FGG.0B.304.CYCD42Z
FGG.0B.304.CYCD42Z
    LEMO(雷莫)
    CONN PLUG MALE 4POS GOLD CRIMP
FGG.0B.304.CYCD42Z 数据手册
FGG.0B.304.CYCD42Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 0B Termination type Male crimp IP rating 50 AWG wire size 26.00 - 22.00 Catalog Cable Ø 3.30 - 4.20 mm See video assembly instructions Status active Matching parts EGG.0B.304.CYM Download Request a quote Eplan PHG.0B.304.CYMD42Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 9.89 g Performance Configuration 0B.304 : 4 Low Voltage Insulator Y: PEEK for crimp contacts Rated Current 7 Amps Specifications Contact Type: Crimp Contact Retention: 22 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Min. Conductor: 0.14 mm^2 (AWG 26) Max. Conductor: 0.34 mm^2 (AWG 22) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 R (max): 6.1 mOhm Vtest (contact-contact): 1350 V (AC), 1910 V (DC) Vtest (contact-shell): 1100 V (AC), 1560 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 9.5 35 25 8 7 in. 0,37 1,38 0,98 0,31 0,28 RECOMMENDED BY LEMO LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Tools Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 22-24-26/6-5-5 Positionner: DCE.91.070.BVC Extractor: DCF.92.070.3LT Replacement contact: FGG.0B.555.ZZC Spanner wrench: DCD.0B.005.PA070 Caps: BFG.0B.100.PCSG Cables 40080 PVC Black 40086 PVC Blue 40140 PVC Black 40240 PTFE White 4260 PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0B.304.CYCD42Z 价格&库存
很抱歉,暂时无法提供与“FGG.0B.304.CYCD42Z”相匹配的价格&库存,您可以联系我们找货
