LFXTAL033644BULK
LFXTAL033644BULK
    IQD
    SMD5032_4P
    无源晶振 -10℃~+60℃
LFXTAL033644BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL033644Bulk Customer Part: Description Standard 5x3.2mm SMD crystal with four pads. Ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-104 iss:9.06 Model Issue number 9 Frequency Parameters Frequency 24.5760MHz Frequency Tolerance Tolerance Condition Frequency Stability ±50.00ppm @ 25°C ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Outline (mm) Electrical Parameters 18.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 40.00Ω max Environmental Parameters Shock: 1500g, 0.5ms, 3 times in each of 3 mutually perpendicular planes Vibration: 20g (20Hz-2000Hz), 1.52mm amplitude, 20mins in 3 mutually perpendicular planes, 4 cycles Storage Temperature Range: -55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp Au 0.3um~1.0um 260degC max for 30s max Recommended Solder Pad Layout Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 2 Dec 21 17:35 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL033644BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL033644BULK”相匹配的价格&库存,您可以联系我们找货
LFXTAL033644BULK
    • 1+14.48280
    • 200+5.77800
    • 500+5.59440
    • 1000+5.49720
