DF50-30DP-1V(51)
DF50-30DP-1V(51)
    HRS(广濑)
    SMD
    CONN HEADER SMD 30POS 1MM
DF50-30DP-1V(51) 数据手册
1mm Pitch, Board to Cable Lock Connector DF50 Series It provides clear tactile click and secure mating Timing of locking function Simultaneous timing of locking function and Figure 1. contact mating provides a clearer tactile click. Robust structure resistant to wrenching forces ■Features 1. It provides clear tactile click and secure mating Locking function and contact mating occur simultaneously, for a clearer tactile click. (Please refer to Figure 1 on the right) 2. Robust structure resistant to wrenching forces Thick and robust housing wall provides higher strength against cracking. Insertion depth for mating housings protects against wrenching. (Please refer to Figure 2 on the right) 3. Robust and reliable lance structure High lance strength by mating with crimp contact on the surface (Please refer to Figure 3 on the right) 4. Ensured adsorption area eliminates the need for adsorption gap. Insertion depth for mating protects against wrenching. Thick and robust outer wall provides higher Figure 2. strength and prevents cracking. Robust and reliable lance structure Adequate adsorption area is ensured despite the small size, allowing for automatic mounting without adsorption gap. (*Specifications for adsor ption gap may be provided according to your requirements) The lance mates with the crimp contact on the surface. 5. Insulation outer diameter Ø0.9mm, compatible with AWG#28 Despite 1 mm Pitch, it is compatible with Ø0.9mm, UL1061· AWG#28 Cable (Ø0.127×7) It is possible to visually inspect the assembled lance. Figure 3. 2013.4② 1 DF50 Series●1mm Pitch, Board to Cable Lock Connector ■Product Specifications Current Rating 1A Operating Temperature Range Operating Humidity Range -35 to + 85°C (Note 1) 20 to 80% Voltage Rating AC/DC 100V Storage Temperature Range Storage Humidity Range -10 to + 60°C (Note 2) 40 to 70% (Note 2) Ratings Items Specifications Conditions 1.Insulation resistance No less than 500Mø Measured at DC 100V 2.Withstand voltage No flashover or breakdown AC300V is applied for one minute 3.Contact resistance No more than 30mø Measured at 1mA and no higher than 20mV 4.Vibration Resistance No electric outage of 1μs or greater 10 cycles in each of three directions at frequency 10-55 Hz, half amplitude 0.75 mm 5.Shock Resistance No electric outage of 1μs or greater Accelerated velocity: 490m/s for 11ms, half-sine in 3 directions, 3 times for each direction 6.Moisture-resistance Contact resistance: no more than 50mø; insulation resistance: no less than 100Mø Temperature: 40±2°C; humidity: 90 to 95%, left as it is for 96 hours 7.Temperature cycles Contact resistance: no more than 50mø; insulation resistance: no less than 500Mø (-55°C for 30 minutes → 5 to 35°C for 2 to 3 minutes → 85°C for 30 minutes → 5 to 35°C for 2 to 3 minutes) in 5 cycles 8.Push-pull durability life Contact resistance: no more than 50mø 30 times of push-pull operation 9.Solder Heat Resistance There should be no dissolution of the resin part which will influence the performance. Reflow: according to the Recommended Temperature Profile Hand soldering: temperature of soldering iron at 350°C for 3 to 4 seconds 2 (Note 1) Temperature rise at the time of electrification is included. (Note 2) The term “storage” refers to the long-term storage condition of unused products before PCB mounting. Operating Temperature Range is applied to the deenergized state after mounting of PCB and the temporary storage state during transportation. (Note 3) The above specifications are representative of this series. Please refer to “delivery specifications” for official individual agreement. ■Materials Product Part Materials Color / Treatment UL Regulation Header (on the board side) Insulator Contact Metal fitting Locking metal fittings (DF50) LCP Brass Brass (Note 1) Stainless steel UL94V-0 ------------------------- Crimp socket Insulator PBT Crimp contact Contact Phosphorous Bronze Black Gold plating Tin Plating --------Black (DF50A) White (DF50S) Gold plating UL94V-0 --------- (Note 1) Phosphor bronze is applied a material for only to the single-row straight pin header. ■Product Number Structure lConnector lCrimp contact DF50 − * DP − 1 V ** ❶ ❷ ❸ ❹ ❶ Series Name: DF50 (Double-row pin header) DF50S (Double-row crimp socket) DF50A (Single-row) ❷ Number of contacts: 20, 30, 40, 50 (Double-row) : 2 to 16 (Single-row) ❸ Connector type DP: Double-row pin header DS: Double-row socket P: Single-row pin header S: Single-row socket ❹ Contact Pitch: 1mm ❺ ❻ DF50 − 2830 SCF A ❶ ❽ ❺ Wire connection method/Geometry of terminal C: Crimp socket V: SMT Straight Type H: SMT Right Angle Type ❻ Specifications 51: SMT Embossed packaging 52: SMT Embossed packaging (with cap, DF50) ❼ Applicable wire size 2830: AWG28, 30 3032: AWG30, 32 (Under development) ❽ Method type/Packaging type SCF: Socket contact reel ❾ Plating specifications A: Gold plating 2 ❼ ❾ DF50 Series●1mm Pitch, Board to Cable Lock Connector ■Double-row straight pin header A B Contact No.2 Contact No.* P=1  Contact No.1 Contact No. *-1 Contact No.1 mark 7.05 8.15 1.6±0.05 0.9±0.05 Contact No.* Contact No.1 0.6±0.05 P=1±0.05 Contact No.*-1 B±0.05 *: No. of Contacts 4±0.05 0.85 MIN Contact No.2 1.6±0.05 1.8±0.05 0.7±0.05 BRecommended pattern schematic [Specification Number : **, (**) ] (51): Gold plating, embossed packaging (52): Gold plating, embossed packaging, with adsorption cap Unit : mm Product No. HRS No. No. of Contacts A B C D E F G DF50-20DP-1V (**) CL665-0019-3-** 20 DF50-30DP-1V (**) CL665-0001-8-** 30 13.18 9 14.2 28.4 32 38.4 32.4 18.18 14 14.2 28.4 32 38.4 32.4 DF50-40DP-1V (**) CL665-0005-9-** DF50-50DP-1V (**) CL665-0011-1-** 40 23.18 19 20.2 40.4 44 50.4 44.4 50 28.18 24 20.2 40.4 44 50.4 44.4 (Note) Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 connectors per reel) Contact No.1 .75 R0 A-A A Ø1 Product Label +2 0 R1 E±0.3 D±0.1 C±0.1 1.75±0.1 8 0. 2±0.1 (2.395)(Center of adsorption area) 1± A 4±0.1 Ø2 .1 +0 0 5 Unreeling direction . Ø1 0.5 2± Ø380±2 Unreeling direction F MAX G Ø80±1 .1 +00 B​ R ​ eel Condition Dimensions 3± 0.2 0.2±0.05 B​​Emboss tape dimensions (in conformity to JIS C 0806) 12±0.1 3 DF50 Series●1mm Pitch, Board to Cable Lock Connector ■Double-row right angle pin header Contact No.1 mark A B P=1 8.66 Contact No.1 Contact No.* Contact No.2 9 Contact No. *-1 1.75±0.05 1.25±0.05 Contact No.*� Contact No.2 0.6±0.05 P=1±0.05 B±0.05 1.6±0.05 1.8±0.05 0.9±0.05 4.1±0.05 Contact No.*-1 Contact No.1 1.6±0.05 BRecommended pattern schematic *: No. of Contacts [Specification Number: **, (**)] (51): Gold plating, embossed packaging Unit : mm Product No. HRS No. No. of Contacts A B C D E F G DF50-20DP-1H(**) CL665-0016-5-** 20 14.35 9 14.2 28.4 32 38.4 32.4 DF50-30DP-1H(**) CL665-0015-2-** 30 19.35 14 20.2 40.4 44 50.4 44.4 DF50-40DP-1H(**) CL665-0014-0-** 40 24.35 19 20.2 40.4 44 50.4 44.4 DF50-50DP-1H(**) CL665-0013-7-** 50 29.35 24 20.2 40.4 44 50.4 44.4 (Note) Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 connectors per reel) +2 0 1.75±0.1 C±0.1 4 4±0.1 R1 E±0.3 8 2±0.1 16±0.15 0. B Unreeling direction 1± .1 +0 0 5 . Ø1 Ø2 D±0.1 0.5 2± Ø380±2 Unreeling direction F MAX G Ø80±1 Product Label Ø1.5 in front of the perforation ±0. B-B B 2 .1 +00 5 .7 R0 B​ R ​ eel Condition Dimensions Ø13 0.2±0.05 B​​Emboss tape dimensions (in conformity to JIS C 0806) DF50 Series●1mm Pitch, Board to Cable Lock Connector ■Single-row straight pin header A B P=1 Contact No.1 Contact No.* C 5.67 7.05 Contact No.1 mark BRecommended pattern schematic B±0.05 P=1±0.05 0.6±0.05 0.7±0.05 4.7±0.05 2.4±0.05 Contact No.1 3.15±0.05 Contact No.* *: No. of Contacts 1.9±0.05 [Specification Number: **, (**) ] (51): Gold plating, embossed packaging Unit : mm HRS No. No. of Contacts A B C DF50A-2P-1V (**) Product No. CL665-1001-3-** 2 5.25 1 5 DF50A-3P-1V (**) CL665-1004-1-** 3 6.25 2 6 DF50A-4P-1V (**) CL665-1006-7-** 4 7.25 3 7 DF50A-5P-1V (**) CL665-1008-2-** 5 8.25 4 8 DF50A-6P-1V (**) CL665-1010-4-** 6 9.25 5 9 DF50A-7P-1V (**) CL665-1012-0-** 7 10.25 6 10 DF50A-8P-1V (**) CL665-1014-5-** 8 11.25 7 11 DF50A-9P-1V (**) CL665-1016-0-** 9 12.25 8 12 DF50A-10P-1V (**) CL665-1017-3-** 10 13.25 9 13 DF50A-11P-1V (**) CL665-1019-9-** 11 14.25 10 14 DF50A-12P-1V (**) CL665-1021-0-** 12 15.25 11 15 DF50A-13P-1V (**) CL665-1023-6-** 13 16.25 12 16 DF50A-14P-1V (**) CL665-1025-1-** 14 17.25 13 17 DF50A-15P-1V (**) CL665-1027-7-** 15 18.25 14 18 DF50A-16P-1V (**) CL665-1029-2-** 16 19.25 15 19 (Note) Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 connectors per reel) 5 DF50 Series●1mm Pitch, Board to Cable Lock Connector B​​Emboss tape dimensions (in conformity to JIS C 0806) B​ R ​ eel Condition Dimensions Product Label A +0.1 0 24.4 +20 Ø1.5 to the depth of the perforation Ø13± Unreeling direction 0.2 A 8 0. 1± Ø2 R1 0.5 2± (24) 22.25 +0.2 0 11.5±0.1 Ø1.5 30.4MAX Ø380±2 1.75±0.1 12±0.1 4±0.1 2±0.1 Ø80±1 ●DF50A-2P-1V to F50A-8P-1V (Number of contacts: 2 to 8) Unreeling direction B​​Emboss tape dimensions (in conformity to JIS C 0806) B​ R ​ eel Condition Dimensions ±0. 2 0.2±0.05 0.2±0.05 0 .1 A R0 Unreeling direction .7 UnreelingAdirection 5 +0 0 .1 8 5 +0 0. .7 1± 6 R0 Ø2 8 0. 1± Ø2 R1 0.5 0.5 2± Ø80±1 Ø380±2 Ø13 Product Label Ø1.5 to the depth 38.4MAX Ø1.5 to the depth 38.4MAX +2 of the perforation of 32.4 the perforation 32.4 +20 0 Ø13 ±0. Unreeling directionUnreeling direction 2 Ø80±1 Ø380±2 Product Label A-A 32±0.3 28.4±0.1 14.2±0.1 4±0.1 Geometry of reelGeometry (FREE) of reel (FREE) 12±0.1 +0.1 .1 +0 0 A A 2±0.1 4±0.1 2±0.1 A-A 1.5 0 .5 Ø1 Ø R1 1.75±0.1 12±0.1 2± 32±0.3 28.4±0.1 14.2±0.1 1.75±0.1 ●​​DF50A-9P-1V to DF50A-16P-1V (Number of contacts: 9 to 16) DF50 Series●1mm Pitch, Board to Cable Lock Connector ■Single-row right angle pin header A B P=1 Contact No.1 Contact No.* Contact No.1 mark 7.6 6.08 C BRecommended pattern schematic B±0.05 P=1±0.05 0.6±0.05 Contact No.* 2.4±0.05 5.67±0.05 7.31±0.05 Contact No.1 1.51±0.05 *: No. of Contacts 1.9±0.05 [Specification Number: **, (**) ] (51): Gold plating, embossed packaging Unit : mm HRS No. No. of Contacts A B C DF50A-2P-1H (**) Product No. CL665-1031-4-** 2 6.81 1 6 DF50A-3P-1H (**) CL665-1032-7-** 3 7.81 2 7 DF50A-4P-1H (**) CL665-1033-0-** 4 8.81 3 8 DF50A-5P-1H (**) CL665-1034-2-** 5 9.81 4 9 DF50A-6P-1H (**) CL665-1035-5-** 6 10.81 5 10 DF50A-8P-1H (**) CL665-1037-0-** 8 12.81 7 12 DF50A-10P-1H (**) CL665-1039-6-** 10 14.81 9 14 DF50A-12P-1H (**) CL665-1041-8-** 12 16.81 11 16 DF50A-16P-1H (**) CL665-1045-9-** 16 20.81 15 20 (Note) Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 connectors per reel) 7 DF50 Series●1mm Pitch, Board to Cable Lock Connector B​​Emboss tape dimensions (in conformity to JIS C 0806) B​ R ​ eel Condition Dimensions ±0.2 C-C Ø Ø380±2 1.75±0.1 C 8 0. R1 1± 11.5±0.1 Ø2 (24) Ø13 .1 +0 0 5 1. Ø1.5 to the depth 30.4 MAX of the perforation +2 24.4 0 Unreeling direction 0.5 2± 22.25 +0.2 0 Product Label 12±0.1 4±0.1 2±0.1 Ø80±1 ●DF50A-2P-1H to DF50A-6P-1H (Number of contacts : 2 to 6) Unreeling direction C B​​Emboss tape dimensions (in conformity to JIS C 0806) B​ R ​ eel Condition Dimensions ●​​DF50A-8P-1H to DF50A-16P-1H (Number of contacts : 8 to 16) Product Label .1 +0 0 C 5 1. Ø G MAX +2 0 H Unreeling direction Ø13 C-C Ø1.5 to the depth of the perforation Ø80±1 4±0.1 2±0.1 ±0.2 D±0.1 R1 0.2±0.05 E±0.1 8 0. C 1± Ø2 F±0.3 0.5 2± Ø380±2 1.75±0.1 12±0.1 Unreeling direction Unit : mm Product No. HRS No. No. of Contacts D E F G H DF50A-8P-1H (**) CL665-1037-0-** 8 14.2 28.4 32 38.4 32.4 DF50A-10P-1H (**) CL665-1039-6-** 10 20.2 28.4 32 38.4 32.4 DF50A-12P-1H (**) CL665-1041-8-** 12 20.2 28.4 32 38.4 32.4 DF50A-16P-1H (**) CL665-1045-9-** 16 20.2 40.4 44 50.4 44.4 (Note) Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 connectors per reel) 8 DF50 Series●1mm Pitch, Board to Cable Lock Connector ■Double-row crimp socket A B Contact No.2 P=1 Contact No.* Contact No.1 Contact No. *-1 Contact No.1 mark 8.5 6 CAV No. HRS mark *: No. of Contacts Unit : mm Product No. HRS No. No. of Contacts A B DF50S-20DS-1C CL665-0020-2-00 20 12.28 9 DF50S-30DS-1C CL665-0021-5-00 30 17.28 14 DF50S-40DS-1C CL665-0022-8-00 40 22.28 19 DF50S-50DS-1C CL665-0012-4-00 50 27.28 24 (Note) Sold in 100 piece units. ■Single-row crimp socket A B P=1 Contact No.1 mark Contact No.* Contact No.1 6 6.85 *: No. of Contacts Unit : mm Product No. HRS No. No. of Contacts A B DF50A-2S-1C CL665-1002-6-00 2 3.95 1 DF50A-3S-1C CL665-1005-4-00 3 4.95 2 DF50A-4S-1C CL665-1007-0-00 4 5.95 3 DF50A-5S-1C CL665-1009-5-00 5 6.95 4 DF50A-6S-1C CL665-1011-7-00 6 7.95 5 DF50A-7S-1C CL665-1013-2-00 7 8.95 6 DF50A-8S-1C CL665-1015-8-00 8 9.95 7 DF50A-9S-1C CL665-1100-5-00 9 10.95 8 DF50A-10S-1C CL665-1018-6-00 10 11.95 9 DF50A-11S-1C CL665-1020-8-00 11 12.95 10 DF50A-12S-1C CL665-1022-3-00 12 13.95 11 DF50A-13S-1C CL665-1024-9-00 13 14.95 12 DF50A-14S-1C CL665-1026-4-00 14 15.95 13 DF50A-15S-1C CL665-1028-0-00 15 16.95 14 DF50A-16S-1C CL665-1030-1-00 16 17.95 15 (Note) Sold in 100 piece units. 9 DF50 Series●1mm Pitch, Board to Cable Lock Connector ■Crimp contact 0.5 4 Ø1.2 3 4.6 1.9 5.05 0.8 0.63 0.12 1.4 2.7 4 Product No. DF50-2830SCFA DF50K-2830SCFA DF50-3032SCFA HRS No. Type Quantity Treatment CL665-0002-0-00 Reel contact 30,000 pieces per reel Gold plating CL665-0017-8-00 Reel contact 30,000 pieces per reel Gold plating Under development --------- --------- --------- (Note) As this product is sold per (30,000 piece) reel, please place orders by the multiple of the number of reels. lApplicable wire (Tinned Annealed Copper Wire) lStrip length Recommended wire Product No. DF50-2830SCFA DF50K-2830SCFA HRS No. Cable name Conductor size (Core structure) UL1061 AWG28 (7pieces / Ø0.127mm) UL1061 AWG30 (7pieces / Ø0.102mm) UL1571 AWG28 (7pieces / Ø0.13mm) CL0665-0002-0-00 CL0665-0017-8-00 Diameter of the wire Ø0.8 to 0.9mm Ø0.58mm (Note) Please contact our Sales Department when you are using wires other than applicable wires. ■Applicable crimping tool Type Applicator Press body Hand tool Pull-out tool Product No. HRS No. Applicable contact AP105-DF50-2830S CL901-4616-0 DF50-2830SCFA CM-105 CL901-0005-4 --------- HT305/DF50-2830HC CL902-4634-8 DF50-2830SCFA DF-C-PO(B) CL550-0179-2 DF50-2830SCFA (Note) Problems caused by tools other than our specified ones are out of warranty events. 10 1.3 to 1.7mm DF50 Series●1mm Pitch, Board to Cable Lock Connector BPrecautions 1.Recommended Temperature Profile (Compatible with lead-free soldering) 10secMAX MAX 250℃ TEMPERATURE (℃) 250 220℃ 200 180℃ 150 100 0 90~120sec PRE-HEATING TIME 60secMAX TIME (sec) SOLDERING TIME [Applicable Conditions] 1.Peak temperature: a maximum of 250°C for no more than 10 seconds 2.Heating unit: no less than 220°C for no more than 60 seconds 3.Preheating unit: 150 to 180°C for 90 to 120 seconds 4.Number of times: no more than 2 times * Measurement is conducted at the contact lead part As it may change depending on the conditions such as solder paste types, manufacturers, PCB size, and other soldering materials, please fully check the mounting conditions before use. (Note 1) This temperature profile is a recommended value. 2.Recommended hand soldering conditions Temperature of soldering iron: 350±10°C, soldering time: 3 to 4 seconds 3.Recommended screen thickness and aperture ratio (Pattern surface ratio) Thickness: 0.1mm, aperture ratio: 100% 4.Warpage of the Board A maximum of 0.02mm at the center of connector, as measured from either end of the connector 5.Cleaning Conditions IPA cleaning is allowed. (Cleaning is not recommended because cleaning may change the push/pull feeling etc. Please contact us when you use other cleaning agents. ) 6.Precautions ▪ When inserting a crimp contact into a crimp socket, do not insert it at a slanted angle in order to maintain the reliability of its performance. ▪ Please refrain from pushing/pulling operation when the PCB is not mounted. It may cause breakage, contact deformation, etc. ▪ Please refrain from pushing/pulling operation with wires in your hand. It may cause damage. ▪ During hand soldering, do not apply flux which will cause flux oozing on connector. ▪ This product may have a little difference in its molded color depending on the production lot, but the difference doesn't have any influence on the performance. 11 DF50 Series●1mm Pitch, Board to Cable Lock Connector USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. San Jose Office 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hiroseusa.com THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hiroseeurope.com GERMANY: HIROSE ELECTRIC EUROPE B.V. German Branch Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.de UNITED KINGDOM: HIROSE ELECTRIC EUROPE B.V. UK Branch 22 Vincent Avenue, Crownhill Business Centre, Crownhill, Milton Keynes, MK8 0AB Phone : +44-1908-305750 Fax : +44-1908-305768 http://www.hirose.co.uk CHINA: HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. 1601,Henderson Metropolitan,NO.300 ,East Nanjing Road,Huangpu District, Shanghai,China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC TRADING (SHANGHAI) CO., LTD. Beijing Branch A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, Chao Yang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre 5002, ShenNanDong Road, ShenZhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: KOREA: HIROSE KOREA CO., LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, Kyunggi-Do 429-450 Phone : +82-31-496-7000,7124 Fax : +82-31-496-7100 http://www.hirose.co.kr SINGAPORE: HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-1 International Plaza 079903 Phone : +65-6324-6113 Fax : +65-6324-6123 http://www.hirose-singapore.com.sg INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. Bangalore Liaison office Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India Phone : +65-6324-6113 Fax : +65-6324-6123 http://www.hirose-singapore.com.sg HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose-taiwan.com.tw INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD Delhi Liaison Office Suite No. 606 5th Floor SB Tower 1A/1 Sector 16 A Filmcity Noida 201301 Uttar Pradesh-India Phone : +91-120-4804917 Fax : +91-120-4804949 http://www.hirose.com/sg/ MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD (Representative office) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2013. Contents are subject to change without notice for the purpose of improvements.
DF50-30DP-1V(51)
物料型号:DF50系列,1mm间距,板对线锁定连接器。
器件简介: - 提供清晰的触觉点击感和安全的锁紧功能,锁紧功能和接触配对同时发生。 - 结构坚固,耐扳手扭力,具有较高的抗裂强度。 - 高强度可靠的凸缘结构,与压接接触表面配合。 - 确保足够的吸附面积,无需吸附间隙,适合自动装配。
引脚分配:文档中提供了详细的引脚分配图和推荐图案示意图,展示了不同型号的DF50连接器的引脚布局。
参数特性: - 电流额定值:1A - 工作温度范围:-35至+85°C - 工作湿度范围:20%至80% - 电压额定值:AC/DC 100V - 存储温度范围:-10至+60°C - 存储湿度范围:40%至70%
功能详解: - 锁紧功能与接触配对的同时进行,提供清晰的触觉点击。 - 结构设计考虑了耐扭力性能,保护连接件不受损害。 - 凸缘结构设计用于与压接接触配合,可目视检查装配的凸缘。
应用信息: - 适用于1mm间距的板对线连接,提供直插和直角两种类型的连接器。
封装信息: - 提供了详细的封装尺寸和材料信息,包括绝缘体材料、接触材料、金属配件材料等。 - 材料符合UL规定,如LCP、PBT、磷青铜、黄铜等,并进行了相应的颜色和表面处理。
DF50-30DP-1V(51) 价格&库存
很抱歉,暂时无法提供与“DF50-30DP-1V(51)”相匹配的价格&库存,您可以联系我们找货
DF50-30DP-1V(51)
  • 1+12.664341+1.57101
  • 10+11.0182910+1.36682
  • 25+10.5538225+1.30920
  • 50+10.3173450+1.27986
  • 100+9.84956100+1.22184
  • 250+8.91105250+1.10541
  • 500+8.20759500+1.01815
库存:5732
