FLEXIBLE
POWER SYSTEMS
FEATURES & BENEFITS
• Board-to-board and discrete wire cable systems
• Power Mate® system with polarized guide posts
• Mini Mate® system with reliable Tiger Buy™ contacts
• Individually shrouded contacts
• Elevated stack heights
• Optional polarization
• Vertical and right-angle for parallel, perpendicular
and coplanar applications
• Rugged metal or plastic latching systems
• Cable components and tooling available
Selectively loading contacts achieves
customer specific creepage and
clearance requrements.
KEY SPECIFICATIONS
SERIES
IPT1/IPS1
IPBT/IPBS
HPM/HPW/HPF
FWJ/HFWJ/FHP
(2.54 mm) .100"
(4.19 mm) .165"
(5.08 mm) .200"
(3.96 mm) .156"
CCC (1 PIN)*
5.9 A
10.3 A /pin (2 pins powered)
16.6 A
13.1 A
CCC (2 PINS)*
4.8 A
8.4 A/pin (4 pins powered)
14.4 A
11.2 A
CCC (3 PINS)*
4.1 A
7.6 A/pin (6 pins powered)
13.2 A
10.3 A
CREEPAGE
(2.54 mm) .100"
(4.27 mm) .168"
(3.94 mm) .155"
(3.92 mm) .154"
CLEARANCE
(1.91 mm) .075"
(3.05 mm) .120"
(3.94 mm) .155"
(2.82 mm) .111"
VAC
775
400
850
600
VDC
1095
565
1200
845
1000 (MFG Tested)
100
100
100
PITCH
CYCLES
F-221
samtec.com/minimate or samtec.com/powermate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MAX
10.3
A
(4.19 mm) .165" PITCH • ISOLATED POWER CONNECTOR SET
IPBT
1
NO. OF POSITIONS PER ROW
LEAD STYLE
02, 03, 04, 05, 08, 10
–H1
= Through-hole
15
PLATING
OPTION
–T
s
OPTIONS
–S
= Matte Tin
–RA
= Single Row
= Right-angle
(Lead Style –H1 only)
–D
= Surface Mount
(Standard Sizes)
p
ROW
OPTION
–H2
(–D Only)
m
–GP
= Double
Row
= Guide Post Holes
(Not available with –K)
–K
= Keyed Polarization (not available
with –GP option, is required
callout if –GP not called out)
IPBT
(10.29)
.405
Board Mates:
IPBS
Cable Mates:
PMSD, PMSS
IPBT/IPBS
CURRENT
PINS
RATING
POWERED
(PER
CONTACT)
(9.65)
.380
–H1–D
–H1–S
(11.43)
.450
No. of Positions x (4.19) .165 + (1.33) .052
(11.40)
.449
(6.58)
.259
(9.60)
.378
(15.62)
.615
2
10.3 A
4
8.4 A
6
7.6 A
8
7.1 A
30
6.0 A
–H2–D
–H2–S
No. of Positions x (4.19) .165 + (12.27) .483
(6.58)
.259
(10.77)
.424
–H1–S–RA
IPBS
1
–H1–D–RA
–GP
LEAD STYLE
–01
= Standard Power
15
PLATING
OPTION
–T
–S
= Matte Tin
= Single Row
–02
(–D Only)
OPTION
–GP
= Guide Post
–D
= Standard Power
Surface Mount
(Standard Sizes)
ROW
OPTION
= Double Row
MATED HEIGHT
IPBS
Board Mates:
IPBT
(12.19)
.480
–01–S
IPBS
–01–D
No. of Positions x (4.19) .165 + (1.02) .040
(7.37)
.290
(5.41)
.213
(9.60)
.378
MATED
HEIGHT
(11.44)
.451
–02–S
(12.65)
.498
No. of Positions x (4.19) .165 + (11.18) .440
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
IPBT
–GP
–02–D
IPBT/IPBS
LEAD STYLE
MATED
HEIGHT*
H1/–01
(15.25) .600
–H2/–02
(16.84) .663
*Processing conditions
will affect mated height.
View complete specifications at: samtec.com?IPBT & samtec.com?IPBS
F-221
很抱歉,暂时无法提供与“IPBS-105-01-T-S-GP”相匹配的价格&库存,您可以联系我们找货
