8P1P01017NGL421
8P1P01017NGL421
    NORCOMP
    8P1P01017NGL421
8P1P01017NGL421 数据手册
DESCRIPTION: QUIK-LOQ - MALE - CABLE MOUNT - PLASTIC UNITS = MM [INCHES] CHARACTERISTICS MATERIALS HOUSING : ABS+PC HOUSING COLOR : GREY COLLET NUT : ABS+PC CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) 8P1P YYY 1 7 N YL YY 1 1 = GOLD FLASH SERIES 14.00 [0.551] COLLET SIZE **SEE CHART B** RoHS COMPLIANT # OF POSITIONS (Ex. 002) **SEE CHART A** 1 = MALE PLASTIC SHELL CABLE MOUNT MECHANICAL DURABILITY: 2000 CYCLES OPERATING TEMP. RANGE: -20 C ~ +120 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TORQUE VALUE: 0.5 Nm [4.4 IN/LBS] COLLET NUT COLOR G = GREY A = BLUE J = YELLOW N = BLACK R = RED V = GREEN IP RATING: 50 1.752 44.50 CHART B 0.551 14.00 COLLET SIZE 1.157 29.40 = KEY LOCATION 1 1 1 CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V 3 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V 4 POSITION 22 AWG MAX. 8 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V RoHS COMPLIANT N C 42 2.20 [0.087] ~ 4.00 [0.157] 52 4.00 [0.157] ~ 5.00 [0.197] 62 5.00 [0.197] ~ 6.00 [0.236] 14 POSITION 26 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 600V WORKING VOLTAGE = 200V CHART A 2 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 1.30 [0.051] 1 WIRE DIAMETER THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. **VIEW FROM TERMINATION END** 1 1 1 1 1 1 5 POSITION 22 AWG MAX. 7 AMP MAX. PIN = 0.90 [0.035] 6 POSITION 24 AWG MAX. 6 AMP MAX. PIN = 0.70 [0.028] 7 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 8 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 9 POSITION 26 AWG MAX. 3 AMP MAX. PIN = 0.50 [0.020] 10 POSITION 26 AWG MAX. 3 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V NorComp DRAWN: M. SIGMON DATE: 08-01-16 SCALE: N.T.S. SHEET 1 DWG NO. OF 1 REV: 8P1PYYY17NYLYY1 2
8P1P01017NGL421 价格&库存
很抱歉,暂时无法提供与“8P1P01017NGL421”相匹配的价格&库存,您可以联系我们找货
