SM04B-SRSS-TB
SM04B-SRSS-TB
    JST
    CONN HEADER SMD R/A 4POS 1MM
SM04B-SRSS-TB 数据手册
IDC 1.0mm SR CONNECTOR Emboss Tape Disconnectable Insulation displacement connectors (.039") pitch Features –––––––––––––––––––––––– • Ultra-compact insulation displacement connector 1.0mm (.039") pitch and only 3.0mm (.118") high (side entry type). This connector is only about 61% as large as the smallest conventional (JST) IDC designs. • Header designed for vacuum pick and place robotics Although this shrouded header has locking features for its mating receptacle, there are no holes in the header shroud that would adversely effect vacuum grippig equipment. Since there is enough flat surface for secure vacuum gripping, this miniature surface mount connector is versatile for designers and economic for manufacturing. • Twin U-slot insulation displacement section The insulation displacement section connected to each wire consists of two tin-plated slots (twin U-slots), which ensures reliable connection. • 3-point grip construction The 3-point insulation grip feature and the strain relief ensure a firm grip on terminated wires and protection of the insulation displacement connection from possible damage. JS T 9 Specifications ––––––––––––––––––– • Current rating: 0.7A DC • Voltage rating: 50V DC • Temperature range: -25˚C to +85˚C(including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/40m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #30 Conductor/7 strands, tin-coated annealed copper Insulation O.D./0.56mm (.022") * Contact JST for details. Standards –––––––––––––––––––––– 0 1 Recognized E60389 Certified LR20812 223 SR CONNECTOR Receptacle ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits Model No. 2 3 02SR-3S 1.0(.039) 3.0(.118) 3,000 03SR-3S 2.0(.079) 4.0(.157) 3,000 4 04SR-3S 3.0(.118) 5.0(.197) 3,000 5 05SR-3S 4.0(.157) 6.0(.236) 2,000 6 06SR-3S 5.0(.197) 7.0(.276) 2,000 7 07SR-3S 6.0(.236) 8.0(.315) 2,000 8 08SR-3S 7.0(.276) 9.0(.354) 2,000 9 09SR-3S 8.0(.315) 10.0(.394) 2,000 10 10SR-3S 9.0(.354) 11.0(.433) 2,000 11 11SR-3S 10.0(.394) 12.0(.472) 2,000 12 12SR-3S 11.0(.433) 13.0(.512) 2,000 13 13SR-3S 12.0(.472) 14.0(.551) 2,000 14 14SR-3S 13.0(.512) 15.0(.591) 2,000 3.6(.142) 1.0 (.039) A 2.1(.083) Q’ty / box B 2.45(.097) B Dimensions mm(in.) A Material and Finish Contact: Phosphor bronze, tin-plated Housing: Polyamide 66, UL94V-0, natural (ivory) Shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Dimensions mm(in.) Side entry type Circuits 2.9(.114) B 1.5 (.059) 1.0 (.039) A 4.25(.167) 0.7(.028) Top entry type 4.25(.167) B Side entry type A B Top entry type 2 BM02B-SRSS-TB SM02B-SRSS-TB 1.0(.039) 4.0(.157) 1,500 3,000 3 BM03B-SRSS-TB SM03B-SRSS-TB 2.0(.079) 5.0(.197) 1,500 3,000 4 BM04B-SRSS-TB SM04B-SRSS-TB 3.0(.118) 6.0(.236) 1,500 3,000 5 BM05B-SRSS-TB SM05B-SRSS-TB 4.0(.157) 7.0(.276) 1,500 3,000 6 BM06B-SRSS-TB SM06B-SRSS-TB 5.0(.197) 8.0(.315) 1,500 3,000 7 BM07B-SRSS-TB SM07B-S RSS-TB 6.0(.236) 9.0(.354) 1,500 3,000 8 BM08B-SRSS-TB SM08B-SRSS-TB 7.0(.276) 10.0(.394) 1,500 3,000 9 BM09B-SRSS-TB SM09B-SRSS-TB 8.0(.315) 11.0(.433) 1,500 3,000 10 BM10B-SRSS-TB SM10B-SRSS-TB 9.0(.354) 12.0(.472) 1,500 3,000 11 BM11B-SRSS-TB SM11B-SRSS-TB 10.0(.394) 13.0(.512) 1,500 3,000 12 BM12B-SRSS-TB SM12B-SRSS-TB 11.0(.433) 14.0(.551) 1,500 3,000 13 BM13B-SRSS-TB SM13B-SRSS-TB 12.0(.472) 15.0(.591) 1,500 3,000 14 BM14B-SRSS-TB SM14B-SRSS-TB 13.0(.512) 16.0(.630) 1,500 3,000 1.5 (.059) 1.0 (.039) 0.7(.028) A Q'ty / reel Side entry type Top entry type Material and Finish 2.9(.114) Contact: Copper alloy, copper-undercoated, tin/lead plated Wafer: Polyamide, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin/lead plated Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the top entry type headers with suction cap. PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– Top entry type Side entry type 0.6 ± 0.05 (.024 ± .002) 2.9(.114) 0.6 ± 0.05 (.024 ± .002) 1.0 ± 0.05 (.039 ± .002) 1.0 ± 0.05 (.039 ± .002) 224 0.7 ± 0.1 (.028 ± .004) 1.2 ± 0.1 (.047 ± .004) 5.55 ± 0.1 (.219 ± .004) 4.0 ± 0.1 (.157 ± .004) 1.8 ± 0.1 (.071 ± .004) 2.95(.116) Shrouded header 0.2 ± 0.1 (.008 ± .004) 1.2 ± 0.1 (.047 ± .004) 4.2 ± 0.1 (.165 ± .004) 1.8 ± 0.1 (.071 ± .004) 0.7 ± 0.1 (.028 ± .004) 0.2 ± 0.1 (.008 ± .004) 4.9(.193) Shrouded header 2.65 ± 0.1 (.104 ± .004) 4.85(.191) Note: 1. Tolerances are non-cumulative: ±0.05mm(±.002" ) for all centers. 2. Dimensions above should serve as a guideline. Contact JST for details. SR CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Feeding direction Feeding direction Cover tape leader area [100(3.937)dia.] 380 ± 2.0 (14.961 ± .079)dia Carrier tape Lead tape (Unloaded area) 20 vacancies min. 13.0(.512)dia. W1 +2.5 -1.0 (W1+.098 -.039 ) Tail tape (Unloaded area) 40(1.575) min. 2.0 ± 0.5 (.079 ± .002) Top entry type Feeding direction F ± 0.1 (.004) W±0.3(.012) (S) Carrier tape Cover tape Carrier tape 0.38 ± 0.05 (.015 ± .002) 0.38±0.05 (.015±.002) 4.55 (.179) 8.0 ± 0.1 (.315 ± .004) Taping dimensions mm(in.) S F 2.0 ± 0.1 (.079 ± .004) W ± 0.3(.012) 1.75±0.1 (.069±.004) F±0.1 (.004) (S) 4.0 ± 0.1 (.157 ± .004) 1.55 ± 0.05 (.061 ± .002)dia. Cover tape 1.75 ± 0.1 (.069 ± .004) 2.0±0.1 (.079±.004) 4.0±0.1 (.157±.004) 12±0.1 (.315±.004) Circuits 400(15.748) min. Side entry type Feeding direction 1.55±0.05 (.061±.002)dia. Connector loaded area 3.25 (.128) Reel dimensions mm(in.) W1 W Q'ty / reel Side entry type Top entry type Side entry type 13.5(.531) 13.5(.531) 1,500 3,000 17.5(.689) 13.5(.531) 1,500 3,000 16(.630) 17.5(.689) 17.5(.689) 1,500 3,000 24(.945) 16(.630) 25.5(1.004) 17.5(.689) 1,500 3,000 24(.945) 24(.945) 25.5(1.004) 25.5(1.004) 1,500 3,000 Top entry type Side entry type Top entry type Side entry type Top entry type Side entry type 2 to 3 5.5(.217) 5.5(.217) 4.75(.187) 4.75(.187) 12(.472) 12(.472) 4 7.5(.295) 5.5(.217) 6.75(.266) 4.75(.187) 16(.630) 12(.472) 5 to 7 7.5(.295) 7.5(.295) 6.75(.266) 6.75(.266) 16(.630) 8 11.5(.453) 7.5(.295) 10.75(.423) 6.75(.266) 9 to 14 11.5(.453) 11.5(.453) 10.75(.423) 10.75(.423) Top entry type Note: 1. Specifications conform to JIS C 0806. The tape width, connector recess hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice. 225
SM04B-SRSS-TB 价格&库存
很抱歉,暂时无法提供与“SM04B-SRSS-TB”相匹配的价格&库存,您可以联系我们找货
SM04B-SRSS-TB
    • 5+1.37080
    • 50+1.08120
    • 150+0.93980
    • 500+0.81370
    • 3000+0.75380
    • 6000+0.73290
    库存:157925
    SM04B-SRSS-TB
      库存:12000
      SM04B-SRSS-TB
        库存:27000
        SM04B-SRSS-TB
          库存:2991
          SM04B-SRSS-TB
          • 1+4.398471+0.55158
          • 10+3.7339110+0.46824
          • 100+3.17318100+0.39793
          • 500+2.83181500+0.35512
          • 1000+2.696441000+0.33814
          库存:62934
          SM04B-SRSS-TB
            • 3000+0.44000
            库存:108000
