BG095-08-A-N-D
BG095-08-A-N-D
    GCT
    插件,P=2.54mm
    排母 间距:2.54mm 1x8P 直插
BG095-08-A-N-D 数据手册
H 2.54 2.54 2.54 G Recommended PCB Layout Minimum Insertion Depth 1.45 Ref. Maximum Insertion Depth 4.40 ref. Specifications 2.54 Material Insulator: Standard: Polyamide, Nylon 6T, UL94V-0 Options: Polymer, LCP, UL94V-0 Polyester, PBT, UL94V-0 Contact: Phosphor Bronze 5.00 F 3.00 E 2.54 D 0.70 x 0.25 Pin A±0.25 Ordering Grid BG095 XX X X X No. of Contacts 02 to 40 B A Request Samples and Quotation Packing Options D = Tube (Standard) E = Tube with Cap F = Tube with Film G = Plastic Box Contact Plating A = Gold Flash All Over (Standard) B = Selective Gold Flash Contact Area/Tin On Tail C = Tin All Over G = 10µ" Gold Contact Area/Tin On Tail I = 30µ" Gold Contact Area/Tin On Tail Insulator Material N = Nylon 6T (Standard) P = PBT L = LCP 1 2 3 4 5.08 8.12 4 7.62 10.66 5 10.16 13.20 6 12.70 15.74 7 15.24 18.28 8 17.78 20.82 9 20.32 23.36 10 22.86 25.90 11 25.40 28.44 12 27.94 30.98 13 30.48 33.52 36.06 38.60 16 38.10 41.14 17 40.64 43.68 18 43.18 46.22 Plating See Ordering Grid 19 45.72 48.76 20 48.26 51.30 Electrical Current Rating: 3 Amp Per Pin Contact Resistance: 20 mΩ max. Insulation Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 600 V AC 21 50.80 53.84 22 53.34 56.38 23 55.88 58.92 24 58.42 61.46 25 60.96 64.00 26 63.50 66.54 27 66.04 69.08 28 68.58 71.62 Product Description BG095 2.54mm Pitch Socket, Single Row, Through-Hole, Vertical, Dual Beam Folded Contact Drawing Date 28th December 2007 5 3 33.02 Part Number Revision Date 5.58 35.56 Mates with (Subject to Pin Length) BG020 BG030 BG031 BG035 BG055 BG060 BG075 BG080 By B 2.54 15 (Not suitable for hi-temp process) Detail A 2 14 Mechanical & Environmental Operating Temperature: -40°C to +105°C Soldering Process Nylon 6T (Standard) IR Reflow: 260°C for 10 sec. Wave: 230°C for 5-10 sec. Manual Solder: 350°C for 3-5sec LCP (Option) IR Reflow: 260°C for 10 sec. Wave: 250°C for 5-10 sec Manual Solder: 350°C for 3-5 sec PBT (Option) Manual Solder: 330°C for 3-5 sec. B±0.38 C Dimensions Number of Contacts Ø1.02 CC Tolerances (Except as Noted) BG095 E PCN E3 16/11/17 X.° ± 5° X. ± 0.30 X.X° ± 2° X.X ± 0.20 X.XX ± 0.15 X.XX° ± 1° X.XXX ± 0.10 X.XXX° ± 0.5° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 29 71.12 74.16 30 73.66 76.70 31 76.20 79.24 32 78.74 81.78 33 81.28 84.32 34 83.82 86.86 35 86.36 89.40 36 88.90 91.94 37 91.44 94.48 38 93.98 97.02 39 96.52 99.56 40 99.06 102.10 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By ASS 8 Sheet No. 1/1
BG095-08-A-N-D 价格&库存
很抱歉,暂时无法提供与“BG095-08-A-N-D”相匹配的价格&库存,您可以联系我们找货
BG095-08-A-N-D
  • 1+6.442761+0.83395
