SMS SERIES
Quick Mating
Overview
SMS Series |
Overview
Similar product range
Typical applications............................................ 06
Features & Benefits............................................ 07
UTS Series.......................................................... 34
UTO Series......................................................... 34
VGE1 / FER1 Series............................................ 35
838 Series........................................................... 35
MSG 3U Series................................................... 36
MSM & MSO Series............................................ 36
MB Series........................................................... 37
Connector
Quick mating...................................................... 10
Quick mating board mount................................ 17
Quick mating pin header.................................... 23
Discrimination keys............................................. 27
Connector
Contents
Contacts
Contacts
Contact selector guide ...................................... 30
Packaging .......................................................... 30
Crimp contacts .................................................. 31
Tooling ............................................................... 31
3
SMS SERIES
© 2018 SOURIAU - SOURIAU is a registered trademark
SMS Series
Overview
Typical applications ................................................................................................. 06
Features & Benefits ................................................................................................. 07
5
© ALSTOM Transport / P. de Salabert
© ALSTOM Transport / ABACA – S. Lee
Robotics
Railway Signaling
6
Machinery
Railway - Closed from electrical operating areas
© ALSTOM Transport / M.Spera/ TOMA – C. Sasso
© Romaset / Shutterstock
© Rainer Plendl / Fotolia
SMS Series | Overview
Railway - Interior & Cabin
Features & Benefits
Quick Mating / Unmating Mechanism
EASY
TO USE
Push to mate - Press and release to unmate.
A simple operation with only two fingers.
High Flammability Rating
Overview
The SMS series offers a flame retardant version (UL94 V0 & HL3/R22
QUALIFIED following the EN 45545-2) to guarantee secure and safe equipment.
Reliable Solution
Pin protection skirts , positive polarization keys and retention locks
SAFE USE will ensure correct mating between the plug and the receptacle.
High Density Solution
SPACE
SAVING
With a pitch of 5.08mm and a low profile version availability,
SMS series is ideal for tight space integration and high density
applications (3 to 36 positions).
Two In One
COST
SAVING
Integrated strain relief hood versions are available to offer
a highly cost-effective solution.
7
SMS SERIES
SMS Series
Connector
SMS Quick Mating.......................................................................................................... 10
SMS Board mount Quick Mating.................................................................................... 17
SMS Quick Mating Pin Header....................................................................................... 23
Discrimination keys......................................................................................................... 27
9
SMS Series | Quick Mating
Quick Mating panel
and cable connectors
Description
The versatile and easy to use “SMS” Quick
Mating panel and cable connectors are a highly
cost-effective system approach to solving the
constant demand for more interconnection
solutions and techniques.
A full plastic solution offered in either Wire
attachment or PCB mounting options to
provide rapid assembly/installation without
requiring additional mounting hardware. Panel
receptacle connectors simply snap and lock into
panel cut-outs and cable plugs quickly connect
and disconnect with positive retention locks.
Just push to mate then press and release to
un-mate.
In addition, cable plug connectors also feature
pin-protection skirts, positive polarization and
are offered with or without integrated strain
relief hoods. Cable receptacle connectors (with
integrated strain relief hoods) are available to
mate with the cable plug connectors for cableto-cable solutions when needed.
These multi-way connectors accept the Size 16
TRIM TRIO (1.6mm) diameter contacts and are
available with 10 contact arrangements from 2
to 36 positions.
Features and benefits
• Available in 10 contact arrangements
• Self mountable panel receptacle with
positive housing retention
• Cable plugs with retaining latches for
positive locking
• Cable plug has pin protection skirt to
prevent damage of male contacts
• Positive polarization keys prevent mismating
• Cable plug and receptacle have integrated
strain relief hood which can accept a wide
range of cables
discrimination cavities in between contact
cavities, thus offering discrimination without
contact loss. See instruction page 27.
• UL recognized File Nr.: E238675
• CSA certififed File Nr.: LR44961-21
Environmental
• Operating temperature: -55°C to +105°C
• Insulation resistance: 5000 MΩ min.
• Test potential: 2000 VAC
• Durability: 500 matings and unmatings
• Sealing performances: IP40
• Electrical performances:
UL: 250V - 10A
CSA: 250V - 15A
Wire insulation acceptance
• SMS PDH1, RDH1, PD3, PDH3, RD3, RDH3
max: 3.2mm
• SMS R1, P1, R3 max: 4.19mm
Material
• Connector: Polyamide 6.6
• Flammability rating:
- Black versions : UL94 V2
- White versions : UL 94 V0 and
HL3/R22 - HL3/R23 following EN 45 545-2
Contact
• “SMS” Quick Mating connectors accept
TRIM TRIO size 16 removable snap-lock
contacts (see contact section)
• Contacts to be ordered seperately.
Ordering information
Connector family
Layout: see page 12
Body variation:
R1: (UL94 V2) Panel mount receptacle - Black
R3: (UL94 V0 & HL3/R22 - HL3/R23) Panel mount receptacle - White
P1: (UL94 V2) Cable plug without strain relief hood - Black
PD3: (UL94 V0 & HL3/R22 - HL3/R23) Cable plug without strain relief hood - White
PDH1: (UL94 V2) Cable plug with integrated strain relief hood - Black
PDH3: (UL94 V0 & HL3/R22 - HL3/R23) Cable plug with integrated strain relief hood - White
RD3: (UL94 V0 & HL3/R22 - HL3/R23) Cable receptacle without integrated strain relief hood - White
RDH1: (UL94 V2) Cable receptacle with integrated strain relief hood - Black
RDH3: (UL94 V0 & HL3/R22 - HL3/R23) Cable receptacle with integrated strain relief hood - White
10
SMS
12
PDH3
Range overview - Quick mating & board mount connectors
SMS...R1/ SMS...R3
SMS...PDH1/SMS...PDH3
Cable plug with strain relief hood
SMS...RDH1/SMS...RDH3
Cable receptacle with strain relief hood
SMS...RD3
Cable receptacle without strain relief hood
Connector
SMS...P1/SMS...PD3
SMS...GE3-SE3/SMS...GE30-RE30
SMS...GE33/SMS...GE4-SE4/
SMS...GE40-RE40/SMS...GE43
Straight board mount
SMS...GE5-SE5/ SMS...GE53
SMS...GE6-SE6/SMS...GE63
Right angle board mount
11
Contacts layout
SMS 2
SMS 3
SMS 6
SMS 4
SMS 9
SMS 15
SMS 24
SMS 12
SMS 18
SMS 36
Contact identifications shown are for mating face. Contact identifications of wiring face are identical as shown on the receptacle arrangements
12
Connectors
Panel mount receptacle without discrimination cavities
A
J
0.75
2.3
K
B
25.0
(wire acceptance: 4.19mm)
13.2
Part number
Nbr. of contact*
A
SMS2R3
2
11.0
SMS3R1
SMS3R3
3
16.2
SMS4R1
SMS4R3
4
21.1
Black UL94 V2
White UL94 V0
SMS2R1
B
C max.
5.8
15.2
SMS6R3
6
10.9
20.3
SMS9R3
9
16.0
25.4
21.1
26.2
30.5
31.2
40.6
21.1
30.5
16.2
12
SMS15R1
SMS15R3
15
SMS18R1
SMS18R3
18
SMS24R1
SMS24R3
24
21.2
SMS36R1
SMS36R3
36
46.6
16.5
11.6
21.7
SMS6R1
SMS12R3
K
11.4
SMS9R1
SMS12R1
J
16.7
16.5
21.6
26.7
35.6
16.7
31.8
36.9
21.7
47.1
26.7
*Contacts supplied separately
A
B max.
32.9
Connector
Cable plug without strain relief hood & without discrimination cavities
25.0
Part number
Nbr. of contact*
A
SMS2P1
2
15.0
SMS3P1
3
18.6
SMS4P1
4
23.7
SMS6P1
6
SMS9P1
9
SMS12P1
12
SMS15P1
15
SMS18P1
18
SMS24P1
24
23.7
SMS36P1
36
49.1
Black UL94 V2
C max.
17.8
22.9
18.6
27.9
33.0
38.1
43.2
33.0
Note: all dimensions are in mm
13
Cable receptacle without strain relief hood & with discrimination cavities
Contact cavity
E
Discrimation
cavity
C
B max.
25.0
D
Part number
Nbr. of contact*
Nbr. of discrimination cavities
SMS2RD3
2
SMS3RD3
3
SMS4RD3
4
SMS6RD3
6
2
SMS9RD3
9
4
20.0
18.5
12
6
25.1
23.6
30.2
28.7
35.3
33.8
25.1
23.6
White UL94 V0
SMS12RD3
B max
C
9.9
8.4
15.0
SMS15RD3
15
8
SMS18RD3
10
SMS24RD3
18
24
15
SMS36RD3
36
24
D
E
11.1
14.1
16.2
18.6
21.2
23.7
16.2
18.6
13.4
21.2
23.7
46.6
49.1
Cable plug without strain relief hood & with discrimination cavities
Contact cavity
Discrimation
cavity
C
B max.
32.7
D
Part number
White UL94 V0
SMS2PD3
Nbr. of contact*
2
SMS3PD3
3
SMS4PD3
4
B max.
C
14.1
16.4
8.4
SMS6PD3
6
2
21.5
13.4
9
4
26.7
18.5
SMS12PD3
12
6
31.7
23.6
36.7
28.7
41.8
33.8
31.7
23.6
SMS15PD3
15
8
10
SMS24PD3
18
24
15
SMS36PD3
36
24
18.6
23.7
SMS9PD3
SMS18PD3
D
18.6
23.7
49.1
14
Connectors (Continued)
Contact cavity
Cable
range
Discrimation
cavity
B
H
A
C
D
Part number
Nbr. of Nbr. of discrimicontact* nation cavities
A
B
C
D
11.1
0.5
69.0
16.2
74.4
21.2
H
Cable
range (mm)
Black UL94 V2
White UL94 V0
SMS2RDH1
SMS2RDH3
2
SMS3RDH1
SMS3RDH3
3
SMS4RDH1
SMS4RDH3
4
SMS6RDH1
SMS6RDH3
6
2
34.6
15.0
72.6
50.9
1.7-9.2
SMS9RDH1
SMS9RDH3
9
4
35.8
20.0
75.3
52.2
3.9-14.2
SMS12RDH1
SMS12RDH3
12
6
38.1
25.1
72.0
52.7
4.0-15.0
SMS15RDH1
SMS15RDH3
15
8
35.9
30.2
SMS18RDH1
SMS18RDH3
18
10
36.1
SMS24RDH1
SMS24RDH3
24
15
39.7
SMS36RDH1
SMS36RDH3
36
24
54.6
9.9
81.3
35.3
25.1
16.2
Cable
tie (1)
0.5-8.4
49.2
0.8-7.3
1.5-10
55.2
5.0-16.2
5.8-20.3
90.4
21.2
57.2
7.1-20.4
128.0
46.6
63.3
8.8-24.5
TF4D
TF5D
(1) Cable tie not included
Contact cavity
Cable
range
Discrimation
cavity
H
B
A
Connector
D
C
Part number
A
B
C
D
64.8
14.1
69.0
18.6
74.4
23.7
H
Cable
range (mm)
Black UL94 V2
White UL94 V0 (2)
SMS2PDH1
SMS2PDH3
2
SMS3PDH1
SMS3PDH3
3
SMS4PDH1
SMS4PDH3
4
SMS6PDH1
SMS6PDH3
6
2
42.5
21.5
72.6
58.8
1.7-9.2
SMS9PDH1
SMS9PDH3
9
4
43.7
26.7
75.3
60.1
3.9-14.2
SMS12PDH1
SMS12PDH3
12
6
46.0
31.7
72.0
60.6
4.0-15.0
SMS15PRDH1
SMS15PDH3
15
8
43.8
36.7
SMS18PDH1
SMS18PDH3
18
10
44.0
SMS24PDH1
SMS24PDH3
24
15
47.6
SMS36PDH1
SMS36PDH3
36
24
62.5
16.4
41.8
31.7
18.6
81.3
Cable
tie (1)
0.5-8.4
57.1
0.8-7.3
1.5-10
63.1
5.0-16.2
5.8-20.3
90.4
23.7
65.1
7.1-20.4
128.0
49.1
71.2
8.8-24.5
TF4D
TF5D
(2) White UL94 V0 & HL3/R22 - HL3/R23
15
Accessories for standard Quick Mating connectors
Pin protection shroud for panel mount receptacle
23.5
B
A
When pins are inserted into the panel mount
receptacle half (SMS...R1) of the Quick Mating
connector, an optional pin protection shroud
can be installed.
The shroud is mounted at the same time as
the receptacle by holding the shroud against
the mating side of the panel with both cutouts lined up. The receptacle is then inserted
in place, trapping the shroud between the
receptacle and panel. The use of the pin
protection shroud reduces the allowable
thickness of the panel from 2.3 to 1.6 mm max.
Part number
Nbr. of contact
position
A
SMS2CSB1
2
19.8
SMS3CSB1
3
23.4
SMS4CSB1
4
28.4
SMS6CSB1
6
SMS9CSB1
9
SMS12CSB1
12
SMS15CSB1
15
SMS18CSB1
18
SMS24CSB1
24
28.4
SMS36CSB1
36
54.1
Black UL94 V2
B
18.8
23.9
29.0
34.0
23.4
39.1
44.2
34.0
Strain relief hoods
Part number
For SMS2H1, SMS3H1, SMS4H1
& SMS6H1
2 pieces are needed for a
complete hool for SMS9H1
to SMS36H1
Separate strain relief hoods are available for all standard plugs SMS...P1.
The hoods consist of identical halves that snap into position on the plug
and are secured in place with the cable tie drawn tightly around the cable
entry collar.
The cable tie is not included (TF4D – TF5D).
Two, three and four position hoods are single piece units.
Black UL94 V2
Nbr. of contact
position
SMS2H1
2
SMS3H1
3
SMS4H1
4
SMS6H1
6
SMS9H1
9
SMS12H1
12
SMS15H1
15
SMS18H1
18
SMS24H1
24
SMS36H1
36
Discrimination pins
For discrimination pins on both standard Quick Mating and Quick Mating Pin Headers cable and board mount:
See page 27.
16
SMS Series | Board mount Quick Mating (Pitch: 5.08mm)
Quick Mating PC
board mount
connectors
Description
• Current rating for SMS PCB version:
- 5 Amp for stamped and formed contacts
- 7.5 Amp for machined contacts
• Electrical performances for crimped versions:
UL: 250V - 15A
CSA: 250V - 15A
• Straight versions available in 10 contact
arrangements from 2 to 36 positions
• Right angled versions available in 3, 6, 12
and 18 positions.
• All versions are available with:
- Pin or socket contacts
- Stamped and formed or solid machined
contacts.
• Board mount connectors have discrimination
cavities in between contact cavities, unless
other wise noted.See instruction page 27.
Environmental
Material
• Connector body:
Glass filled thermoplast UL94 V0
• Railway version :
HL2/R22 - HL2/R23 following EN 45 545-2
• Contacts:
High conductive copper alloy
• Soldering information:
compatible with wave soldering up to 245°C.
Not compatible with reflow soldering.
Plating table
• Plating for solid machined contacts:
- Made for 2.4mm or 3.2mm PCB thickness
(straight contacts) and for 3.2mm PCB
thickness (right contacts)
K9 (std) = Min. 0.4µ Gold in contact area,
Tin on solder tail, over Nickel
J9 = Gold flash in contact area,
T = 3 - 5µ Tin all over
• Plating for Stamped and formed contacts:
- Made for 2.4mm PCB thickness (straight
contacts) and for 3.2mm PCB thickness
(right contacts)
K9 = Min. 0.4µ Gold in contact area,
3- 5µ Tin on solder tail, over Nickel
- Made for 3.2mm PCB thickness (straight contacts)
S6 = Min. 0.75µ Gold in contact area
Gold flash on solder tail, over Nickel
D70 = G
old flash all over
TR29 = 3 - 5µ Tin all over
Intermateability
• “SMS” Quick Mating board mount
connectors with preassembled TRIM TRIO
size 16 board mount contacts are
intermateable only with the “SMS” Quick
Mating cable plug connectors equipped
with TRIM TRIO crimp type removable
snap-lock contacts (see contact section).
Connector
These PC board mount connectors enable
Quick Mating and preassembled TRIM TRIO
contacts to be PC board mounted, using
conventional solder production techniques.
They will then mate and latch with the standard
Quick Mating plugs.
Straight board mount connectors is available
in 10 insert arrangements from 2 to 36 positions.
Right angled board mount Quick Mating is
available in 3, 6, 12 and 18 positions.
All board mount connectors are supplied fully
loaded with pin or socket contacts, either
in solid machined or stamped and formed
contacts.
Stamped and formed contact have selective tin
plating on the solder tails, thus eliminating flux
operations.
Connector family
Layout: see page 12
SMS
12
GE
3
K9
Body variation:
GE: Solid machined contacts (2.4mm or 3.2mm, see option below)
SE: Stamped and formed contacts for 2.4mm PCB
RE: Stamped and formed contacts for 3.2mm PCB
Design variation:
3: Straight board mount with female contact
4: Straight board mount with male contacts
5: Right angle board mount with female contacts
6: Right angle board mount with male contacts
Option:
-: 2.4mm for GE3, GE4 and SE variation
0: 3.2mm for GE variation
3: Railway version: HL2/R22 - HL2/R23 following EN 45 545-2
Plating indication
17
Connectors
Straight board mount with female contacts
PCB tail length
E
Ø0.8
7.0
A
5.9
5.08
5.08
Ø3.5
2.4
B
D
Dimensions
Nbr. of contact
cavities
A
B
C
2
19.1
3
4
6
9
4
24.2
12
8
18
10
24
36
14.0
16.2
29.2
D
E
10.2
5.9
15.2
10.9
10.2
16.0
13.4
21.1
34.3
39.4
15.2
26.1
31.2
15.2
54.6
20.9
Contacts type
Part number
Standard version
Stamped & formed contacts
PCB thickness 2.4mm
PCB tail length 3.4mm
PCB thickness 3.2mm
PCB tail length 4.2mm
PCB thickness 2.4mm
PCB thickness 3.2mm
PCB tail length 4.4mm
PCB thickness 2.4mm
SMS2GE3*
SMS2GE30*
SMS2SE3*
SMS2RE3*
SMS3GE3*
SMS3GE30*
SMS3SE3*
SMS3RE3*
SMS3GE33*
SMS4GE3*
SMS4GE30*
SMS4SE3*
SMS4RE3*
SMS6GE3*
SMS6GE30*
SMS6SE3*
SMS6RE3*
SMS6GE33*
SMS9GE3*
SMS9GE30*
SMS9SE3*
SMS9RE3*
SMS9GE33*
SMS12GE3*
SMS12GE30*
SMS12SE3*
SMS12RE3*
SMS12GE33*
SMS15GE3*
SMS15GE30*
SMS15SE3*
SMS15RE3*
SMS15GE33*
SMS18GE3*
SMS18GE30*
SMS18SE3*
SMS18RE3*
SMS18GE33*
SMS24GE3*
SMS24GE30*
SMS24SE3*
SMS24RE3*
SMS24GE33*
SMS36GE3*
SMS36GE30*
SMS36SE3*
SMS36RE3*
SMS36GE33*
* for coding see page 30
Example: SMS12GE3J9 - SMS with 12 solid machined contacts, plating J9
18
NFF certified version
PCB tail length
E
Ø0.8
7.0
5.9
A
5.08
C
2.4
5.08
Ø3.5
7.0
D
B
Dimensions
Nbr. of contact
cavities
A
B
C
2
19.1
3
4
6
9
4
24.2
12
8
18
10
24
36
14.0
16.2
29.2
D
E
10.2
5.9
15.2
10.9
10.2
16.0
13.4
21.1
34.3
39.4
15.2
26.1
31.2
15.2
54.6
20.9
Connector
Contacts type
Part number
Standard version
PCB thickness 2.4mm
PCB thickness 3.2mm
PCB thickness 2.4mm
PCB thickness 3.2mm
PCB thickness 2.4mm
SMS2GE4*
SMS2GE40*
SMS2SE4*
SMS2RE4*
SMS3GE4*
SMS3GE40*
SMS3SE4*
SMS3RE4*
SMS3GE43*
SMS4GE4*
SMS4GE40*
SMS4SE4*
SMS4RE4*
SMS6GE4*
SMS6GE40*
SMS6SE4*
SMS6RE4*
SMS6GE43*
SMS9GE4*
SMS9GE40*
SMS9SE4*
SMS9RE4*
SMS9GE43*
SMS12GE4*
SMS12GE40*
SMS12SE4*
SMS12RE4*
SMS12GE43*
SMS15GE4*
SMS15GE40*
SMS15SE4*
SMS15RE4*
SMS15GE43*
SMS18GE4*
SMS18GE40*
SMS18SE4*
SMS18RE4*
SMS18GE43*
SMS24GE4*
SMS24GE40*
SMS24SE4*
SMS24RE4*
SMS24GE43*
SMS36GE4*
SMS36GE40*
SMS36SE4*
SMS36RE4*
SMS36GE43*
Example: SMS12GE4J9 - SMS with 12 solid machined contacts, plating J9
19
F
5.08
16.5
4.5
Ø0.8
A
G
2.5
B
E
3x5.08
Ø3.4
D
Dimensions
Nbr. of contact
cavities
A
3
19.0
6
6
18
10
B
C
20.5
14.4
21.6
24.5
29.5
D
E
F
30.2
24.2
16.2
35.2
29.2
21.2
45.4
39.4
31.2
Contacts type
Part number
Standard version
PCB thickness 3.2mm
PCB tail length 4.5mm
PCB thickness 3.2mm
PCB thickness 3.2mm
SMS3GE5*
SMS3SE5*
SMS3GE53*
SMS6GE5*
SMS6SE5*
SMS6GE53*
SMS12GE5*
SMS12SE5*
SMS12GE53*
SMS18GE5*
SMS18SE5*
SMS18GE53*
Example: SMS12GE5J9 - SMS with 12 solid machined contacts, plating J9
G
6.8
11.9
17.2
F
5.08
4.5
Ø0.8
A
G
2.5
B
E
16.5
3x5.08
Dimensions
D
Ø3.4
Nbr. of contact
cavities
A
3
19.0
6
6
18
10
B
C
20.5
14.4
21.6
24.5
29.5
D
E
F
30.2
24.2
16.2
35.2
29.2
21.2
45.4
39.4
31.2
G
6.8
11.9
17.2
Contacts type
Part number
PCB thickness 3.2mm
PCB thickness 3.2mm
PCB thickness 3.2mm
SMS3GE6*
SMS3SE6*
SMS3GE63*
SMS6GE6*
SMS6SE6*
SMS6GE63*
SMS12GE6*
SMS12SE6*
SMS12GE63*
SMS18GE6*
SMS18SE6*
SMS18GE63*
Connector
Standard version
Example: SMS12GE6J9 - SMS with 12 solid machined contacts, plating J9
21
Drilling Pattern
Dimensions
Straight angle board mount
4 contacts
10.2
9 contacts
19.0
14.0
19.0
6 contacts
24.1
3 contacts
14.0
2 contacts
15.2
10.2
10.2
12 contacts
15 contacts
18 contacts
24 contacts
36 contacts
Ø3.5
5.08
54.7
39.4
39.4
34.3
29.2
Ø1.2
10.2
10.2
10.2
15.3
5.08
15.3
3 contacts
6 contacts
12 contacts
18 contacts
34.9
5.08
29.2
24.1
24.1
Ø3.5
Ø0.12
5.08
22
Secure connector with screws (not supplied), recommended torque 0.3 N.m
SMS Series | Quick Mating Pin Header
Quick Mating PC
board mount
Pin Headers and plugs
Description
• Available in 3, 4, 6, 9 and 10 positions.
• In-line contact design, offering significant PC
board space savings.
• Board mount connectors available in straight
and right angled version preassembled with:
- Solid machined or stamped and formed
pin contacts.
- Coax pin contacts.
• CSA metter certififed File Nr.: LR44961-21
Environmental
J = Gold flash over 2µ Ni
D28 = Min. 0.75µ Au over nickel.
D70 = A
ctive part: Gold flash over Ni
Crimp area: Ni
• Plating for coax contacts:
Z17 =
Min. 0.75µ Au in contact area,
Flash on solder tail (inner)
Min 0.75µ Au in contact area,
Tin on solder tail (outer)
• Operating temperature: -55°C to +125°C
• Current rating:
- 7.5 Amps for machined contacts
• Durability: 500 matings and unmatings.
Material
• Connector body:
Color: Black
• Contacts: High conductive copper alloy
Intermateability
• “SMS” Socket plugs accept TRIM TRIO size
16 removable snap-lock contacts (see
contact section)
Plating table
No digit (std) = Min. 0.4µ Gold all over,
over Nickel.
Connector family
Layout: see page 12
SMS
12
PH
3
TR29
Body variation:
PH: Pin header board mount
CH: Coax header board mount
P3: Socket cable plug for pin and coax header board mount
Design variation:
2: Straight coax header board mount with male contacts
3: Right angle pin header board mount with stamped male contacts
4: Straight pin header board mount with stamped male contacts
GE6: Right angle pin header board mount with machined male contacts
GE4: Straight pin header board mount with machined male contacts
Plating indication
23
Connector
Quick Mating Pin Header, available in 3, 4, 6,
9 and 10 positions, provides the additional
versatility of straight and right angle board
mounting.
Offered as an alternative to stacked connectors,
the in-line contact design of the pin header
provides the user with significant PC board
space savings.
The board mount receptacle features positive
polarization and a moulded on pin protection
skirt and is supplied preassembled with straight
or right angled:
• Solid machined or stamped and formed PC
board pin contacts.
• Coax PC board pin contacts.
The socket cable plug features positive quick
connect / disconnect latches and is designed to
accept N° 16 TRIM TRIO 1.6mm diameter socket
contacts for maximum contact protection.
Right angle pin header board mount with male contacts
Ø3.5
5.08
Ø3.5
Ø08
B
C
9.4
4.2
Part number
22.9
Nbr. of
contact
A
B
C
SMS3PH3*
SMS3PHGE6
3
31.2
25.4
19.3
SMS4PH3*
SMS4PHGE6
4
36.3
30.4
24.4
SMS6PH3*
SMS6PHGE6
6
46.5
40.6
34.5
SMS9PH3*
SMS9PHGE6
9
61.7
55.9
49.8
SMS10PH3*
SMS10PHGE6
10
66.8
61.0
54.9
Example: SMS9PH3J9 - SMS with 9 solid machined contacts, plating J9
Straight pin header board mount with male contacts
4.0
Ø3.5
B
9.4
Part number
22.9
Nbr. of
contact
A
B
C
SMS3PH4*
SMS3PHGE4
3
31.2
25.4
19.3
SMS4PH4*
SMS4PHGE4
4
36.3
30.4
24.4
SMS6PH4*
SMS6PHGE4
6
46.5
40.6
34.5
SMS9PH4*
SMS9PHGE4
9
61.7
55.9
49.8
SMS10PH4*
SMS10PHGE4
10
66.8
61.0
54.9
Example: SMS9PH4J9 - SMS with 9 solid machined contacts, plating J9
24
C
A
Ø0.8
5.08
Ø3.5
4.2
Ø3.5
9.4
Ø1.0
B
C
A
Ø0.8
5.08
Ø3.5
5.0
22.9
Part number
Nbr. of contact
A
B
C
SMS3CH2Z17
3
31.2
25.4
19.3
SMS4CH2Z17
4
36.3
30.4
24.4
SMS6CH2Z17
6
46.5
40.6
34.5
SMS9CH2Z17
9
61.7
55.9
49.8
SMS10CH2Z17
10
66.8
61.0
54.9
5.8
Connector
Socket cable plug for pin and coax board mount header
A
5.9
25.0
Part number
Number of contact*
A
SMS3P3
3
16.0
SMS4P3
4
21.1
SMS6P3
6
31.2
SMS9P3
9
46.5
SMS10P3
10
51.6
25
Drilling Pattern
Dimensions
Right angle Pin Header
Straight Pin Header
Ø1.2
Ø1.2
4.32
5.08
5.08
Ø3.5
7.62
7.62
F
F
2.34
5.08
Straight Coax Header
2.54
2.54
Right angle Coax Header
E
Ø1.4
Ø1.4
E
5.08
Ø3.5
7.62
Ø3.5
7.62
F
F
Number of contact
E
F
3
10.18
25.40
4
15.24
30.48
6
25.40
40.64
9
40.64
55.88
10
45.72
60.96
26
Ø3.5
SMS Series | Accessories
Discrimination keys for SMS connectors
In applications where similar connectors are used next to each other, mismatching can be a reason for disturbances, system failure or even danger to
operator.
To eliminate mismatching, all SMS can be equipped with discrimination solutions, which offer unlimited possibilities for a "fool-proof" interconnection
system.
When one of these discrimination keys is used, the SMS will only mate with a connector which has a vacant contact or discrimination cavity at the
corresponding position.
This system offers boundless opportunities for all applications.
The material used is polyamide 6.6.
Both connectors have removable contacts: SMSPKE0
For fixe female contacts and without discrimination cavities:
SMSPKE2V1
Male contact
Empty cavity
Female contact
Discrimination key
A dummy contact, which can be inserted into an empty contact cavity
in any of SMS connectors.
A pin, which can be inserted into a preassambled female contact in all
female boardmount connectors SMS.
Specially for connectors without discrimination cavities and
without removable pin contact: SMSPKB2
Both connectors have discrimination cavities: SMSPKE3
Discrimination
sleeve
Female contact
Empty cavity
A tube, which can be fitted over a preassembled male contact in all
industrial male boardmount connectors SMS.
Discrimination pins
Connector
Male contact
Empty discrimination
cavities
A pin, which can be inserted in the discrimination cavities of the SMS
Quick mating cable and boardmount connectors. The discrimination
cavities are in between of the contact cavities and offer the advantage
that no contact cavities are lost due to discrimination.
As extraction tool, the
RX2025GE1 without the
"extraction tool tip" can
be used.
RX2025GE1
27
SMS SERIES
SMS Series
Contacts
Contact selector guide .............................................................................................. 30
Packaging .................................................................................................................. 30
Crimp contacts .......................................................................................................... 31
Tooling ....................................................................................................................... 31
29
Contact Selector Guide
Contact supplied separately
Electrical characteristics: contact resistance
#16
Ø1.6mm
Machined
Stamped & Formed
Available platings (contact supplied separately)
< 3mΩ
< 6mΩ
J
Gold flash over Nickel 2μm mini
K
0.4 μm Gold over 2 μm Nickel mini
S31
S18
Active part: Gold flash over Nickel
Crimp area: 1.3μm Tin mini over Nickel
Other: 1.3μm Tin mini
Active part: 0.75μm Gold mini over Nickel
TK6
0.5μm - 2.5μm Sn pre-plated
D70
Superseded by S31
S6
Superseded by S18
Other platings on request (contact supplied separately)
T
Tin 3μm (-0/+2) over 1.3μm Nickel mini
D28
0.75μm mini Gold over 2μm Nickel mini
Packaging
Due to the wide variety of applications, contact packaging is offered for small series (bulk package) and high volume production (reeled contacts):
Size contacts #16 (Ø1.6mm)
• 25 pieces loose package
(Stamped & Formed
contacts)
30
• 50 pieces bulk package
(Machined contacts)
• 1,000 pieces
bulk package
(Machined contacts)
• 3,000 pieces reeled
(Stamped & Formed
contacts)
• 2,000 pieces reeled
(Machined contacts)
Size #16 only
Crimp Contacts
Standard Version
Wire size
Contact
size
#16
Ø1.6
mm
Part number
Available
plating
see page 30
AWG
mm²
Male
Female
Max
insulator Ø
Machined
30-28
0.05-0.08
RM28M1-
RC28M1-
1.1
K, J
Machined
26-24
0.13-0.2
RM24M9-
RC24M9-
1.6
K, J
SM24M1-(1)
SM24ML1-(2)
SC24M1-(1)
SC24ML1-(2)
0.89-1.58
S31, S18, TK6
RM20M13-
RC20M13-
1.8
RM20M12-
RC20M12-
2.2
SM20M1-(1)
SM20ML1-(2)
SC20M1-(1)
SC20ML1-(2)
1.17-2.08
S31, S18, TK6
Type
Stamped &
Formed
26-24
0.13-0.25
Machined
22-20
0.32-0.52
Stamped &
Formed
22-20
0.35-0.5
Machined
18-16
0.92-1.5
RM16M23-
RC16M23-
3.2
K, J
SC16M1-(1)
SC16ML1-(2)
No insulation
grip
S31, S18, TK6
K, J
Stamped &
Formed
18-16
0.8-1.5
SM16M1-(1)
SM16ML1-(2)
Stamped &
Formed
18-16
0.8-1.5
SM16M11-(1)
SM16ML11-(2)
SC16M11-(1)
SC16ML11-(2)
2.08-3
S31, S18, TK6
Machined
16-14
1.5-2.5
RM14M30-
RC14M30-
3.2
K, J
2.0-2.5
SM14M1SM14ML1-(2)
SC14M1SC14ML1-(2)
No insulation
grip
S31, S18, TK6
Stamped &
Formed
14
(1)
(1)
(1) contact reeled (2) loose contact
Exemple: RM20M13K - Size #16, Machined, AWG20 wire.
Tooling
Crimp Tool Table
Contact size
Part number
#16
Ø1.6 mm
RM/RC 28M1*
RM/RC 24M9*
RM/RC 20M13*
RM/RC 20M12*
RM/RC 16M23*
RM/RC 14M30*
SM/SC 24ML1*(1)
SM/SC 20ML1*(1)
SM/SC 16ML1*(1)
SM/SC 14ML1*(1)
SM/SC 16ML11*(1)
(1) loose contact
Head*
Handles*
Contacts
Standard contacts
Extraction tools
S16RCM20
S16RCM16
S16RCM14
S16SCM20
RX2025GE1
SHANDLES
Long endurance tool
RX2031J
S16SCML1
S16SCML11
* endurance of SHANDLES & Head tools = 50,000 cycles
31
SMS SERIES
SMS Series
UTS Series...................................................................................................................... 34
UTO Series..................................................................................................................... 34
VGE1 & FER1 Series....................................................................................................... 35
838 Series....................................................................................................................... 35
MSG 3U Series............................................................................................................... 36
MSM & MSO Series........................................................................................................ 36
MB Series....................................................................................................................... 37
33
SMS Series |
UTS Series
Plastic waterproof solution with bayonet
coupling system.
Fire smoke:
. HL2/R22 - HL2/R23 according to EN 45545-2.
. UL94 V-0.
Indoor and outdoor use:
. Waterproof: IP68/69K Dynamic Mated & Unmated.
. UV resistant: F1 rated per UL 746C. No mechanical
detrioration after 5 years of exposure in natural environment.
High speed data transmision:
. Signal (Trim Trio contacts).
. LC and MPO contacts.
See «UTS Series» catalog on
www.souriau.com
UTO Series
Metal waterproof solution with bayonet
coupling system.
Fire smoke:
. UL94 V-0.
. High vibration Cat. 2 (Cat 3 for size E) according EN 61373.
. EMI shielded: 65 dB at 100 Mhz.
. 500 mating cycles.
Cost saving:
. Trim trio contacts : Machined or stamp contacts for a secure
solution with optimized costs.
. Mixed Power & Signal contacts layouts.
See «UTO Series» catalog on
www.souriau.com
34
SMS Series |
VGE1 & FER1 Series
A reverse bayonet coupling system adpated
for high vibration applications.
Fire smoke:
. HL3/R22 - HL3/R23 according to EN 45545-2.
. NFPA 130 compliant.
. JRMA Class 3.
Ruggedized solution:
. High vibration Cat 2 according EN 61373.
. 500h salt spray.
. IP67.
. -40°C to 100°C.
. Compact solution with the size 14 (32 mm diameter up
to 10 contacts).
High speed data transmission:
. Signal up to 60 contacts (Trim Trio contacts).
. Quadrax.
. Fiber optic.
See «VGE1 & FER1 Series» catalog on
www.souriau.com
838 Series
Intercoach solution with screw coupling system.
Fire smoke:
. HL2/R22 - HL3/R23 according to EN 45545-2.
. IP 67.
. -40°C to 100°C.
. Current up to 180 A.
. Signal up to 61 contacts.
. Quadrax.
. Fiber optic.
See «838 Series»
www.souriau.com
35
SMS Series |
MSG 3U Series
Easy & Secure Connectors for rack systems.
Front I/O solutions.
Fire smoke:
Easy and secure solution:
. Quick lever with safe locking system.
. 360° metal housing for an improved shielding.
. High density solution with 4 layouts: 29 pos / 41 pos /
51 pos / 5 quadrax.
Cost saving solution:
. Trim trio contacts : machined or stamp contacts for a secure
. Full plastic solution.
. Integrated strain relief.
See «MSG 3U Series» catalog on
www.souriau.com
MSM & MSO Series
High Performance Boardmount Connector.
High Performances:
. From 9 to 75 positions.
. -55°C to +125°C.
. Up to 500 mating cycles.
. UL 94V0.
. Trim Trio contacts.
See «MSM & MSO Series»
www.souriau.com
36
SMS Series |
MB Series
High Density Rectangular connector.
. High density solution up to 52 contacts.
. -55°C to +125°C.
See «MB Series»
www.souriau.com
37
SMS Series |
Notes
38
Our contribution to environmental
protection:
This catalog is printed on PEFC
certified paper
Advancement of sustainable
wood cultivation. www.pefc.org
technical.emear@souriau.com (Europe - Asia - Africa)
technical.americas@souriau.com (North America)
www.souriau.com
All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing.
Your local contact
CASMSWUSEN01 © Copyright SOURIAU 2018 - SOURIAU is a registered trademark
Reliable People, Reliable Solutions
