NPPN302FFKS-RC
NPPN302FFKS-RC
    SULLINS
    SMD,P=2mm
    排母 间距:2mm 2x30P SMT
NPPN302FFKS-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO H 2631 J 2829 DESCRIPTION DATE ADD TOLERANCE FOR GUIDE POST & PCB HOLE FOR 7/19/2012 GUIDE POSTS ADD INSULATOR MATERIAL 'LCP' OPTION, UPGRADE 09/11/2014 NYLON 6T TO NYLON 9T BY JH LH/JHSU F F E E .079 2.00 .079 2.00 A±.008 [ .20] B±.012 [ .30] D D .157 4.00 .065 1.65 .173±.006 4.40±0.15 .039 1.00 .020 0.50 C .213 5.40 .008 0.20 OPTIONAL .031±.004 0.80±0.10 .228±.006 5.80±0.15 C±.008 [ .20] C A 2X .039±.003 1.00±0.08 .079 2.00 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. .268 6.80 .071 1.80 B B .098 2.50 A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, COLOR: BLACK 2. CONTACT MATERIAL: PHOSPHOR BRONZE 3. CONTACT PLATING: .000030" - .000050" NICKEL UNDERPLATING, GOLD FLASH OVERALL 4. CURRENT RATING: 2 AMPS 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX 7. DIELECTRIC WITHSTANDING: 500 VAC 8. OPERATING TEMPERATURE: SEE PART NUMBER CODING 9. PROCESSING TEMP.: SEE PART NUMBER CODING 10. MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES (.020 [0.50] SQUARE POSTS) 8 7 6 5 .039 1.00 .039 1.00 C RECOMMENDED PCB SMT LAYOUT Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: DECIMALS .XX= .01 [.3] .XXX= .008 [.20] .XXXX= .0040 [.100] DRAWN DATE NAME 01/12/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER, FEMALE 2mm CC, 2 ROWS, SMT PART NUMBER SIZE C CAGE CODE 54453 SCALE: 8:1 3 2 xPPNxx2FFKx-RC DWG. NO. 10485 SHEET 1 OF 1 1 REV J FILE NAME: 10485, xPPNxx2FFKx-RC A
NPPN302FFKS-RC 价格&库存
很抱歉,暂时无法提供与“NPPN302FFKS-RC”相匹配的价格&库存,您可以联系我们找货
