Circular Connectors Conforming to JIS C 5432
JR Series
Features
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1. These round connectors conform to
JIS C 5432 "Circular connectors for
electric appliances."
Product Specifications
Shell size
13
16
Ratings
Rated
current
21
25
Ratings
Rated
voltage
Shell size
13
16
21
25
Ratings
Number of contacts
3
5
7
10, 14
10
16
26
4
5, 16
24
Rated current
10A
5A
10A
5A
10A
5A (Crimp type : 3A)
5A (Contact numbers A and B only : 10A)
30A
10A
Number of contacts
3, 5
7, 10, 14
10, 16, 26
4, 5
16, 24
Rated voltage
AC250, DC350V
AC1000V, DC1400V
AC250, DC350V
Operating temperature range
-25 to +85ç
Storage temperature range
-10 to +60ç
Items
Specifications
Conditions
1. Contac resistance
5mø max.
JR 21-16 contact crimping type : 10mø max.
JR 25-24 contact crimping type : 10mø max.
Measured at DC 1A
2. Insulation resistance
1,000Mø min.
JR 25-4 and 5 contacts : 10,000Mø min.
Measured at DC 500V
3. Withstanding voltage No flashover or dielectric breakdown.
AC 1,000V for 1 minute
JR 25-4, 5 contacts : AC 3,000V for 1 minute
4. Vibration resistance
No electrical discontinuity for 10µs or greater
10 to 55Hz/cycle, amplitude : 0.75mm, 3 directions,
2 hours each
5. Shock resistance
Acceleration : 490m/s2, duration : 11ms,
6 axis directions, 3 cycles each
6. Mating cycles
Contact resistance : 10mø max.
500 times
Insulation resistance : 1,000Mø min.
-40ç : 30 minutes ➝ Normal temperature : 10 to
7. Temperature cycle JR 25-4 and 5 contacts : Insulation resistance : 15 minutes ➝ 100ç : 30 minutes ➝ Normal
10,000Mø min.
temperature : 10 to 15 minutes, left for 5 cycles
8. Moisture resistance
Insulation resistance (when dry) 100Mø min.
5,000Mø min. : JR 25-4 , 5 contacts
Temperature : 40ç, relative humidity: 90 to 95%,
left for 96 hours
■Materials / Finish
Part
Material
Finish
Remarks
Shell
Aluminum alloy
Nickel plating
Insulator
Phenol resin
PPS resin
UL94V-0
Contact
Copper alloy
Silver plating
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.10⑦
1
JR Series●Circular Connectors Conforming to JIS C 5432
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
JR 16 P A - 10 S C (**)
❶
❷
❸
❹
❺
❻
❼
❽
qModel name : JR Series
tNumber of contacts
wShell size : The shell size is the outer shell diameter of the yContact form
mating end of the plug.
P : Male contact
S : Female contact
eShell type
P : Threaded lock plug
J : Threaded lock jack
uContact termination method:
R : Threaded lock receptacle BP : Bayonet-lock plug
None : Solder termination
RC : Threaded lock receptacle cap BR : Bayonet-lock receptacle
C
: Crimp termination
rShell variation : Letters such as A, B, C, etc. indicate
variations in the shell.
iOther specifications : A two-digit number is added to
indicate other specifications.
Solder Type
Threaded lock plug
E
3
ØD
1
ØC
4
ØA
Z
Y
2
X
B
JR25PH-4S
JR13PK-3P(71)
114-0501-7 71
No. of
contacts
3
JR13PK-5P(71)
114-0502-0 71
5
7
Part No.
2
HRS No.
ØA
B
ØC
ØD
E
12.7
M18×1
21.8
8.5
45.5
16.3
M22×1
25.8
11.5
49.5
20.5
M26×1
29.8
15
53.5
JIS No.
CNR01SPM013003
CNR01SPM013005
JR16PK-7P(71)
114-0503-2 71
JR16PK-10P(71)
114-0504-5 71
JR21PK-10P(71)
114-0505-8 71
JR21PK-16P(71)
114-0506-0 71
JR25PK-16P(71)
114-0507-3 71
JR25PK-24P(71)
114-0508-6 71
24
JR25PH-4P
114-0626-2
4
JR25PH-5P
114-0624-7
5
JR13PK-3S(71)
114-0509-9 71
3
CNR01SPF013003
JR13PK-5S(71)
114-0510-8 71
5
JR16PK-7S(71)
114-0511-0 71
7
JR16PK-10S(71)
114-0512-3 71
JR21PK-10S(71)
114-0513-6 71
JR21PK-16S(71)
114-0514-9 71
JR25PK-16S(71)
114-0515-1 71
10
16
24.7
12.7
M30×1
M18×1
33.8
21.8
18
8.5
56.5
45.5
16.3
M22×1
25.8
11.5
49.5
20.5
M26×1
29.8
15
53.5
16
114-0516-4 71
24
JR25PH-4S
114-0627-5
4
CNR01SPM021010
CNR01SPM021016
CNR01SPM025016
10
JR25PK-24S(71)
CNR01SPM016007
CNR01SPM016010
CNR01SPM025024
CNR01SPF013005
CNR01SPF016007
CNR01SPF016010
CNR01SPF021010
CNR01SPF021016
CNR01SPF025016
24.7
M30×1
33.8
18
56.5
CNR01SPF025024
C
2
D
E
10.5
X
2
ØA
B
15.9
M18×1
19.9
M22×1
23.9
M26×1
27.9
M30×1
15.9
M18×1
19.9
M22×1
23.9
M26×1
27.9
M30×1
10
16
24
4
3
5
7
D
E
26
23
32
26
35
29
26
23
32
26
35
29
16
27
28
27
28
27
28
27
28
27.8
D
JIS No.
CNR01SRM013003
CNR01SRM013005
CNR01SRM016007
CNR01SRM016010
CNR01SRM021010
CNR01SRM021016
CNR01SRM025016
CNR01SRM025024
-------------CNR01SRF013003
CNR01SRF013005
CNR01SRF016007
CNR01SRF016010
CNR01SRF021010
CNR01SRF021016
CNR01SRF025016
CNR01SRF025024
28
10
24
4
5
C
26.6
26.1
26.6
26.1
26.6
26.1
26.6
26.1
.3
Threaded lock jack
C
ØA
016010
X1 2 3 Z
4 5 6 7
8 9 10
ØD
Y
No. of contacts
3
5
7
Z
3
HRS No.
114-0517-7
114-0518-0
114-0519-2
114-0520-1
114-0521-4
114-0522-7
114-0523-0
114-0524-2
114-0628-8
114-0525-5
114-0526-8
114-0527-0
114-0528-3
114-0529-6
114-0530-5
114-0531-8
114-0532-0
114-0629-0
114-0625-0
E
4
ØA
1
Y
Part No.
JR13RK-3P
JR13RK-5P
JR16RK-7P
JR16RK-10P
JR21RK-10P
JR21RK-16P
JR25RK-16P
JR25RK-24P
JR25RH-4P
JR13RK-3S
JR13RK-5S
JR16RK-7S
JR16RK-10S
JR21RK-10S
JR21RK-16S
JR25RK-16S
JR25RK-24S
JR25RH-4S
JR25RH-5S
Ø3
4×
B
JR25RH-4P
B
JR25JK-24P
Part No.
JR13JK-3P
JR13JK-5P
JR16JK-7P
JR16JK-10P
JR21JK-10P
JR21JK-16P
JR25JK-16P
JR25JK-24P
JR13JK-3S
JR13JK-5S
JR16JK-7S
JR16JK-10S
JR21JK-10S
JR21JK-16S
JR25JK-24S
HRS No.
114-0533-3
114-0534-6
114-0535-9
114-0536-1
114-0537-4
114-0538-7
114-0539-0
114-0540-9
114-0541-1
114-0542-4
114-0543-7
114-0544-0
114-0545-2
114-0546-5
114-0548-0
No. of contacts
3
5
7
ØA
B
C
ØD
19
M18×1
44.5
8.5
23
M22×1
48.5
11.5
27
M26×1
52.5
15
31
M30×1
55.5
18
19
M18×1
44.5
8.5
23
M22×1
48.5
11.5
27
M26×1
52.5
15
31
M30×1
55.5
18
10
16
24
3
5
7
10
16
24
3
Crimp Type
Threaded lock plug
E
1
Y4
8
ØD
ØA
ØC
X
Z
3
7
10
B
JR21PK-10PC(71)
Part No.
JR21PK-10PC(71)
JR21PK-10SC(71)
JR21PK-16PC(71)
JR21PK-16SC(71)
JR25PK-24PC(71)
JR25PK-24SC(71)
HRS No.
114-0570-0 71
114-0571-2 71
114-0572-5 71
114-0573-8 71
114-0574-0 71
114-0575-3 71
No. of contacts
ØA
B
ØC
ØD
E
Remarks
20.5
M26×1
29.8
15
53.5
24.7
M30×1
33.8
18
56.5
10
Contact Ø1.6
16
Contact Ø1
24
D
C
2
E
10.5
7
3
10
E
X
D
ØA
Z
1
8
Y
Part No.
JR21RK-10SC
JR21RK-16PC
JR21RK-16SC
JR25RK-24SC
HRS No.
114-0577-9
114-0578-1
114-0579-4
114-0581-6
.3
Ø3
4×
B
JR21RK-10SC
No. of contacts
10
16
24
ØA
B
23.9
M26×1
27.9
M30×1
C
27.6
25.4
23
D
E
32
26
35
29
Remarks
Contact Ø1.6
Contact Ø1
.3
Ø3
Ø6
ØB
JRC25RC
(71)
Part No.
JRC13RC(71)
JRC16RC(71)
JRC21RC(71)
JRC25RC(71)
4
HRS No.
114-0053-8 71
114-0054-0 71
114-0055-3 71
114-0056-6 71
A
M18×1
M22×1
M26×1
M30×1
ØB
21
25
29
33
C
10
JIS No.
CNR01RC013
CNR01RC016
CNR01RC021
CNR01RC025
A
4
C
80
Solder Type
Bayonet - lock plug
5
9
6
ØB
ØA
8
X 10160102
4
7
3 Z
10
ØD
Y
C
JRC16BP-14P(71)
HRS No.
No. of contacts
ØA
ØB
C
ØD
JRC16BP-14P(71)
114-0251-1 71
14
16.3
27
91
11.2
JRC21BPA-26P(31)
114-0268-4 31
26
20.5
31
98
12.2
JRC16BP-14S(71)
114-0254-0 71
14
16.3
27
91
11.2
JRC21BP-26S(31)
114-0267-1 31
26
20.5
31
98
12.2
Remarks
Bayonet - lock receptacle
D
C
2
E
10.5
D
5
E
2
ØA
6
4
1Z
8
.3
Ø3
4×
JRC16BR-14S(71)
Part No.
X3
10 9
7
ØB
Y
Part No.
HRS No.
No. of contacts
ØA
ØB
C
D
E
JRC16BR-14P(71)
114-0257-8 71
14
20.5
19.9
26.6
29
23
JRC21BR-26P(71)
114-0269-7 71
26
25.8
23.9
26.8
32
26
JRC16BR-14S(71)
114-0260-2 71
14
20.5
19.9
25.8
29
23
JRC21BRA-26S
114-0270-6
26
25.8
23.9
28
32
26
Remarks
5
Crimp Contacts
Contact diameter Ø1.0mm
Male contact
A−A
B
1.4
C
A
A
19.3
Female contact
A−A
1.4
C
Part No.
HRS No.
B
C
Applicable wire
Loose
contact
JRC-PC2-112
114-0243-3
1.6
2.0
20 to 24 AWG
JRC-PC2-122
114-0244-6
1.45
1.5
24 to 28 AWG
Reel
contact
JRC-PC2-212
114-0245-9
1.6
2.0
20 to 24 AWG
JRC-PC2-222
114-0246-1
1.45
1.5
24 to 28 AWG
Type
Part No.
HRS No.
B
C
Applicable wire
Loose
contact
JRC-SC2-112
114-0247-4
1.6
2.0
20 to 24 AWG
JRC-SC2-122
114-0248-7
1.45
1.5
24 to 28 AWG
Reel
contact
JRC-SC2-212
114-0249-0
1.6
2.0
20 to 24 AWG
JRC-SC2-222
114-0250-9
1.45
1.5
24 to 28 AWG
B
A
17
Type
A
Note : Loose contact in pack of 100 pcs. Reel contact contains 8,000 pcs.
Contact diameter Ø1.6mm
Male contact
A−A
B
C
2.4
A
23.7
A
Type
Loose
contact
Reel
contact
Part No.
HRS No.
JRC-PC-112
114-0239-6
JRC-PC-212
114-0240-5
Part No.
HRS No.
JRC-SC-112
114-0241-8
JRC-SC-212
114-0242-0
B
C
Applicable wire
2.3
2.9
16 to 20 AWG
B
C
Applicable wire
2.3
2.9
16 to 20 AWG
Female contact
A−A
B
24
A
C
2.4
A
Type
Loose
contact
Reel
contact
Note : Loose contact in pack of 100 pcs. Reel contact contains 5,000 pcs.
6
Applicable Tools
Contact dia.
Type
Item
Manual
Manual
crimping tool
Automatic
crimping press
Ø1
Automatic
Part No.
HRS No.
Applicable terminal
Applicable wire
HT802/RM-11
150-0401-6
JRC-PC2-112
JRC-SC2-112
20 to 24 AWG
HT802/RM-12
150-0402-9
JRC-PC2-122
JRC-SC2-122
24 to 28 AWG
CM-105C
901-0001-0
AP105-JRC2-1
901-2037-1
AP105-JRC2-2
901-2038-4
RM-TP
150-0008-7
Applicator
Extraction tool
Manual
Manual
crimping tool
Automatic
crimping press
Ø1.6
JRC-PC2-212
JRC-SC2-212
JRC-PC2-222
JRC-SC2-222
-------------JRC-PC-112
JRC-SC-112
JRC-PC-112
JRC-SC-112
20 to 24 AWG
24 to 28 AWG
-------------16 AWG
JRC-TC-11
150-0033-4
JRC-TC-12
150-0034-7
CM-105C
901-0001-0
AP105-JRC-1
901-2039-7
JRC-PC-212
JRC-SC-212
16 to 20 AWG
JRC-TP
150-0035-0
18 to 20 AWG
Automatic
Applicator
Extraction tool
Hand Tool Crimp
(For Contact Diameter Ø1.0mm)
(For Contact Diameter Ø1.6mm)
Extraction Tool
Automatic Crimping
Machine CM-105C
Precautions
1. This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may
cause tarnishing.
・Dusty environments
・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas
and so on.
Example; In close proximity to factory exhaust, automotive emissions, etc.
・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.
・Close to rubber products includes rubber adhesives.
The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins.
2. Storage
Packing state; Packed in original packing or equivalent container
Temperature -10 to +60℃
Humidity
85% Max
(It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any
temperature fluctuation)
Please use this products within 6 months of delivery.
(After 6 month, please check the solderbility before use)
“Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB.
3. Ask a Hirose sales personnel to provide Cable Assembly Procedure (ETAD-C0473-00)
7
Contact Position Arrangement
Shell size
13
No. of contacts
Current rating
Contact resistance
Solderpot inner diameter
3
5
AC1000V a minute
10A
5A
1000Mø MIN.
5mø MAX.
1.7mm dia.
1.1mm dia.
Shell size
16
No. of contacts
Current rating
Contact resistance
7
10
14
AC1000V a minute
10A
5A
1000Mø MIN.
5mø MAX.
1.7mm dia.
1.1mm dia.
Shell size
21
No. of contacts
Current rating
Contact resistance
10
5mø MAX.
16
AC1000V a minute
5A (crimp type 3A)
1000Mø MIN.
5mø MAX. (crimp type 10mø)
1.7mm dia.
1.1mm dia.
10A
26
5A
10A (only A, B)
5mø MAX.
1.7mm dia.
(only A, B)
Shell size
25
No. of contacts
Current rating
Contact resistance
4
5
16
AC3000V a minute
30A
10A
10,000Mø MIN.
5mø MAX.
3.4mm dia.
1.7mm dia.
24
AC1000V a minute
5A (crimp type 3A)
1000Mø MIN.
1.1mm dia.
Remarks : 1. Viewed from mating face.
2. The withstand voltage is the test value.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
8
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 10/2021. Contents are subject to change without notice for the purpose of improvements.
