FGJ.2B.308.CLLD72
www.lemo.com
SUMMARY
# Wires
Low voltage
8
Image is for illustrative purpose only
Series
2B
Termination type
Female solder
IP rating
50
AWG wire size
30.00 - 22.00
Cable Ø
6.30 - 7.20 mm
Status
active
Matching parts
EGJ.2B.308.CLA
Download
Request a quote
Eplan
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet
Keying
2 keys (alpha=37.5, plug: female contacts, receptacle: male contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
29.78 g
Performance
Configuration
2B.308 : 8 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
10 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 4.8 mOhm
Vtest (contact-shell): 1250 V (AC), 1770 V (DC)
Vtest (contact-contact): 1500 V (AC), 2120 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
15
50
38
13
12
in.
0,59
1,97
1,50
0,51
0,47
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.2B.025.PA120
2/3
Cables
108220
PVC
Black
280250
PVC
Grey
3/3
很抱歉,暂时无法提供与“FGJ.2B.308.CLLD72”相匹配的价格&库存,您可以联系我们找货
