MAXI-CON-X® FIELD INSTALLABLE CONNECTORS
Cable Pin
Panel Mount
P/C Tail Panel Mount
13X8X-XXPG-XXX
Matching Mates:
• Cable-Cable
14X8X-XXXG-XXX
Matching Mates:
• Cable Pin
14XXX-XXXG-XXX
Matching Mates:
• Cable Pin
15X8X-XXSG-XXX
• Panel
13X8X-XXPG-XXX
• Cable Socket
14XXX-XXSG-XXX
13X8X-XXSG-XXX
13X8X-XXPG-XXX
•Cable Socket
13X8X-XXSG-XXX
Cable Socket
Cable to Cable
Winged Coupling Ring
13X8X-XXSG-XXX
Matching Mates:
• Cable-Cable
15X8X-XXXG-XXX
Matching Mates:
• Cable Pin
W/14482
15X8X-XXPG-XXX
• Panel
13X8X-XXPG-XXX
• Cable Socket
14XXX-XXPG-XXX
13X8X-XXSG-XXX
Dust Cap
14295
Molded Cable Assemblies
Cable End
(See pages 3 & 26)
Cable to Cable
Right Angle
601 East Wildwood, Villa Park, Illinois 60181 • Telephone (630) 834-7504 • Fax (630) 834-8540
18
Dimensions
(See pages 3 & 26)
1.500 [38.1]
2.000 [50.8]
2.062 [52.4]
1.625
[41.3]
CABLE END ASSEMBLY
CABLE TO CABLE ASSEMBLY
CABLE END ASSEMBLY
STRAIGHT BOOT
0.545 [13.8] MAX. CABLE O.D.
STRAIGHT BOOT
90º BOOT
0.445 [11.3] MAX. CABLE O.D.
19
Part Number to Order
XX X XX-XX XG-3XX
Grommet Code –
Cable O.D. Range:
Connector Type:
13 - Cable End
14 - Panel Mount
15 - Cable to Cable
Back
Shell
Style 3
Contact Size:
21 - .21 - .25 (5.3-6.3)
26 - .26 - .30 (6.6-7.6)
31 - .31 - .38 (7.8-9.6)
Back Shell Style:
1 - #12 (7 Contacts)
2 - #20 (18 & 20 Contacts)
3 - #16 (10 Contacts)
Mechanical screw-down
cable clamp with grommet
seal and (1) interfacial “O”
ring for cable end.
3
Contact Style:
80 81 82 91 92 -
Crimp (Supplied loose)
P/C Tail .187” (4.7) (Supplied assembled)
Solder Cup (Supplied assembled)
P/C Tail .280” (7.1) (Supplied assembled)*
P/C Tail .335” (8.5) (Supplied assembled)*
300 - Panel mount with hex nut &
gasket.
3ES - 300 with Epoxy
Number of Contacts:
7, 10, 18 & 20
Type of Contact:
P - Pin
S - Socket
Contact Plating:
G - Gold over Nickel (Standard)
EMI/RFI shielded assemblies available - consult factory.
*Available in #20 size contact only.
Consult factory for optional threaded coupling.
Consult factory for your custom design cable assemblies and connectors. (See pages 3 & 26)
Contact Arrangements
1
1
2
3
3
3
5
5
6
6
8
4
2
3
4
2
1
1
2
7
7
10
11
11
13
8
6
9
12
7
10
7-#12
15
16
10-#16
7
15
12
18-#20
14
16
17
18
9
18
19
20-#20*
Contact arrangements shown are wiring view of cable end pins/sockets.
Key/keyway shown for orientation only.
*Available in connector types: cable end socket, panel mount pin styles only.
Specifications
Typical Specifications
Manufacturers Identifications
Description
Rating
Conductor Size
Configuration
Certification
Maxi-Con-X®
Field Installable Connector & Custom Cable Assemblies
1.35 thru 13.0A, 600V
#12 Contacts, 12 thru 14 AWG
#16 Contacts, 16 thru 18 AWG
#20 Contacts, 20 thru 24 AWG
7 - #12 Contacts
10 - #16 Contacts
18 - #20 Contacts
20 - #20 Contacts
UL Recognized File #E138878 - 250V
CSA Certified File #LR89277 - 600V
Material Specifications
Cable Pin/Socket
Mechanical Backshell (Threaded)
Strap
Screws
Grommet
Coupling Ring
Contacts
Connector Body
O-Ring
Nylon, UL Recognized, Black
Cadmium Plated
Santoprene Rubber, Black
Brass, Gold over Nickel
Nitrile Rubber, Black
Optional
Nylon, UL Recognized, Black (W/14482)
Cable to Cable
Grommet
Strap
Screws
Contacts
Connector Body
Cadmium Plated
Panel Mount
Contacts
Panel Body
Gasket
Hex Nut
Optional
Dust Cap
Santoprene Rubber, Black (Part No. 14295)
Mechanical Specifications
Durability
Minimum 300 mate/unmate cycles without mechanical or electrical
failure
Coupling rings have overriding locking feature to prevent loosening or
separation of connector
All series hex nut to withstand 10-12 inch/lb tightening torque
Vibration
Hex Nut Torque
Electrical Specifications
Voltage
Current
600 V
See Electrical Current Rating Chart (Page 27)
Environmental Specifications
Temperature Rating
Corrosion
Weathertight
-55°C to +125°C (-67°F to +257°F)
300 Hr salt spray contacts
Consult factory with specific application
(See Pages 3 & 26)
Watertight
NEMA 6P, 13: IEC IP67
21
很抱歉,暂时无法提供与“14182-7PG-3ES”相匹配的价格&库存,您可以联系我们找货
