LFXTAL056808BULK
LFXTAL056808BULK
    IQD
    SMD5032_4P
    无源晶振 -40℃~+85℃
LFXTAL056808BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL056808Bulk Customer Part: Description Standard 5x3.2mm SMD crystal with four pads. Ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPX-104 iss:9.06 Model Issue number 9 Frequency Parameters Frequency 20.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±20.00ppm @ 25°C ±30.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Outline (mm) Electrical Parameters 18.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 50.00Ω max Environmental Parameters Shock: 1500g, 0.5ms, 3 times in each of 3 mutually perpendicular planes Vibration: 20g (20Hz-2000Hz), 1.52mm amplitude, 20mins in 3 mutually perpendicular planes, 4 cycles Storage Temperature Range: -55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp Au 0.3um~1.0um 260degC max for 30s max Recommended Solder Pad Layout Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 2 Dec 21 23:52 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL056808BULK
物料型号:LFXTAL056808,封装为5x3.2mm SMD晶体,带有四个垫片。
器件简介:该器件是一个标准尺寸的SMD晶体,采用陶瓷封装和密封金属盖,密封性良好。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 频率:20.0MHz,频率公差为±20.00ppm在25°C,-40.00至85.00°C范围内±30.00ppm。 - 负载电容(CL):18.00pF,最大偏差为7pF。 - 驱动级别和等效串联电阻(ESR):文档中未提供具体数值。 - 谐振频率:基本模式。 - 老化:每年在25°C下最大±3ppm。
功能详解:文档中未提供详细的功能解释。
应用信息:文档中未提供具体的应用信息
封装信息:封装尺寸为5x3.2mm,采用陶瓷材料,带有密封金属盖。
环境参数:抗冲击1500g,0.5ms,每个相互垂直的平面上3次;抗振20g(20Hz-2000Hz),1.52mm振幅,每个相互垂直的平面上20分钟,4个周期。
制造细节:符合RoHS指令2015/863/EU和REACh法规,MSL等级为JDEC-STD-033。
销售办公室联系方式:提供了英国、德国、法国、美国的销售联系电话和电子邮件地址。
LFXTAL056808BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL056808BULK”相匹配的价格&库存,您可以联系我们找货
LFXTAL056808BULK
    • 1+10.29240
    • 200+4.11480
    • 500+3.97440
    • 1000+3.90960
