85106EC2255S50
85106EC2255S50
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN PLUG FMALE 55P GOLD SLD CUP
85106EC2255S50 数据手册
851 SERIES Metal Connectors - Rugged - Industry Proven 851 Series | Introduction Introduction • • • • • • Sealing options Black Zinc Nickel, Nickel plated and Black anodized Solder and PC tail versions Thermocouple crimp contacts available The 851 versions with solder contacts and Zinc Nickel plating (RoHS compliant) is on US QPL 851 connectors are also widely available from distributors. SOURIAU 851 circular connectors were originally developed to ensure reliable electrical connections in aircraft. Due to the lightweight compact size and general characteristics, the 851-series has been utilized in numerous civil and military aviation applications and also in a multitude of light and heavy industrial applications (Robotics, Geophysics, Off-Road, Instrumentation, Factory Automation, etc.). 851 connectors conform to the following international standards: MIL-DTL-26482H series 1, NFC 93422, HE 301B, VG 95328, GAM/T1 list. 851 connectors feature a positive bayonet coupling mechanism which ensures reliable mechanical and electrical connection between mating halves. The plug features a helical locking ring which couples with the three dowel pegs on the receptacle ensuring rapid locking. Orientation and location is achieved with a system of five raised keys on the plugs which couple with corresponding slots on the receptacles. Connectors with different angular positioning of the insulator relative to the shell can be provided to prevent undesired accidental mating of adjacent connectors with the same contact arrangements. The connector shells are manufactured from aluminum alloy with several finish options. The insulators are molded from elastomer and are bonded into the shells. Grommets are also made from elastomer and are supplied with appropriate accessories in the solder version. Copper alloy contacts have gold or tin over nickel plating. To facilitate cabling, we offer solder and PC tail contacts size 20 with a gold plated active part and tin plated terminations. Contents Overview Typical Applications .......................................... Features & Benefits .......................................... Range Overview ............................................... Ordering Information ....................................... Layouts ............................................................. General Technical Characteristics ..................... Connectors 06 07 08 10 11 12 Receptacles ...................................................... Plugs ................................................................. Harnesses ......................................................... Orientation ....................................................... Cross Reference List ......................................... 16 18 23 24 25 3 851 SERIES © 2014 SOURIAU - SOURIAU is a registered trademark 851 Series Overview Typical Applications ................................................................................................ 06 Features & Benefits ................................................................................................ 07 Range Overview ..................................................................................................... 08 Ordering Information .............................................................................................. 10 Layouts ................................................................................................................... 11 General Technical Characteristics ........................................................................... 12 5 851 Series | Overview Off-Road - Railway © SOURIAU Traffic Control Hardware Fracturing Monitoring 6 Land Aquisition Systems © Sergey Milovidov / Fotolia Robotics - Machine Tools © HappyAlex / Fotolia Pavers - GPS Systems © SOURIAU © SOURIAU © Rainer Plendl / Fotolia Typical Applications 851 Series | Overview Features & Benefits 500 Mating Cycles Overview ENDURANCE Equipped with a coupling ring made from high strength aluminum. The plug provides a minimum of 500 mating unmating cycles. The receptacle is equipped with rugged stainless steel bayonet pins. MIL-DTL-26482H Fully in accordance with the MIL spec requirements. QUALIFIED Salt Spray 500 Hours CORROSION RESISTANT Designed to withstand climate ingress and exposure to salt spray or corrosive atmospheres while still maintaining mechanical and electrical functionality. 1/3 Bayonet Coupling QUICK MATING With only 1/3 twist of the bayonet coupling system, connectors are mated with audible "click" and tactile feel to confirm proper mating. This mating features eliminates connection uncertainty and reduces time and labor during installation. Arrangements from 2 to 61 contacts FLEXIBILITY Power supply and signal transmission can be combined in a unique interconnect solution to reduce system complexity and minimize component/installation costs. 7 851 Series | Overview Range PLUG Plug with Backnut 06S Plug with Short Metallic Adaptor and Plastic Cable Gland Plug with Straight Cable Clamp 06L Plug with Long Metallic Adaptor and Plastic Cable Gland Plug with Adaptor Backnut 06NS Plug with Right Angle Cable Clamp Plug with Short Metallic Adaptor and Plastic Cable Gland with Spiral Protector 06NL Plug with Straight Sealing Gland Backshell Plug with Long Metallic Adaptor and Plastic Cable Gland with Spiral Protector Overmolded 8 Plug with Straight Sealing Gland and Cable Clamp Backshell 851 Series | Overview Overview Overview 06E 06EC 02E 06A Square Flange RECEPTACLE 08EC 07A Jam Nut 06J 06JC 9 851 Series | Overview Ordering information Basic Series 02E 851 8 3A - P 5716 Shell type: 02E: square flange receptacle not accepting backshells 07A: jam nut receptacle not accepting backshell 06E: plug with backnut 06EC: plug with straight cable clamp 06A: plug with adaptor backnut 08EC: plug with right angle cable clamp 06J: plug with straight sealing gland backshell 06JC: plug with straight sealing gland and cable clamp backshell 06S: plug with short metallic adaptor and plastic cable gland 06L: plug with long metallic adaptor and plastic cable gland 06NS: plug with short metallic adaptor and plastic cable gland with spiral protector 06NL: plug with long metallic adaptor and plastic cable gland with spiral protector Shell size: 8 - 10 - 12 - 14 - 16 Contact layouts: See page 11 Contact type: P: male S: female Orientation: Normal (not included in part number). For others note: w, x, y, z - see table page 24 Obligatory suffix: Suffix solder type contact* See table below Suffix PC tail contact with shoulder* See table below Suffix PC tail contact without shoulder* See table below Black Zinc Nickel 54 1 5416 1 54A7 3 Black Zinc Nickel 57 2 5716 2 - - Black Anodized 5029 1 50F9 1 50B3 3 Shell plating Black Anodized 5129 2 51F9 2 - - Nickel 5044 1 5045 1 50G9 3 Nickel 5144 2 5145 2 - - Description 1 #20 contact layouts except 8-2, 8-3, 8-4 and 12-4 #16 contact layouts, mix #20, #16 contact layouts and contacts for 8-2, 8-3, 8-4 and 12-4 Gold plated on active part and tin lead plated on termination area 2 #20 contact layouts except 8-2, 8-3, 8-4 and 12-4 Gold plated overall 3 All contact sizes and layouts Gold plated overall * All contacts are machined 10 Plating 851 Series | Overview Layouts Contact #16 (Ø 1.6 mm) Contact #20 (Ø 1.0 mm) 8-2 8-3 8-3A/8-98 2 contacts 3 contacts 3 contacts 2xØ1.0 (#20) 3xØ1.0 (#20) 3xØ1.0 (#20) Mixed Power Overview Shell size 8 8-33 8-4 3 contacts 4 contacts 3xØ1.0 (#20) 4xØ1.0 (#20) 10-6 10-98 10-7 6 contacts 6 contacts 7 contacts 6xØ1.0 (#20) 6xØ1.0 (#20) 7xØ1.0 (#20) 10 12 12-2 12-3 2 contacts 3 contacts 2xØ1.6 (#16) 3xØ1.6 (#16) 14-5 14-7 5xØ1.6 (#16) 16 12-8 12-10 12-14 8 contacts 10 contacts 14 contacts 8xØ1.0 (#20) 10xØ1.0 (#20) 14xØ1.0 (#20) 4xØ1.6 (#16) 5 contacts 14 12-4 3 contacts +ground 6 contacts +ground 14-18 14-19 14-12 14-15 18 contacts 19 contacts 12 contacts 15 contacts 18xØ1.0 (#20) 19xØ1.0 (#20) 8xØ1.0 (#20) 4xØ1.6 (#16) 14xØ1.0 (#20) 1xØ1.6 (#16) 7xØ1.6 (#16) 16-8 16-26 16-23 8 contacts 26 contacts 23 contacts 8xØ1.6 (#16) 26xØ1.0 (#20) 22xØ1.0 (#20) 1xØ1.6 (#16) 11 851 Series | Overview General Technical Characteristics Materials • Shell: Aluminum alloy • Backshells: Aluminum alloy • Cable glands: Thermoplastic • Coupling ring: Aluminum alloy • Coupling spring: Spring stainless steel • Insert: Elastomeric soft neoprene • RoHS compliant & conforms to the Chinese standard SJ/T1166-2006 (Chinese RoHS equivalent) • Dynamic salt spray: per EIA-364-26 - 48 h Nickel version - 500 h Black Anodized version - 500 h Black Zinc Nickel version • Insulation resistance ≥ 5000 MΩ under 500 Vcc • Sealing: - Globally IP65 (unmated conditions) - With J or JC backshell IP67 (mated conditions) - With cable gland IP68 (mated conditions) Under 10 meter of water during 48 hours • Contact resistance - Environmental version: Size 20 ≤ 4 mΩ / Size 16 ≤ 3 mΩ • Fluid resistance: - Hydraulic fluids - Lubricating oil • Operating temperature: from -55°C to +125°C • Flammability rating: UL94 HB 12 • Shielding effectiveness: 70 dB to 5 MHz - 40 dB to 100 MHz Mechanical Electrical Environmental • Current rating per contact Size 20 = 7.5 A / Size 16 = 13 A • Dielectric withstanding voltage: - At standard pressure: mated and unmated connectors - 1500 Vrms between size 20 contacts (service 1) - 2300 Vrms between size 16 contacts (service 2) - 1500 Vrms between mixed size 20 and 16 contacts (service 1) - At reduced pressure 10 mbar: connectors mated and unmated - 200 Vrms between size 20 contacts (service 1) - 300 Vrms between size 16 contacts (service 2) • Durability: 500 matings and unmatings per MIL-DTL-26482H • Vibration resistance: 10-2000 Hz, acceleration 15 g test procedure per EIA-364-28 • Thermal shock: 5 cycles, 30 min. from -55°C to 125°C per EIA-364-32 • Mechanical shock: 50 g, 11 ms period per EIA-364-27 851 Series | Overview Overview Notes 13 851 SERIES © 2014 SOURIAU - SOURIAU is a registered trademark 851 Series Connector Receptacles ....................................................................................................... 16 Plugs ....................................................................................................... 18 Harnesses ...................................................................................................... 23 Orientation ...................................................................................................... 24 Cross Reference List ....................................................................................................... 25 15 851 Series | Connector Receptacles Square Flange Receptacle not Accepting Backshell, Solder Contact - 02E E 11.70 maxi Part numbers solder contacts Shell size 8 851 02E 8 10 * P S F ØA ØD L 1.39 maxi Ø 3.02 mini L maxi solder ØA maxi ØD maxi E F maxi 25.10 12.05 10.87 15.09 21.02 15.01 14.02 18.26 24.22 851 02E 10 P S * 25.10 12 851 02E 12 P S * 25.10 19.09 17.40 20.62 26.57 14 851 02E 14 P S * 25.10 22.27 20.60 23.00 28.92 16 851 02E 16 P S * 25.10 25.42 23.75 24.61 31.32 Black anodized* See page 10 "obligatory specification". Example: 85102E123P54 Jam Nut Receptacle not Accepting Backshell, Solder Contact - 07A P S ØA L 17.90 maxi Shell size Part numbers solder contacts ØF L maxi solder ØA maxi ØF maxi P maxi S maxi 8 851 07A 8 25.10 12.05 26.97 19.29 23.97 10 851 07A 10 P S * 25.10 15.01 30.17 22.38 26.97 12 851 07A 12 P S * 25.10 19.09 34.97 27.13 31.77 14 851 07A 14 P S * 25.10 22.27 38.07 30.33 34.97 16 851 07A 16 P S * 25.10 25.42 41.27 33.48 38.27 * P S Black anodized* See page 10 "obligatory specification". Example: 85107A123P54 Note: all dimensions are in mm 16 2.67 maxi 851 Series | Connector Square Flange Receptacle not Accepting Backshell, PC Tail - 02E L T E Ø 3.02 mini F ØA ØD 2.36 mini U Shell size Part numbers PC tail contacts 8 851 02E 8 10 * P S 1.39 maxi L maxi ØA maxi ØD maxi E F maxi 20.57 12.05 10.87 15.09 21.02 15.01 14.02 18.26 24.22 851 02E 10 P S * 20.57 12 851 02E 12 P S * 20.57 19.09 17.40 20.62 26.57 14 851 02E 14 P S * 20.57 22.27 20.60 23.00 28.92 16 851 02E 16 P S * 20.57 25.42 23.75 24.61 31.32 T (1) mini U (2) mini 9.46 8.68 Connector 11.70 maxi (1) PC tail contact with shoulder (2) PC tail contact without shoulder Black anodized* See page 10 "obligatory specification". Example: 85102E123P54A7 Jam Nut Receptacle not Accepting Backshell, PC Tail - 07A L P 2.36 mini S ØA T U 17.90 maxi Shell size Part numbers PC tail contacts P 2.67 maxi ØF L maxi ØA maxi ØF maxi P maxi S maxi T (1) mini U (2) mini 9.46 8.68 S 8 20.57 12.05 26.97 19.29 23.97 P S * 20.57 15.01 30.17 22.38 26.97 P P S S P P S S * 20.57 19.09 34.97 27.13 31.77 * 20.57 22.27 38.07 30.33 34.97 P S * 20.57 25.42 41.27 33.48 38.27 851 07A 8 P * P S S 10 851 07A 10 P S 12 851 07A 12 14 851 07A 14 16 851 07A 16 Black anodized* See page 10 "obligatory specification". Example: 85107A123P54A7 (1) PC tail contact with shoulder (2) PC tail contact without shoulder Note: all dimensions are in mm 17 851 Series | Connector Plugs Plug with Backnut - 06E ØA ØD L Shell size Part numbers solder contacts 8 851 06E 8 10 12 L maxi solder ØA maxi * P S ØD maxi 19.05 13.50 21.80 16.70 26.15 19.90 * 29.35 23.40 * 32.50 26.60 851 06E 10 P S * 851 06E 12 P S * 14 851 06E 14 P S 16 851 06E 16 P S 32.54 Black anodized* See page 10 "obligatory specification". Example: 85106E123P54 Plug with Straight Cable Clamp - 06EC Shell size Part numbers solder contacts 8 851 06EC 8 10 12 * P S L maxi solder ØA maxi D maxi ØG maxi 48.00 19.05 19.90 3.50 851 06EC 10 P S * 48.00 21.80 21.50 5.00 851 06EC 12 P S * 48.00 26.15 25.00 8.20 14 851 06EC 14 P S * 48.00 29.35 27.80 10.00 16 851 06EC 16 P S * 51.00 32.50 29.40 13.00 Black anodized* See page 10 "obligatory specification". Example: 85106EC123P54 Note: all dimensions are in mm 18 D ØA ØG L 851 Series | Connector Plug with Adaptor Backnut - 06A Part numbers solder contacts 8 851 06A 8 * P S ØD F L maxi solder ØA maxi ØD maxi ØG maxi UNEF 2A 41.00 19.05 14.50 9.10 1/2 28 threading 10 851 06A 10 P S * 41.00 21.80 18.70 12.08 5/8 24 12 851 06A 12 P S * 41.00 26.15 21.70 15.25 3/4 20 14 851 06A 14 P S * 41.00 29.35 25.10 18.15 7/8 20 16 851 06A 16 P S * 41.00 32.50 28.13 21.32 1 20 Connector Shell size F ØA ØG L Black anodized* See page 10 "obligatory specification". Example: 85106A123P54 Plug with Right Angle Cable Clamp - 08EC ØA R L ØG Shell size Part numbers solder contacts 8 851 08EC 8 10 P S * D L maxi solder ØA maxi D maxi R maxi ØG maxi 50.10 19.05 19.70 16.00 3.50 21.80 21.20 18.00 5.00 851 08EC 10 P S * 52.60 12 851 08EC 12 P S * 54.90 26.15 24.20 19.50 8.20 14 851 08EC 14 P S * 58.50 29.35 27.50 22.00 10.00 16 851 08EC 16 P S * 60.80 32.50 29.10 23.50 13.00 Black anodized* See page 10 "obligatory specification". Example: 85108EC123P54 Note: all dimensions are in mm 19 851 Series | Connector Plugs (Continued) Plug with Straight Sealing Gland Backshell - 06J ØA Part numbers solder contacts Shell size 8 851 06J 8 10 12 * P S ØD ØG L ØG L maxi solder ØA maxi ØD maxi mini maxi 47.60 19.05 14.40 5.02 5.84 851 06J 10 P S * 47.60 21.80 17.60 5.94 6.76 851 06J 12 P S * 49.20 26.15 21.10 9.34 10.16 14 851 06J 14 P S * 54.00 29.35 24.40 11.32 12.14 16 851 06J 16 P S * 59.60 32.50 27.60 14.73 15.55 Black anodized* See page 10 "obligatory specification". Example: 85106J123P54 Plug with Straight Sealing Gland and Cable Clamp Backshell - 06JC Shell size Part numbers solder contacts P S ØG L maxi solder ØA maxi ØD maxi mini maxi 8 851 06JC 8 57.68 19.05 19.90 5.02 5.84 10 851 06JC 10 P S * 57.68 21.80 21.50 5.94 6.76 851 06JC 12 P S * 61.24 26.15 25.00 9.34 10.16 14 851 06JC 14 P S * 66.01 29.35 27.80 11.32 12.14 16 851 06JC 16 P S * 74.75 32.50 29.40 14.73 15.50 12 * Black anodized* See page 10 "obligatory specification". Example: 85106JC123P54 Note: all dimensions are in mm 20 ØD ØA ØG L 851 Series | Connector Plugs with Metallic Adaptor and Plastic Cable Glamp Plug with Short Metallic Adaptor and Plastic Cable Gland - 06S B Part numbers solder contacts 8 851 06S 8 10 12 * P S ØG A maxi B maxi ØC maxi mini maxi 37.00 61.00 19.30 4.00 5.00 851 06S 10 P S * 37.00 64.00 22.00 4.00 6.00 851 06S 12 P S * 37.00 66.00 26.30 4.00 7.00 14 851 06S 14 P S * 37.00 67.00 29.50 4.00 9.00 16 851 06S 16 P S * 42.00 75.00 32.70 6.00 12.00 Connector Shell size ØG ØC A Black anodized* See page 10 "obligatory specification". Example: 85106S123P54 Plug with Long Metallic Adaptor and Plastic Cable Gland - 06L E Shell size Part numbers solder contacts ØG ØC D ØG D maxi E maxi ØC maxi mini maxi 8 851 06L 8 57.00 81.00 19.30 4.00 5.00 10 851 06L 10 P S * 57.00 84.00 22.00 4.00 6.00 12 851 06L 12 P S * 57.00 86.00 26.30 4.00 7.00 14 851 06L 14 P S * 57.00 87.00 29.50 4.00 9.00 16 851 06L 16 P S * 57.00 90.00 32.70 6.00 12.00 * P S Black anodized* See page 10 "obligatory specification". Example: 85106L123P54 Note: all dimensions are in mm 21 851 Series | Connector Plugs with Metallic Adaptor and Plastic Cable Glamp (Continued) Plug with Short Metallic Adaptor and Plastic Cable Gland with Spiral Protector - 06NS B ØC ØG A Shell size 8 Part numbers solder contacts 851 06NS 8 * P S ØG A maxi B maxi ØC maxi mini maxi 37.00 91.00 19.30 4.00 6.50 10 851 06NS 10 P S * 37.00 101.00 22.00 4.00 7.00 12 851 06NS 12 P S * 37.00 114.00 26.30 4.00 7.00 851 06NS 14 P S * 37.00 125.00 29.50 4.00 7.00 851 06NS 16 P S * 42.00 144.00 32.70 6.00 11.0 14 16 Black anodized* See page 10 "obligatory specification". Example: 85106NS123P54 Plug with Long Metallic Adaptor and Plastic Cable Gland with Spiral Protector - 06NL E Shell size Part numbers solder contacts ØG ØC D E maxi ØC maxi mini maxi 8 851 06NL 8 57.00 111.00 19.30 4.00 6.50 10 851 06NL 10 P S * 57.00 121.00 22.00 4.00 7.00 12 851 06NL 12 P S * 57.00 134.00 26.30 4.00 7.00 14 851 06NL 14 P S * 57.00 145.00 29.50 4.00 7.00 16 851 06NL 16 P S * 57.00 159.00 32.70 6.00 11.0 * P S Black anodized* See page 10 "obligatory specification". Example: 85106NL123P54 Note: all dimensions are in mm 22 ØG D maxi 851 Series | Connector Harnesses Connector • Shielded metal connector • Sealing: IP68 mated • 4 layouts: (8-4/10-6/12-10/14-19) • Other layouts on request, consult us • Rapid 1/3 turn coupling • Conforms to the international standard MIL-DTL-26482H series 1 Cable • TPE outer sheath (black color) • Multi-conductor 10, 12 or 14 • 300V • Shielded • Flammability rating UL 1581 Sec.1080 (VW-1) • Resistant to a wide range of chemical fluids Plating Salt spray Temperature Sealing Mated Mechanical Black Zinc Nickel 500 H -55° C up to + 125° C IP68 500 matings unmatings Black Anodized 500 H -55° C up to + 125° C IP68 500 matings unmatings Nickel 48 H -55° C up to + 125° C IP68 500 matings unmatings Connector Applications • Instrumentation & measurement • Industrial robots • Machine tools • Off-Road • Mining Shielding 70 dB With appropriate cable and overmold 23 851 Series | Connector Orientation Insulator Rotated Inside Metal Body Viewed from front face of male insulator (receptacle or plug) Shells 8 10 12 14 16 Layouts W X Y Z #16 1500 Vrms #20 2300 Vrms 2 58 122 - - X - 3 60 210 - - X - 3A (98)* 60 210 - - X - 4 45 - - - X - 33 90 - - - X - 6 90 - - - X - 7* 90 - - - X - 98 90 180 240 270 X - 2 - - - - - X 3 - - 180 - - X 4 - - - - X - 8 90 112 203 292 X - 10 60 155 270 295 X - 14* 45 5 40 92 184 273 X - - X 7 - - - - X - 12 43 90 - - X - 15 17 110 155 234 X - 18 15 90 180 270 X - 19 30 165 315 - X - 8 54 152 180 331 - X 23 158 270 - - X - 26 60 - 275 338 X - * 8-98 layout, W and X non standard ortientations 10-7 & 12-14 layouts, W non standard orientation 24 Angle in degrees 851 Series | Connector Cross Reference List SOURIAU MIL-DTL-26482H Series 1 851 00 E .. .. .. 54/57 MS 3110 E .. .. ..K 851 00 EC .. .. .. 54/57 MS 3110 F .. .. ..K 851 00 AC .. .. .. 54/57 - 851 00 P .. .. .. 54/57 MS 3110 P .. .. ..K 851 00 A .. .. .. 54/57 - 851 00 J .. .. .. 54/57 - 851 00 JC .. .. .. 54/57 MS 3110 J .. .. ..K 851 01 E .. .. .. 54/57 MS 3111 E .. .. ..K 851 01 EC .. .. .. 54/57 MS 3111 F .. .. ..K 851 01 AC .. .. .. 54/57 - 851 01 P .. .. .. 54/57 MS 3111 P .. .. ..K 851 01 A .. .. .. 54/57 - 851 01 J .. .. .. 54/57 - 851 01 JC .. .. .. 54/57 MS 3111 J .. .. ..K 851 02 E .. .. .. 54/57 MS 3112 E .. .. ..K 851 06 E .. .. .. 54/57 MS 3116 E .. .. ..K 851 06 EC .. .. .. 54/57 MS 3116 F .. .. ..K 851 06 AC .. .. .. 54/57 - 851 06 P .. .. .. 54/57 MS 3116 P .. .. ..K 851 06 A .. .. .. 54/57 - 851 06 J .. .. .. 54/57 - 851 06 JC .. .. .. 54/57 MS 3116 J .. .. ..K 851 08 EC .. .. .. 54/57 - 851 08 P .. .. .. 54/57 - 851 07 E .. .. .. 54/57 MS 3114 E .. .. ..K 851 07 EC .. .. .. 54/57 MS 3114 F .. .. ..K 851 07 AC .. .. .. 54/57 - 851 07 P .. .. .. 54/57 MS 3114 P .. .. ..K 851 07 A .. .. .. 54/57 - Connector 851 Version with Solder Contacts (Black Zinc Nickel) 25 851 Series | Connector Notes 26 Our contribution to environmental protection: This catalog is printed on PEFC certified paper Advancement of sustainable wood cultivation. www.pefc.org www.souriau-industrial.com contactindustry@souriau.com CA851INDUSWUSEN01 © Copyright SOURIAU 2014 - SOURIAU is a registered trademark All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Photos: Fotolia.com Your local contact
85106EC2255S50 价格&库存
很抱歉,暂时无法提供与“85106EC2255S50”相匹配的价格&库存,您可以联系我们找货
