LFXTAL071270REEL
LFXTAL071270REEL
    IQD
    SMD2520_4P
    无源晶振 25MHz ±10ppm 10pF 100Ω -40℃~+125℃
LFXTAL071270REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL071270Reel Customer Part: Description Ceramic package with a hermetically seam sealed metal lid suitable for automotive applications. Qualified to AEC-Q200 and with IATF-16949:2016 release.Not suitalbe for safety critical applications. Model CFPX-218 AUTO Model Issue number 1 Frequency Parameters Frequency 25.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±10.00ppm @ 25°C ±100.00ppm Operating Temperature Range -40.00 to 125.00°C Overtone Order Ageing Fundamental ±5ppm max per year @ 25°C Outline (mm) Electrical Parameters 10.00pF 5pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 100.00Ω max Environmental Parameters Storage Temperature Range: -55 to 150°C Qualified to AEC-Q200 Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 7 Dec 21 2:48 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL071270REEL
1. 物料型号:CFPX-218 AUTO 2. 器件简介:该器件是一个陶瓷封装,带有密封金属盖,适用于汽车应用,符合AEC-Q200标准和IATF-16949:2016发布,但不适合安全关键应用。 3. 引脚分配:文档中提到了4个引脚,编号为1、2、3、4,其中1和3为晶体引脚,2和4为地引脚。 4. 参数特性: - 频率:25.0MHz - 频率容差:±10.00ppm @ 25°C - 频率稳定性:±100.00ppm (-40.00 to 125.00°C) - 基频:5pF最大 - 负载电容(CL):10.00pF - 驱动级别:最大100µW - ESR:最大100.00Ω 5. 功能详解:文档未提供详细的功能详解,但根据参数特性可以推断其为一个高精度的石英晶体振荡器。 6. 应用信息:适用于汽车应用。 7. 封装信息:封装尺寸为2.5+0.1mm x 1.65mm x 0.85mm,符合RoHS标准,MSL等级不适用,采用EIA-481-D标准的胶带和卷轴包装,卷轴尺寸为3,000,提供替代包装选项。
LFXTAL071270REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL071270REEL”相匹配的价格&库存,您可以联系我们找货
