DESCRIPTION: QUIK-LOQ - MALE - CABLE MOUNT - PLASTIC
UNITS = MM [INCHES]
CHARACTERISTICS
MATERIALS
HOUSING : ABS+PC
HOUSING COLOR : GREY
COLLET NUT : ABS+PC
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
8P1P YYY 1 7 N YL YY 1
1 = GOLD FLASH
SERIES
14.00 [0.551]
COLLET SIZE
**SEE CHART B**
RoHS COMPLIANT
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
1 = MALE
PLASTIC SHELL
CABLE MOUNT
MECHANICAL
DURABILITY: 2000 CYCLES
OPERATING TEMP. RANGE: -20 C ~ +120 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE: 0.5 Nm [4.4 IN/LBS]
COLLET NUT COLOR
G = GREY
A = BLUE
J = YELLOW
N = BLACK
R = RED
V = GREEN
IP RATING: 50
1.752
44.50
CHART B
0.551
14.00
COLLET
SIZE
1.157
29.40
= KEY LOCATION
1
1
1
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1200V
WORKING VOLTAGE = 400V
3 POSITION
22 AWG MAX.
10 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
4 POSITION
22 AWG MAX.
8 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
RoHS COMPLIANT
N
C
42
2.20 [0.087] ~ 4.00 [0.157]
52
4.00 [0.157] ~ 5.00 [0.197]
62
5.00 [0.197] ~ 6.00 [0.236]
14 POSITION
26 AWG MAX.
2 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 600V
WORKING VOLTAGE = 200V
CHART A
2 POSITION
22 AWG MAX.
10 AMP MAX.
PIN
= 1.30 [0.051]
1
WIRE DIAMETER
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
**VIEW FROM TERMINATION END**
1
1
1
1
1
1
5 POSITION
22 AWG MAX.
7 AMP MAX.
PIN
= 0.90 [0.035]
6 POSITION
24 AWG MAX.
6 AMP MAX.
PIN
= 0.70 [0.028]
7 POSITION
24 AWG MAX.
5 AMP MAX.
PIN
= 0.70 [0.028]
8 POSITION
24 AWG MAX.
5 AMP MAX.
PIN
= 0.70 [0.028]
9 POSITION
26 AWG MAX.
3 AMP MAX.
PIN
= 0.50 [0.020]
10 POSITION
26 AWG MAX.
3 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1050V
WORKING VOLTAGE = 350V
CONTACT
RESISTANCE = 7.5 mΩ
CONTACT
RESISTANCE = 7.5 mΩ
CONTACT
RESISTANCE = 7.5 mΩ
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 850V
WORKING VOLTAGE = 280V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 850V
NorComp
DRAWN:
M. SIGMON
DATE:
08-01-16
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
1
REV:
8P1PYYY17NYLYY1
2
很抱歉,暂时无法提供与“8P1P01017NJL421”相匹配的价格&库存,您可以联系我们找货
