LFXTAL003071BULK
LFXTAL003071BULK
    IQD
    HC-49S/SMD
    无源晶振 -10℃~+60℃
LFXTAL003071BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL003071Bulk Customer Part: Description Industry standard SMD crystal Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Lead wires are mounted onto a plastic former to create a gull wing mount Model HC49/4HSMX Model Issue number 17 Frequency Parameters Frequency 4.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±2°C ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±5ppm typ per year @ 25°C Outline (mm) Electrical Parameters 16.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 130.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C RoHS Terminations RoHS Reflow Temp 260°C max for 10s max Typical Frequency vs Temperature Curves Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 1 Sep 21 4:06 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL003071BULK
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高响应速度,适用于各种工业自动化控制领域。
3. 引脚分配:EL817共有6个引脚,分别为Vcc、Out、GND、A、B和C。
4. 参数特性:工作电压范围为5V-24V,响应波长为820nm,响应时间小于1ms。
5. 功能详解:EL817通过光电转换实现信号隔离,提高系统的抗干扰能力。
6. 应用信息:广泛应用于工业自动化、医疗设备、安防系统等领域。
7. 封装信息:EL817采用DIP6封装。
LFXTAL003071BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL003071BULK”相匹配的价格&库存,您可以联系我们找货
