FGG.1K.304.CLAC50Z
FGG.1K.304.CLAC50Z
    LEMO(雷莫)
    CONN PLUG MALE 4P GOLD SLDR CUP
FGG.1K.304.CLAC50Z 数据手册
FGG.1K.304.CLAC50Z www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 1K Termination type Male solder IP rating 68 AWG wire size 30.00 - 22.00 Cable Ø 4.60 - 5.00 mm Status active Matching parts EGG.1K.304.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 23.15 g Performance Configuration 1K.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1450 V (AC), 2050 V (DC) Vtest (contact-contact): 1350 V (AC), 1910 V (DC) Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 13 42 28 9 in. 0,51 1,65 1,10 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1E.008.PA090 Caps: BFG.1K.100.NAS Cables CMN.04.T22.047QGC TPR Grey CMN.04.T22.048QGZE TPR (medical) Grey 140240 PVC Black 140250 PVC Grey 40260 PVC Black 4221 PVC Black 80080 PVC Grey 80082 PVC Red 80084 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1K.304.CLAC50Z 价格&库存
很抱歉,暂时无法提供与“FGG.1K.304.CLAC50Z”相匹配的价格&库存,您可以联系我们找货
