification - by:
25108
J.GAMBIER
Q.LEBRETON Date:20/01/17
CUSTOMER DRAWING
MOD N $
PLUG - STANDARD VERSION SIZE 1 WITH CABLE GLAND - TYPE FH (IP68)
GAMME JMX
General linear
Tolerances:
SEE TABLE
NPRDS / PROJECT
BE150710A
This document is the property of
SOURIAU
www.esterline-connection-technologies.com
It must not be reproduced or
communicated without permission
PEI_ULTEM
SILICONE
FORMAT
PEI_ULTEM
C
A2
2
SOURIAU DRG N°
C0002-PPP1-A
B
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“JMXFH1G05FSUDSU”相匹配的价格&库存,您可以联系我们找货
