HGG.1B.306.CLLPV
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
1B
Termination type
Female solder
IP rating
68
AWG wire size
30.00 - 22.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FGG.1B.306.CLAD42
Download
Request a quote
Eplan
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
HG*: Fixed receptacle, nut fixing, watertight or vacuum-tight
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
PV : Watertight / Vacuum-tested
Weight
13.44 g
Performance
Configuration
1B.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
7 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 6.1 mOhm
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Vtest (contact-shell): 1200 V (AC), 1700 V (DC)
Vtest (contact-contact): 1050 V (AC), 1490 V (DC)
Others
Endurance (Shell): 5000
Temp (min / max): -20°C / +100°C
Humidity (max): 1000 hr
Pressure: 60 bars
12NC part number: 4022.438.33303
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
18
16
7
26.6
4.5
10.5
14
M12x1.0
in.
0,71
0,63
0,28
1,05
0,18
0,41
0,55
RECOMMENDED BY LEMO
2/3
Tools
Cables
CMN.06.T26.037QGZE
TPR (medical)
Grey
CMN.06.T28.031PGCE
PVC
GREY
CMN.06.T28.031PGZE
CMN.06.T28.031PNCE
Grey
PVC
Black
CMN.06.T28.031PNZE
CMN.06.T28.042QBCE
TPR (medical)
CMN.06.T28.044PGZE
Grey
CMN.06.T28.044PNZE
106220
PVC
Black
106240
PTFE
White
12080
PVC
Grey
160140
PVC
Grey
160240
PVC
Black
160260
PVC
Black
260250
PVC
Grey
60260
PTFE
White
6280
PVC
Black
3/3
很抱歉,暂时无法提供与“HGG.1B.306.CLLPV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+690.015211+89.31528
