UTS SERIES
Waterproof Plastic Connectors
IP68 and IP69K
Overview
UTS Series |
Overview
Contacts
Typical Applications ........................................... 06
Features & Benefits ........................................... 07
Range Overview ................................................ 08
Layouts .............................................................. 10
General Technical Characteristics ...................... 12
Description ........................................................ 162
Contact Plating Selector Guide ......................... 163
Contact Selector Guide ..................................... 164
Packaging .......................................................... 164
Crimp Contacts ................................................. 165
#16 Coaxial Contacts ........................................ 167
PCB Contacts .................................................... 168
Fiber Optic Contacts ......................................... 170
Technical Information
Contacts
Tooling ............................................................... 174
Stripping & Crimping Instructions ..................... 176
Handle & Interchangeable Heads ..................... 178
Insertion & Extraction Tools ............................... 179
Overmolded Cable Assembly Dimensions ........ 179
Assembly Instructions ........................................ 180
Mated Connector Lengths ................................ 184
Mating Procedure .............................................. 185
Rated Current & Working Voltage ..................... 186
UV Resistance .................................................... 187
UL94 + UL1977 .................................................. 188
IEC 61984 & IP Codes Explained ...................... 191
IEC 61140 Explained ......................................... 193
What is NEMA Rating ? ..................................... 194
Ethernet for the Layman .................................... 195
Overmolded Cable Assembly ........................... 16
2 contacts .......................................................... 20
2 + ground contacts .......................................... 28
3 contacts .......................................................... 36
3 + ground contacts .......................................... 52
4 contacts .......................................................... 60
5 contacts .......................................................... 72
6 contacts .......................................................... 80
6 + ground contacts .......................................... 92
7 contacts .......................................................... 96
8 contacts .......................................................... 100
10 contacts ........................................................ 112
12 contacts ........................................................ 116
14 contacts ........................................................ 128
15 contacts ........................................................ 132
18 contacts ........................................................ 136
19 contacts ........................................................ 140
23 contacts ........................................................ 144
32 contacts ........................................................ 148
LC (Fiber Optic) ................................................. 152
MPO (Fiber Optic) ............................................. 156
Appendices
#16 Coaxial Contacts/Cabling Notices ............. 200
Glossary of Terms .............................................. 207
Discrimination/Keying Methods ........................ 208
Part Number Index ............................................ 209
Appendices
Connector
Connector
Contents
3
UTS SERIES
© 2015 SOURIAU - SOURIAU is a registered trademark
UTS Series
Overview
Typical Applications ................................................................................................. 06
Features & Benefits ................................................................................................. 07
Range Overview ..................................................................................................... 08
Layouts ................................................................................................................... 10
General Technical Characteristics ............................................................................ 12
5
UTS Series | Overview
Off-Road - Mining - Railway
© cachoudesign / Fotolia
Instrumentation - Measurement
Stage - Light
6
Building Automation & Control
© Olivier Tuffé / Fotolia
© krungchingpixs / Fotolia
Energy - Power
Telecom - Data infrastructure
© Volodymyr Kyrylyuk / Fotolia
© Vibe Images / Fotolia
© Sergey Milovidov / Fotolia
Features & Benefits
IP68/69K Dynamic Mated & Unmated
Ideal for outdoor and indoor dynamic applications requiring
continuous underwater immersion, routine pressure washing
and dust protection.
Overview
WATER
PROOF
No Degradation Over Time
UV
RESISTANT
No mechanical deterioration or important color variation after
5 years of exposure in natural environment (equivalent exposure
to sun and moisture as per ISO4892) and F1 rated per UL 746C.
Qualified & Certified
UL/IEC
COMPLIANT
In accordance with:
- UL 1977 - Certificate ECBT2, File number: E169916
- CSA C22.2 n°182.3 - Certificate ECBT8, File number: E169916.
1/3 Bayonet Coupling
quick
mating
With only 1/3 twist of the bayonet coupling system, connectors are
mated with audible "click" and tactile feel to confirm proper mating.
This mating feature eliminates connection uncertainty and reduces
time and labor during installation.
Mixed Power & Signal Layouts
Cost
savings
Power supply and signal transmission can be combined in
a unique interconnect solution to reduce system complexity
and minimize component and installation costs.
7
Range
UTS Standard
UTS Series
Cable Sealed
Single Wire
Sealed
Sealed mated:
IP68/69K dynamic
UV resistant
UL/IEC compliant
UTS Backshells
Corrosion-proof
Plastic housing
Contacts Supplied Separately
Cable Sealing
Choice of Crimp Contacts
• Machined
• Stamped and Formed
• Coaxial
Plug
PCB Contacts
Double Sealing
(Wires + Cable)
Fiber Optic
Contacts Loaded
Screw Termination
Grommet
Single Wire
Sealed
Flexible conduit
adaptors
Contact us for more information
8
Contacts Loaded
Handsolder
UTS Sealed Unmated
Sealed Unmated: IP68/69K dynamic
MIL-C-26482 compatible
UV resistant
UL/IEC compliant
Corrosion-proof
Plastic housing
Overview
UTS Standard Receptacle
UTS Backshells
• Machined
• Coaxial
Overview
Square Flange
Cable Sealing
PCB Contacts
Threaded
Receptacle
Fiber Optic
Double Sealing
(Wires + Cable)
• Machined
• Coaxial
In-line
Grommet
PCB Contacts
Single Wire
Sealed
Fiber Optic
Contacts Loaded
Jam Nut
Flexible conduit
adaptors
Screw Termination
PCB
UTS Sealed
Unmated Receptacle
UTS PCB Contacts
Contacts Loaded
Jam Nut
Stand-offs to allow
cleaning after
soldering
Handsolder
Metal hold down clips
- to lock the connector easily on
the PCB and to release stress
on solder joints
- suitable for soldering in a
metallic hole
PCB
Square Flange
Low profile housing to limit
space between panel and PCB
Pre-assembled PCB contacts
- machined or stamped versions
available
- different solder tails lengths
possible
- different plating options
9
Layouts
Shell Size
(Electrical parameter according to UL1977)
Contact #16 (Ø 1.6mm)
Contact #20 (Ø 1.0mm)
8E2/8D2(1)
8E3/8D3(1)
Page 20
Page 36
8E3A/8D3A(1)
8E98/8D98(1)
Page 40
Page 40
8E33/8D33(1)
8E4*/8D4*(1)
Page 44
Page 60
7A 250V
3 contacts
7A 250V
3 contacts
103
10
10A 500V
4 contacts
6A 250V
6 contacts
Page 28
Page 68
Page 84
12E2/12D2
13A 650V
2 contacts
Page 24
102W2
10E98/10D98
10E7(1)/10D7
Page 88
Page 96
12E3/12D3
13A 600V
3 contacts
103W3
20A 500V
4 contacts
10A 500V
6 contacts
2xØ2.4 (#12)
2xØ1.0 (#20)
3xØ1.6 (#16)
3xØ1.0 (#20)
Page 64
Page 80
6A 250V
7 contacts
1210*
12E10*/12D10*
5A 250V
10 contacts
Page 48
Page 112
124
12E4/12D4
(4)
128(1) (3)
10A 500V
3+ground
10A 500V
8 contacts
Page 52
Page 100
1: M12, M16 and M20 threaded receptacle available
10
7A 250V
4 contacts
10A 500V
2+ground
6A 250V
6 contacts
12
7A 250V
3 contacts
106*
10E6*(1)/10D6*
104*(3)
Hybrid & others
7A 250V
3 contacts
7A 250V
2 contacts
8
Contact #8 (Ø 3.6mm)
2: NPT available
12E8/12D8
12E14/12D14
Page 104
Page 128
4.5A 250V
8 contacts
4.5A 250V
14 contacts
3: Discrete wire grommet option
4: Screw termination contacts
* Ethernet compatible: see pages 195 & 196
Shell Size
Contacts #16:
from AWG 30 to 14
0.05 to 2.5 mm²
14E5/14D5
14
147(3) (4)
14E7/14D7
12A 600V
5 contacts
10A 500V
6+ground
Page 72
Page 92
1412(3)
1492(3)
10A 500V
12 contacts
10A 600V
12 contacts
Contacts #12:
from AWG 22 to 12
0.13 to 4 mm²
Contacts #8:
from AWG 16 to 8
1.5 to 10 mm²
Contact #20 (Ø 1.0mm) Contact #8 (Ø 3.6mm)
14E18/14D18
Hybrid & others
148
142G1(2)
4A 250V
18 contacts
44A 600V
2+ground
Page 136
Page 32
25A 250V
8 contacts
4xØ1.6 (#16)+4xØ2.4 (#12)
Overview
Contacts #20:
from AWG 26 to 18
0.13 to 0.93 mm²
Page 108
14E12/14D12
4.5A 250V
12 contacts
1419
14E19/14D19
4xØ1.6 (#16)+8xØ1.0 (#20)
5A 250V
19 contacts
Page 120
Page 116
14E15/14D15
Page 124
12A 600V
15 contacts
Page 140
1xØ1.6 (#16)+14xØ1.0 (#20)
Page 132
1823
10A 500V
23 contacts
1832
18E32
5A 250V
32 contacts
183G1(2)
18X2M3(2)
44A 600V
3+ground
44A 600V
5 contacts
3xØ1.6 (#16) + 2xØ3.6
(#8)
1
11
1
12
11
22
2
22
2
5
55
Page 144
Page 148
Page 56
1
1
22 225
5
24
5
2 3
44
33
3
33
11 11
5
55 55
4
33 33
44
5
5
4
44 44
4
4
3
3
Page 763
LC
18
Page 156
MPO
Page 160
XXXXXX blue highlighted items: UTS Sealed in Unmated Condition
11
Materials
Environmental
Electrical
• Body connector + Backshell: Thermoplastic
• Operating temperature:
from -40°C to +105°C
40/100/21 per NFF 61-030
• In accordance with:
- UL 1977: Certificate ECBT2
- CSA C22.2 n°182.3: Certificate ECBT8
• Insert:
- UTS Standard, UTS Single Wire Sealed,
UTS Screw Termination Contacts:
Thermoplastic
- UTS Sealed Unmated Handsolder &
UTS Sealed Unmated with PC Tails Contacts:
Elastomer
• Nut: Metal
• Contacts: See page 161
• Halogen free
• RoHS compliant & conforms to the Chinese
standard SJ/T1166-2006
(Chinese RoHS equivalent)
• Flammability rating:
- UL94 V-0 (all UTS except the Sealed
Unmated version) see page 188
- UL94 HB (UTS Sealed Unmated version
only) see page 188
- I2F3 according to NFF 16101 & NFF 16102
• Also see pages 10 & 11
• Salt spray:
≥500 hours per EIA-026A
• UV resistant:
No mechanical degradation or important
color variation after 5 years of exposure
to sun and moisture as per ISO 4892) and
• Sealing:
- UTS Standard: IP68/IP69K dynamic (mated)
- UTS Sealed Unmated version:
IP68/IP69K dynamic (unmated)
- UTS Single Wire Sealed: IP67/69K (up to
IP68 with double sealing backshell)
- UTS Screw Termination Contacts:
Note: IP68=10 m underwater during 1 week
• Fluid resistance:
- Gas and Oil
- Mineral Oil
- Acid Bath
- Basic Bath
12
Optical
• Please consult us for more information
about UTSLC and UTSMPO
Mechanical
• Durability:
250 matings & unmatings per MIL-C-26482
• Vibration resistance (all UTS versions
except UTS Screw Termination contacts):
Sinusoidal vibrations per IEC 60512-4 - from
10 to 2000 Hz
• Thermal shock:
5 cycles 30 min. from -40°C to 105°C per
MIL-STD-1344 method 1003
Overview
Notes
13
UTS SERIES
UTS Series
Connector
Overmolded Cable Assembly ................................................................................. 16
2 contacts
8E2/8D2: 7A 250V.................................................................. 20
12E2/12D2: 13A 650V.................................................................. 24
2 contacts + ground
103: 10A 500V.................................................................. 28
142G1: 44A 600V.................................................................. 32
3 contacts
8E3/8D3: 7A 250V.................................................................. 36
8E3A/8D3A - 8E98/8D98: 7A 250V.................................................................. 40
8E33/8D33: 7A 250V.................................................................. 44
12E3/12D3: 13A 600V.................................................................. 48
3 contacts + ground
124 - 12E4/12D4: 10A 500V.................................................................. 52
183G1: 44A 600V.................................................................. 56
4 contacts
8E4/8D4*: 7A 250V.................................................................. 60
102W2: 20A 500V.................................................................. 64
104*: 10A 500V.................................................................. 68
5 contacts
14E5/14D5: 12A 600V.................................................................. 72
18X2M3: 44A 600V.................................................................. 76
6 contacts
103W3: 10A 500V.................................................................. 80
106* - 10E6*/10D6*: 6A 250V.................................................................. 84.
10E98/10D98: 6A 250V.................................................................. 88
6 contacts + ground
147 - 14E7/14D7: 10A 500V.................................................................. 92
7 contacts
10E7/10D7: 6A 250V.................................................................. 96
8 contacts
128: 10A 500V.................................................................. 100
12E8/12D8: 4.5A 250V.................................................................. 104
148: 25A 250V.................................................................. 108
10 contacts
1210* - 12E10*/12D10*: 5A 250V.................................................................. 112.
12 contacts
1412: 10A 500V.................................................................. 116.
14E12/14D12: 4.5A 250V.................................................................. 120
1492: 10A 600V.................................................................. 124
14 contacts
12E14/12D14: 4.5A 250V.................................................................. 128
15 contacts
14E15/14D15: 12A 600V.................................................................. 132
18 contacts
14E18/14D18: 4A 250V.................................................................. 136
19 contacts
1419 - 14E19/14D19: 5A 250V.................................................................. 140.
23 contacts
1823: 10A 500V.................................................................. 144
32 contacts
1832 - 18E32: 5A 250V.................................................................. 148
LC ........................................................................................................................ 156
MPO .................................................................................................................... 160
Electrical parameters according to UL
* Ethernet compatible see pages 195 & 199
15
UTS Series | Connector
SOURIAU has provided connectors for various applications for more than 90 years and has been used in the most extreme environments.
Conscious about the difficulty in finding a quick and reliable harness manufacturer, we began our own in-house cable assembly production.
It allows customers to reduce the number of suppliers and to take advantage of the “best in class” quality of the SOURIAU group.
Overmolding is a process that further enhances the sealing properties and helps to minimize stress on the cable termination to the
connector. In addition, the wires are encapsulated inside the molding which creates a barrier preventing liquid/moisture from entering the
equipment through the connector or cable jacket if breached.
How to choose the outer jacket material
TPE
Static installation
OUTDOOR
(black outer jacket)
PUR
Static or dynamic installation
SILICON
Static installation
FEP
Static installation
PTFE
Static installation
INDOOR
PVC
-40°C
16
+80°C Ambient temperature
UV resistance
Chemical aggression
Wet
Immersed
Cleaner,
chlorine
Please consult us
Overmolding Description
O-ring
Compound
Overmolding adapter
PVC or PUR
overmolding
Connector
Thermoplastic or
elastomer insert
Connector with cable gland backshell
If cable jacket is breached...
GOOD
...water ingress unhampered, leading to damage.
Overmolded connector
BEST
...prevents water ingress via capillary action.
17
UTS Waterproof Plastic Overmold
Description
Cable
• PVC Jacket (Black)
• 16 AWG conductors
• Multi-conductor 4, 8 or 12
• 300V
• Unshielded
• Flammability rating UL 1685 (UL1581 Sec.1160)
Applications
• Industrial Controls
• Electronics
• Controlled Environment Equipment
• LED Lighting
Overmolding Specifications
PLATING
SALT SPRAY
TEMPERATURE*
WATERPROOF*
MECHANICAL
No plating
500 H
-30°C up to +50°C
250 matings/unmatings
* With appropriate cable and overmolding
Example of Customized Cable Assemblies
Overmolding on Curly Cable
Overmolding with Double Ends
Harness for PCB Connection
To define your customized cable assembly needs, please contact our Technical Service Team for support.
18
Cable Information
Range of temperature:
-30°C +50°C
Rated voltage:
U0/U: 300/500V
Wire section :
Layouts with #16 contact: wire section 1.5 mm² / 16AWG
Harmonized reference:
H05 VV - F XX
Nomenclature Key
Definitions of Cable Types
S:
Service Grade (also means extra hard service when not
followed by J, V, or P)
J:
Hard Service
V:
Vacuum cleaner cord (also light duty cable)
P:
Parallel cord (also known as zip cord) – Always light duty
E:
Thermoplastic Elastomer (UL/NEC designation ONLY)
O:
Oil Resistant outer jacket
OO: Oil Resistant outer jacket and insulation
T: Thermoplastic
W:
Outdoor-includes sunlight resistant jacket and wet location
rated conductors (formerly "W-A")
H:
Heater cable
VW-1: Flame retardant (vertical grade)
FT2: Flame retardant (horizontal grade)
SVT:
Thermoplastic insulated vacuum cleaner cord, with or
without 3rd conductor for grounding purposes;
300V (PVC)
SJT:
Junior hard service, thermoplastic insulated conductors
and jacket. 300V (PVC)
SJTW: Same as SJT except outdoor rated. (PVC)
SJTO: Same as SJT but oil resistant outer jacket. (PVC)
SJTOW: Same as SJTO except outdoor rated. (PVC)
ST:
Hard service cord with all thermoplastic construction,
600V (PVC)
STW: Same as ST except outdoor rated. (PVC)
STO: Same as ST but with oil resistant outer jacket. (PVC)
STOW: Same as STO except outdoor rated. (PVC)
Connector
Standardization of American Cable
19
8E2/8D2 (Shell size 8, 2x#20)
Layout
OR
OR
OR
WITH
Connector Part Numbers
Contact type
Handsolder
electrical contacts
loaded
see page 23
PCB
contacts loaded
see page 23
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 1)
UTS08E2P
UTS08E2S
Without (Fig. 7)
UTS68E2P
UTS68E2S
Cable gland (Fig. 8)
UTS6JC8E2P
UTS6JC8E2S
Jam nut
receptacle
Without (Fig. 4)
UTS78E2P
UTS78E2S
M12 threaded receptacle
Without (Fig. 3)
UTS78E2PM12
UTS78E2SM12
Square flange
receptacle
Without (Fig. 2)
UTS08D2P
UTS08D2S
Jam nut receptacle
with stand off and
with hold down clips
Without (Fig. 6)
UTS78D2P32
UTS78D2S32
Jam nut receptacle
with stand off and
without hold down clips
Without (Fig. 5)
UTS78D2P
UTS78D2S
Without (Fig. 3)
UTS78D2PM12
UTS78D2SM12
Plug
Possibilities of discrimination/keying methods see page 208
Part number
Male insert
Sealed unmated
2 contacts
7A/250V
per UL 1977
2
Dimensions
Square Flange Receptacle - UTS0
0.295" Fig. 1
0.814"
0.342"
0.275"
mini
Ø0.125"
0.090"
0.866"
0.303"
Ø0.472"
0.602"
Ø0.472"
0.460"
M12 Threaded Receptacle - UTS7
M12x1.5
0.196"
Front view
Fig. 2
Fig. 3
Front view
Jam Nut Receptacle - UTS7
0.133"
0.145"
mini
0.133"
0.133"
0.137"
0.137"
Fig. 4
0.137"
Fig. 5
Front view
Fig. 6
Plug - UTS6
0.996"
0.952"
0.165"
0.708"
Ø0.472"
Ø0.472"
Ø0.472"
0.708"
0.952"
0.708"
Fig. 7
2.405"
Ø0.885"
UTS0
UTS7
2.126"
Fig. 8
2.622"
Panel Cut Out
Drilling Pattern
Ø0.122"
Ø0.129"
15°
15°
0.541"
0.602"
Ø0.696"
Front mounting
Ø0.492"
0.602"
Rear mounting
Ø0.570"
Hole size:
0.035"
Ø0.531"
Ø0.157"
Ø0.866"
0.574"
0.059"
0.059"
Note: all dimensions are in inches
21
Accessories
Jam Nut or M12 Threaded Receptacle Sealing Caps
IP68/69K
IP68/69K
Metal terminal
Square Flange Sealing Cap
IP68/69K
Metal terminal
IP40
Part number
Part number
Part number
Part number
UTS8DCG
UTS8DCGR
UTS8DCGE
UTS68C
Plastic Protective Cap
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
22
Plug Protective Cap
Receptacle
cap
Plug cap
85005585A
85005594
Part numbers
UTFD11B
Part numbers
R for Red
Receptacles
Plugs
UTS78CCRR
UTS68CCRR
UTS78CCRY
UTS68CCRY
UTS78CCRG
UTS68CCRG
2 contacts
7A/250V
per UL 1977
2
#20
Contact type
Plating
Cable acceptance (AWG)
Wire stripping length
Handsolder
Loaded in the connector
Min 0.4µ gold over 0.8µ Ni
22 to 18
0.196"
PCB
Contacts
Machined, loaded in the connector (1)
(1): For dimensions see page 169
Electrical Characteristics
UTS 8E2/8D2 Derating Curves
Current (A)
18
UL
7A 250V UL94 HB
CSA
7A 250V UL94 HB
IEC
7A 32V 1.5kV 3
16
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
14
12
10
8
6
4
2
Current use
60
80
100
Ambient Operating Temperature (°C)
Limited use
120
Not recommended use
23
12E2/12D2 (Shell size 12, 2x#16)
Layout
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 27
PCB
contacts loaded
see page 27
Connector type
Backshell
Square flange
receptacle
Part number
Male insert
Female insert
Without (Fig. 1)
UTS012E2P
UTS012E2S
Without (Fig. 6)
UTS612E2P
UTS612E2S
Cable gland (Fig. 7)
UTS6JC12E2P
UTS6JC12E2S
Jam nut
receptacle
Without (Fig. 3)
UTS712E2P
UTS712E2S
Square flange
receptacle
Without (Fig. 2)
UTS012D2P
UTS012D2S
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS712D2P32
UTS712D2S32
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS712D2P
UTS712D2S
Plug
Sealed unmated
24
2 contacts
13A/650V
per UL 1977
2
Dimensions
0.295"
0.295"0.318"
mini
1.039"
0.090"
0.818"
Ø0.748"
0.444"
Ø0.748"
0.444"
Ø0.125"
0.090"
Fig. 1
Front view
Fig. 2
0.118"
0.708"
0.118"
0.708"
0.137"
1.255"
0.137"
Fig. 3
0.137"
Fig. 4
Front view
Fig. 5
Plug - UTS6
0.996"
1.070"
0.165"
Ø0.748"
0.185"
mini
Ø0.748"
Ø0.748"
0.118"
0.708"
Fig. 6
3.055"
Ø1.185"
UTS0
UTS7
2.626"
Fig. 7
3.216"
Panel Cut Out
Drilling Pattern
Ø0.129"
22°
Ø0.122"
68°
Front mounting
Ø0.720"
0.818"
Rear mounting
Ø0.877"
0.055"
0.826"
0.818"
Ø1.031"
Hole size:
0.051"
Ø0.866"
0.393"
Ø1.200"
0.875"
0.090"
0.090"
30°
25
Accessories
Jam Nut Sealing Caps
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
IP68/69K
Metal terminal
Part number
Part number
Part number
Part number
UTS12DCG
UTS12DCGR
UTS612DCG
UTS12DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
26
Receptacle
cap
Plug cap
85005587A
85005596
Part numbers
UTFD13B
Part numbers
R for Red
Receptacles
Plugs
UTS712CCRR
UTS612CCRR
UTS712CCRY
UTS612CCRY
UTS712CCRG
UTS612CCRG
2 contacts
13A/650V
per UL 1977
2
#16
Contact type
Plating
Handsolder
18 to 14
0.196"
PCB
Contacts
UTS 12E2/12D2 Derating Curves
Current (A)
UL
13A 650V UL94 HB
CSA
13A 600V UL94 HB
IEC
16A 150V 2.5kV 3
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
Current use
30
28
26
24
22
16
14
12
10
8
6
4
2
60
80
100
Limited use
120
Not recommended use
27
103 (Shell size 10, 2 + ground, 3x#16)
Layout
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 31
PCB
contacts supplied
separately
see page 31
28
Connector type
Backshell
Free hanging
receptacle
Part number
Male insert
Female insert
Cable gland (Fig. 1)
UTS1JC103P
UTS1JC103S
Without (Fig. 2)
UTS6103P
UTS6103S
Cable gland (Fig. 3)
UTS6JC103P
UTS6JC103S
Jam nut receptacle
Without (Fig. 4)
UTS7103P
UTS7103S
Jam nut receptacle
Without (Fig. 4)
UTS7103P
UTS7103S
Plug
2 + ground
10A/500V
per UL 1977
Dimensions
2+
Free Hanging - UTS1
Ø0.594"
2.755"
Fig. 1
Plug - UTS6
1.299"
2.488"
Ø1.031"
Ø1.031"
Male
Female
0.996"
Fig. 2
Fig. 3
Ø0.594"
0.720"
Mated Connector Length - UTS7
1.070"
0.484"
0.137"
Fig. 4
3.043"
0.885"
Drilling Pattern
Hole size:
0.051"
0.686"
0.059"
0.651"
0.118"
Panel Cut Out
0.102"
0.102"
29
Accessories and Tooling
IP68/69K
Handle (without Head)
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS10DCG
UTS10DCGR
Shandles
Toolkit
Plug Sealing Cap
Dummy Contact #16
Crimp Tooling (without Shandles)
IP68/69K
Part number
Part number / Polyamide 6.6
UTS610DCG
SMSPKE0
See page 212 for more information
Extraction Tool #16
Part numbers
Receptacle
cap
Plug cap
85005586A
85005595
Part number
RX2025GE1
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS710CCRR
UTS610CCRR
UTS710CCRY
UTS610CCRY
UTS710CCRG
UTS610CCRG
Contacts
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
(1): Example of plating, for other plating options see page 164
* Heads to be used with handle PN: SHANDLES
Handle
30
Part number
of head
Contact size
Head
Complete set
2 + ground
10A/500V
per UL 1977
Contacts
#16
2+
Crimp
Machined
Stamped & Formed reeled
contacts
See note (2) for loose piece
PCB
Wire size
Contact type
Part number
Coaxial
Max
wire Ø
Max
insulator Ø
RM28M1K(1)
RC28M1K(1)
0.021"
0.039"
RM24M9K
RC24M9K
0.031"
0.062"
RM20M13K(1)
RC20M13K(1)
0.045"
0.070"
RM20M12K
(1)
RC20M12K
0.045"
0.086"
RM16M23K(1)
RC16M23K(1)
0.070"
0.125"
RM14M30K
RC14M30K
0.090"
0.125"
SC24M1TK6(1)(2)
0.035"-0.062"
SM20M1TK6(1)(2)
SC20M1TK6(1)(2)
0.047"-0.082"
0.125"
0.118"
(1)(2)
mm²
Male
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
26-24
0.13-0.20
SM24M1TK6(1)(2)
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
Machined (3)
14
2.08
Cable Multipiece
Cable Monocrimp
Twisted pair Multipiece
see pages 167,
200 to 206
Twisted pair Monocrimp
Fiber
optic
Female
AWG
POF contacts
(Plastic Optical Fiber)
see page
170
(1)
(1)
(1)
(1)
(1)
SM16M1TK6
SC16M1TK6
SM16M11TK6(1)(2)
SC16M11TK6(1)(2)
SM14M1TK6
SC14M1TK6
0.125"
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RCDXK1D28
RMDX60xxD28
RCDX60xxD28
RMDXK10D28 +
york090
RCDXK1D28 +
york090
RMDX60xxD28
RCDX60xxD28
RMPOF1000
RCPOF1000B
(1)(2)
(1)(2)
(1)(2)
(1): Example of plating, for other plating see page 164
(2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6
(3): For dimensions see page 172
UTS 103 Derating Curves
Current (A)
30
UL
10A 500V UL94 V-0
CSA
7A 500V UL94 V-0
IEC
16A 300V 4kV 3
Temperature elevation: 50°C
28
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
31
142G1 (Shell size 14, 2 + ground, 3x#8)
Layout
OR
OR
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 35
PCB
contacts supplied
separately
see page 35
32
Connector type
Backshell
Square flange receptacle
Free hanging
receptacle
Part number
Male insert
Female insert
Without (Fig. 1)
UTS0142G1P
Cable gland (Fig. 6)
UTS1JC142G1P
UTS1JC142G1S
Without (Fig. 3)
UTS6142G1P
UTS6142G1S
Cable gland (Fig. 4)
UTS6JC142G1P
UTS6JC142G1S
Jam nut
receptacle
Without (Fig. 2)
UTS7142G1P
UTS7142G1S
NPT 1/2" threaded
receptacle
Without (Fig. 5)
UTS7142G1SNPT
Without (Fig. 1)
UTS0142G1P
Jam nut
receptacle
Without (Fig. 2)
UTS7142G1P
UTS7142G1S
NPT 1/2" threaded
receptacle
Without (Fig. 5)
UTS7142G1SNPT
NPT 1/2" threaded
receptacle with nut
Without (Fig. 5)
UTS7142G1SNPTNUT
Plug
2 + ground
44A/600V
per UL 1977
Dimensions
2+
1.133"
0.913"
Ø0.877"
0.708"
0.090"
Fig. 1
Fig. 1
0.137"
Ø0.125"
Front view
Fig. 2
Plug - UTS6
1.378"
1.381"
0.062"
Ø0.877"
0.862"
1.196"
NPT Threaded Receptacle - UTS7
1.389"
2.755"
Ø1.381"
Ø0.877"
Male
1.000"
1.000"
0.444"
Female
1.263"
NPT - 1/2˝
0.909"
Fig. 3
Fig. 5
Fig. 4
Free Hanging - UTS1
3.090"
2.952"
Ø0.877"
UTS0
UTS7
3.228"
Fig. 6
1.003"
NPT
40 /2"
1
PT
N
7
0.
Hole size:
0.129"
0.082"
0.948"
Drilling Pattern
0.165"
Panel Cut Out
0.141"
0.141"
33
Jam Nut or NPT Threaded Receptacle Sealing Caps
IP68/69K
Hand Tool
Metal terminal
IP68/69K
Part number
Part number
UTS14DCG
UTS14DCGR
Part number
M317
Plug Sealing Cap
Positioner + Locator Setting #8
IP68/69K
Part number
UTS614DCG
Gasket
Part number
VGE10078A
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005588A
85005597
Part numbers
UTFD14B
Extraction Tool #8
Color Coding Rings
G for Green
Y for
Yellow
34
Part numbers
R for Red
Receptacles
Plugs
Part number
UTS714CCRR
UTS614CCRR
51060210936
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
2 + ground
44A/600V
per UL 1977
Contacts
PCB
Crimp
#8
2+
Contact type
Wire size
Part number
AWG
mm²
Male
Female
Max
wire Ø
16
1.31
82913601A
82913600A
0.067"
Machined
Machined (1)
14
2.08
82913603A
82913602A
0.087"
12
3.31
82913605A
82913604A
0.111"
10
5.26
82913607A
82913606A
0.137"
8
8.37
82913609A
82913608A
0.171"
82911685NPC
82911684NPC
(1): For dimensions see page 168
Max
insulator Ø
0.255"
UTS 142G1 Derating Curves
Current (A)
50
UL
44A 600V UL94 V-0
CSA
30A 600V UL94 V-0
IEC
40A 300V 4kV 3
45
40
Test
conditions
Contact used:
Machined contacts
Wires used:
6mm²
35
30
25
10
5
Current use
60
80
100
Limited use
120
Not recommended use
35
8E3/8D3 (Shell size 8, 3x#20)
Layout
OR
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 39
PCB
contacts loaded
see page 39
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 1)
UTS08E3P
UTS08E3S
Without (Fig. 7)
UTS68E3P
UTS68E3S
UTS6JC8E3P
UTS6JC8E3S
Jam nut
receptacle
Without (Fig. 4)
UTS78E3P
UTS78E3S
Without (Fig. 3)
UTS78E3PM12
UTS78E3SM12
Square flange
receptacle
Without (Fig. 2)
UTS08D3P
UTS08D3S
Jam nut receptacle
with stand off and
Without (Fig. 6)
UTS78D3P32
UTS78D3S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS78D3P
UTS78D3S
Without (Fig. 3)
UTS78D3PM12
UTS78D3SM12
Plug
36
Part number
Male insert
Sealed unmated
3 contacts
7A/250V
per UL 1977
Dimensions
0.295" Fig. 1
0.814"
Ø0.472"
0.275"
mini
Ø0.125"
0.090"
3
0.866"
0.303"
0.342"
0.602"
Ø0.472"
0.460"
M12x1.5
0.196"
Front view
Fig. 2
Fig. 3
Front view
0.133"
0.145"
mini
0.133"
0.708"
0.952"
Ø0.472"
0.137"
Fig. 5
0.137"
Fig. 4
0.165"
Ø0.472"
0.708"
Ø0.472"
0.708"
0.952"
0.133"
0.137"
Fig. 6
Plug - UTS6
Front view
Fig. 7
2.405"
0.996"
Ø0.885"
UTS0
UTS7
2.622"
2.126"
Fig. 8
Panel Cut Out
Drilling Pattern
Front mounting
Ø0.492"
0.602"
Rear mounting
Ø0.570"
0.541"
0.602"
0.035"
Ø0.129"
0.574"
Ø0.122"
Ø0.866"
15°
Hole size:
0.035"
15°
Ø0.157"
Ø0.531"
0.074"
Ø0.696"
0.062"
0.062"
37
Accessories
IP68/69K
IP68/69K
Metal terminal
IP68/69K
Metal terminal
IP40
Part number
Part number
Part number
Part number
UTS8DCG
UTS8DCGR
UTS8DCGE
UTS68C
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
38
Plug Protective Cap
Receptacle
cap
Plug cap
85005585A
85005594
Part numbers
UTFD11B
Part numbers
R for Red
Receptacles
Plugs
UTS78CCRR
UTS68CCRR
UTS78CCRY
UTS68CCRY
UTS78CCRG
UTS68CCRG
3 contacts
7A/250V
per UL 1977
Contacts
Contact type
Plating
Handsolder
3
22 to 18
0.196"
PCB
#20
UTS 8E3/8D3 Derating Curves
Current (A)
18
UL
7A 250V UL94 HB
CSA
7A 250V UL94 HB
16
14
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
IEC
7A 32V 1.5kV 3
12
10
8
6
4
2
Current use
60
80
100
Limited use
120
Not recommended use
39
8E3A/8D3A - 8E98/8D98 (Shell size 8, 3x#20)
Layout
OR
OR
OR
WITH
Contact type
Connector type
Square flange
receptacle
Backshell
Without (Fig. 1)
Without (Fig. 7)
Handsolder
electrical contacts
loaded
see page 43
PCB
contacts loaded
see page 43
Plug
Jam nut
receptacle
Without (Fig. 4)
Without (Fig. 3)
Square flange
receptacle
Without (Fig. 2)
Jam nut receptacle
with stand off and
Without (Fig. 6)
Jam nut receptacle
with stand off and
Without (Fig. 5)
Without (Fig. 3)
40
Part number
Male insert
Female insert
UTS08E3AP
UTS08E98P
UTS68E3AP
UTS68E98P
UTS6JC8E3AP
UTS6JC8E98P
UTS78E3AP
UTS08E3AS
UTS08E98S
UTS68E3AS
UTS68E98S
UTS6JC8E3AS
UTS6JC8E98S
UTS78E3AS
UTS78E98P
UTS78E98S
UTS78E3APM12
UTS78E3ASM12
UTS78E98PM12
UTS78E98SM12
UTS08D3AP
UTS08D98P
UTS78D3AP32
UTS08D3AS
UTS08D98S
UTS78D3AS32
UTS78D98P32
UTS78D98S32
UTS78D3AP
UTS78D3AS
UTS78D98P
UTS78D98S
UTS78D3APM12
UTS78D3ASM12
UTS78D98PM12
UTS78D98SM12
Sealed unmated
3 contacts
7A/250V
per UL 1977
Dimensions
0.295" Fig. 1
0.814"
Ø0.472"
0.275"
mini
Ø0.125"
0.090"
Fig. 2
3
0.866"
0.303"
0.342"
0.602"
Ø0.472"
0.460"
M12x1.5
0.196"
Front view
Fig. 3
Front view
0.118"
0.118"
0.137"
0.952"
0.137"
Fig. 5
Front view
Fig. 6
Plug - UTS6
0.996"
0.165"
0.708"
0.137"
Fig. 4
0.952"
0.118"
Ø0.472"
Ø0.472"
0.708"
Ø0.472"
0.708"
0.145"
mini
Fig. 7
2.405"
Ø0.885"
UTS0
UTS7
2.126"
2.622"
Fig. 8
Panel Cut Out
0.035"
Front mounting
Ø0.492"
0.602"
Rear mounting
Ø0.570"
0.574"
Ø0.122"
Ø0.866"
15°
Hole size:
0.035"
15°
Ø0.157"
Ø0.531"
0.074"
0.541"
0.602"
Ø0.129"
Drilling Pattern
Ø0.696"
0.062"
0.062"
41
Accessories
IP68/69K
IP68/69K
Metal terminal
IP68/69K
Metal terminal
IP40
Part number
Part number
Part number
Part number
UTS8DCG
UTS8DCGR
UTS8DCGE
UTS68C
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
42
Plug Protective Cap
Receptacle
cap
Plug cap
85005585A
85005594
Part numbers
UTFD11B
Part numbers
R for Red
Receptacles
Plugs
UTS78CCRR
UTS68CCRR
UTS78CCRY
UTS68CCRY
UTS78CCRG
UTS68CCRG
3 contacts
7A/250V
per UL 1977
Contacts
Contact type
Plating
Handsolder
3
22 to 18
0.196"
PCB
#20
UTS 8E3A/8D3A - 8E98/8D98 Derating Curves
Current (A)
18
UL
7A 250V UL94 HB
CSA
7A 250V UL94 HB
IEC
7A 50V 1.5kV 3
16
14
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
12
10
8
6
4
2
Current use
60
80
100
Limited use
120
Not recommended use
43
8E33/8D33 (Shell size 8, 3x#20)
Layout
OR
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 47
PCB
contacts loaded
see page 47
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 1)
UTS08E33P
UTS08E33S
Without (Fig. 7)
UTS68E33P
UTS68E33S
UTS6JC8E33P
UTS6JC8E33S
Jam nut
receptacle
Without (Fig. 4)
UTS78E33P
UTS78E33S
Without (Fig. 3)
UTS78E33PM12
UTS78E33SM12
Square flange
receptacle
Without (Fig. 2)
UTS08D33P
UTS08D33S
Jam nut receptacle
with stand off and
Without (Fig. 6)
UTS78D33P32
UTS78D33S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS78D33P
UTS78D33S
Without (Fig. 3)
UTS78D33PM12
UTS78D33SM12
Plug
44
Part number
Male insert
Sealed unmated
3 contacts
7A/250V
per UL 1977
Dimensions
0.814"
0.275"
mini
Ø0.125"
0.090"
3
0.866"
0.303"
0.342"
0.602"
Ø0.472"
Fig. 1
Ø0.472"
0.295"
0.460"
M12x1.5
0.196"
Front view
Fig. 2
Fig. 3
Front view
0.133"
0.133"
0.137"
0.165"
0.708"
0.952"
0.137"
Fig. 4
0.952"
0.133"
Ø0.472"
Ø0.472"
0.708"
Ø0.472"
0.708"
0.145"
mini
0.137"
Fig. 5
Front view
Fig. 6
Plug - UTS6
Fig. 7
2.405"
0.996"
Ø0.885"
UTS0
UTS7
2.622"
2.126"
Fig. 8
Panel Cut Out
Drilling Pattern
Ø0.122"
Ø0.866"
15°
Hole size:
0.035"
0.602"
Rear mounting
Ø0.570"
0.574"
15°
Ø0.157"
Ø0.531"
0.035"
Front mounting
Ø0.492"
0.541"
0.602"
0.074"
Ø0.129"
Ø0.696"
0.062"
0.062"
45
Accessories
IP68/69K
IP68/69K
Metal terminal
IP68/69K
Metal terminal
IP40
Part number
Part number
Part number
Part number
UTS8DCG
UTS8DCGR
UTS8DCGE
UTS68C
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
46
Plug Protective Cap
Receptacle
cap
Plug cap
85005585A
85005594
Part numbers
UTFD11B
Part numbers
R for Red
Receptacles
Plugs
UTS78CCRR
UTS68CCRR
UTS78CCRY
UTS68CCRY
UTS78CCRG
UTS68CCRG
3 contacts
7A/250V
per UL 1977
Contacts
Contact type
Plating
Handsolder
3
22 to 18
0.196"
PCB
#20
UTS 8E33/8D33 Derating Curves
Current (A)
18
UL
7A 250V UL94 HB
CSA
7A 250V UL94 HB
IEC
7A 50V 1.5kV 3
16
14
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
12
10
8
6
4
2
Current use
60
80
100
Limited use
120
Not recommended use
47
12E3/12D3 (Shell size 12, 3x#16)
Layout
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 51
PCB
contacts loaded
see page 51
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 6)
UTS012E3P
UTS012E3S
Without (Fig. 1)
UTS612E3P
UTS612E3S
Cable gland (Fig. 2)
UTS6JC12E3P
UTS6JC12E3S
Jam nut
receptacle
Without (Fig. 3)
UTS712E3P
UTS712E3S
Square flange
receptacle
Without (Fig. 7)
UTS012D3P
UTS012D3S
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS712D3P32
UTS712D3S32
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS712D3P
UTS712D3S
Plug
48
Part number
Male insert
Sealed unmated
3 contacts
13A/600V
per UL 1977
Dimensions
Plug - UTS6
0.996"
2.626"
Ø1.185"
3
Fig. 1
Fig. 2
0.118"
0.708"
0.118"
0.708"
0.137"
1.255"
0.137"
Fig. 3
1.070"
0.165"
Ø0.748"
0.185"
mini
Ø0.748"
Ø0.748"
0.118"
0.708"
0.137"
Fig. 4
Fig. 7
0.318"
0.444" 0.295" mini
Front view
Fig. 5
1.039"
3.055"
0.818"
Ø0.748"
UTS0
Fig. 6
3.216"
Ø0.125"
Front view
Panel Cut Out
Ø0.129"
Drilling Pattern
22°
Ø0.122"
68°
0.818"
Rear mounting
Ø0.877"
0.875"
Ø0.866"
0.393"
0.110"
0.826"
0.818"
Ø1.031"
Front mounting
Ø0.720"
Hole size:
0.051"
0.055"
0.090"
UTS7
Ø1.200"
0.090"
0.090"
30°
49
Accessories
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS12DCG
UTS12DCGR
UTS612DCG
UTS12DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
50
Receptacle
cap
Plug cap
85005587A
85005596
Part numbers
UTFD13B
Part numbers
R for Red
Receptacles
Plugs
UTS712CCRR
UTS612CCRR
UTS712CCRY
UTS612CCRY
UTS712CCRG
UTS612CCRG
3 contacts
13A/600V
per UL 1977
Contacts
Contact type
Plating
Handsolder
3
18 to 14
0.196"
PCB
#16
UTS 12E3/12D3 Derating Curves
Current (A)
UL
13A 600V UL94 HB
CSA
13A 600V UL94 HB
IEC
16A 150V 2.5kV 3
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
30
28
26
24
22
16
14
12
10
8
6
4
2
80
60
100
Current use
Limited use
120
Not recommended use
51
124 - 12E4/12D4 (Shell size 12, 3 + ground, 4x#16)
Layout
OR
WITH
Contact type
Crimp
contacts supplied
separately see page 55
Connector type
Backshell
Without (Fig. 1)
Jam nut receptacle
Without (Fig. 4)
Free hanging receptacle
Cable gland (Fig. 12)
Handsolder
electrical contacts
loaded see page 55
PCB
contacts loaded
see page 55
UTS7124S
UTS1JC124S
UTS6124S
UTS6JC124S
UTS7124SSCR
UTS6124SSCR
UTS6JC124SSCR
UTS7124S
UTS012E4S
UTS712E4S
UTS612E4S
UTS6JC12E4S
UTS012D4S
Plug
Cable gland (Fig. 11)
Without (Fig. 3)
Jam nut receptacle
with stand off and
Without (Fig. 9)
UTS712D4P
UTS712D4S
Jam nut receptacle
with stand off and
Without (Fig. 8)
UTS712D4P32
UTS712D4S32
Jam nut receptacle
PCB contacts supplied
Female insert
UTS0124P
UTS7124P
UTS1JC124P
UTS6124P
UTS6JC124P
UTS7124PSCR
UTS6124PSCR
UTS6JC124PSCR
UTS1JC124PSCR
UTS0124P
UTS7124P
UTS012E4P
UTS712E4P
UTS612E4P
UTS6JC12E4P
UTS012D4P
Plug
Screw
contacts loaded
Part number
Male insert
Plug
Without (Fig. 10)
Without (Fig. 6 & 7)
Without (Fig. 10)
Without (Fig. 3)
Jam nut receptacle
Without (Fig. 5)
Without (Fig. 2)
Jam nut receptacle
Without (Fig. 9)
Plug
Without (Fig. 10)
Sealed unmated
52
3 + ground
10A/500V
per UL 1977
Dimensions
0.318"
0.444"
0.295"
0.444"
0.295" mini
0.444"
0.295"
1.039"
0.090"
0.090"
0.090"
Fig. 1
0.818"
Ø0.748"
Ø0.748"
Ø0.748"
3+
Fig. 2
Ø0.125"
Front view
Fig. 3
Fig. 4
0.708"
Fig. 6
0.708"
0.094"
Fig. 8
0.708"
0.094"
Hold
down clip
1.255"
Ø0.748"
Ø0.748"
Ø0.748"
Male
1.070"
0.165"
Female
0.137"
0.137"
Fig. 5
0.137"
Fig. 7
Front view
Fig. 9
Free Hanging - UTS1 / Plug - UTS6
Fig. 10
0.118"
2.626" Fig. 11
3.055"
0.996"
Ø1.185"
UTS0
UTS7
3.216"
2.913"
Fig. 12
Ø0.129"
Drilling Pattern
22°
Ø0.122"
68°
0.818"
Rear mounting
Ø0.877"
0.875"
Ø0.866"
0.393"
0.122"
0.826"
0.818"
Ø1.031"
Front mounting
Ø0.720"
Hole size:
0.051"
0.122"
Panel Cut Out
Ø1.200"
0.122"
0.122"
30°
53
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS12DCG
UTS12DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS612DCG
UTS12DCGE
Contacts
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005587A
85005596
Part numbers
UTFD13B
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS712CCRR
UTS612CCRR
UTS712CCRY
UTS612CCRY
UTS712CCRG
UTS612CCRG
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
54
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
(1): Example of plating, for other plating options see p. 168
Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208.
Part number
of head
Contact size
Handle
Coaxial contacts available
see pages 167, 200 to 206
Head
Complete set
3 + ground
10A/500V
per UL 1977
Contacts for 124
#16
Wire size
Contact type
Crimp
Machined
contacts
PCB
Machined (3)
Coaxial
Cable Monocrimp
Part number
Fiber
optic
Handsolder
RC28M1K(1)
RC24M9K(1)
RC20M13K(1)
RC20M12K(1)
RC16M23K(1)
RC14M30K(1)
0.021"
0.039"
0.031"
0.062"
0.045"
0.070"
0.045"
0.086"
0.070"
0.125"
0.090"
0.125"
SC24M1TK6
SC20M1TK6(1)(2)
SC16M1TK6(1)(2)
SC16M11TK6(1)(2)
SC14M1TK6(1)(2)
0.035"-0.062"
0.047"-0.082"
0.125"
0.118"
0.125"
Male
Female
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
RM28M1K(1)
RM24M9K(1)
RM20M13K(1)
RM20M12K(1)
RM16M23K(1)
RM14M30K(1)
26-24
0.13-0.20
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
14
2.08
SM24M1TK6
SM20M1TK6(1)(2)
SM16M1TK6(1)(2)
SM16M11TK6(1)(2)
SM14M1TK6(1)(2)
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RMDX60xxD28
RMDXK10D28 +
york090
RMDX60xxD28
RCDXK1D28
RCDX60xxD28
RCDXK1D28 +
york090
RCDX60xxD28
RMPOF1000
RCPOF1000B
see pages 167,
200 to 206
POF contacts
Max
insulator Ø
mm²
Cable Multipiece
Max
wire Ø
AWG
(1)(2)
see page
170
14-18
2.08-0.80
(1)(2)
3+
(1): Example of plating, for other plating see page 168 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 168 Note: all dimensions are in inches
#16
Contact type
Plating
Handsolder
18 to 14
0.196"
PCB
Contacts for 12E4/12D4
UTS 124 - 12E4/12D4 Derating Curves
Current (A)
30
UTS 124
UL
10A 500V UL94 V-0
CSA
7A 500V UL94 V-0
UTS 12E4/12D4
UL
10A 500V UL94 HB
CSA
7A 500V UL94 HB
28
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
IEC
16A 300V 4kV 3
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
55
183G1 (Shell size 18, 3 + ground, 4x#8)
Layout
WITH
Contact type
Crimp
contacts supplied
separately
see page 59
separately see page 59
56
Connector type
Backshell
NPT 3/4" threaded
receptacle
Part number
Male insert
Female insert
Without (Fig. 1)
UTS7183G1SNPT
Plug
Without (Fig. 2)
UTS6183G1P
Plug
UTS6JC183G1P
NPT 3/4" threaded
receptacle
Without (Fig. 1)
UTS7183G1SNPT
Plug
Without (Fig. 2)
UTS6183G1P
3 + ground
44A/600V
per UL 1977
Dimensions
0.681"
0.570"
1.252"
Ø0.771"
Ø1.126"
3+
NPT - 3/4˝
Fig. 1
Plug - UTS6
3.200"
Fig. 2
Fig. 3
Ø1.653"
1.476"
Mated Connector Length - UTS6JC
3.563"
NPT
Drilling Pattern
0.200"
0.200"
0.200"
Panel cut
Hole size:
0.129"
1"
92 PT
N
4
3/
0.200"
0.
57
IP68/69K
Hand Tool
Metal terminal
IP68/69K
Part number
Part number
UTS18DCG
UTS18DCGR
Part number
M317
Plug Sealing Cap
IP68/69K
Part number
UTS618DCG
Gasket
Part number
VGE10078A
Extraction Tool #8
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005590A
85005599
Part numbers
UTFD16B
Color Coding Rings
G for Green
Y for
Yellow
58
Part numbers
R for Red
Receptacles
Plugs
UTS718CCRR
UTS618CCRR
UTS718CCRY
UTS618CCRY
UTS718CCRG
UTS618CCRG
Part number
51060210936
3 + ground
44A/600V
per UL 1977
Contacts
PCB
Crimp
#8
Contact type
Wire size
Part number
AWG
mm²
Male
Female
Max
wire Ø
16
1.31
82913601A
82913600A
0.067"
Machined
Machined (1)
14
2.08
82913603A
82913602A
0.087"
12
3.31
82913605A
82913604A
0.111"
10
5.26
82913607A
82913606A
0.137"
8
8.37
82913609A
82913608A
0.171"
82911685NPC
82911684NPC
Max
insulator Ø
3+
0.255"
UTS 183G1 Derating Curves
Current (A)
50
UL
44A 600V UL94 V-0
CSA
26A 600V UL94 V-0
IEC
32A 300V 4kV 3
45
40
Test
conditions
Contact used:
Machined contacts
Wires used:
6mm²
35
30
25
10
5
Current use
60
80
Limited use
100
120
Not recommended use
59
8E4/8D4 (Shell size 8, 4x#20)
Layout
OR
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 63
PCB
contacts loaded
see page 63
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 1)
UTS08E4P
UTS08E4S
Without (Fig. 7)
UTS68E4P
UTS68E4S
UTS6JC8E4P
UTS6JC8E4S
Jam nut
receptacle
Without (Fig. 4)
UTS78E4P
UTS78E4S
Without (Fig. 3)
UTS78E4PM12
UTS78E4SM12
Square flange
receptacle
Without (Fig. 2)
UTS08D4P
UTS08D4S
Jam nut receptacle
with stand off and
Without (Fig. 6)
UTS78D4P32
UTS78D4S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS78D4P
UTS78D4S
Plug
60
Part number
Male insert
Sealed unmated
4 contacts
7A/250V
per UL 1977
Dimensions
0.295" Fig. 1
0.814"
0.090"
Fig. 2
0.866"
0.303"
Ø0.472"
0.342"
0.602"
Ø0.472"
0.460"
0.275"
mini
Ø0.125"
4
M12x1.5
0.196"
Front view
Fig. 3
Front view
0.145"
mini
0.133"
0.133"
0.708"
0.708"
0.137"
0.952"
0.137"
0.137"
Fig. 4
Fig. 5
Front view
Fig. 6
Plug - UTS6
0.996"
0.165"
Ø0.472"
Ø0.472"
Ø0.472"
0.708"
0.952"
0.133"
Fig. 7
2.405"
Ø0.885"
UTS0
UTS7
2.622"
2.126"
Fig. 8
Panel Cut Out
Drilling Pattern
0.541"
0.602"
0.055"
Ø0.129"
Front mounting
Ø0.492"
0.602"
Rear mounting
Ø0.570"
0.574"
Ø0.122"
Ø0.866"
15°
Hole size:
0.035"
15°
Ø0.157"
Ø0.531"
0.055"
Ø0.696"
0.055"
0.055"
61
Accessories
IP68/69K
IP68/69K
Metal terminal
IP68/69K
Metal terminal
IP40
Part number
Part number
Part number
Part number
UTS8DCG
UTS8DCGR
UTS8DCGE
UTS68C
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
62
Plug Protective Cap
Receptacle
cap
Plug cap
85005585A
85005594
Part numbers
UTFD11B
Part numbers
R for Red
Receptacles
Plugs
UTS78CCRR
UTS68CCRR
UTS78CCRY
UTS68CCRY
UTS78CCRG
UTS68CCRG
4 contacts
7A/250V
per UL 1977
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts
4
UTS 8E4/8D4 Derating Curves
Current (A)
18
UL
7A 250V UL94 HB
CSA
7A 250V UL94 HB
IEC
7A 32V 1.5kV 3
16
14
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
12
10
8
6
4
2
Current use
60
80
100
Limited use
120
Not recommended use
63
102W2 (Shell size 10, 2x#20, 2x#12)
Layout
WITH
Contact type
Crimp
contacts supplied
separately
see page 67
64
Connector type
Backshell
Free hanging
receptacle
Part number
Male insert
Female insert
UTS1JC102W2P
UTS1JC102W2S
Plug
Without (Fig. 2)
UTS6102W2P
UTS6102W2S
Plug
UTS6JC102W2P
UTS6JC102W2S
Jam nut
receptacle
Without (Fig. 4)
UTS7102W2P
UTS7102W2S
4 contacts
20A/500V
per UL 1977
Dimensions
Free Hanging - UTS1
Ø0.594"
2.755"
4
Fig. 1
Plug - UTS6
0.996"
2.488"
Ø1.031"
Ø1.031"
1.299"
Fig. 2 Male
Fig. 2 Female
0.094"
1.070"
Ø0.594"
0.720"
Fig. 3
Fig. 4
3.043"
0.885"
Panel Cut Out
Drilling Pattern
0.118"
0.137"
0.686"
0.118"
0.118"
0.118"
0.651"
65
IP68/69K
Crimp Tooling #20
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS10DCG
UTS10DCGR
Shandles
Toolkit
Plug Sealing Cap
Extraction Tool #20
IP68/69K
Part number
Part number
UTS610DCG
RX20D44
Gasket
Contacts
Part number
of head
Contact size
RM/RC 24W3K(1)
RM/RC 20W3K(1)
RM/RC 18W3K(1)
SM/SC 24WL3(1)(2)
SM/SC 20WL3(1)(2)
S20RCM*
S20RCM*
S20RCM*
S20SCM20*
S20SCM20*
Standard contacts
#20
Ø 1.0 mm
(2): loose contact
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005586A
85005595
Part numbers
Handle
Head
Complete set
UTFD12B
Crimp Tooling #12
Extraction Tool #12
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS710CCRR
UTS610CCRR
UTS710CCRY
UTS610CCRY
UTS710CCRG
UTS610CCRG
Part number hand tool
M317
51060210924
Part number
positioner + locator setting
VGE10078A
66
Part number
extraction tool
4 contacts
20A/500V
per UL 1977
Contacts
#20
Contact type
Crimp
Machined
contacts
Wire size
Part number
AWG
mm²
Male
Female
Max
wire Ø
Max
insulator Ø
26-24
0.13-0.20
RM24W3K
RC24W3K
0.031"
0.062"
22-20
0.32-0.52
RM20W3K
RC20W3K
0.045"
0.062"
20-18
0.52-0.80
RM18W3K
RC18W3K
0.051"
0.082"
26-24
0.13-0.20
SM24W3TK6(1)(2)
SC24W3TK6(1)(2)
0.035"-0.062"
26-24
0.13-0.20
SM24W3S26
(1)(2)
SC24W3S25
0.035"-0.062"
22-20
0.32-0.52
SM20W3TK6(1)(2)
SC20W3TK6(1)(2)
0.047"-0.082"
22-20
0.32-0.52
SM20W3S26(1)(2)
SC20W3S25(1)(2)
0.047"-0.082"
22
0.32
82911457NA
82911456A
0.034"
(1)(2)
Crimp
#12
Machined
82911459NA
82911458A
0.044"
18
0.80
82911461NA
82911460A
0.055"
16
1.31
82911463NA
82911462A
0.067"
14
2.08
82911465NA
82911464A
0.087"
12
3.31
82911467NA
82911466A
0.111"
(2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6
0.192"
UTS 102W2 Derating Curves
Current (A)
50
UL
20A 500V UL94 V-0
CSA
18A 500V UL94 V-0
IEC
25A 150V 2.5kV 3
45
40
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
35
30
25
10
5
Current use
60
80
100
Limited use
120
Not recommended use
67
4
104 (Shell size 10, 4x#16)
Layout
OR
OR
OR
OR
WITH
Contact type
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 1)
UTS0104P
UTS0104S
Free hanging
receptacle
Cable gland and grommet*
(Fig. 2)
UTS1GJC104P
Free hanging
receptacle
Nut and grommet* (Fig. 3)
UTS1GN104P
Free hanging
receptacle
UTS1JC104P
UTS1JC104S
Plug
Without (Fig. 4)
UTS6104P
UTS6104S
Plug
(Fig. 5)
UTS6GJC104S
Plug
Nut and grommet* (Fig. 6)
UTS6GN104S
Crimp
contacts supplied
separately
see page 71
separately see page 71
Part number
Male insert
Plug
Cable gland (Fig. 5)
UTS6JC104P
UTS6JC104S
Jam nut
receptacle
Without (Fig. 7)
UTS7104P
UTS7104S
Jam nut
receptacle
(Fig. 9)
UTS7GJC104P
Jam nut
receptacle
Nut and grommet* (Fig. 8)
UTS7GN104P
Jam nut
receptacle
Without (Fig. 7)
UTS7104P
UTS7104S
* Grommet for discrete wire sealing
Overmolded Cable Assembly Part Numbers
Overmolding type
Overmolded harnesses, straight ending
Description
Wire size
Part number (length: 3 ft)*
D/E assembly 1 male plug & 1 female plug
16 AWG
UTS6V1004PS03FT00
S/E assembly 1 female plug
16 AWG
UTS6V1004S03FT00
S/E assembly 1 male plug
16 AWG
UTS6V1004P03FT00
* Other lengths available: 3, 6, 12 feet only: e.g. UTS6V1004PS06FT00 for a 6 feet version
68
4 contacts
10A/500V
per UL 1977
Dimensions
0.413"
Fig. 2
0.944"
0.090"
4
Ø0.125"
Fig. 1
2.755"
Ø0.594"
0.728"
Ø0.594"
0.444"
Free Hanging - UTS1
1.610"
Front view
Fig. 3
Plug - UTS6
1.299"
2.488"
1.279"
Ø1.031"
Male
Female
0.996"
Fig. 4
Fig. 5
Fig. 6
0.720"
1.614"
0.720"
2.791"
UTS0
Ø27.2
Ø0.594"
0.094"
Fig. 8
UTS7
0.137"
0.137"
Fig. 7
3.043"
2.783"
Fig. 9
Panel Cut Out
Drilling Pattern
Hole size:
0.051"
Front mounting
Ø0.598"
0.728"
Rear mounting
Ø0.704"
Note: Overmolded cable assembly dimensions available page 179.
0.118" 0.118"
0.651"
0.728"
Ø0.129"
0.686"
0.118" 0.118"
69
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS10DCG
UTS10DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS610DCG
UTS10DCGE
Contacts
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005586A
85005595
Part numbers
UTFD12B
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS710CCRR
UTS610CCRR
UTS710CCRY
UTS610CCRY
UTS710CCRG
UTS610CCRG
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
70
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
Part number
of head
Contact size
Handle
Head
Complete set
4 contacts
10A/500V
per UL 1977
Contacts
#16
Crimp
Machined
contacts
PCB
Wire size
Contact type
Part number
Coaxial
Max
wire Ø
Max
insulator Ø
RM28M1K(1)
RC28M1K(1)
0.021"
0.039"
RM24M9K
RC24M9K
0.031"
0.062"
RM20M13K(1)
RC20M13K(1)
0.045"
0.070"
RM20M12K
(1)
RC20M12K
0.045"
0.086"
RM16M23K(1)
RC16M23K(1)
0.070"
0.125"
RM14M30K
RC14M30K
0.090"
0.125"
SC24M1TK6(1)(2)
0.035"-0.062"
SM20M1TK6(1)(2)
SC20M1TK6(1)(2)
0.047"-0.082"
0.125"
0.118"
(1)(2)
mm²
Male
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.50
16-14
1.31-2.08
26-24
0.13-0.20
SM24M1TK6(1)(2)
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
Machined (3)
14
2.08
Cable Multipiece
Cable Monocrimp
see pages 167,
200 to 206
Fiber
optic
Female
AWG
POF contacts
see page
170
(1)
(1)
(1)
(1)
(1)
SM16M1TK6
SC16M1TK6
SM16M11TK6(1)(2)
SC16M11TK6(1)(2)
SM14M1TK6
SC14M1TK6
0.125"
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RCDXK1D28
RMDX60xxD28
RCDX60xxD28
RMDXK10D28 +
york090
RCDXK1D28 +
york090
RMDX60xxD28
RCDX60xxD28
RMPOF1000
RCPOF1000B
(1)(2)
(1)(2)
(1)(2)
4
UTS 104 Derating Curves
Current (A)
30
UL
10A 500V UL94 V-0
CSA
7A 500V UL94 V-0
IEC
13A 150V 2.5kV 3
28
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
71
14E5/14D5 (Shell size 14, 5x#16)
Layout
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 75
PCB
contacts loaded
see page 75
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 6)
UTS014E5P
UTS014E5S
Without (Fig. 1)
UTS614E5P
UTS614E5S
UTS6JC14E5P
UTS6JC14E5S
Jam nut
receptacle
Without (Fig. 3)
UTS714E5P
UTS714E5S
Square flange
receptacle
Without (Fig. 6)
UTS014D5P
UTS014D5S
Jam nut receptacle
Without (Fig. 5)
UTS714D5P32
UTS714D5S32
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS714D5P
UTS714D5S
Plug
72
Part number
Male insert
Sealed unmated
5 contacts
12A/600V
per UL 1977
Dimensions
Plug - UTS6
0.996"
Ø1.381"
2.755"
Fig. 1
5
Fig. 2
0.188"
mini
0.118"
0.118"
0.137"
Fig. 3
0.708"
1.381"
0.137"
0.137"
Fig. 4
1.133"
2.952"
0.913"
Ø0.877"
0.444"
Front view
Fig. 5
0.318"
0.295" mini
0.165"
Ø0.877"
Ø0.877"
0.708"
Ø0.877"
0.708"
1.196"
0.118"
UTS0
UTS7
3.228"
Ø0.125"
Fig. 6
Front view
Panel Cut Out
Ø0.129"
Drilling Pattern
22°
Ø0.122"
68°
0.950"
0.913"
Rear mounting
Ø0.988"
Ø0.866"
0.393"
1.005"
0.145"
0.913"
Ø1.031"
Front mounting
Ø0.846"
Hole sizes:
0.051"
0.023"
0.098"
0.090"
Ø1.200"
0.157"
0.090"
30°
73
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
UTS614DCG
UTS14DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
74
Receptacle
cap
Plug cap
85005588A
85005597
Part numbers
UTFD14B
Part numbers
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
5 contacts
12A/600V
per UL 1977
#16
Contact type
Plating
Handsolder
18 to 14
0.196"
PCB
Contacts
5
UTS 14E5/14D5 Derating Curves
Current (A)
30
UL
12A 600V UL94 HB
CSA
12A 600V UL94 HB
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
IEC
16A 150V 2.5kV 3
10
5
Current use
60
80
100
Limited use
120
Not recommended use
75
18X2M3 (Shell size 18, 3x#16, 2x#8)
Layout
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 79
separately see page 79
76
Connector type
Backshell
NPT 3/4" threaded
receptacle
Part number
Male insert
Female insert
Without (Fig. 1)
UTS718X2M3PNPT
UTS718X2M3SNPT
Plug
Without (Fig. 2)
UTS618X2M3P
UTS618X2M3S
Plug
UTS6JC18X2M3P
UTS6JC18X2M3S
NPT 3/4" threaded
receptacle
Without (Fig. 1)
UTS718X2M3PNPT
UTS718X2M3SNPT
5 contacts
44A/600V
per UL 1977
Dimensions
0.566"
1.252"
1.252"
Ø1.122"
Ø0.767"
0.677"
NPT - 3/4˝
5
Fig. 1
Plug - UTS6
3.200"
Ø1.563"
Ø0.846"
1.460"
Fig. 2
Fig. 3
3.563"
Panel cut
NPT
21
9
PT
#16
Hole sizes:
0.051"
0.232"
#8
Hole sizes:
0.129"
/4
-3
N
0.255"
0.
Drilling Pattern
77
IP68/69K
Crimp Tooling #16
Metal terminal
IP68/69K
Part number
Part number
UTS18DCG
UTS18DCGR
Part number
Part number
Shandles
Toolkit
RX2025GE1
Plug Sealing Cap
Dummy Contact #16
Contacts
IP68/69K
Part number
UTS618DCG
SMSPKE0
See page 208 for more information
Extraction Tool
RX2025GE1
51060210936
Part numbers
Receptacle
cap
Plug cap
85005590A
85005599
Part numbers
# 16
#8
RX2025GE1
51060210936
Y for
Yellow
78
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
Part numbers
R for Red
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
Coaxial contacts
M10S1J
with die set
& stop bushing
see page
202 to 205
Color Coding Rings
G for Green
Part number
of head
Contact size
Receptacles
Plugs
UTS718CCRR
UTS618CCRR
UTS718CCRY
UTS618CCRY
UTS718CCRG
UTS618CCRG
Crimp Tooling #8
Part number
M317
VGE10078A
5 contacts
44A/600V
per UL 1977
Contacts
#16
Contact type
Crimp
Machined
contacts
PCB
Machined (3)
Coaxial
Cable Monocrimp
Wire size
AWG
Part number
RC28M1K
RC24M9K
RC20M13K
RC20M12K
RC16M23K
RC14M30K
0.021"
0.039"
0.031"
0.062"
0.045"
0.070"
0.045"
0.086"
0.070"
0.125"
0.090"
0.125"
SC24M1TK6(1)(2)
SC20M1TK6(1)(2)
SC16M1TK6(1)(2)
SC16M11TK6(1)(2)
SC14M1TK6(1)(2)
0.035"-0.062"
0.047"-0.082"
0.125"
0.118"
0.125"
Female
RM28M1K
RM24M9K
RM20M13K
RM20M12K
RM16M23K
RM14M30K
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
26-24
0.13-0.20
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
14
2.08
SM24M1TK6(1)(2)
SM20M1TK6(1)(2)
SM16M1TK6(1)(2)
SM16M11TK6(1)(2)
SM14M1TK6(1)(2)
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RMDX60xxD28
RMDXK10D28 +
york090
RMDX60xxD28
RCDXK1D28
RCDX60xxD28
RCDXK1D28 +
york090
RCDX60xxD28
RMPOF1000
RCPOF1000B
see pages 167,
200 to 206
Fiber
optic
Max
insulator Ø
Male
Cable Multipiece
Max
wire Ø
mm²
POF contacts
see page
170
PCB
Crimp
#8
Machined
Machined (3)
16
1.31
82913601A
82913600A
0.067"
14
2.08
82913603A
82913602A
0.087"
12
3.31
82913605A
82913604A
0.111"
10
5.26
82913607A
82913606A
0.137"
8
8.37
82913609A
82913608A
0.171"
82911685NPC(1)
82911684NPC(1)
0.255"
UTS 18X2M3 Derating Curves
Current (A)
50
UL
44A 600V UL94 V-0
CSA
34A 600V UL94 V-0
IEC
32A 300V 4kV 3
45
40
Test
conditions
Contact used:
Machined contacts
Wires used:
8.37mm²
35
30
25
10
5
Current use
60
80
Limited use
100
120
Not recommended use
79
5
103W3 (Shell size 10, 3x#20, 3x#16)
Layout
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 83
PCB
contacts supplied
separately
see page 83
80
Connector type
Backshell
Free hanging
receptacle
Part number
Male insert
Female insert
UTS1JC103W3P
UTS1JC103W3S
Plug
Without (Fig. 2)
UTS6103W3P
UTS6103W3S
Plug
UTS6JC103W3P
UTS6JC103W3S
Jam nut
receptacle
Without (Fig. 4)
UTS7103W3P
UTS7103W3S
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS7103W3P
UTS7103W3S
6 contacts
10A/500V
per UL 1977
Dimensions
Free Hanging - UTS1
Ø0.594"
2.755"
Fig. 1
Plug - UTS6
6
0.996"
2.488"
Ø1.031"
Ø1.031"
1.299"
Fig. 2 Male
Fig. 2 Female
0.094"
1.070"
Ø0.594"
0.720"
Fig. 3
3.043"
Fig. 4
0.885"
Drilling Pattern
Hole sizes:
#20:0.035"
#16:0.051"
0.027"
0.651"
0.098"
Panel Cut Out
0.031"
0.137"
0.686"
0.118"
0.098"
81
IP68/69K
Part number
Part number
Part number
Part number
UTS10DCG
UTS10DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Part number
UTS610DCG
UTS10DCGE
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005586A
85005595
Part numbers
UTFD12B
Color Coding Rings
G for Green
Part numbers
R for Red
Crimp Tooling
Metal terminal
IP68/69K
Part number
Receptacles
Plugs
UTS710CCRR
UTS610CCRR
UTS710CCRY
UTS610CCRY
UTS710CCRG
UTS610CCRG
82
Tool Kit
Metal terminal
IP68/69K
Y for
Yellow
Handle
Contacts
RM/RC 28M1K
RM/RC 24M9K
RM/RC 20M13K
RM/RC 20M12K
RM/RC 16M23K
RM/RC 14M30K
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28
RCDXK1D28
RMDX60xxD28
RCDX60xxD28
RM/RC DXK10D28 +
york090
RM/RC 24W3K(1)
RM/RC 20W3K(1)
RM/RC 18W3K(1)
SM/SC 24WL3S
SM/SC 20WL3S
Contact size
Standard contacts
#16
Ø 1.6 mm
Coaxial contacts
Standard contacts
#20
Ø 1.0 mm
*: Heads to be used with handle PN: shandles
Part number
of head
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
M10S1J
with die set
& stop bushing
see page
202 to 205
S20RCM*
S20RCM*
S20RCM*
S20SCM20*
S20SCM20*
6 contacts
10A/500V
per UL 1977
Contacts
Contact type
PCB
Part number
mm²
Machined
30-28
26-24
22-20
22-20
20-16
16-14
Max
insulator Ø
0.021"
0.031"
0.045"
0.045"
0.070"
0.090"
0.039"
0.062"
0.070"
0.086"
0.125"
0.125"
SC24M1TK6(1)(2)
SC20M1TK6(1)(2)
SC16M1TK6(1)(2)
SC16M11TK6(1)(2)
SC14M1TK6(1)(2)
0.035"-0.062"
0.047"-0.082"
0.125"
0.118"
0.125"
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RMDX60xxD28
RMDXK10D28 +
york090
RMDX60xxD28
RCDXK1D28
RCDX60xxD28
RCDXK1D28 +
york090
RCDX60xxD28
RMPOF1000
RCPOF1000B
0.50-0.08
0.13-0.20
0.32-0.52
0.32-0.52
0.52-1.50
1.31-2.08
Female
RC28M1K
RC24M9K
RC20M13K
RC20M12K
RC16M23K
RC14M30K
Stamped & Formed reeled contacts
26-24
22-20
18-16
18-16
14
0.13-0.20
0.32-0.52
0.80-1.31
0.80-1.31
2.08
SM24M1TK6(1)(2)
SM20M1TK6(1)(2)
SM16M1TK6(1)(2)
SM16M11TK6(1)(2)
SM14M1TK6(1)(2)
Machined (3)
Cable Multipiece
Cable Monocrimp
see pages 167,
200 to 206
Fiber
optic
Max
wire Ø
Male
RM28M1K
RM24M9K
RM20M13K
RM20M12K
RM16M23K
RM14M30K
Coaxial
Wire size
AWG
Crimp
#16
see page
170
POF contacts
6
#20
Crimp
Machined
PCB
Machined (3)
26-24
0.13-0.20
RM24W3K(1)
RC24W3K(1)
0.031"
0.062"
22-20
0.32-0.52
RM20W3K
(1)
RC20W3K
0.045"
0.062"
20-18
0.50-0.93
RM18W3K(1)
RC18W3K(1)
0.051"
0.082"
26-24
0.13-0.20
SM24W3TK6(2)
SC24W3TK6(2)
0.035"-0.062"
26-24
0.13-0.20
SM24W3S26(2)
SC24W3S25(2)
0.035"-0.062"
22-20
0.32-0.52
SM20W3TK6
SC20W3TK65
0.047"-0.082"
22-20
0.32-0.52
SM20W3S26(2)
SC20W3S25(2)
0.047"-0.082"
RMW5016K
RCW5016K
(1)
(2)
(2)
UTS 103W3 Derating Curves
Current (A)
UL
10A 500V UL94 V-0
CSA
7A 500V UL94 V-0
IEC
5A 32V 1.5kV 3
30
28
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
0.518mm²
25
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
83
106 - 10E6/10D6 (Shell size 10, 6x#20)
Layout
OR
OR
OR
OR
WITH
Contact type
Crimp contacts
supplied separately
see page 87
separately see page 87
Handsolder
electrical contacts
loaded see page 87
Handsolder
electrical contacts
loaded see page 87
PCB
contacts loaded
see page 87
Connector type
Backshell
Female insert
UTS1JC106S
UTS6106S
UTS6JC106S
UTS7106S
Plug
Without (Fig. 2)
Plug
Jam nut receptacle
Without (Fig. 4)
UTS1JC106P
UTS6106P
UTS6JC106P
UTS7106P
Jam nut receptacle
Without (Fig. 4)
UTS7106P
UTS7106S
Without (Fig. 10)
UTS010E6S
UTS610E6S
UTS6JC10E6S
UTS710E6S
UTS710E6SM16
Jam nut receptacle
Without (Fig. 5)
UTS010E6P
UTS610E6P
UTS6JC10E6P
UTS710E6P
M16 threaded
receptacle
Without (Fig. 8)
UTS710E6PM16
Without (Fig. 9)
UTS010D6P
UTS010D6S
Jam nut receptacle
with stand off and
Without (Fig. 7)
UTS710D6P32
UTS710D6S32
Jam nut receptacle
with stand off and
Without (Fig. 6)
UTS710D6P
UTS710D6S
Plug
84
Part number
Male insert
Without (Fig. 2)
Sealed unmated
6 contacts
6A/250V
per UL 1977
Dimensions
Free Hanging - UTS1
Plug - UTS6
1.299"
2.755"
2.488"
Ø1.031"
Ø0.594"
Male
Female
0.996"
Fig. 1
Fig. 2
M16 Threaded Receptacle - UTS7
0.094"
0.720"
1.070"
0.118"
M16x0.059"
0.137"
0.165"
Fig. 7
Fig. 5
Front view
Fig. 9
0.295" 0.318"
0.444"
mini
Fig. 8
2.791"
UTS0
UTS7
3.043"
Ø0.125"
Front view
Panel Cut Out
Ø0.129"
Drilling Pattern
Jam nut receptacle
UTS7
M16
Chf.45°x0.104"
Ø0.122"
59
x0
.0
16
Hole size:
0.035"
15°
Ø0.531"
Ø0.157"
0.129"
Rear
mounting
Ø0.704"
68
0.
15°
M
Front
mounting
Ø0.598"
6"
0.651"
0.728"
Ø0.696"
0.728"
Front view
Mated Connector Lengths
0.728"
Fig. 10
0.547"
0.944"
Ø0.594"
0.090"
0.944"
0.196"
0.062"
0.137"
0.846"
0.885"
mini
Ø0.594"
0.720"
0.185"
Ø0.594"
Fig. 4
Fig. 6
Fig. 3
Ø0.866"
0.771"
0.110"
85
6
Jam Nut or M16 Threaded Receptacle Sealing Caps
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS10DCG
UTS10DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS610DCG
UTS10DCGE
Gasket
Receptacle
cap
Plug cap
85005586A
85005595
Contacts
RM/RC
RM/RC
RM/RC
SM/SC
SM/SC
IP68/69K
Part numbers
Part numbers
UTFD12B
Part number
of head
Contact size
24W3K(1)
20W3K(1)
18W3K(1)
24WL3S
20WL3S
S20RCM*
S20RCM*
S20RCM*
S20SCM20*
S20SCM20*
Standard contacts
#20
Ø 1.0 mm
Handle
Head
Complete set
Color Coding Rings
G for Green
Y for
Yellow
86
Part numbers
R for Red
Receptacles
Plugs
UTS710CCRR
UTS610CCRR
UTS710CCRY
UTS610CCRY
UTS710CCRG
UTS610CCRG
Extraction Tool #20
Part number
RX20D44
6 contacts
6A/250V
per UL 1977
Contacts for 106
#20
Wire size
Contact type
Crimp
Machined
contacts
PCB
Part number
Female
Max
wire Ø
Max
insulator Ø
RM24W3K(1)
RC24W3K(1)
0.031"
0.062"
0.32-0.52
RM20W3K
(1)
RC20W3K
0.045"
0.062"
0.52-0.80
RM18W3K(1)
RC18W3K(1)
0.051"
0.082"
0.13-0.20
SM24W3TK6(2)
SC24W3TK6(2)
0.035"-0.062"
26-24
0.13-0.20
SM24W3S26
(2)
SC24W3S25
0.035"-0.062"
22-20
0.32-0.52
SM20W3TK6(2)
SC20W3TK6(2)
0.047"-0.082"
22-20
0.32-0.52
SM20W3S26
SC20W3S25
0.047"-0.082"
RMW5016K
RCW5016K
AWG
mm²
Male
26-24
0.13-0.20
22-20
20-18
26-24
Machined (3)
(1)
(2)
(2)
(2)
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts for 10E6/10D6
UTS 106 - 10E6/10D6 Derating Curves
Current (A)
UTS 106
UL
5A 250V UL94 V-0
UTS 10E6/10D6
UL
6A 250V UL94 HB
CSA
4A 250V UL94 V-0
CSA
6A 250V UL94 HB
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
IEC
7A 32V 1.5kV 3
Current use
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
60
80
100
Limited use
120
Not recommended use
87
6
10E98/10D98 (Shell size 10, 6x#20)
Layout
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 91
PCB
contacts loaded
see page 91
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 6)
UTS010E98P
UTS010E98S
Without (Fig. 1)
UTS610E98P
UTS610E98S
UTS6JC10E98P
UTS6JC10E98S
Jam nut
receptacle
Without (Fig. 3)
UTS710E98P
UTS710E98S
Square flange
receptacle
Without (Fig. 7)
UTS010D98P
UTS010D98S
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS710D98P32
UTS710D98S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS710D98P
UTS710D98S
Plug
88
Part number
Male insert
Sealed unmated
6 contacts
6A/250V
per UL 1977
Dimensions
Plug - UTS6
2.755"
Ø1.031"
0.996"
Fig. 1
Fig. 2
0.118"
0.165"
0.720"
0.137"
0.720"
0.137"
Fig. 3
0.137"
0.944"
2.791"
UTS0
0.728"
Ø0.594"
Fig. 6
UTS7
3.043"
Ø0.125"
Front view
Panel Cut Out
Drilling Pattern
Ø0.129"
22°
Ø0.122"
68°
Front mounting
Ø0.598"
0.728"
Rear mounting
Ø0.704"
0.686"
Ø0.531"
0.393"
0.110"
0.651"
0.728"
Ø0.696"
Hole size:
0.035"
0.129"
0.090"
Front view
Fig. 5
Fig. 4
Fig. 7
0.295"0.318"
0.444"
mini
6
0.881"
1.070"
Ø0.594"
Ø0.594"
Ø0.594"
0.720"
0.185"
mini
0.118"
0.118"
Ø0.866"
0.129"
0.062"
30°
89
IP68/69K
IP68/69K
Plug Protective Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS10DCG
UTS10DCGR
UTS610DCG
UTS10DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
90
Receptacle
cap
Plug cap
85005586A
85005595
Part numbers
UTFD12B
Part numbers
R for Red
Receptacles
Plugs
UTS710CCRR
UTS610CCRR
UTS710CCRY
UTS610CCRY
UTS710CCRG
UTS610CCRG
6 contacts
6A/250V
per UL 1977
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts
6
UTS 10E98/10D98 Derating Curves
Current (A)
UL
6A 250V UL94 HB
CSA
6A 250V UL94 HB
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
IEC
7A 50V 1.5kV 3
Current use
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
60
80
100
Limited use
120
Not recommended use
91
147 - 14E7/14D7 (Shell size 14, 6 + ground, 7x#16)
Layout
OR
OR
OR
OR
OR
WITH
Contact type
Backshell
Without (Fig. 1)
Cable gland and grommet* (Fig. 4)
Nut and grommet* (Fig. 5)
Part number
Male insert
Female insert
UTS0147S
UTS1JC147S
UTS6147S
UTS6GJC147S
UTS6GN147S
UTS6JC147S
UTS7147S
Jam nut receptacle
Nut and grommet* (Fig. 10)
UTS0147P
UTS1GJC147P
UTS1GN147P
UTS1JC147P
UTS6147P
UTS6JC147P
UTS7147P
UTS7GJC147P
UTS7GN147P
PCB
contacts supplied
separately see page 95
Jam nut receptacle with stand
off and hold down clips
Without (Fig. 12)
UTS7147PSEK9
Screw
contacts loaded
Jam nut receptacle
Without (Fig. 9)
Plug
UTS7147SSCR
UTS6JC147SSCR
UTS014E7S
UTS6JC14E7S
UTS714E7S
UTS014D7S
Crimp
contacts supplied
separately
see page 95
Plug
Without (Fig. 6)
Plug
Cable gland and grommet* (Fig. 7)
Plug
Plug
Jam nut receptacle
Without (Fig. 9)
Jam nut receptacle
Cable gland and grommet* (Fig. 11)
Handsolder
electrical contacts loaded
see page 95
Without (Fig. 3)
Plug
Jam nut receptacle
Without (Fig. 9)
Without (Fig. 2)
UTS7147PSCR
UTS1JC147PSCR
UTS6JC147PSCR
UTS014E7P
UTS6JC14E7P
UTS714E7P
UTS014D7P
PCB
contacts loaded
see page 95
Without (Fig. 12)
UTS714D7P32
UTS714D7S32
off and without hold down clips
Without (Fig. 12)
UTS714D7P
UTS714D7S
92
Connector type
Sealed unmated
6 + ground
10A/500V
per UL 1977
Dimensions
Fig. 2
0.444"
0.862"
0.444"
1.145"
1.133"
Female
0.913"
Ø0.877"
Ø0.877"
Male
0.413"
0.090"
0.090"
0.866"
Ø0.125"
Front view
Fig. 3
Fig. 1
Free Hanging - UTS1
Fig. 4
Plug - UTS6
3.090"
6+
Fig. 7
2.755"
1.299"
Ø0.877"
Ø1.381"
Male
Female
0.996"
1.692"
Fig. 6
Fig. 5
Fig. 10
1.929"
0.708"
2.952"
UTS0
Ø31.8
UTS7
0.165"
0.137"
Fig. 8
Ø0.877"
Fig. 9
0.708"
0.062"
1.259"
0.137"
0.118"
3.228"
2.783"
Fig. 11
Fig. 12
Panel Cut Out
Drilling Pattern
Hole size:
0.051"
Ø0.122"
Ø0.129"
Ø0.696"
Front mounting
Ø0.846"
0.913"
Rear mounting
Ø0.988"
1.005"
0.393"
0.204"
0.950"
0.913"
Ø0.531"
Ø0.866"
0.251"
0.125"
93
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS614DCG
UTS14DCGE
Contacts
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005588A
85005597
Part numbers
UTFD14B
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
94
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
Part number
of head
Contact size
Handle
Head
Complete set
6 + ground
10A/500V
per UL 1977
Contacts for 147
#16
Wire size
Contact type
Crimp
Machined
contacts
PCB
Machined (3)
Part number
Coaxial
0.021"
0.039"
0.031"
0.062"
0.045"
0.070"
0.045"
0.086"
0.070"
0.125"
0.090"
0.125"
SC24M1TK6
SC20M1TK6(1)(2)
SC16M1TK6(1)(2)
SC16M11TK6(1)(2)
SC14M1TK6(1)(2)
0.035"-0.062"
0.047"-0.082"
0.125"
0.118"
0.125"
Female
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
RM28M1K(1)
RM24M9K(1)
RM20M13K(1)
RM20M12K(1)
RM16M23K(1)
RM14M30K(1)
26-24
0.13-0.20
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
14
2.08
SM24M1TK6
SM20M1TK6(1)(2)
SM16M1TK6(1)(2)
SM16M11TK6(1)(2)
SM14M1TK6(1)(2)
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RMDX60xxD28
RMDXK10D28 +
york090
RMDX60xxD28
RCDXK1D28
RCDX60xxD28
RCDXK1D28 +
york090
RCDX60xxD28
RMPOF1000
RCPOF1000B
Fiber
optic
RC28M1K(1)
RC24M9K(1)
RC20M13K(1)
RC20M12K(1)
RC16M23K(1)
RC14M30K(1)
Male
see pages 167,
200 to 206
Max
insulator Ø
mm²
Cable Multipiece
Cable Monocrimp
Max
wire Ø
AWG
POF contacts
(1)(2)
see page
170
(1)(2)
6+
#16
Contact type
Plating
Handsolder
18 to 14
0.196"
PCB
Contacts for 14E7/14D7
UTS 147 - 14E7/14D7 Derating Curves
Current (A)
30
UTS 147
UL
10A 500V UL94 V-0
UTS 14E7/14D7
UL
10A 500V UL94 HB
CSA
7A 500V UL94 V-0
CSA
7A 500V UL94 HB
28
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
IEC
16A 300V 4kV 3
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
95
10E7/10D7 (Shell size 10, 7x#20)
Layout
OR
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 99
PCB
contacts loaded
see page 99
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 1)
UTS010E7P
UTS010E7S
Without (Fig. 2)
UTS610E7P
UTS610E7S
UTS6JC10E7P
UTS6JC10E7S
Jam nut
receptacle
Without (Fig. 4)
UTS710E7P
UTS710E7S
M16 threaded
receptacle
Without (Fig. 7)
Square flange
receptacle
Without (Fig. 1)
UTS010D7P
UTS010D7S
stand off and hold down
clips
Without (Fig. 5)
UTS710D7P32
UTS710D7S32
stand off and without hold
down clips
Without (Fig. 6)
UTS710D7P
UTS710D7S
Plug
96
Part number
Male insert
UTS710E7PM16
UTS710E7SM16
Sealed unmated
7 contacts
6A/250V
per UL 1977
Dimensions
0.444"
Plug - UTS6
0.944"
0.295"
0.996"
2.755"
0.090"
Ø1.031"
0.728"
Ø0.594"
0.318"
mini
Ø0.125"
Fig. 1
Fig. 2
Front view
Fig. 3
0.185"
0.118"
0.137"
0.137"
Fig. 4
Fig. 5
0.137"
0.165"
Front view
Fig. 6
0.846"
7
1.070"
Ø0.594"
0.720"
Ø0.594"
0.720"
Ø0.594"
0.720"
0.881"
0.118"
mini
0.944"
2.791"
Ø0.594"
UTS0
UTS7
0.196"
3.043"
Fig. 7
0.728"
Rear
mounting
Ø0.704"
Ø0.122"
Ø0.866"
15°
Hole size:
0.035"
15°
16
x0
.0
59
M16
Chf.45°x0.104"
M
86
6
0.
0.651"
0.728"
Front
mounting
Ø0.598"
Drilling Pattern
Jam nut receptacle
UTS7
0.062"
Panel Cut Out
Ø0.129"
Ø0.157"
Ø0.531"
0.129"
0.547"
M16x0.059"
Ø0.696"
0.771"
0.110"
97
IP68/69K
IP68/69K
Metal terminal
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS10DCG
UTS10DCGR
UTS610DCG
UTS10DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
98
Receptacle
cap
Plug cap
85005586A
85005595
Part numbers
UTFD12B
Part numbers
R for Red
Receptacles
Plugs
UTS710CCRR
UTS610CCRR
UTS710CCRY
UTS610CCRY
UTS710CCRG
UTS610CCRG
7 contacts
6A/250V
per UL 1977
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts
7
UTS 10E7/10D7 Derating Curves
Current (A)
UL
6A 250V UL94 HB
CSA
6A 250V UL94 HB
IEC
7A 50V 1.5kV 3
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
Current use
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
60
80
100
Limited use
120
Not recommended use
99
contacts loaded
see page
128 (Shell size 12, 8x#16)
Layout
OR
OR
OR
OR
OR
OR
WITH
Contact type
Connector type
Backshell
Female insert
Without (Fig. 1)
UTS0128P
UTS0128S
(Fig. 2)
UTS1GJC128P
UTS1GN128P
Gasket and nut (Fig. 8)
Gasket (Fig. 9)
UTS7128PM20NUT
UTS7128PM20
UTS7128SM20NUT
UTS7128SM20
UTS1JC128P
UTS1JC128S
Plug
Without (Fig. 10)
UTS6128P
UTS6128S
Plug
(Fig. 11)
UTS6GJC128S
Plug
Nut and grommet* (Fig. 12)
UTS6GN128S
Plug
UTS6JC128P
UTS6JC128S
Without (Fig. 4)
UTS7128P
UTS7128S
(Fig. 7)
UTS7GJC128P
UTS7GN128P
Without (Fig. 5)
UTS7128PSEK9
Square flange
receptacle
Free hanging
receptacle
Free hanging
receptacle
M20 threaded
receptacle
Crimp
contacts supplied
separately
see page 103
Part number
Male insert
Free hanging
receptacle
Jam nut
receptacle
Jam nut
receptacle
Jam nut
receptacle
PCB
contacts loaded see page 103 stand off and hold down clips
Overmolding type
Description
Wire size
16 AWG
UTS6V1208PS03FT00
16 AWG
UTS6V1208S03FT00
16 AWG
UTS6V1208P03FT00
* Other lengths available: 3, 6, 12 feet only: e.g. UTS6V128PS06FT00 for a 6 feet version
100
8 contacts
10A/500V
UTS Series | Connector
per UL 1977
Dimensions
0.712"
Fig. 2
0.818"
0.413"
0.090"
Fig. 1
Ø0.125"
2.933"
Ø0.751"
1.039"
Ø0.751"
0.444"
Free Hanging - UTS1
1.610"
Front view
Fig. 3
Jam Nut & M20 Threaded Receptacle - UTS7
0.062"
0.708"
1.933"
1.000"
Ø0.751"
8
0.165"
0.137"
0.137"
0.118"
0.767"
2.933"
Fig.7
Fig. 9
Plug - UTS6
1.259"
M20X0.059"
Fig. 11
2.586"
1.299"
1.063"
Ø1.255"
Fig. 4
Fig. 5
0.240"
Panel gasket
Fig. 8
Fig. 6
Ø0.751"
0.708"
3.055"
UTS0
Female
UTS7
0.996"
3.216"
1.299"
Fig. 12
Panel Cut Out
Drilling Pattern
Front mounting
Ø0.720"
0.818"
Rear mounting
Ø0.877"
0.078"
0.177" 0.157"
0.826"
0.818"
Ø0.129"
Hole size:
0.051"
0.035"
Fig. 10
0.110"
Ø1.185"
Male
0.875"
0.173"
0.133"
101
Jam Nut or M20 Threaded Receptacle Sealing Caps
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS12DCG
UTS12DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS612DCG
UTS12DCGE
Contacts
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005587A
85005596
Part numbers
UTFD13B
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS712CCRR
UTS612CCRR
UTS712CCRY
UTS612CCRY
UTS712CCRG
UTS612CCRG
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
102
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
Part number
of head
Contact size
Handle
Head
Complete set
8 contacts
10A/500V
per UL 1977
Contacts
#16
Contact type
Crimp
Machined
contacts
Part number
Female
Max
wire Ø
Max
insulator Ø
RM28M1K(1)
RC28M1K(1)
0.021"
0.039"
RM24M9K
RC24M9K
0.031"
0.062"
RM20M13K(1)
RC20M13K(1)
0.045"
0.070"
RM20M12K
(1)
RC20M12K
0.045"
0.086"
RM16M23K(1)
RC16M23K(1)
0.070"
0.125"
RM14M30K
RC14M30K
0.090"
0.125"
SC24M1TK6(1)(2)
0.035"-0.062"
SM20M1TK6(1)(2)
SC20M1TK6(1)(2)
0.047"-0.082"
0.125"
0.118"
(1)(2)
AWG
mm²
Male
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
26-24
0.13-0.20
SM24M1TK6(1)(2)
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
2.08
(1)
(1)
(1)
(1)
SM16M1TK6
SC16M1TK6
SM16M11TK6(1)(2)
SC16M11TK6(1)(2)
SM14M1TK6
SC14M1TK6
0.125"
RM20M12E83K(1)
RC20M12E84K(1)
(1)(2)
(1)(2)
(1)(2)
PCB
14
(1)
Machined (3)
Cable Multipiece
RMDXK10D28
RCDXK1D28
Coaxial
Wire size
Cable Monocrimp
RMDX60xxD28
RCDX60xxD28
RMDXK10D28 +
york090
RCDXK1D28 +
york090
RMDX60xxD28
RCDX60xxD28
RMPOF1000
RCPOF1000B
see pages 167,
200 to 206
Fiber
optic
POF contacts
see page
170
8
UTS 128 Derating Curves
Current (A)
30
UL
10A 500V UL94 V-0
CSA
7A 500V UL94 V-0
IEC
10A 80V 1.5kV 3
28
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
103
12E8/12D8 (Shell size 12, 8x#20)
Layout
OR
OR
WITH
Connector Part Numbers
Contact type
Handsolder
electrical contacts
loaded
see page 107
PCB
contacts loaded
see page 107
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 6)
UTS012E8P
UTS012E8S
Without (Fig. 1)
UTS612E8P
UTS612E8S
UTS6JC12E8P
UTS6JC12E8S
Jam nut
receptacle
Without (Fig. 3)
UTS712E8P
UTS712E8S
Square flange
receptacle
Without (Fig. 7)
UTS012D8P
UTS012D8S
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS712D8P32
UTS712D8S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS712D8P
UTS712D8S
Plug
104
Part number
Male insert
Sealed unmated
8 contacts
4.5A/250V
per UL 1977
Dimensions
Plug - UTS6
2.626"
Ø1.185"
0.996"
Fig. 1
Fig. 2
0.118"
0.122"
0.708"
0.137"
Fig. 3
8
0.137"
Fig. 4
Front view
Fig. 5
Fig. 7
0.444"
0.295" 0.318"
mini
1.070"
1.255"
Ø0.748"
Ø0.748"
0.137"
0.185"
mini
0.118"
0.165"
0.708"
Ø0.748"
0.708"
1.039"
3.055"
0.818"
Ø0.748"
UTS0
UTS7
3.216"
0.090"
Ø0.125"
Front view
Panel Cut Out
Square Flange Receptacle - UTS0
Drilling Pattern
Ø0.129"
22°
Ø0.122"
68°
0.062"
Front mounting
Ø0.720"
0.818"
Rear mounting
Ø0.877"
0.875"
0.393"
0.118"
0.169"
0.826"
0.818"
Ø1.031"
Ø0.866"
Hole sizes:
0.035"
0.043"
0.153"
Fig. 6
Ø1.200"
0.169"
0.118"
30°
105
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS12DCG
UTS12DCGR
UTS612DCG
UTS12DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005587A
85005596
106
Part numbers
UTFD13B
Part numbers
R for Red
Receptacles
Plugs
UTS712CCRR
UTS612CCRR
UTS712CCRY
UTS612CCRY
UTS712CCRG
UTS612CCRG
8 contacts
4.5A/250V
per UL 1977
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts
8
UTS 12E8/12D8 Derating Curves
Current (A)
UL
4.5A 250V UL94 HB
CSA
4.5A 250V UL94 HB
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
IEC
6A 32V 1.5kV 3
Current use
15
14
13
12
11
10
9
8
7
6
5
4
3
2
1
60
80
100
Limited use
120
Not recommended use
107
148 (Shell size 14, 4x#16, 4x#12)
Layout
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 111
108
Connector type
Backshell
Free hanging
receptacle
Part number
Male insert
Female insert
UTS1JC148P
UTS1JC148S
Plug
Without (Fig. 2)
UTS6148P
UTS6148S
Plug
UTS6JC148P
UTS6JC148S
Jam nut
receptacle
Without (Fig. 4)
UTS7148P
UTS7148S
8 contacts
25A/250V
per UL 1977
Dimensions
Free Hanging - UTS1
Ø1.381"
3.090"
Fig. 1
Plug - UTS6
2.815"
0.996"
Ø1.381"
Ø1.381"
1.299"
8
Fig. 2 Male
Fig. 2 Female
Jam Nut Receptacle - UTS7
0.484 "
1.381"
Ø0.877"
0.708"
Fig. 3
0.137"
3.228"
1.196"
Fig. 4
Drilling Pattern
0.102"
0.015"
0.011"
0.177"
0.950"
0.177"
1.005"
0.216"
0.200"
0.102"
0.122"
0.173"
0.007"
0.031"
0.137"
0.220"
Panel Cut Out
109
IP68/69K
Crimp Tooling #16
Metal terminal
IP68/69K
Part number
Part number
UTS14DCG
UTS14DCGR
Plug Sealing Cap
IP68/69K
Part number
UTS614DCG
UTS14DCGE
Plastic Protective Cap
Gasket
IP68/69K
Plug cap
85005588A
85005597
Part numbers
UTFD14B
Color Coding Rings
HEAD (without Shandles)
Contacts
Part number
of head
Contact size
RM/RC 28M1K
RM/RC 24M9K
RM/RC 20M13K
RM/RC 20M12K
Standard contacts
RM/RC 16M23K
RM/RC 14M30K
#16
SM/SC 24ML1TK6(1)
Ø 1.6 mm
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Part numbers
G for Green
Y for
Yellow
Toolkit
(without Head)
Metal terminal
Part number
Receptacle
cap
Shandles
Part number
Square Flange Sealing Cap
IP68/69K
Part numbers
Part number
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
Handle
Head
Complete set
Crimp Tooling #12
Extraction Tool
Part number
Extraction tool #12
Part number
Extraction tool #16
M317
RX2025GE1
110
M317
Part number
VGE10078A
8 contacts
25A/250V
per UL 1977
Contacts
#16
Contact type
Crimp
Machined
contacts
Wire size
Coaxial
Female
Max
wire Ø
Max
insulator Ø
RM28M1K(1)
RC28M1K(1)
0.021"
0.039"
RM24M9K
RC24M9K
0.031"
0.062"
RM20M13K(1)
RC20M13K(1)
0.045"
0.070"
RM20M12K
(1)
RC20M12K
0.045"
0.086"
RM16M23K(1)
RC16M23K(1)
0.070"
0.125"
RM14M30K
RC14M30K
0.090"
0.125"
SC24M1TK6(1)(2)
0.035"-0.062"
SM20M1TK6(1)(2)
SC20M1TK6(1)(2)
0.047"-0.082"
0.125"
0.118"
0.125"
AWG
mm²
Male
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
26-24
0.13-0.20
SM24M1TK6(1)(2)
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
14
2.08
(1)
(1)
(1)
(1)
(1)
SM16M1TK6
SC16M1TK6
SM16M11TK6(1)(2)
SC16M11TK6(1)(2)
SM14M1TK6
SC14M1TK6
(1)(2)
(1)(2)
(1)(2)
(1)(2)
Cable Multipiece
RMDXK10D28
RCDXK1D28
Cable Monocrimp
RMDX60xxD28
RCDX60xxD28
RMDXK10D28 +
york090
RCDXK1D28 +
york090
RMDX60xxD28
RCDX60xxD28
RMPOF1000
RCPOF1000B
see pages 167,
200 to 206
Fiber
optic
Part number
POF contacts
see page
170
8
Crimp
#12
Machined
22
0.32
82911457NA(1)
82911456A(1)
0.034"
82911459NA
(1)
82911458A
0.044"
0.80
82911461NA
(1)
82911460A
0.055"
16
1.31
82911463NA
(1)
(1)
82911462A
0.067"
14
2.08
82911465NA(1)
82911464A(1)
0.087"
3.31
82911467NA
82911466A
0.111"
18
12
(1)
(1)
(1)
(1)
Electrical Characteristics
0.192"
UTS 148 Derating Curves
Current (A)
45
UL
25A 250V UL94 V-0
CSA
17A 230V UL94 V-0
IEC
17A 230V 1.5kV 3
40
35
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
30
25
10
5
Current use
45
65
85
105
Ambient Operating Temperature (°C)
Limited use
125
Not recommended use
111
1210 - 12E10/12D10 (Shell size 12, 10x#20)
Layout
OR
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 115
Handsolder
electrical contacts
loaded
see page 115
PCB
contacts loaded
see page 115
Connector type
Backshell
Free hanging
receptacle
Female insert
Cable gland (Fig. 1)
UTS1JC1210P
UTS1JC1210S
Plug
Without (Fig. 2)
Plug
Cable gland (Fig. 3)
UTS61210P
UTS6JC1210P
UTS61210S
UTS6JC1210S
Jam nut
receptacle
Without (Fig. 4)
UTS71210P
UTS71210S
Without (Fig. 8)
UTS012E10S
UTS612E10S
UTS6JC12E10S
UTS712E10S
UTS012D10S
Jam nut receptacle
Without (Fig. 5)
Without (Fig. 8)
UTS012E10P
UTS612E10P
UTS6JC12E10P
UTS712E10P
UTS012D10P
Jam nut receptacle
with stand off and
with hold down clips
Without (Fig. 6)
UTS712D10P32
UTS712D10S32
Jam nut receptacle
with stand off and
Without (Fig. 7)
UTS712D10P
UTS712D10S
Plug
Possibilities of discrimination/keying methods see page 208
112
Part number
Male insert
Without (Fig. 2)
Sealed unmated
10 contacts
5A/250V
per UL 1977
Dimensions
Free Hanging - UTS1
Plug - UTS6
2.913"
2.626"
1.299"
Ø1.185"
Ø0.751"
Male
Female
0.996"
Fig. 1
Fig. 3
Fig. 2
0.708"
0.137"
Fig. 5
0.118"
0.708"
0.444"
1.070"
1.255"
0.137"
Fig. 6
0.137"
Fig. 7
0.318"
0.295" mini
0.185"
mini
0.118"
0.165"
Ø0.751"
Ø0.751"
0.708"
0.122"
0.484"
Ø0.751"
Fig. 4
10
Front view
1.039"
3.055"
0.818"
Ø0.751"
UTS0
UTS7
3.216"
Fig. 8
Ø0.125"
Front view
Panel Cut Out
Ø0.129"
Drilling Pattern
22°
Ø0.122"
Hole size:
0.035"
68°
0.118"
0.090"
0.826"
0.818"
Ø1.031"
Front mounting
Ø0.720"
0.818"
Rear mounting
Ø0.877"
Ø0.866"
0.393"
Ø1.200"
0.875"
0.062"
0.129"
0.192"
30°
113
Accessories and Tooling
Jam Nut Sealing Caps
IP68/69K
Handle (without Head)
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS12DCG
UTS12DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS612DCG
UTS12DCGE
Gasket
Receptacle
cap
Plug cap
85005587A
85005596
Contacts
RM/RC
RM/RC
RM/RC
SM/SC
SM/SC
IP68/69K
Part numbers
Crimp Tooling (without Shandles)
Part numbers
UTFD13B
Part number
of head
Contact size
24W3K(1)
20W3K(1)
18W3K(1)
24WL3S
20WL3S
S20RCM*
S20RCM*
S20RCM*
S20SCM20*
S20SCM20*
Standard contacts
#20
Ø 1.0 mm
Handle
Head
Complete set
Color Coding Rings
G for Green
Y for
Yellow
114
Part numbers
R for Red
Extraction Tool #20
Receptacles
Plugs
UTS712CCRR
UTS612CCRR
UTS712CCRY
UTS612CCRY
Part number
UTS712CCRG
UTS612CCRG
RX20D44
10 contacts
5A/250V
per UL 1977
Contacts for 1210
#20
Wire size
Contact type
Crimp
Machined
contacts
Female
Max
wire Ø
Max
insulator Ø
RM24W3K(1)
RC24W3K(1)
0.031"
0.062"
0.32-0.52
RM20W3K
(1)
RC20W3K
0.045"
0.062"
0.50-0.80
RM18W3K(1)
RC18W3K(1)
0.051"
0.082"
0.13-0.20
SM24W3TK6(2)
SC24W3TK6(2)
0.035"-0.062"
0.13-0.20
SM24W3S26
SC24W3S25(2)
0.035"-0.062"
22-20
0.32-0.52
SM20W3TK6
(2)
SC20W3TK6
0.047"-0.082"
22-20
0.32-0.52
SM20W3S26(2)
SC20W3S25(2)
0.047"-0.082"
AWG
mm²
Male
26-24
0.13-0.20
22-20
20-18
26-24
26-24
See note (2) for loose piece
Part number
(1)
(2)
(2)
(1): Example of plating, for other plating see page 164
#20
Contact type
Plating
Cable acceptance (AWG)
Wire stripping length
Handsolder
Loaded in the connector
Min 0.4µ gold over 0.8µ Ni
22 to 18
0.196"
PCB
Contacts for 12E10/12D10
Machined, loaded in the connector (1)
(1): For dimensions see page 169
10
UTS 1210 - 12E10/12D10 Derating Curves
Current (A)
13
UTS 1210
UL
5A 250V UL94 V-0
CSA
4A 250V UL94 V-0
UTS 12E10/12D10
UL
4.5A 250V UL94 HB
CSA
4.5A 250V UL94 HB
IEC
6A 50V 1.5kV 3
12
11
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
10
9
8
7
6
5
4
3
2
1
Current use
60
80
100
Limited use
120
Not recommended use
115
1412 (Shell size 14, 12x#16)
Layout
OR
OR
OR
OR
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 119
PCB
contacts supplied
separately
see page 119
Connector type
Backshell
Square flange
receptacle
Part number
Male insert
Female insert
Without (Fig. 1)
UTS01412P
UTS01412S
Free hanging
receptacle
(Fig. 2)
UTS1GJC1412P
Free hanging
receptacle
UTS1GN1412P
Free hanging
receptacle
UTS1JC1412P
UTS1JC1412S
Plug
Without (Fig. 4)
UTS61412P
UTS61412S
Plug
(Fig. 5)
UTS6GJC1412S
Plug
UTS6GN1412S
Plug
UTS6JC1412P
UTS6JC1412S
Jam nut receptacle
Without (Fig. 7)
UTS71412P
UTS71412S
Jam nut receptacle
(Fig. 9)
UTS7GJC1412P
Jam nut receptacle
UTS7GN1412P
Square flange
receptacle
Without (Fig. 1)
UTS01412P
UTS01412S
Jam nut receptacle
Without (Fig. 7)
UTS71412P
UTS71412S
Overmolding type
Description
Wire size
16 AWG
UTS6V1412PS03FT00
16 AWG
UTS6V1412S03FT00
16 AWG
UTS6V1412P03FT00
* Other lengths available: 3, 6, 12 feet only: e.g. UTS6V1412PS06FT00 for a 6 feet version
116
12 contacts
10A/500V
per UL 1977
Dimensions
0.444"
Free Hanging - UTS1
Fig. 2
1.133"
0.862"
3.090"
Female
0.413"
0.090"
Fig. 1
Ø0.877"
0.913"
Ø0.877"
Male
Ø0.125"
1.692"
Front view
Fig. 3
Plug - UTS6
1.299"
2.755"
1.259"
Fig. 5
Fig. 6
Ø1.381"
Male
Female
0.996"
Fig. 4
1.929"
0.708"
12
2.952"
UTS0
Ø0.877"
0.062"
UTS7
0.137"
3.228"
2.783"
Fig. 9
Drilling Pattern
0.913"
Rear mounting
Ø0.988"
1.005"
0.200" Hole size:
0.051"
0.055"
0.011"
0.086"
0.149"
0.114"
0.078"
0.086"
Front mounting
Ø0.846"
0.232"
0.913"
0.950"
0.216"
Panel Cut Out
Ø0.129"
0.177"
Fig. 7
0.039"
0.137"
0.039"
Ø0.877"
0.708"
Fig. 8
0.027"
0.228"
117
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS614DCG
UTS14DCGE
Contacts
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005588A
85005597
Part numbers
UTFD14B
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
118
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
(1): Example of plating, for other plating options see page 164
* Heads to be used with handle PN: SHANDLES
Part number
of head
Contact size
Handle
Head
Complete set
12 contacts
10A/500V
per UL 1977
Contacts
#16
Contact type
Crimp
Machined
contacts
PCB
Wire size
Part number
Coaxial
Max
wire Ø
Max
insulator Ø
RM28M1K(1)
RC28M1K(1)
0.021"
0.039"
RM24M9K
RC24M9K
0.031"
0.062"
RM20M13K(1)
RC20M13K(1)
0.045"
0.070"
RM20M12K
(1)
RC20M12K
0.045"
0.086"
RM16M23K(1)
RC16M23K(1)
0.070"
0.125"
RM14M30K
RC14M30K
0.090"
0.125"
SC24M1TK6(1)(2)
0.035"-0.062"
SM20M1TK6(1)(2)
SC20M1TK6(1)(2)
0.047"-0.082"
0.125"
0.118"
(1)(2)
mm²
Male
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
26-24
0.13-0.20
SM24M1TK6(1)(2)
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
Machined (3)
14
2.08
Cable Multipiece
Cable Monocrimp
Twisted pair Multipiece
see pages 167,
200 to 206
Twisted pair Monocrimp
Fiber
optic
Female
AWG
POF contacts
(Plastic Optical Fiber)
see page
170
(1)
(1)
(1)
(1)
(1)
SM16M1TK6
SC16M1TK6
SM16M11TK6(1)(2)
SC16M11TK6(1)(2)
SM14M1TK6
SC14M1TK6
0.125"
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RCDXK1D28
RMDX60xxD28
RCDX60xxD28
RMDXK10D28 +
york090
RCDXK1D28 +
york090
RMDX60xxD28
RCDX60xxD28
RMPOF1000
RCPOF1000B
(1)(2)
(1)(2)
(1)(2)
(3): For dimensions see page 172
UTS 1412 Derating Curves
Current (A)
30
UL
10A 500V UL94 V-0
CSA
7A 500V UL94 V-0
IEC
10A 63V 1.5kV 3
28
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
119
12
14E12/14D12 (Shell size 14, 8x#20, 4x#16)
Layout
OR
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 123
PCB
contacts loaded
see page 123
Connector type
Backshell
Square flange
receptacle
Without (Fig. 6)
Female insert
UTS014E12P
UTS014E12S
Without (Fig. 1)
UTS614E12P
UTS614E12S
UTS6JC14E12P
UTS6JC14E12S
Jam nut
receptacle
Without (Fig. 3)
UTS714E12P
UTS714E12S
Square flange
receptacle
Without (Fig. 6)
UTS014D12P
UTS014D12S
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS714D12P32
UTS714D12S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS714D12P
UTS714D12S
Plug
120
Part number
Male insert
Sealed unmated
12 contacts
4.5A/250V
per UL 1977
Dimensions
Plug - UTS6
2.755"
Ø1.381"
0.996"
Fig. 1
Fig. 2
0.118"
0.118"
0.118"
0.165"
0.137"
0.137"
Fig. 4
1.133"
12
2.952"
0.913"
Ø0.877"
0.444"
Front view
Fig. 5
0.318"
0.295" mini
1.196"
1.381"
0.137"
Fig. 3
0.188"
mini
0.708"
Ø0.877"
Ø0.877"
0.708"
Ø0.877"
0.708"
UTS0
UTS7
3.228"
Ø0.125"
Front view
Panel Cut Out
Drilling Pattern
0.950"
0.913"
Ø0.129"
Front mounting
Ø0.846"
0.913"
Rear mounting
Ø0.988"
22°
Ø0.122"
Ø1.200"
68°
Hole sizes:
#20:0.035"
#16:0.051"
Ø1.031"
Ø0.866"
0.090"
0.393"
1.005"
0.161"
0.177"
0.062"
0.263"
Fig. 6
0.177"
0.090"
30°
121
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
UTS614DCG
UTS14DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005588A
85005597
122
Part numbers
UTFD14B
Part numbers
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
12 contacts
4.5A/250V
per UL 1977
#16
Contact type
Plating
Handsolder
18 to 14
0.196"
PCB
#20
Contact type
Plating
Handsolder
22 to 18
0.149"
PCB
Contacts
12
UTS 14E12/14D12 Derating Curves
Current (A)
UL
4.5A 250V UL94 HB
CSA
4.5A 250V UL94 HB
IEC
4A 50V 1.5kV 3
14
12
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
10
8
6
4
2
Current use
60
80
100
Limited use
120
Not recommended use
123
1492 (Shell size 14, 12x#16)
Layout
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 127
PCB
contacts supplied
separately
see page 127
Connector type
Backshell
Free hanging
receptacle
Female insert
UTS1JC1492P
UTS1JC1492S
Plug
Without (Fig. 2)
UTS61492P
UTS61492S
Plug
UTS6JC1492P
UTS6JC1492S
Jam nut receptacle
Without (Fig. 4)
UTS71492P
UTS71492S
Jam nut receptacle
Without (Fig. 4)
UTS71492P
UTS71492S
124
Part number
Male insert
12 contacts
10A/600V
per UL 1977
Dimensions
Free Hanging - UTS1
Ø0.877"
Fig. 1
3.090"
Plug - UTS6
1.299"
2.755"
Ø1.381"
Male
Female
0.996"
Fig. 2
Fig. 3
0.708"
0.062"
12
Ø1.381"
UTS7
0.137"
3.228"
Fig. 4
Drilling Pattern
0.102"
0.208"
0.200"
0.055"
0.031"
0.181"
0.224" Hole size:
0.051"
0.074"
0.090"
1.005"
0.141"
0.094"
0.950"
0.232"
Panel Cut Out
125
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS614DCG
UTS14DCGE
Contacts
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005588A
85005597
Part numbers
UTFD14B
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
126
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
Part number
of head
Contact size
Handle
Head
Complete set
12 contacts
10A/600V
per UL 1977
Contacts
#16
Contact type
Crimp
Machined
contacts
PCB
Wire size
Part number
Coaxial
Max
wire Ø
Max
insulator Ø
RM28M1K(1)
RC28M1K(1)
0.021"
0.039"
RM24M9K
RC24M9K
0.031"
0.062"
RM20M13K(1)
RC20M13K(1)
0.045"
0.070"
RM20M12K
(1)
RC20M12K
0.045"
0.086"
RM16M23K(1)
RC16M23K(1)
0.070"
0.125"
RM14M30K
RC14M30K
0.090"
0.125"
SC24M1TK6(1)(2)
0.035"-0.062"
SM20M1TK6(1)(2)
SC20M1TK6(1)(2)
0.047"-0.082"
0.125"
0.118"
(1)(2)
mm²
Male
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
26-24
0.13-0.20
SM24M1TK6(1)(2)
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
Machined (3)
14
2.08
Cable Multipiece
Cable Monocrimp
see pages 167,
200 to 206
Fiber
optic
Female
AWG
POF contacts
see page
170
(1)
(1)
(1)
(1)
(1)
SM16M1TK6
SC16M1TK6
SM16M11TK6(1)(2)
SC16M11TK6(1)(2)
SM14M1TK6
SC14M1TK6
0.125"
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RCDXK1D28
RMDX60xxD28
RCDX60xxD28
RMDXK10D28 +
york090
RCDXK1D28 +
york090
RMDX60xxD28
RCDX60xxD28
RMPOF1000
RCPOF1000B
(1)(2)
(1)(2)
(1)(2)
UTS 1492 Derating Curves
Current (A)
30
UL
10A 600V UL94 V-0
CSA
7A 500V UL94 V-0
IEC
10A 63V 1.5kV 3
28
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
127
12
12E14/12D14 (Shell size 12, 14x#20)
Layout
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 131
PCB
contacts loaded
see page 131
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 6)
UTS012E14P
UTS012E14S
Without (Fig. 1)
UTS612E14P
UTS612E14S
Cable gland (Fig. 2)
UTS6JC12E14P
UTS6JC12E14S
Jam nut
receptacle
Without (Fig. 3)
UTS712E14P
UTS712E14S
Square flange
receptacle
Without (Fig. 7)
UTS012D14P
UTS012D14S
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS712D14P32
UTS712D14S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS712D14P
UTS712D14S
Plug
128
Part number
Male insert
Sealed unmated
14 contacts
4.5A/250V
per UL 1977
Dimensions
Plug - UTS6
2.626"
Ø1.185"
0.996"
Fig. 1
Fig. 2
0.118"
0.122"
0.137"
0.708"
0.137"
Fig. 3
0.137"
Fig. 4
Front view
Fig. 5
Fig. 7
0.444" 0.295" 0.318"
mini
1.070"
1.255"
Ø0.748"
Ø0.748"
0.708"
Ø0.748"
0.708"
0.149"
mini
0.118"
0.165"
1.039"
3.055"
14
0.818"
Ø0.748"
UTS0
UTS7
3.216"
0.090"
Ø0.125"
Fig. 6
Front view
Drilling Pattern
Ø0.129"
22°
Ø0.122"
0.078"
Front mounting
Ø0.720"
0.818"
Rear mounting
Ø0.877"
0.875"
Ø0.866"
0.070"
0.818"
0.826"
Ø1.031"
Hole size:
0.035"
68°
0.055"
0.149"
0.393"
Ø1.200"
30°
0.173"
0.185"
Panel Cut Out
0.106"
129
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS12DCG
UTS12DCGR
UTS612DCG
UTS12DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005587A
85005596
130
Part numbers
UTFD13B
Part numbers
R for Red
Receptacles
Plugs
UTS712CCRR
UTS612CCRR
UTS712CCRY
UTS612CCRY
UTS712CCRG
UTS612CCRG
14 contacts
4.5A/250V
per UL 1977
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts
14
UTS 12E14/12D14 Derating Curves
Current (A)
UL
4.5A 250V UL94 HB
CSA
4.5A 250V UL94 HB
IEC
5A 32V 1.5kV 3
11
10
9
Test
conditions
8
Contact used:
Machined contacts
Wires used:
0.518mm²
5
7
6
4
3
2
1
Current use
60
80
100
Limited use
120
Not recommended use
131
14E15/14D15 (Shell size 14, 14x#20, 1x#16)
Layout
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 135
PCB
contacts loaded
see page 135
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 6)
UTS014E15P
UTS014E15S
Without (Fig. 1)
UTS614E15P
UTS614E15S
UTS6JC14E15P
UTS6JC14E15S
Jam nut
receptacle
Without (Fig. 3)
UTS714E15P
UTS714E15S
Square flange
receptacle
Without (Fig. 7)
UTS014D15P
UTS014D15S
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS714D15P32
UTS714D15S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS714D15P
UTS714D15S
Plug
132
Part number
Male insert
Sealed unmated
15 contacts
12A/600V
per UL 1977
Dimensions
Plug - UTS6
0.996"
Ø1.381"
2.755"
Fig. 1
Fig. 2
0.118"
0.118"
0.137"
0.708"
0.137"
Fig. 3
0.137"
Fig. 4
Fig. 7
0.295"0.318"
mini
Front view
Fig. 5
1.133"
2.952"
UTS0
0.913"
Ø0.877"
0.444"
1.196"
1.381"
Ø0.877"
Ø0.877"
0.708"
Ø0.877"
0.708"
0.188"
mini
0.118"
0.165"
15
UTS7
3.228"
0.090"
Ø0.125"
Front view
Drilling Pattern
0.913"
Rear mounting
Ø0.988"
1.005"
0.240"
0.106"
68°
0.039"
0.011"
0.098"
0.074"
0.137"
0.950"
0.913"
Front mounting
Ø0.846"
22°
Hole sizes:
#20: 0.035" 0.125"
#16: 0.051" 0.216"
0.224"
Panel Cut Out
Ø0.129"
0.110"
0.208"
0.244"
Fig. 6
0.200"
30°
133
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
UTS614DCG
UTS14DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005588A
85005597
134
Part numbers
UTFD14B
Part numbers
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
15 contacts
12A/600V
per UL 1977
#16
Contact type
Plating
Handsolder
18 to 14
0.196"
PCB
#20
Contact type
Plating
Handsolder
22 to 18
0.149"
PCB
Contacts
15
UTS 14E15/14D15 Derating Curves
Current (A)
30
UL
12A 600V UL94 HB
CSA
12A 600V UL94 HB
IEC
4A 50V 1.5kV 3
28
25
23
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
13
18
15
10
8
5
3
Current use
60
80
100
120
Limited use
Not recommended use
135
14E18/14D18 (Shell size 14, 18x#20)
Layout
OR
OR
WITH
Contact type
Handsolder
electrical contacts
loaded
see page 139
PCB
contacts loaded
see page 139
Connector type
Backshell
Square flange
receptacle
Female insert
Without (Fig. 6)
UTS014E18P
UTS014E18S
Without (Fig. 1)
UTS614E18P
UTS614E18S
UTS6JC14E18P
UTS6JC14E18S
Jam nut
receptacle
Without (Fig. 3)
UTS714E18P
UTS714E18S
Square flange
receptacle
Without (Fig. 7)
UTS014D18P
UTS014D18S
Jam nut receptacle
with stand off and
Without (Fig. 4)
UTS714D18P32
UTS714D18S32
Jam nut receptacle
with stand off and
Without (Fig. 5)
UTS714D18P
UTS714D18S
Plug
136
Part number
Male insert
Sealed unmated
18 contacts
4A/250V
per UL 1977
Dimensions
Plug - UTS6
2.755"
Ø1.381"
0.996"
Fig. 1
Fig. 2
0.118"
0.118"
0.708"
0.137"
0.137"
Fig. 4
Fig. 7
0.295" 0.318"
mini
Front view
Fig. 5
1.133"
2.952"
UTS0
0.913"
Ø0.877"
0.444"
1.196"
1.381"
Ø0.877"
Ø0.877"
0.137"
Fig. 3
0.188"
mini
0.118"
0.165"
0.708"
Ø0.877"
0.708"
UTS7
3.228"
0.090"
18
Ø0.125"
Front view
Drilling Pattern
0.913"
0.950"
Ø0.129"
Front mounting
Ø0.846"
0.913"
Rear mounting
Ø0.988"
1.005"
22°
Ø0.122"
Ø1.200"
Ø1.031"
Ø0.866"
68°
0.393"
0.062"
0.129"
0.259"
30°
0.192"
Hole size:
0.035"
0.251"
Panel Cut Out
0.110"
0.224"
Fig. 6
Note: all dimensions are in inches
137
IP68/69K
IP68/69K
Plug Sealing Cap
Metal terminal
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
UTS614DCG
UTS14DCGE
Gasket
Color Coding Rings
G for Green
Y for
Yellow
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005588A
85005597
138
Part numbers
UTFD14B
Part numbers
R for Red
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
UTS714CCRG
UTS614CCRG
18 contacts
4A/250V
per UL 1977
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts
18
UTS 14E18/14D18 Derating Curves
Current (A)
10
UL
4A 250V UL94 HB
CSA
4A 250V UL94 HB
IEC
5A 50V 1.5kV 3
9
8
Test
conditions
7
Contact used:
Machined contacts
Wires used:
0.518mm²
4
6
5
3
2
1
Current use
60
80
100
Limited use
120
Not recommended use
139
1419 - 14E19/14D19 (Shell size 14, 19x#20)
Layout
OR
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 143
PCB
contacts supplied
separately
see page 143
Handsolder
electrical contacts
loaded
see page 143
PCB
contacts loaded
see page 143
Connector type
Backshell
Free hanging receptacle
Female insert
UTS1JC1419S
UTS61419S
UTS6JC1419S
UTS71419S
Plug
Without (Fig. 2)
Plug
Jam nut receptacle
Without (Fig. 4)
UTS1JC1419P
UTS61419P
UTS6JC1419P
UTS71419P
Jam nut receptacle
Without (Fig. 4)
UTS71419P
UTS71419S
Square flange receptacle
Without (Fig. 8)
UTS014E19P
UTS014E19S
Without (Fig. 2)
UTS614E19P
UTS614E19S
Plug
UTS6JC14E19P
UTS6JC14E19S
Jam nut receptacle
Without (Fig. 5)
UTS714E19P
UTS714E19S
Without (Fig. 9)
UTS014D19P
UTS014D19S
Jam nut receptacle
with stand off and
Without (Fig. 6)
UTS714D19P32
UTS714D19S32
Jam nut receptacle
with stand off and
Without (Fig. 7)
UTS714D19P
UTS714D19S
140
Part number
Male insert
Sealed unmated
19 contacts
5A/250V
per UL 1977
Dimensions
Free Hanging - UTS1
Plug - UTS6
2.755"
1.299"
3.090"
Ø1.381"
Ø0.877"
Male
Female
0.996"
Fig. 2
Fig. 1
Fig. 3
0.118"
0.484"
0.165"
0.137"
0.118"
Fig. 5
0.708"
0.137"
0.137"
Fig. 6
Front view
Fig. 7
Fig. 9
0.444" 0.295"0.318"
mini
1.196"
1.381"
Ø0.877"
0.708"
Ø0.877"
0.708"
0.188"
mini
0.118"
Ø0.877"
Fig. 4
1.133"
2.952"
0.913"
Ø0.877"
UTS0
UTS7
3.228"
Ø0.125"
Front view
Fig. 8
Panel Cut Out
0.913"
0.950"
Ø0.129"
Front mounting
Ø0.846"
0.913"
Rear mounting
Ø0.988"
22°
Ø0.122"
Ø1.200"
Ø1.031"
Hole size:
0.035"
68°
Ø0.866"
0.110"
19
Drilling Pattern
0.224"
0.090"
0.393"
1.005"
0.192"
0.062"
30°
0.129"
0.259"
141
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS14DCG
UTS14DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS614DCG
UTS14DCGE
Gasket
Receptacle
cap
Plug cap
85005588A
85005597
Contacts
RM/RC
RM/RC
RM/RC
SM/SC
SM/SC
IP68/69K
Part numbers
Part numbers
UTFD14B
Part number
of head
Contact size
24W3K(1)
20W3K(1)
18W3K(1)
24WL3S
20WL3S
S20RCM*
S20RCM*
S20RCM*
S20SCM20*
S20SCM20*
Standard contacts
#20
Ø 1.0 mm
Handle
Head
Complete set
Color Coding Rings
G for Green
Y for
Yellow
142
Part numbers
R for Red
Extraction Tool #20
Receptacles
Plugs
UTS714CCRR
UTS614CCRR
UTS714CCRY
UTS614CCRY
Part number
UTS714CCRG
UTS614CCRG
RX20D44
19 contacts
5A/250V
per UL 1977
Contacts for 1419
#20
Wire size
Contact type
Crimp
Machined
contacts
PCB
Machined (3)
Part number
Female
Max
wire Ø
Max
insulator Ø
RM24W3K(1)
RC24W3K(1)
0.031"
0.062"
0.32-0.52
RM20W3K
(1)
RC20W3K
0.045"
0.062"
0.50-0.80
RM18W3K(1)
RC18W3K(1)
0.051"
0.082"
0.13-0.20
SM24W3TK6(2)
SC24W3TK6(2)
0.035"-0.062"
26-24
0.13-0.20
SM24W3S26
(2)
SC24W3S25
0.035"-0.062"
22-20
0.32-0.52
SM20W3TK6(2)
SC20W3TK6(2)
0.047"-0.082"
22-20
0.32-0.52
SM20W3S26
SC20W3S25
0.047"-0.082"
RMW5016K
RCW5016K
AWG
mm²
Male
26-24
0.13-0.20
22-20
20-18
26-24
(1)
(2)
(2)
(2)
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
PCB
Contacts for 14E19/14D19
UTS 1419 - 14E19/14D19 Derating Curves
Current (A)
UTS 1419
UL
5A 250V UL94 V-0
UTS 14E19/14D19
UL
4A 250V UL94 HB
CSA
4A 250V UL94 V-0
CSA
4A 250V UL94 HB
10
9
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
IEC
5A 32V 1.5kV 3
8
7
6
5
4
3
2
1
Current use
60
80
100
Limited use
120
Not recommended use
143
19
1823 (Shell size 18, 23x#16)
Layout
OR
OR
OR
WITH
Contact type
Crimp
contacts supplied
separately
see page 147
PCB
contacts supplied
separately
see page 147
Connector type
Backshell
Square flange
receptacle
Free hanging
receptacle
Female insert
Without (Fig. 1)
UTS01823P
UTS01823S
UTS1JC1823P
UTS1JC1823S
Plug
Without (Fig. 3)
UTS61823P
UTS61823S
Plug
Cable gland (Fig. 4)
UTS6JC1823P
UTS6JC1823S
Jam nut
receptacle
Without (Fig. 5)
UTS71823P
UTS71823S
Square flange
receptacle
Without (Fig. 1)
UTS01823P
UTS01823S
Jam nut
receptacle
Without (Fig. 5)
UTS71823P
UTS71823S
144
Part number
Male insert
23 contacts
10A/500V
per UL 1977
Dimensions
0.444"
0.744"
Free Hanging - UTS1
1.318"
3.503"
Female
0.405"
0.098"
Ø1.126"
1.066"
Ø1.126"
Male
Ø0.125"
Fig. 1
Fig. 2
Front view
Plug - UTS6
1.299"
3.200"
Female
Ø1.653"
Ø1.653"
Male
0.996"
Fig. 3
Fig. 4
1.452"
0.708"
3.311"
0.484"
1.633"
Ø1.126"
UTS0
UTS7
0.137"
3.574"
Front view
Drilling Pattern
1.066"
1.195"
Front mounting
Ø1.098"
1.066"
Rear mounting
Ø1.255"
1.253"
0.263"
0.137"
0.145"
Hole size:
0.051"
0.212"
0.326"
0.196"
0.074"
Ø0.129"
0.338" 0.303"
0.188"
Panel Cut Out
0.133"
Fig. 5
145
23
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS18DCG
UTS18DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS618DCG
UTS18DCGE
Contacts
Gasket
IP68/69K
Part numbers
Receptacle
cap
Plug cap
85005590A
85005599
Part numbers
UTFD16B
Color Coding Rings
G for Green
Y for
Yellow
Part numbers
R for Red
Receptacles
Plugs
UTS718CCRR
UTS618CCRR
UTS718CCRY
UTS618CCRY
UTS718CCRG
UTS618CCRG
RM/RC 28M1K(1)
RM/RC 24M9K(1)
RM/RC 20M13K(1)
RM/RC 20M12K(1)
RM/RC 16M23K(1)
RM/RC 14M30K(1)
SM/SC 24ML1TK6(1)
SM/SC 20ML1TK6(1)
SM/SC 16ML1TK6(1)
SM/SC 14ML1TK6(1)
SM/SC 16ML11TK6(1)
RMDXK10D28K
RCDXK1D28K
RM/RC DX60xxD28K
RM/RC DXK10D28 +
york090
RM/RC DX60xxD28
146
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM20*
S16RCM16*
S16RCM14*
S16SCM20*
S16SCM20*
S16SCML1*
S16SCML1*
S16SCML11*
Standard contacts
#16
Ø 1.6 mm
M10S1J
with die set
& stop bushing
see page
202 to 205
Coaxial contacts
Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208.
Part number
of head
Contact size
Handle
Head
Complete set
23 contacts
10A/500V
per UL 1977
Contacts
#16
Crimp
Machined
contacts
PCB
Wire size
Contact type
Part number
Coaxial
Max
wire Ø
Max
insulator Ø
RM28M1K(1)
RC28M1K(1)
0.021"
0.039"
RM24M9K
RC24M9K
0.031"
0.062"
RM20M13K(1)
RC20M13K(1)
0.045"
0.070"
RM20M12K
(1)
RC20M12K
0.045"
0.086"
RM16M23K(1)
RC16M23K(1)
0.070"
0.125"
RM14M30K
RC14M30K
0.090"
0.125"
SC24M1TK6(1)(2)
0.035"-0.062"
SM20M1TK6(1)(2)
SC20M1TK6(1)(2)
0.047"-0.082"
0.125"
0.118"
(1)(2)
mm²
Male
30-28
0.50-0.08
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
26-24
0.13-0.20
SM24M1TK6(1)(2)
22-20
0.32-0.52
18-16
0.80-1.31
18-16
0.80-1.31
Machined (3)
14
2.08
Cable Multipiece
Cable Monocrimp
see pages 167,
200 to 206
Fiber
optic
Female
AWG
POF contacts
see page
170
(1)
(1)
(1)
(1)
(1)
SM16M1TK6
SC16M1TK6
SM16M11TK6(1)(2)
SC16M11TK6(1)(2)
SM14M1TK6
SC14M1TK6
0.125"
RM20M12E83K(1)
RC20M12E84K(1)
RMDXK10D28
RCDXK1D28
RMDX60xxD28
RCDX60xxD28
RMDXK10D28 +
york090
RCDXK1D28 +
york090
RMDX60xxD28
RCDX60xxD28
RMPOF1000
RCPOF1000B
(1)(2)
(1)(2)
(1)(2)
(2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6
UTS 1823 Derating Curves
Current (A)
30
UL
10A 500V UL94 V-0
CSA
7A 500V UL94 V-0
IEC
9A 63V 1.5kV 3
28
23
25
Test
conditions
Contact used:
Machined contacts
Wires used:
1.31mm²
23
15
13
10
8
5
3
Current use
60
80
100
Limited use
120
Not recommended use
147
1832 - 18E32 (Shell size 18, 32x#20)
Layout
OR
OR
OR
WITH
Contact type
Connector type
Backshell
Free hanging
receptacle
Female insert
UTS1JC1832P
UTS1JC1832S
Plug
Without (Fig. 3)
UTS61832P
UTS61832S
Plug
UTS6JC1832P
UTS6JC1832S
Jam nut
receptacle
Without (Fig. 5)
UTS71832P
UTS71832S
PCB
contacts supplied
separately
see page 151
Jam nut
receptacle
Without (Fig. 5)
UTS71832P
UTS71832S
Handsolder
electrical contacts
loaded
see page 151
Square flange
receptacle
Without (Fig. 1)
UTS018E32P
Crimp
Contact supplied
separately
see page 151
148
Part number
Male insert
Sealed unmated
32 contacts
5A/250V
per UL 1977
Dimensions
0.444"
0.744"
Free Hanging - UTS1
1.318"
3.503"
Ø1.126"
1.066"
Ø1.126"
Male
Female
0.405"
0.098"
Fig. 1
Ø0.125"
Front view
Fig. 2
Plug - UTS6
1.299"
3.200"
Ø1.653"
Ø1.653"
Male
Female
0.996"
Fig. 3
Fig. 4
0.708"
1.452"
0.484"
3.311"
1.633"
Ø1.126"
UTS0
UTS7
0.137"
3.574"
Front view
Drilling Pattern
0.220" 0.228"
0.094"
Front mounting
Ø1.098"
Rear mounting
Ø1.255"
0.149" 0.192"
1.253"
0.358"
1.066"
1.195"
0.094"
Ø0.129"
0.318"
0.342"
0.283"
Hole size:
0.035"
0.188"
0.334" 0.350"
0.208"
0.122"
0.263" 0.303"
0.094"
0.157" 0.216"
Panel Cut Out
1.066"
0.031"
Fig. 5
32
0.129"
0.062"
0.173" 0.240"
0.381"
0.224"
149
IP68/69K
Tool Kit
Metal terminal
IP68/69K
Part number
Part number
Part number
Part number
UTS18DCG
UTS18DCGR
Shandles
Toolkit
Plug Sealing Cap
IP68/69K
Metal terminal
IP68/69K
Part number
Part number
UTS618DCG
UTS18DCGE
Gasket
Receptacle
cap
Plug cap
85005590A
85005599
Contacts
RM/RC
RM/RC
RM/RC
SM/SC
SM/SC
IP68/69K
Part numbers
Part numbers
UTFD16B
Part number
of head
Contact size
24W3K(1)
20W3K(1)
18W3K(1)
24WL3S
20WL3S
S20RCM*
S20RCM*
S20RCM*
S20SCM20*
S20SCM20*
Standard contacts
#20
Ø 1.0 mm
Handle
Head
Complete set
Color Coding Rings
G for Green
Y for
Yellow
150
Part numbers
R for Red
Extraction Tool #20
Receptacles
Plugs
UTS718CCRR
UTS618CCRR
UTS718CCRY
UTS618CCRY
Part number
UTS718CCRG
UTS618CCRG
RX20D44
32 contacts
5A/250V
per UL 1977
Contacts
#20
Contact type
Crimp
Machined
contacts
PCB
Wire size
Part number
Female
Max
wire Ø
Max
insulator Ø
RM24W3K(1)
RC24W3K(1)
0.031"
0.062"
0.188"
0.32-0.52
RM20W3K
(1)
RC20W3K
0.045"
0.062"
0.188"
0.50-0.80
RM18W3K(1)
RC18W3K(1)
0.051"
0.082"
0.188"
0.13-0.20
SM24W3TK6(2)
SC24W3TK6(2)
0.035"-0.062"
0.157"
SM24W3S6
(2)
SC24W3S25
0.035"-0.062"
0.157"
SM20W3TK6(2)
SC20W3TK6(2)
0.047"-0.082"
0.157"
SM20W3S6
SC20W3S25
0.047"-0.082"
0.157"
RCW5016K
AWG
mm²
Male
26-24
0.13-0.20
22-20
20-18
26-24
26-24
0.13-0.20
22-20
0.32-0.52
22-20
0.32-0.52
Machined (3)
(1)
(2)
(2)
(2)
RMW5016K
#20
Contact type
Plating
Handsolder
22 to 18
0.196"
UTS 1832 - 18E32 Derating Curves
Current (A)
10
UL
5A 250V UL94 V-0
CSA
4A 250V UL94 V-0
IEC
4A 32V 1.5kV 3
9
8
Test
conditions
Contact used:
Machined contacts
Wires used:
0.518mm²
7
6
32
5
4
3
2
1
Current use
60
80
100
Limited use
120
Not recommended use
151
LC (Fiber Optic)
Layout
OR
OR
WITH
Connector type
Backshell
Plug
Jam nut receptacle
LC contacts not included
For IP rating and general details please consult us
152
Part number
Male insert
Female insert
UTS1JC18LCN
UTS6JC18LCN
Without (Fig. 3)
UTS718LCN
LC (Fiber Optic)
Dimensions
Free Hanging Receptacle -UTS1JC18LCN
4.803" max
1.653" maxi
Ø 0.236" max
Ø 0.118" min
Fig. 1
Plug - UTS6JC18LCN
4.409" max
1.653" maxi
Ø 0.236" max
Ø 0.118" min
Fig. 2
Mated Connector Length - UTS7
Jam Nut Receptacle - UTS718LCN
4.566"
0.688"
max
Ø 1.791" max
0.196"
max
Fig. 3
Panel Cut Out
1.195"
0.728"
max
1.253"
LC
153
LC (Fiber Optic)
Accessories
Sealing Caps
For UTS1JC18LCN & UTS718LCN
For UTS6JC18LCN
154
Part number
Part number
UTS618DCG2
UTS18DCG2
LC
155
MPO (Fiber Optic)
Layout
OR
OR
WITH
Connector type
Part number
Male insert
Female insert
UTS1JC18MPN
Plug
UTS6JC18MPN
Jam nut receptacle
Without (Fig. 3)
UTS718MPN
156
Backshell
MPO (Fiber Optic)
Dimensions
Free Hanging Receptacle -UTS1JC18MPN
4.803" max
1.653" maxi
Ø 0.236" max
Ø 0.118" min
Fig. 1
Plug - UTS6JC18MPN
4.409" max
1.653" maxi
Ø 0.236" max
Ø 0.118" min
Fig. 2
Jam Nut Receptacle - UTS718MPN
4.566"
0.688"
max
Ø 1.791" max
0.196"
max
Fig. 3
Panel Cut Out
1.195"
0.728"
max
1.253"
MPO
157
MPO (Fiber Optic)
Accessories
Sealing Caps
For UTS1JC18MPN & UTS718MPN
For UTS6JC18MPN
158
Part number
Part number
UTS618DCG2
UTS18DCG2
MPO
159
UTS SERIES
© 2015 SOURIAU - SOURIAU is a registratred trademark
UTS Series
Contacts
Description ................................................................................................................ 162
Contact Plating Selector Guide ................................................................................. 163
Contact Selector Guide ............................................................................................. 164
Packaging .................................................................................................................. 164
Crimp Contacts ......................................................................................................... 165
#16 Coaxial Contacts ................................................................................................ 167
PCB Contacts ............................................................................................................ 168
Fiber Optic Contacts ................................................................................................. 170
161
UTS Series | Contacts
Contacts
Description
The UTS series is delivered with (solder, PCB versions and screw termination) or without contact (crimp version) and offers the unique feature
to use the same contact style in any layout with the same active part size (i.e. #20, #16, #12, etc.). This provides our customers with an easy
solution to buy only one type of contact to equip all their connectors even if housings/shell sizes are different.
This provides the benefit of standardization and subsequent reduced inventory costs. In addition, it eliminates the need for added tooling and
simplifies the assembly process. Souriau contacts are designed for simple snap-in installation and further eliminate the need for insertion
tooling.
In addition to the below “crimp” style contact options, the UTS series can also be equipped with PCB contacts.
Crimp contacts are available in different versions:
• Machined
162
• Stamped & Formed
• Coaxial
• Fiber Optic
Once the contact size has been selected, the next step is to decide on which type to use. Souriau offers two main types of electrical contacts:
• Machined
• Stamped & Formed
Machined contacts are generally chosen as a better solution for power applications or when lower quantities are needed.
Stamped & Formed contacts offer the ability to be crimped automatically which makes them more suitable for high volume production
applications.
The next decision to make is: What plating should I choose?
The graph below can help guide you to plating recommendations based on application, mating cycles and current/voltage needs.
Note: To avoid galvanic couples, fretting corrosion and at the end interruption of electrical signal do not mix different platings (i.e. tin plated
pin contacts with gold plated socket contacts).
If customer mixes different contact platings, Souriau can’t guarantee electrical performances.
Number of
cycles
Vibration
250
100
0.4μm of gold
min
Contacts
Gold flash
Silver
Tin
Current /
Voltage
1Amp
5mV
Contact
size
#20
#12
#16
#8
163
Contacts supplied separately
Electrical characteristics: contact resistance
#20
Ø0.039"
#16
Ø0.062"
Machined
Available platings (contacts supplied separately)
< 6mΩ
A
2μm Nickel + 2μm Ag
J
Gold flash over Nickel 2μm mini
K
0.4 μm Gold over 2 μm Nickel mini
Stamped & Formed
< 6mΩ
Machined
< 3mΩ
Stamped & Formed
< 6mΩ
Machined
< 5mΩ
S18
Machined
< 5mΩ
S25
S26
Active part: Gold flash over Nickel
Crimp area: 1.3μm Tin mini over Nickel
Other: 1.3μm Tin mini
Active part: 0.75μm Gold mini over Nickel
Active part: 0.75μm Au over Nickel
Crimp area: flash Au over Nickel
TK6
0.5μm - 2.5μm Sn pre-plated
D70
Superseded by S31
S6
Superseded by S18
#12
Ø0.094"
#8
Ø0.141"
S31
Other platings on request (contacts supplied separately)
Contact preloaded
T
Tin 3μm (-0/+2) over 1.3μm Nickel mini
D28*
0.75μm mini Gold over 2μm Nickel mini
NPC
2 μm Ni
* For Coax contacts only
#20
Ø0.039"
#16
Ø0.062"
Machined
< 4mΩ
Machined
< 3mΩ
Available plating (contact preloaded)
Min 0.4μm gold over 0.8μm Nickel
Packaging
Due to the wide variety of applications, contact packaging is offered for small series (bulk package) and high volume production (reeled contacts):
Size contacts #20 (Ø0.039") & #16 (Ø0.062")
• 25 pieces loose package
(Stamped & Formed
contacts)
• 50 pieces bulk package
(Machined contacts)
• 1,000 pieces
bulk package
(Machined contacts)
• 3,000 pieces reeled
(Stamped & Formed
contacts)
Size contacts #12 (Ø0.094") & #8 (Ø0.141")
• 100 pieces bulk package
(Machined contacts)
Note: 1,000 pieces bulk package available by adding 1000 at the end of the part number: e.g. RC16M23K1000
2,000 pieces reeled package available by adding K at the beginning of the part number: e.g. KRC16M23K
164
• 2,000 pieces reeled
(Machined contacts)
size #16 only
Crimp Contacts
Standard Version
Wire size
Type
Machined
#20
Ø1.0mm
Ø0.039"
#16
Ø1.6mm
Ø0.062"
#8
Ø3.0mm
Ø0.141"
AWG
mm²
Male
26-24
0.13-0.20
RM24W3K
26-24
0.13-0.20
Machined
22-20
0.32-0.52
Female
Max
wire Ø
Max
insulator Ø
Available
plating
see page 164
RC24W3K
0.062" max
K
SM24W3-
SC24W3-
SM24WL3-(2)
SC24WL3-(2)
RM20W3K
RC20W3K
(1)
Stamped &
Formed
(1)
SM20W3-
SC20W3-
SM20WL3-(2)
SC20WL3-(2)
0.52-0.80
RM18W3K
RC18W3K
(1)
Stamped &
Formed
22-20
0.33-0.52
Machined
20-18
(1)
TK6
0.035"-0.062" S25 (female)
S26 (male)
0.062" max
K
TK6
0.046"-0.081" S25 (female)
S26 (male)
0.082" max
K
Machined
30-28
0.05-0.08
RM28M1-
RC28M1-
0.021"
0.043"
K, J
Machined
26-24
0.13-0.20
RM24M9-
RC24M9-
0.031"
0.062"
K, J
SM24M1SM24ML1-(2)
SC24M1SC24ML1-(2)
0.035"-0.050"
No insulation
grip
S31, S18, TK6
RM20M13-
RC20M13-
RM20M12-
RC20M12-
SM20M1-(1)
SM20ML1-(2)
SC20M1-(1)
SC20ML1-(2)
0.046"-0.081"
(1)
(1)
Stamped &
Formed
26-24
0.13-0.20
Machined
22-20
0.32-0.52
Stamped &
Formed
22-20
0.35-0.52
Machined
20-16
0.52-1.31
RM16M23-
RC16M23SC16M1-(1)
SC16ML1-(2)
0.046"
0.070"
0.086"
K, J
No insulation
grip
S31, S18, TK6
0.070"
0.125"
K, J
0.118"
No insulation
grip
S31, S18, TK6
Stamped &
Formed
18-16
0.80-1.31
SM16M1-(1)
SM16ML1-(2)
Stamped &
Formed
18-16
0.80-1.31
SM16M11-(1)
SM16ML11-(2)
SC16M11-(1)
SC16ML11-(2)
0.078"-0.118"
Insulation
grip
S31, S18, TK6
Machined
16-14
1.31-20.8
RM14M30-
RC14M30-
0.089"
0.125"
K, J
2.08
SM14M1SM14ML1-(2)
SC14M1SC14ML1-(2)
0.125"
No insulation
grip
S31, S18, TK6
0.192"
A, K
0.255"
A
Stamped &
Formed
#12
Ø2.4mm
Ø0.094"
Part number
Machined
Machined
14
(1)
(1)
22
0.32
82911457N-
82911456-
82911459N-
82911458-
18
0.80
82911461N-
82911460-
16
1.31
82911463N-
82911462-
14
2.08
82911465N-
82911464-
12
3.31
82911467N-
82911466-
16
1.31
82913601A
82913600A
14
2.08
82913603A
82913602A
12
3.31
82913605A
82913604A
10
5.26
82913607A
82913606A
8
8.37
82913609A
82913608A
(1) contact reeled (2) loose contact
Example: RM24W3K - Size #20, Machined, AWG24 wire.
Contacts
Contact
size
Note: all dimensions are in inches, other wise noted
165
Crimp Contacts (Continued)
First Mate Last Break Contacts
Contact
size
Type
#16
Ø0.062"
Machined
Longer male
contact
(+0.039")
#16
Ø0.062"
Shorter
female contact
(-0.027")
Machined
Wire size
Part number
AWG
mm²
Male
30-28
0.05-0.08
26-24
0.13-0.20
22-20
0.32-0.52
20-16
0.52-1.31
RM28M1GE1K
RM24M9GE1K
RM20M13GE1K
RM20M12GE1K
RM16M23GE1K
RM14M30GE1K
RC28M1GE7K
RC24M9GE7K
RC20M13GE7K
RC20M12GE7K
RC16M23GE7K
RC14M30GE7K
16-14
1.31-2.08
30-28
0.05-0.08
26-24
0.13-0.20
22-20
0.32-0.52
20-16
0.52-1.31
16-14
1.31-2.08
Female
Color band
Max
wire Ø
(mm)
Max
insulator Ø
(mm)
Front
0.021"
0.043"
Red
0.031"
0.062"
Red
Red
0.046"
0.070"
Rear
0.070"
Black
Red
0.086"
Blue
Red
0.125"
Red
2.28
Red
0.021"
0.043"
Blue
0.031"
0.062"
Red
Blue
0.070"
Black
Blue
0.086"
Blue
Blue
0.070"
0.125"
Blue
0.089"
Blue
0.046"
Available
plating
see p. 164
K
K
How to make FMLB / LMFB connection
Contact 1
Contact 2
Standard male
contact
Standard female
contact
Longer male contact
Standard male
contact
Standard female
contact
Shorter female
contact
166
First Mate Last Break contacts should be
chosen only if the cavity is not marked with
the ground symbol. For cavities marked
with the ground symbol, standard contacts
will fulfill the same role as a first mate, last
break contact used in a standard cavity.
FMLB
LMFB
Ground symbol
Coaxial Contact Range
souriau provides 2 types of coaxial contacts suitable for 50 or 75Ω, coaxial cable or twisted pair cable.
Monocrimp coaxial contact
• The monocrimp one-piece coaxial contacts offer high reliability plus the economic advantage of a 95% reduction in installation time over conventional assembly
methods.
• This economy is achieved by simultaneously crimping both the inner conductor
and outer braid or drain wire.
Multipiece crimp coaxial contact
• The inner conductor and outer braid is crimped individually.
• The thermoplastic insulating bushing in the outer body is designed to accept
and permanently retain the inner contact.
• An outer ferrule is used to connect the braid to the outer contact and provide
cable support to ensure against bending and vibration.
Suitable for coaxial cable or twisted cable
Contacts
• For jacket diameter from 0.025" to 0.057"
Inner conductor from AWG30 to AWG24
• For jacket diameter from 0.070" to 0.120"
Inner conductor up to 0.096" diameter
Contacts for coaxial cable summary
Contact range
Contact type
Male contact
Female contact
Multipiece
RMDXK10D28
RCDXK1D28
Monocrimp
RMDX60xxD28
RCDX60xxD28
Contact part number with
cable combination
See page 200
Cabling notice
See pages 204 & 205
See page 206
Contacts for twisted pairs cable summary
Contact range
Male contact
Female contact
cable combination
Multipiece
RMDXK10D28
+ YORK090
RCDXK1D28
+ YORK090
See page 201
Monocrimp
RMDX60xxD28
RCDX60xxD28
Contact type
Cabling notice
See page 202
See page 203
167
PCB Contacts
PCB Contacts Supplied Separately - UTS Standard Series
PCB soldering
The UTS Series can be used in a wave soldering process, but not reflow soldering process.
All high temperature processes are prohibited.
Part number
Contact size
Male
Female
#20
Ø0.039"
RMW50A7K
RMW5016K
#16
Ø0.062"
RM20M12E8K
RM20M12E83K
RM20M12E84K
RCW50A7K
RCW5016K
RC20M12E8K
RC20M12E83K
RC20M12E84K
RC20M12E85K
RC20M12E86K
RC20M12E87K
#8
Ø0.141"
82911685NPC
Plating
see page 164
K
K
82911684NPC
2 μm Ni
G
Nominal length G (inches)
Dimension of dipsolder contacts out of connector
(contacts to be ordered separately).
UTS0 with PCB contacts #16
Connector size
Pin contact
RM20M
12E83K*
RM20M
12E8K*
RM20M
12E84K*
RC20M
12E8K*
Socket contact
RC20M
RC20M
12E83K*
12E84K*
RC20M
12E87K*
10
0.165"
0.370"
0.507"
0.165"
0.370"
0.507"
0.255"
12
0.141"
0.346"
0.484"
0.165"
0.370"
0.507"
0.255"
14
0.129"
0.334"
0.472"
0.102"
0.307"
0.444"
0.192"
18
0.165"
0.366"
0.507"
0.165"
0.370"
0.507"
0.255"
RMW
5016K*
RC20M
12E84K*
Socket contact
RCW
50A7K*
RCW
5016K*
0.366"
0.141"
0.330"
0.366"
0.366"
UTS7 with PCB contacts #20 and #16
Connector size
RM20M
12E83K*
10
0.287"
Pin contact
RM20M
RMW
12E84K*
50A7K*
0.425"
0.330"
12
0.287"
0.425"
0.330"
0.366"
0.153"
0.330"
14
0.287"
0.425"
0.330"
0.366"
0.141"
18
0.318"
0.456"
0.330"
0.366"
0.141"
UTS7 with PCB contacts #16 and #8
Connector type
Socket contact
RC20M12E87K*
82911684NPC*
82911685NPC*
UTS7142G1P
0.251"
UTS7142G1S
0.322"
UTS7142G1SNPT
0.228"
0.212"
UTS718X2M3
0.192"
0.177"
0.114"
0.204"
UTS7183G1SNPT
0.164"
* Plating indication see page 164
168
Pin contact
RM20M12E83K*
PCB Contacts Loaded - UTS Sealed Unmated Series
PCB soldering
UTS0
UTS7
G
G
UTS0
8
10
12
14
Connector
Part Number
Pin contact
Socket contact
G mini
G maxi
G mini
G maxi
8D2 - 8D3
8D4
0.283"
0.362"
0.275"
0.354"
8D3A/8D98
8D33
0.318"
0.409"
0.318"
0.397"
10D6 - 10D98
10D7
0.318"
0.401"
0.318"
0.405"
12D2 - 12D3
12D8 - 12D10
0.318"
0.401"
0.318"
0.405"
12D4
0.322"
0.393"
0.318"
0.405"
12D14
0.283"
0.354"
0.279"
0.362"
14D5 - 14D12 - 14D15
14D18 - 14D19
0.318"
0.401"
0.318"
0.405"
14D7
0.322"
0.393"
0.318"
0.405"
Connector
Part Number
G mini
G maxi
G mini
G maxi
8D2 - 8D3
8D4
0.149"
0.240"
0.145"
0.232"
8D3A/8D98
8D33
0.185"
0.287"
0.185"
0.275"
10D6 - 10D98
10D7
0.185"
0.287"
0.185"
0.275"
12D2 - 12D3
12D8 - 12D10
0.185"
0.287"
0.185"
0.275"
12D4
0.192"
0.279"
0.185"
0.275"
Contacts
Connector
size
UTS7
Connector
size
8
10
12
14
Pin contact
Socket contact
12D14
0.149"
0.232"
0.149"
0.232"
14D18 - 14D19
0.188"
0.287"
0.192"
0.275"
14D7
0.192"
0.279"
0.192"
0.275"
169
Description
Size 16 fiber optic contacts for UTS and other TRIM TRIO® connectors
Size 16 fiber optic contacts are designed for the integration of optical links in UTS and other TRIM TRIO® cable connectors.
The Fiber optic contacts are designed to accommodate:
• Plastic Optical Fiber (POF) 0.039" core and 0.086" jacket
Typical features and benefits are:
• Socket contact is spring loaded to avoid any air gap between the two optical faces.
• Low insertion loss is provided by high precision pieces.
• Single jumpers, multiway harness and active device housings can be supplied regarding customer requirement.
Technical Characteristics
Performance
• Fiber type:................................................................................................... POF
• Wave length:................................................................................................ 650 nm
• Optical insertion loss (typ.):......................................................................... 2 dB max.
• Jacketed external diameter:........................................................................ 0.086"
• Temperature range:..................................................................................... -25°C to +70°C
• Cable retention:........................................................................................... 49N
• Mating cycles without cleaning:.................................................................. 50
• Max. mating cycles:..................................................................................... 500
Construction
• Contact body: Copper alloy
Connector accommodation
Any TRIM TRIO® size 16 contact can be used in any contact position in any connector in the TRIM TRIO® size 16 interconnection system:
UTP, UTS, UTG, UTO, UTL.
170
Ordering Information
POF Contacts (Plastic Optical Fiber)
Male contact......................................... RMPOF1000
Female contact................................... RCPOF1000B
POF Contact (Plastic Optical Fiber)
Part numbers
Descriptions
SPECIFIC TOOLING LIST - Can only be ordered separately
Part numbers
Descriptions
80WD0005
Stripping tool
80WG0010
Needle
80WD0025
Automatic stripping tool for Ø 0.019",
0.023", 00.027" & 0.149"
80WG0015
Capsule
80WM0006
Ruler
80WG0016
Syringe
80WP0005
Polishing plate
80WN0005
Dry air spray
80WP0013
Non slip base (to hold the polishing plate)
80WN0006
Optical paper
80WP0014
Polishing disk (grain size 9µm)
80WN0012
Dropper bottle
80WP0018
Polishing tool
80WN0008
Wiping solvent
80WP0019
Polishing disk (grain size 30µm)
80WS0002
Crimping plier
Contacts
STANDARD TOOLING KIT - P/N 80MS0004
The standard tooling kit is made of the part numbers below
that can be ordered separately as well.
171
UTS SERIES
UTS Series
Technical Information
Tooling ..................................................................................................................... 174
Stripping & Crimping Instructions ........................................................................... 176
Handle & Interchangeable Heads ........................................................................... 178
Insertion & Extraction Tools ..................................................................................... 179
Overmolded Harnesses Dimensions ....................................................................... 179
Assembly Instructions .............................................................................................. 180
Mated Connector Lengths ...................................................................................... 184
Mating Procedure .................................................................................................... 185
Rated Current & Working Voltage ........................................................................... 186
UV Resistance .......................................................................................................... 187
UL94 + UL1977 ........................................................................................................ 188
IEC 61984 & IP Codes Explained ............................................................................ 191
IEC 61140 Explained ............................................................................................... 193
What is NEMA Rating ? ........................................................................................... 194
Ethernet for the Layman .......................................................................................... 195
173
UTS Series | Technical Information
Automatic Crimping Tools
Mecal is a leader in manufacturing tooling for
crimping terminals over a stripped wire.
Established in 1976, Mecal has become one of the
world's leading companies dedicated to the design
and manufacture of semi automatic production tools
for strip fed, open barrel crimp terminals, serving the
Automotive, Telecom and Datacom industries.
The extreme environment interconnect specialist
“from deep sea to deep space”.
SOURIAU designs, manufactures and markets high
performance interconnect solutions for severe
environments dedicated to the aerospace, defense,
light and heavy industry markets.
SOURIAU has been working in partnership with Mecal for many years. With sales offices located in all major
industrial regions of the world, the combined strengths of both organizations has resulted in a truly global
solution to all your production tooling needs.
Mini Applicator
Stripper
Mecal sales network:
http://www.mecalbystarn.com/
174
Presses
Tooling
Crimp Tool Table
Standard contacts
Contact size
#16
Ø0.062"
(1) loose contact
Head*
S20RCM
RX20D44
S20SCM20
S16RCM20
SHANDLES
S16RCM16
S16RCM14
RX2025GE1
S16SCM20
S16SCML1
S16SCML11
Part number
Hand tool
82911457N* / 82911456*
82911459N* / 82911458*
82911461N* / 82911460*
82911463N* / 82911462*
M317
82911465N* / 82911464*
82911467N* / 82911466*
82913601A / 82913600A
#8
Ø0.141"
Extraction tools
* endurance of SHANDLES & Head tools = 50,000 cycles
Contact size
#12
Ø0.094"
Handles*
82913603A / 82913602A
82913605A / 82913604A
M317
82913607A / 82913606A
82913609A / 82913608A
Tool with separate locator
Positioner + locator setting
1-2
2
2
VGE10077A
3
3
4
3
3
4
VGE10078A
5
6/7
Extraction tools
51060210924
51060210936
#20
Ø0.039"
Part number
RM/RC 24W3K
RM/RC 20W3K
RM/RC 18W3K
SM 24WL3S*(1)
SC 24WL3S*(1)
SM/SC 20WL3S*(1)
RM/RC 28M1*
RM/RC 24M9*
RM/RC 20M13*
RM/RC 20M12*
RM/RC 16M23*
RM/RC 14M30*
SM/SC 24ML1*(1)
SM/SC 20ML1*(1)
SM/SC 16ML1*(1)
SM/SC 14ML1*(1)
SM/SC 16ML11*(1)
* see page 165 for plating options and other contact details
Specific contacts (First mate Last break contacts)
Contact size
#16
Ø0.062"
Longer RM
contact
Part number*
RM28M1GE1K
RM24M9GE1K
RM20M13GE1K
RM16M23GE1K
RM20M12GE1K
RM14M30GE1K
Hand tools
(SHANDLES) head
Hand tool
S16RCM20
S16RCM16
S16RCM14
MH860
MH86186
6/8
MH860
MH86164G
RC28M1GE7K
#16
Ø0.062"
Shorter RC
contact
RC24M9GE7K
RC20M13GE7K
RC20M12GE7K
RC16M23GE7K
RC14M30GE7K
* see page 164 for plating options and other contact details
S16RCM20
S16RCM16
S16RCM14
M317
UH25
4/6
5/6
Extraction tools
RX2025GE1
5/7
6/8
3
Coaxial contacts
See coax contacts details on page 167 and cabling notice pages 202 to 206.
175
Wire Stripping Crimp Version
Part number
Male
Female
Machined contact
Stripping length L
(inches)
#20 (Ø0.039")
RM24W3- / RM20W3RM18W3-
RC24W3- / RC20W3RC18W3-
0.188"
#16 (Ø0.062")
L
RM28M1- / RM24M9RM20M13- / RM20M12-
RC28M1- / RC24M9RC20M13- / RC20M12-
0.188"
RM16M23- /RM14M30-
RC16M23- /RC14M30-
0.279"
#8 (Ø0.141")
82913601- / 8291360382913605- / 8291360782913609Stamped & Formed
82913600- / 8291360282913604- / 8291360682913608-
0.255" to 0.295"
#16 (Ø0.062")
With insulation support
SM24M1- / SM24ML1SM20M1- / SM20ML1-
SC24M1- / SC24ML1SC20M1- / SC20ML1-
0.157"
SM16M11- / SM16ML11-
SC16M11- / SC16ML11-
0.183"
SM24W3- / SM24WL3SM20W3- / SM20WL3-
SC24W3- / SC24WL3SC20W3- / SC20WL3-
#20 (Ø0.039")
L
Without insulation support
0.157"
#16 (Ø0.062")
L
SM16M1- / SM16ML1-
SC16M1- / SC16ML1-
0.250"
SM14M1- / SM14ML1-
SC14M1- / SC14ML1-
0.250"
Power Contacts Machined
#12 (Ø0.094")
L
82911457- / 8291145982911461- / 8291146382911465- / 82911467-
82911456- / 8291145882911460- / 8291146282911464- / 82911466-
0.275" to 0.314"
#8 (Ø0.141")
L
82913601- / 8291360382913605- / 8291360782913609-
0.255" to 0.295"
Note: See page 165 for plating options and other contact details
Wire Stripping Solder and Screw Versions
Stripping length L
Solder contact delivered with connector
L
#16 (Ø0.062") & #20 (Ø0.039")
0.196"
Screw contact delivered with connector
L
176
#16 (Ø0.062")
0.228"
Crimping
One of the key factors which affects the performance of a connector is
the way contacts are terminated. Crimped connections are nowadays
seen as the best solution to ensure quality throughout the lifetime of
the product. Here are some reasons why we recommend this method
of termination for UTS connectors:
To ensure that the crimp tooling is performing according to original
specifications, it is important to carry out regular checks. A common
way to check the performance of tooling is with a simple pull test,
ideally using a dedicated electric pull tester. Minimum recommended
pull forces are indicated in the tables below:
Active
contact
part
Machined
contacts size
#20
Ø0.039"
S&F
contacts size
#20
Ø0.039"
Machined
contacts size
#16
Ø0.062"
W
Contact type
Die
location
on heads
RM24W3K
RC24W3K
26/24
RM20W3K
RC20W3K
22/20
RM18W3K
RC18W3K
20/18
SM24WL3TK6*
SC24WL3TK6*
26/24
SM20WL3TK6*
SC20WL3TK6*
22/20
RM28M1K*
RC28M1K*
30/28
RM24M9K*
RC24M9K*
26/24
RM20M13K*
RC20M13K*
RM20M12K*
RC20M12K*
S&F
contacts size
#16
Ø0.062"
18
16
18
16
0.004" min
0.009" max
0.012" min
0.019" max
0.019" max
0.032" max
0.004" min
0.009" max
0.012" min
0.019" max
0.001" min
0.08 max
0.004" min
0.009" max
0.012" min
0.019" max
0.012" min
0.019" max
0.019" max
0.032" max
0.059" max
0.059" min
0.098" min
0.004" min
0.009" max
0.012" min
0.019" max
0.032" min
0.059" max
0.032" min
0.059" max
Tensile
straight
test (mini)
15 N
32 N
40 N
60 N
60 N
90 N
15 N
32 N
40 N
60 N
11 N
11 N
15 N
32 N
40 N
60 N
40 N
60 N
60 N
90 N
150 N
150 N
230 N
15 N
32 N
40 N
60 N
90 N
150 N
90 N
150 N
14
AWG 14
0.098" max
230 N
16
16
14
RM14M30K*
RC14M30K*
SM24ML1TK6*
SC24ML1TK6*
26/24
SM20ML1TK6*
SC20ML1TK6*
22/20
SM16ML11TK6*
SC16ML11TK6*
SM16ML1TK6*
SC16ML1TK6*
SM14ML1TK6*
SC14ML1TK6*
W
Wire
section
range
AWG 26
AWG 24
AWG 22
AWG 20
AWG 20
AWG 18
AWG 26
AWG 24
AWG 22
AWG 20
AWG 30
AWG 28
AWG 26
AWG 24
AWG 22
AWG 20
AWG 22
AWG 20
AWG 20
AWG 18
AWG 16
AWG 16
AWG 14
AWG 26
AWG 24
AWG 22
AWG 20
AWG 18
AWG 16
AWG 18
AWG 16
22/20
RM16M23K*
RC16M23K*
Stamped & Formed
contact
Section
(inches²)
Height
Width
(inches)
(inches)
H (±0.002") W (±0.002")
0.037"
0.050"
0.049"
0.070"
0.053"
0.073"
0.031"
0.058"
0.039"
0.060"
0.044"
0.055"
0.045"
0.055"
Tooling head
p/n
S20RCM
S20SCM20
S16RCM20
0.049"
0.069"
0.065"
0.070"
0.077"
0.082"
0.090"
0.085"
0.089"
0.095"
0.105"
0.109"
0.033"
0.059"
0.040"
0.060"
0.051"
0.053"
0.058"
0.066"
0.082"
0.082"
0.079"
0.080"
0.070"
0.1001"
Machined
contact
H
H
Advantages (Extract from the IEC 60352-2):
- Efficient processing of connections at each production level
- Processing by fully-automatic or semi- automatic crimping
machines, or with hand operated tools
- No cold-soldered joints
- No degradation of the spring characteristic of female contacts
by the soldering temperature
- No health risk from heavy metal and flux steam
- Preservation of conductor flexibility behind the crimped
connection
- No burnt, discolored and overheated wire insulation
- Good connections with reproducible electrical and mechanical
performances
- Easy production control.
S16RCM16
S16RCM14
S16SCM20
S16SCML11
S16SCML1
* example of plating options, for other plating see page 164
177
User Guide
1) Fully close then release the tool, keep it open.
Open the 2 pins.
2) Choose the adapter head (sold separately), keep vertical and
slide it into the handle until the mechanical end.
3) Close the two pins simultaneously to maintain the head.
4) Strip the cable properly check the recommended size
in the catalog on page 180.
GOOD
178
WRONG
WRONG
5) Place conductors, with no deteriorations, in the bucket contact.
All strands to be located in the crimp bucket.
6) Position the contact in the bottom of the tool by checking
its orientation.
7) To crimp contact assembly-cable, tighten sharply the clip
to the end of the mechanism (maxi 175N).
8) To control crimp quality, slighty pull cable with two fingers
to control retention.
Contact size
Insertion tool
#20
Ø0.039"
RTM205
#16
Ø0.062"
RTM205
Contact size
Extraction tools
#20
Ø0.039"
RX20D44
#16
Ø0.062"
RX2025GE1
#12
Ø0.094"
51060210924
#8
Ø0.141"
51060210936
RX2025GE1
RTM205
RX20D44
51060210936
51060210924
Contact extraction instruction
Place the tool into the cavity from front face of the connector, push on the handle, then remove the contact.
Overmolded Cable Assembly Dimensions
L
L1
UTS7
UTS0
UTS0
UTS7
Shell
size
L max
L1 max
L max
L1 max
10
3.44"
3.2"
3.67"
3.2"
12
3.55"
3.3"
3.79"
3.3"
14
3.85"
3.6"
4.08"
3.6"
L
179
UTS0 Assembly (Mounting Suggestion)
• Strip wires, crimp or solder contacts (see pages 176 & 177)
• Insert contacts into connector cavities (insert manually or use tool RTM205 crimp contacts)
• Place receptacle in the panel cut-out
• Secure receptacle with screws (not supplied)
Tighten screws: M2.5 (recommended torque: see table below)
• For complete sealing of the system use optional gasket and sealed screw solution (not sold by Souriau).
Front mounting: Crimp version
Rear mounting: Crimp version
1
1
Optional
coding ring
Gasket (optional)
Front mounting: Solder version
2
Optional
coding ring
3
Gasket (optional)
Optional
coding ring
Rear mounting: Solder version
2
Gasket (optional)
Optional
coding ring
3mm max
3
Gasket (optional)
0.118" max
Receptacle flange
Receptacle flange
Panel thickness:
0.098" max
Panel
Shell size
Screw tightening torque
(Nm)
180
8
10
12
14
18
0.30/0.40
0.30/0.40
0.30/0.40
0.30/0.40
0.35/0.45
UTS7 Assembly (Mounting Suggestion)
• Strip wires and crimp contacts (see pages 176 & 177)
RTM205 crimp contacts )
• Seat o-ring, place receptacle in the panel cut-out
• Tighten jam nut
Shell size
Jam nut
torque
(Nm) maxi
Exterior
jam nut
dim.
(inches)
8
1.5
0.748"
10
3
0.874"
12
4
1.063"
14
5
1.185"
18
5
1.437"
Crimp or solder version
Optional
coding ring
O-ring
Ø Wire
Standard
version
Discrete
wire
sealing
0.125"
max.
From
0.066"
to
0.118"
Jam nut
Panel thickness:
3.2mm max
Threaded version
Threaded receptacle
Shell size
Jam nut torque
(Nm) maxi
Threading
P mini
(mm)
8
2.5
M12 x 1.5
0.303"
10
3.75
M16 x 1.5
0.303"
12
3.75
M20 x 1.5
0.409"
14
4.18
1/2"
0.326"
18
4.76
3/4"
0.456"
P
Receptacle
Panel
thickness
• Insert first contact into the grommet (first contact in cavity A,
no tool is required). Then insert the contact in the connector
cavity A (insert manually or use tool RTM205)
• Insert the other contacts
• Tighten the nut to rear of either UTS6 or UTS7 (recommended
torque values to be applied according to the table below).
UTS6 or UTS7 with GN Backshell Assembly
UTS6
Nut
Optional
coding ring
Shell size
layout
Nut tightening
torque (Nm)
10
4
1
12
8
1.5
14
7
1.5
14
12
1.5
Ø Wire
From
0.066"
to
0.118"
Grommet
+ Compression ring
UTS7
181
Assembly Instructions (Continued)
UTS1JC or UTS6JC Assembly: Crimp Version
• Slide accessories onto the cable
Adapter + mounted gasket
UTS6
Make sure the seal is positioned as shown.
Reducing
Coding ring
Standard
(optional)
• Mate the plug with a corresponding
counter part
• Strip external cable jacket
• Tighten adapter with plug UTS6 or receptacle
UTS1, choose right seal (waste the other seal)
• Tighten the nut to rear of either UTS1 or
UTS6 (recommended torque values to be
applied according table to the right)
• Caution: only one of both delivered gasket
should be used !
Nut
Cable
range
UTS1
Cable ranges
Recommended Adapter
Nut
Ø Cable range Ø Cable range
Ø
jacket strip
Shell
tightening tightening
Standard seal Reducing seal
Wire
size length (inches)
torque
torque
(inches)
(inches)
(inches)
(Nm)
(Nm)
Male Female
10 0.826" 1.141"
1.5
1
0.098"/0.0314" 0.059"/0.196" From
12 0.984" 1.299"
2
2.5
0.196"/0.472" 0.118"/0.354" 0.066"
to
14 1.141" 1.417"
3
2.5
0.275"/0.551" 0.196"/0.472"
0.118"
18 1.456" 1.771"
4
3.5
0.354"/0.708" 0.275"/0.629"
UTS6JC Assembly: Solder Version
Cable
range
Reducing
receptacle
• Tighten adapter with plug, choose right
should be used !
182
Nut
Standard
Coding ring
(optional)
Shell
size
8
10
12
14
Recommended
jacket strip
length (inches)
Male
0.669"
0.826"
0.984"
1.141"
Cable ranges
Adapter
Nut
Ø Wire
torque
torque
(inches)
(inches)
(inches)
(Nm)
(Nm)
1
1.5
2
3
0.75
1
2.5
2.5
0.098"/0.255"
0.098"/0.314"
0.196"/0.472"
0.275"/0.551"
1.5/0.196"
1.5/0.196"
0.118"/0.354"
0.196"/0.472"
From
0.066"
to
0.118"
UTS6JC Screw Termination Assembly
• Mate the plug with a corresponding receptacle equiped with
its contacts
• Choose and place right seal depending on cable diameter
(see table below)
1
• Slide accessories on the cable
• Strip external jacket (see table below).
2
Receptacle
Plug
Nut
• Strip the wires (strip length 0.228")
• Place the conductors in the contact barrel.
Make sure all conductor strands are inside the barrel
• Tight the contact screws, advised torque 20 Ncm
3
4
0.228"
Torque: 20Ncm
Head dimension 0.157"x 0.078"
• Check the mechanical cable retention, by gently pulling the cable
with 2 fingers
• Tighten adapter with the plug (recommended torque: see table)
5
• Tighten backshell nut with adapter
(cables should not turn into the backshell during this operation).
6
Shell
size
Recommended jacket
strip length (inches)
Male
Female
Adapter
tightening torque
(Nm)
Nut
tightening torque
(Nm)
Ø Cable range
Standard seal
(inches)
Ø Cable range
Reducing seal
(inches)
12
0.897" max 0.594" max
2
2.5
0.196"/0.472"
0.118"/0.354"
14
1.051" max 0.74" max
3
2.5
0.275"/0.551"
0.196"/0.472"
Ø Wire
(inches)
From 0.066"
to 0.118"
183
UTS1GJC or UTS6GJC Assembly
• Slide accessories onto the cable (make sure
to keep compression ring on the grommet)
contact in cavity A, no tool is required).
• Place the grommet and compression ring on
the insulator
applied according to the table right).
Coding ring
(optional)
Cable
range
UTS6
Nut
Reducing
Grommet +
Compression ring
Standard
UTS1
Cable ranges
10
12
Recommended Adapter
jacket strip
tightening
length (inches)
torque
(Nm)
Male Female
0.826" 1.141"
1.5
0.984" 1.299"
2
14
1.141" 1.417"
Shell
size
3
Nut
tightening
torque
(Nm)
(inches)
(inches)
2
2.5
0.098"/8.0
0.196"/0.472"
0.059"/0.196"
0.118"/0.354"
2.5
0.275"/0.551"
0.196"/0.472"
UTS0 + UTS6
UTS7 + UTS6
UTS6JC or UTS6GJC
UTS6JC or UTS6GJC
UTS0
UTS7
UTS6GN
B
D
A
Shell size
UTS0
+ UTS6JC or UTS6GJC
UTS0
+ UTS6GN
A max
8
2.405"
C
UTS7
+ UTS6JC or UTS6GJC
UTS7
+ UTS6GN
B max
C max
D max
3.622"
10
2.881"
1.559"
3.043"
1.720"
12
3.055"
1.551"
3.216"
1.712"
14
3.287"
1.574"
3.448"
1.736"
18
3.665"
3.826"
184
UTS6GN
Ø Wire
(inches)
From
0.066"
to
0.118"
Mating Procedure
UTS Coupling Procedure
The pictures below provide step by step instructions on how to mate a plug and receptacle connector in order to avoid damaging any of the
contacts.
• Identify the primary key of each connector.
1
• Align the primary keys of the connectors.
2
• Offer the plug to the receptacle.
• Incorrect positioning:
3
4
• Turn coupling ring until you hear a 'click'
• If the cable is free, a mechanical stress can appear on the plug
and receptacle, at the end you can have a break of the plug or
receptacle if there is a high vibration level.
5
6
7
Example of installation
185
Current Carrying Capacity
The current carrying capacity of a connector is limited by the thermal properties of materials used in its construction. The amount of current that
can be handled depends on the size of cable used, the ambient temperature and the heat that is generated inside the connector. Part 3 of the
IEC 60512 standard determines through a derating curve, the maximum current permissible, which varies from one layout to another (Fig.1 &
Fig.2). Wire size plays an important role in dissipating heat and avoid overheating (Fig.1 & Fig.3).
Please note that the curve should be adjusted when dealing with potential hot spots, which can occur as a result of unequal loading of current
across a number of contacts. As a general rule, it is best to avoid placing power handling contacts in the middle of the connector; try to locate
them towards the edge where heat can be dissipated more effectively. Eventually you should find a level which represents the permissible operating range:
Fig.1: UTS 12-4 – 1.5mm² wires
28
28
25
25
23
23
15
13
10
18
15
13
10
8
5
5
3
3
60
80
100
Ambient Operating Temperature (°C)
120
60
80
100
120
Fig.3: UTS 12-4 – 2.5mm² wires
35
33
Current (A)
Fig.2: UTS 12-8 – 1.5mm² wires
30
Current (A)
Current (A)
30
30
28
25
23
Current use
Limited use
15
13
Not recommended use
10
8
5
3
60
80
100
120
The rated current is defined as uninterrupted continuous current that a connector can take when all contacts are energized simultaneously
without exceeding the maximum limit of temperature. The earth contact is never loaded.
186
UV Resistance
Exposure in Natural Environment
Solar radiation affects all materials, but plastics can be
susceptible to extreme degradation over time.
The choice of materials for the UTS series was therefore
a critical consideration.
Yearly mean of daily irradiation in UV (280-400 nm)
on horizontal plane (J/cm²) (1990-2004)
90°
60°
All over the world we are not exposed to the same
amount of energy given by the sun. The chart shown
here clearly illustrates this.
30°
0°
So we performed test according to the ISO 4892-2 and
simulated 5 years exposure to outdoor environments
(temperature, humidity, etc.).
After this period there was no significant colour variation,
no crazing, no cracking and no major variation of
mechanical properties.
- 30°
- 60°
- 90°
- 180°
- 150°
- 120°
- 90°
- 60°
- 30°
0°
30°
60°
90°
120°
150°
180°
190
180
170
160
150
140
130
120
110
100
90
70
80
60
50
40
30
J/cm²
In addition, we asked UL to perform UV test per the
UL746C. Our material has been rated F1 which is the
highest level in this standard.
187
UL94 + UL1977
Underwriter Laboratories
There are two main standards for industrial connectors: UL94 & UL1977
UL94
This standard is dedicated to plastics flammability. It characterises how the material burns in various orientation and thicknesses.
The UTS series has been rated at V-0 for UTS sealed mated & HB for UTS sealed unmated.
Procedure: A specimen is supported in a vertical or horizontal position and a flame is applied to the bottom of the specimen. The flame is applied
for ten seconds and then removed until flaming stops, at which time the flame is reapplied for another ten seconds and then removed. Two sets
of five specimens are tested.
V-0 Vertical burning:
• Specimens must not burn with flaming combustion for more
than 10 seconds after each test flame application
• Total flaming combustion time must not exceed 50 seconds
for each set of 5 specimens
• Specimens must not burn with flaming or glowing combustion
up to the specimen holding clamp
• Specimens must not drip flaming particles that ignite
the cotton
• No specimen can have glowing combustion remain for longer
than 30 seconds after removal of the test flame.
Material
13±0.5mm
125±1mm
45°
300±1mm
Cotton
100±1mm
HB Horizontal burning:
• A material classified HB shall not have a burning rate
exceeding 40 mm per minute over a 75 mm span for
specimens having a thickness of 3.0 to 13 mm
exceeding 75 mm per minute over a 75 mm span for
specimens having a thickness less than 3.0 mm
• A material classified HB shall cease to burn before the
100 mm reference mark.
188
25±1mm
Material
13±0.5mm
45°
Wire gauze
45°
10±1mm
Wire gauze
UL1977
There are several standards which deal with plug and receptacle. Each of them is only for a small area of applications. It could be
telecommunication, etc. The UL 1977 covers single and multipole connectors intended for factory assembly.
Requirements apply to devices taking into account intensity and voltage. The categories are as follows:
30 V
(42 V peak)
600 V
Type 0
Type 1A
Type 2
31 A
Tybe 1B
Type 3
Type 4
1000 A
According to above table, the level of performance that has to be reached could be different. Most of them are explained in the following page.
Insulating materials:
Material uses for electrical insulation, as a minimum, have to comply with the characteristics shown below:
• Minimum ratings for polymeric materials
Type
Flame rating
Relative thermal index (RTI)
Electrical/mechanical w/o impact */**
1A
HB
50/50
1B
HB
50/50
2
HB
50/50
3
HB
50/50
4
HB
50/50
* The RTI of the material shall not be lower than the temperature measured during
the Temperature Test.
** For a thickness less than that for which a value has been established, the RTI of
the minimum thickness with an established value shall be used.
Assembly:
Connector has to be keyed to prevent any mismating that can damage the machine or hurt the user. In the same way, plugs and sockets have to
be equipped to protect persons against contact with live parts.
Finally the identified grounding contact shall be located so that the corresponding electrical continuity has to be completed before any other
contact.
189
UL94 + UL1977 (Continued)
UL1977
Spacing:
For a 250V max connector, distance through air or over material shall be 1.2mm whereas from 250V to 600V connector the spacing is 3.2mm
minimum. These distances have to be taken between uninsulated live parts as shown in the matrix below:
• Applicability of spacing requirements
Type
Uninsulated live part - uninsulated
live part of opposite polarity
grounded metal part
Uninsulated live part - exposed dead
metal part
No
No
No
1A
Yes
Yes
Yes
1B
Yes
Yes
No
2
Yes
Yes
Yes
3
Yes
Yes
Yes
4
Yes
Yes
Yes
An alternative way to determine voltage rating is with the Dielectric-Withstand test. If during one minute there is no arc-over or breakdown the
rated voltage is given as shown below:
a) 500 volts for a type 1B device
b) 1000 volts plus twice rated voltage for types 1A, 2, 3 and 4 devices.
Marking:
A device shall be legibly marked with the manufacturer's trade name, trade mark, or other descriptive marking by which the organization
responsible for the product may be identified. (Exception: If the device is too small, or where the legibility would be difficult to attain, the
manufacturer’s name, trademark, or other descriptive marking may appear on the smallest unit container or carton)
The following shall be marked on the device or on the smallest unit container or carton or on a stuffer sheet in the smallest unit container or
carton:
a) The catalog number or an equivalent designation
b) The electrical rating in both volts and amperes, if assigned
c) Whether ac or dc, if restricted
d) Flammability class, if identified
Example - Marking for the arrangement 10-3:
190
10A 500V UL94 V-0
IEC 61984
The norm is dedicated to connectors with rated voltage above 50V and up to 1000V and rated currents up to 125A per contact.
Depending on your application connectors should be compliant with another standard. This has to be double checked with the customer.
There are a lot of constructional requirements and performances specified in that standard. Most of them are illustrated in greater details hereafter.
Provisions for earthing:
The UTS connector is intended to be used on Class I or Class III (see IEC 61140) systems. Even if the purpose of our connector is not to interrupt
current, there is a need to add a protective earth contact. This one shall be a “First mate, last break” style. Critically, among all of the normal
assumptions we make in designing a connector, this contact has to be considered as a live part and must be protected attached to the ground
wire.
First digit
(foreign bodies
protection)
IP Code:
IP is a coding system defined by the IEC 60529 to indicate the
degrees of protection provided by an enclosure. The aim of this is to
give information regarding the accessibility of live parts against ingress
of water and other foreign bodies.
5
6
Full protection against contact. Protection against interior injurious
dust deposits.
Total protection against contact.
Protection against penetration of dust.
UTS offers high sealing
performance IP68 / 69K…
Even in dynamic situations.
IP 6 8
Second digit
(water
protection)
2nd digit
Degree of protection
No protection against water.
1
2
Drip-proof.
Protection against vertical water drips.
Drip-proof.
Protection against water drips up to a 15° angle.
3
Spray-proof.
Protection against diagonal water drips up to a 60° angle.
4
Splash-proof.
Protection against splashed water from all directions.
Hose-proof.
Protection against water (out of a nozzle) from all directions.
Protection against temporary flooding.
5
6
7
8
1st digit
No protection against accidental contact.
No protection against solid foreign bodies.
1
Protection against contact with any large area by hand and against
large solid foreign bodies with a diameter bigger than 50 mm.
2
Protection against contact with the fingers.
Protection against solid foreign bodies with a diameter bigger than
12 mm.
3
Protection against tools, wires or similar objects with a diameter
bigger than 2.5 mm.
Protection against small solid bodies with a diameter bigger than
2.5 mm.
4
Same as 3 however diameter is bigger than 1 mm.
Code letters
(international
Protection)
Protection against temporary immersions.
Protection against water pressure.
Pressure to be specified by supplier.
In addition to the IEC 60529 we conjointly use the DIN 40050 part 9
which are dedicated to road vehicles. The main differences are:
• First digit: 5 replaced by 5K, 6 by 6K. In the DIN the tested
equipment is not depressurized as it is in the IEC.
• Second digit: 5K and 6K has been added and are equivalent
respectively to 5 and 6 but with higher pressure.
9K which represents the High pressure cleaning.
9K
High pressure hose-proof.
Protection against high pressure water (out of a nozzle) from all
directions.
IEC 61984 ed.2.0 “Copyright © 2008 IEC Geneva, Switzerland.www.iec.ch"
IEC 60664-1 ed.2.0 “Copyright © 2007 IEC Geneva, Switzerland.www.iec.ch”
191
IEC 61984 & IP Codes Explained (Continued)
IEC 61984
Overvoltage
UTS connectors are qualified to be used on systems rated at Overvoltage category III
Per the IEC 60664-1 (formely VDE 0110) each category is linked to the end application and where the device will be implemented:
• Category IV (primary overcurrent protection equipment):
Origin of the installation
• Category III (any fixed installation with a permanent connection)
Fixed installation and equipment and for cases where the reliability and the availability is subject to special requirements
• Category II (domestic appliances):
Energy consuming equipment to be supplied from the fixed installation
• Category I (protected electronic circuit):
For connection to circuit in which measures are taken to limit transient overvoltage.
Pollution degree
Per the IEC 60664-1 (formerly VDE 0110) the environment affects the performance of the insulation. Particles can build a bridge between
two metal parts. As a rule dust mixed with water can be conductive and more generally speaking metal dust is conductive. Finally, the
standard defines 4 levels of pollution:
• Degree 1 (Air conditioned dry room):
No pollution or only dry, non conductive pollution occurs. The pollution has no influence.
• Degree 2 (Personal computer in a residential area):
Only non conductive pollution occurs except that occasionally a temporary conductivity caused by condensation is to be
expected.
• Degree 3 (Machine tools):
Conductive pollution occurs or dry non-conductive pollution occurs which becomes conductive due to condensation which is to
be expected.
• Degree 4 (Equipments on roof, locomotives):
Continuous conductivity occurs due to conductive dust, rain or other wet conditions.
Finally, the harsher the environment is, the longer clearance and creepage distances should be. Nonetheless, according the IEC 61984,
enclosure rated at IP54 or higher can be dimensioned for a lower pollution degree. This applies to mated connectors disengaged for test and
maintenance.
Marking
The marking should give enough details to the user to know what the main characteristics are and without going deep in technical
documentation. Below examples identify the suitability of the connector:
• Example 1:
Marking of a connector with rated current 16A, rated voltage 400V, rated impulse voltage 6kV and pollution degree 3, 2 and 1 for
use in any system, preferably unearthed or delta-earthed systems:
16A
400V
6kV
16A
400V
6kV
33
• Example 2:
Marking of a connector with rated current 16A, rated insulation voltages line-to-earth 250V, line-to-line 400V, rated impulse
voltage 4kV and pollution degree 3, 2 and 1 for use in earthed systems:
16A250V
250V400V
400V4kV
4kV3 3
16A
192
IEC 61140 Explained
IEC 61140
On a daily basis, we are using many electrical appliances, some are grounded, and some are not. The levels of grounding protection are clearly
defined by the International Electrotechnical Commission standard IEC 61140, a standard that has an influence on our connectors and how
they should be used; our customers therefore need to pay particular attention to the three categories defined within this standard to ensure
compatibility with their system. Everything explained hereafter is valid for connectors not intended to interrupt current.
Class I:
Devices which belong to this category have their chassis grounded via the ground wire (green/yellow in Europe, green in the US, Canada and
Japan). A fault in the appliance might cause a live conductor to energize the casing. In this case, the current flows to the ground conductor and
the circuit interrupter will cut off the power supply. In case of the UTS series, it means the envelope (coupling ring, backshell and housing) may
become live, therefore, care needs to be taken to attach the connector to the ground. This is usually done via the ground conductor using a splice
between the ground contact and the housing.
Class II:
Products in this category have reinforced insulation, meaning that the casing does not need to be connected to ground. In this case, the possibility
of electric shock has been removed. Most of the time, reinforced insulation means double insulation, i.e. the second layer will take over the first
one in case the first one fails. The UTS series is not designed to comply with this standard, so we cannot recommend it for this product category.
Note: UL 1310 also defines a class II device, but in that case this is just to set the upper limit of use, like a wall charger for our cell phone.
Class III:
In this category, electrical appliances are fed by a low voltage source (
