Miniature, Waterproof Plastic Connectors
HR30 Series - Overmold Version
With typical example of overmold
Building on the success of the standard HR30 connector, Hirose now offers a version that
allows for a custom overmold to be applied to the connector. This gives the design engineer
the opportunity to design the overmold that suits the application. Hirose supplies the
un-overmolded connectors and it is up to the design engineer to have the overmold applied
to the connector.
1. Small size
Short in length when fully terminated and mated.
2. Water and dust protected
IP67 protection rating: Complete protection against dust penetration and against water
penetration when submerged 1 meter deep for half hour when mated with the corresponding
connector or protective cap.
3. Simple pull lock release
Built-in lock/release mechanism securely locks mated connectors while allowing quick
disconnection by simply pulling on the plug’s release collar. Molded-in grooves prevent finger
slippage when pulled. The round configuration of the collar allows easy side-by-side panel mounting
and will not snag on objects when the cable is pulled-out.
4. Light weight, corrosion resistant
Glass reinforced thermoplastic compounds and noncorrosive components are used in all assemblies.
5. Contact protection and self- alignment
Multiple polarizing keys protect the contacts from missalignment or attempted insertion of
the wrong connector, while assuring correct mating between the corresponding connectors.
6. Visual alignment indicators
Permanent alignment indicators in a contrasting color on all connectors aid in correct alignment
and engagement.
Applications
Test and measuring equipment, portable devices, instrumentation, industrial devices,
recreational equipment, I/O applications and other applications requiring use of lightweight,
corrosion resistant quick mate-release cable connections.
The product information in this catalog is for reference only. Please request the engineering drawing for the most current and accurate design information.
All non-RoHS products have been discontinued or will be discontinued soon. Please check the product status on the Hirose website RoHS search at www.hirose-connectors.com or contact your Hirose sales representative.
1
Ordering Information &
Product Specifications
HR30 - 6 P A - 6 S C ( * * )
2
1
4
3
6
5
8
7
1
Series Name
:HR30
5
5
Number of contacts:
3, 6, 10 and 12
2
Shell Size
:Outside diameter/plug mating side
6
Contact type
S: Female contact
P: Male contact
P: Plug
3
4
Connector type
Variation
R: Receptacle
J: Jack
7
Blank: Standard
A: Fine wire
B: Overmold
Characteristics
Contact wiring type
8
Plating
Blank: Solder
C
: Crimping
D
: Through hole
(71) : Gold plated (except caps)
Specification
Conditions
5m ohms max. (3 pos)
1. Contact resistance
15m ohms max. (Solder type: 6, 10, and 12 pos.)
2. Insulation resistance
1000M ohms min
3. Withstanding voltage
No flashover or insulation breakdown
1A DC
30m ohms max. (Through hole type: 6 and 12 pos.)
100V DC
300V AC/one minute
Frequency: 10 to 55 Hz, single amplitude of 0.75mm
4. Vibration
No Electrical discontinuity of 10 µs or more
1 cycle = 5min, 10 cycles in each of the three directions
Contact resistance 10m ohms min. (3 pos.)
5. Durability (mating/unmating)
1000 cycles
Contact resistance 30m ohms min. (Solder type: 6, 10, and 12 pos.)
Contact resistance 100m ohms min. (through hole type: 6 and 12 pos.)
6. Temperature cycle
Insulation resistance 100M ohms min.
7. Humidity resistance
10M ohms min. (when humidity is high)
(-5°C: 30 minutes Room temperature: 10 to 15 minutes +85°C: 30
minutes Room temperature: 10 to 15 minutes) for 5 cycles
96 hours at room temperature of 40 ohms and humidity of 90% to 95%
100M ohms min. (when dry)
8. Waterproof performance
While mated with corresponding or protective cap submerged at depth of 1
meter for 1/2 hour
No penetration inside
9. Dust protection
Assembly
Component
Insulator
Plug
Gasket
Contacts
Receptacles
Crimp Contact
(male/female)
Material
Finish
Remarks
PPS
Black
UL94V-0
PBT
Polyacetal
Black
UL94V-0
Silicone rubber, chloroprene rubber
Brass, phosphor bronze
Natural
Red/Black
Gold plated
Spring
Stainless steel
Insulator
PPS
Black
Gasket
Chloroprene rubber
Black
Gold plated
Hexagonal nut
Zinc alloy
Chromate
Washer
Phosphor bronze
Nickel plated
Contacts
Phosphor bronze
Selective gold plated
Contacts
UL94V-0
Current rating
5A (3 pos)
2A (6, 10, 12 pos.)
Operation Temperature Range
-25°C to +85°C
Voltage rating
100V AC, 140V DC (3, 6 pos.)
30V AC, 42V DC (10, 12 pos)
Storage Temperature Range
-25°C to +85°C
Ratings
2
Solder Type Plugs
A (Fully tightened)
B
ޓ
HR30-6PB-6S
Part Number
CL No.
A
HR30-6PB-3S
130-0034-2 00
22.7
HR30-6PB-6P
130-0037-0 00
23.2
B
Solder Pot Inner Diameter
Cable Diameter Range
Weight
3.1 g
1.1 mm
O
12.6
RoHS
5.2 MAX
2.84 g
0.8 mm
HR30-6PB-6S
130-0032-7-00
22.7
HR30-7PB-12S
130-0035-5 00
25.9
2.91 g
O
15.5
HR30-8PB-12P
130-0030-1-00
0.6 mm
25.9
6.4 MAX.
4.7 g
O 6.4 MAX.
4.4 g
Yes
A (Fully tightened)
Crimp Type Plugs
15.5
HR30-7PB-12SC
Part Number
CL No.
HR30-7PB-10SC
130-0036-8 00
HR30-7PB-12SC
130-0033-0 00
HR30-8PB-12PC
130-0031-4-00
A
Crimp Contact
HR30-SC-211
Weight
4.1 g
O 6.4 MAX
25.9
HR30-PC-211
RoHS
Yes
4.3 g
3
B (Fully tightened)
Solder and Crimp Type Jacks
A
HR30-6JB-6P
Part Number
CL No.
HR30-6JB-6P
130-2021-1-00
HR30-7JB-12P
130-2023-7 00
HR30-8JB-12S
130-2024-0 00
HR30-7JB-10PC
130-2025-2 00
HR30-7JB-12PC
130-2022-4 00
HR30-8JB-12SC
130-2026-5 00
A
O 12
B
Solder Pot Inner Diameter Cable Diameter Range
21.7
0.8 mm
Weight
O 5.2 MAX.
2.2 g
O 6.4 MAX.
3.6 g
RoHS
Yes
O 15
23.7
0.6 mm
4.0 g
O 6.4 MAX.
1.4
Caps
OA
OB
1.0
OD
C
OE
HR30-6P-C(71)
Part Number
HR30-6P-C(71)
HR30-7P-C(71)
HR30-8P-C(71)
CL No.
130-3000-7 -71
130-3004-8-71
130-3003-5-71
Applicable Connector
HR30-6P-3S(71)
HR30-6P-6S(71)
HR30-6P-6P(71)
HR30-6PA-3S(71)
HR30-6PA-6S(71)
HR30-6PA-6P(71)
HR30-6PB-3S
HR30-6PB-6P
HR30-6PB-6S
HR30-7P-10SC(71)
HR30-7PB-10SC
HR30-7P-12S(71)
HR30-7P-12SC(71)
HR30-7PB-12SC
HR30-8P-12P(71)
HR30-8P-12PC(71)
HR30-8PB-12PC
A
B
C
D
E
Weight
13
8.4
8.9
4
8.8
1g
RoHS
YES
16
10.4
10.5
6
11.4
2g
4
Receptacles
A
Gasket
B
Solder Type
ޓ
C D
E (Thread)
F (Hex nut)
HR30-6R-6P(71)
Lock washer
Part Number
HR30-6R-3P(71)
HR30-6R-6P(71)
CL No.
B
A
C
D
E
F
16
130-1009-0-71
130-1008-8-71
HR30-7R-12P(71)
130-1016-6-71
HR30-8R-12S(71)
130-1018-1-71
RoHS
1.1mm
130-1003-4-71
HR30-6R-6S(71)
Weight
8.3
12
8.9
M8 x 0.75
10
2g
0.8mm
Yes
18.4
9.3
18.6
15
11.5
M11 x 1
3.4 g
0.6mm
13
Crimp Type
15.5
HR30-7R-12PC(71)
Gasket
15
O
O11.5
9.3
M11 x 1 (Thread)
Part Number
CL No.
HR30-7R-10PC(71)
130-1012-5-71
HR30-7R-12PC(71)
130-1013-8-71
HR30-8R-12SC(71)
130-1014-0-71
Weight
Crimp Contact
13 (Hex nut)
RoHS
Lock washer
HR30-PC-211
Yes
3g
A
HR30-SC-211
2
B
Dip Type
D
E (Thread)
HR30-8R-12SD(71)
F (Hex nut)
Lock washer
Part Number
CL No.
A
HR30-6R-6PD(71)
130-1020-3-71
14.9
HR30-6R-6SD(71)
130-1021-6-71
15.2
B
C
D
8.3
12
8.9
E
F
M8 x 0.75
10
Weight
RoHS
Gasket
2g
Yes
HR30-7R-12PD(71) 130-1017-9-71
HR30-8R-12SD(71)
16
9.3
15
11.5
M11 x 1
13
3.4 g
130-1019-4-71
5
Receptacle Caps
1.4
oA
oB
0.9
oC
oE
oD
Part Number
A
B
C
D
E
12.6
11.8
7.5
12.1
9.1
CL No.
Weight
RoHS
1g
Yes
HR30-6R-3P(71)
HR30-6R-6P(71)
HR30-6R-C(71)
130-3001-0-71
HR30-6R-6PD(71)
HR30-6R-6S(71)
HR30-6R-6SD(71)
HR30-7R-10PC(71)
HR30-7R-12P(71)
HR30-7R-12PC(71)
HR30-7R-C(71)
130-3002-2-71
HR30-7R-12PD(71)
15.5
14.8
8.5
15
12.1
HR30-8R-12S(71)
HR30-8R-12SC(71)
HR30-8R-12SD(71)
Note: When using these caps, do not use the gasket that is normally supplied with the receptacle. The "B" diameter end of the
receptacle cap will serve as the gasket.
Crimp Contacts
1.2
1.2
A
1.15
0.82
0.82
1.15
A
A
A
A-A cross section
A-A cross section
11
Part Number
CL No.
HR30-PC-111 130-0022-3
HR30-PC-211 130-0016-0
11
Packaging Type
100 pcs/bag
10,000 pcs/reel
Weight
RoHS
0.03g/1per pin
Part Number
CL No.
HR30-SC-111 130-0023-6
0.03g/1per pin
Yes
Weight
Packaging Type
RoHS
100 pcs/bag
0.03g/1per pin
10,000 pcs/reel
0.03g/1per pin
Yes
HR30-SC-211
130-0017-3
Note: Use wire size AWG 26 to 30 with a jacket diameter of 1 mm max.
6
Applicable Tools
Type
Description
Part Number
CL No.
HT102/HR30-1
150-0229-6
Applicable Contact
Applicable wire
HR30-SC-111
Manual
Manual Crimping Tool
AWG #26-#30
HR30-PC-111
Automatic Crimping Machine
CM-105
901-0005-4
Applicator
AP105-HR30-1
901-4571-3
Automatic
HR30-SC-211
AWG #26-#30
HR30-PC-211
HR30-SC-111
HR30-SC-211
Extraction Tool
HR30-TP
150-0219-2
HR30-PC-111
HR30-PC-211
Manual contact crimping tool HT-102/HR30-1
Contact extraction tool
Automatic contact crimping machine CM105
HR30-TP
Receptacle, Board Mounting Through Hole Pattern
6R-6PD
Notes
6R-6SD
8R-12SD
7R-12PD
1. The receptacle through hole configuration depicts a view from the mating side of the connector.
2. The recommended board maximum thickness: 1.2mm
3. Tolerance of +0.03 mm is recommended for the plated through hole location.
Tolerance of +0.02mm is recommended for the plated through hole diameter.
Alignment mark
A +0.05
B +0.05
D+0.05
Alignment mark
HR30-6P-6S(71)
HR30-6P-6P(71)
O
HR30-6P-3S(71)
.05
+00
C
HR30-7P-10SC(71)
Notes
HR30-7P-12SC(71)
HR30-8P-12PC(71)
A
B
C
D
Panel Thickness
3, 6 pos.
1.25
6.45
8.05
3.95
0.7 - 2
10, 12 pos
1.35
9.25
11.05
5.45
0.7 - 3
1. The contact configuration depicts a view from the wiring side.
2. Mounting to the panel is accomplished by tightening the hexagonal nut fron the rear side of the panel.
7
Hirose Electric is a leading, global interconnect manufacturer specializing in a wide
range of solutions for advanced technologies.
We have connectors for: automotive, fiber optic, circular, power, mobile/cellular
telephones, board-to-board, wire-to-board, microwave, telecomm, flex circuit (FPC/FFC),
memory card connectors, ribbon cable, mini/micro USB, HDMI and other connectors.
US Headquarters
World Headquarters
Hirose Electric Co., Ltd
5-23 Osaki 5-Chome
Shinagawa-Ku, Tokyo 141-8587 Japan
T: 81-3-3492-3293 | F: 81-3-3493-2933
Hirose Electric (USA), Inc.
2688 Westhills Court
Simi Valley, CA 93065
Tel: 805-522-7958 | F: 805-522-3217
No. Cal. Regional Office
20400 Stevens Creek Blvd.
Suite 250
Cupertino, CA 95014
T: 408-253-9640
F: 408-253-9641
Attach rep or distributor label here
www.hiroseusa.com
Copyright Hirose Electric USA 5/2010, all rights reserved
8
