21033211520
21033211520
    HARTING(浩亭)
    CONN PLUG MALE 5POS GOLD SOLDER
21033211520 数据手册
M12 PCB adapter A-coded Mating face A-coding Mating face acc. to IEC 61 076-2-101 03 Technical characteristics: M12 PCB adapter Degree of protection IP20, IP67 (mated and locked) Temperature during connection Rated current max. 4 A (dependant on PCB layout) Termination PIH Contact material Copper alloy max. 100 Contact plating (mating side) Au over Ni -40 °C … +85 °C Insulator material PA Rated voltage 50 V Mating cycles Limiting temperature Identification Part No. M12 PCB adapter Male, A-coding, straight 4 poles, IP20 21 03 321 1410 4 poles, IP67 21 03 321 1420 5 poles, IP20 21 03 321 1510 5 poles, IP67 21 03 321 1520 M12 PCB adapter Male, A-coding, straight 03 32 -5 °C … +50 °C Further information and data sheets see www.HARTING.com Drawing Dimensions in mm
21033211520 价格&库存
很抱歉,暂时无法提供与“21033211520”相匹配的价格&库存,您可以联系我们找货
    • 1+228.10680
    • 200+91.02240
    • 500+87.97680
    • 1000+86.47560
