PRPN222PAEN
PRPN222PAEN
    SULLINS
    CONN HEADER VERT 44POS 2MM
PRPN222PAEN 数据手册
1 2 3 No. of 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 40.00 38.00 36.00 34.00 32.00 30.00 28.00 26.00 24.00 22.00 20.00 18.00 16.00 14.00 12.00 10.00 8.00 46.00 44.00 42.00 A B +-0.20 B 4.00 +-0.15 C 2.00 +-0.05 40.00 38.00 36.00 34.00 32.00 30.00 28.00 26.00 24.00 22.00 20.00 18.00 16.00 14.00 12.00 2.00 +-0.05 SCALE UNIT SIZE NTS MM 2.00 +-0.15 2.80 +-0.20 DRAWN DATE DATE 04.18.2000 DWG. NO. PARTS NO. D SPECIFICATIONS T0030 PRPNxx2PAEN D TITLE E E SHEET REV. Note that "xx" in part number designates number of dual positions, not total contacts. CHECK DATE C APPROVE PIN 0.5X0.5 +-0.05 A +-0.05 B 40 42.00 48.00 GENERAL TOLERANCE XX. +XXX. +.XXX +X.ß +.Xß +- B 4.00 +-0.20 A DIMENSIONS 42 44.00 50.00 Contacts 44 46.00 52.00 1 Amp 5000 Mega Ohm Min. 46 48.00 54.00 4.00 48 50.00 56.00 2.00 50 52.00 58.00 500 VAC 52 54.00 60.00 Current Rating: Insulator Resistance: 54 56.00 62.00 Dielectric withstanding: 56 58.00 64.00 6.00 58 60.00 66.00 8.00 60 62.00 68.00 4.00 62 64.00 70.00 6.00 64 66.00 72.00 -40 Degrees C. to +105 Degrees C. Brass or Phospher bronze 66 68.00 74.00 Operating Temperature: Contact Material: 68 70.00 76.00 10.00 70 72.00 78.00 Polyester,UL 94V-0 Standard: P.B.T 72 74.00 Insulator Material: 74 76.00 Gold/Tin, Selective Plating 76 80.00 Contact Finish: 78 78.00 +-0.50 80 -Yµô¤Á PIN DIM. B SULLINS 801 E. MISSION RD. SAN MARCOS, CA 92069 X. +- 0.20 .X +- 0.10 .XX +- 0.05 A 1 2 3
PRPN222PAEN 价格&库存
很抱歉,暂时无法提供与“PRPN222PAEN”相匹配的价格&库存,您可以联系我们找货
