Crimp
3.96mm
VH CONNECTOR
Disconnectable Crimp style connectors
(.156") pitch
Features ––––––––––––––––––––––––
• Proven box contact
This connector was developed with the same box-shaped
contact design used successfully in the NH connectors. The
reliable VH connector can be used in a wide variety of
applications, from low-voltage, low-current signal circuits to
power supply circuits having a relatively large capacity.
• Compact connector with a large capacity
Even though this connector has a large current carrying
capacity (10A), it is compact, with a mounting height of 16.5mm
(.650").
• Secure contact and mounting
The housing has a lock mechanism which prevents the
connector from coming loose due to vibration. The mechanism
also prevents misinsertion (misalignment or reverse insertion).
Specifications –––––––––––––––––––
• Current rating: 10A AC, DC (AWG#16)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #22 to #16
• Applicable PC board thickness: 1.6mm(.063")
JS
T
6
1
2
3
4
5
6
This small, field-proven connector for
printed circuit boards is reliable and has a
large current carrying capacity. It can be
used with a wide variety of signal, power
supply, and output circuits that appear in
consumer electronic products.
Note:
Do not branch in parallel current which exceeds the rated current. If branched in
parallel, current imbalance or other problems may develop. If it is absolutely
necessary to branch such a large current in parallel, be sure to use contacts
made of phosphor bronze. Design the circuits without causing imbalance and
provide an extra margin for each circuit.
* Contact JST if Lead-Free product is required.
* Temperature Range:
The aforementioned temperature range of this connector is
described in JST Standard Product Specification.
Maximum temperature registered in UL is 105˚C.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
0 Recognized E60389
1
2
Certified LR20812
R75122
190
VH
CONNECTOR
Contact –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Applicable wire
Model No.
10.6(.417)
4.0(.157)
4.2(.165)
3.8(.150)
3.0(.118)
mm
2
AWG #
Insulation O.D.
mm(in.)
Q'ty /
reel
SVH-21T-P1.1
0.33 to 0.83
22 to 18
1.7 to 3.0
(.067 to .118)
4,500
SVH-41T-P1.1
0.5 to 1.25
20 to 16
1.7 to 3.0
(.067 to .118)
3,500
Material and Finish
Phosphor bronze, tin-plated
Note: 1. Contact JST if you require contacts made of brass.
2. When using retainer mountable type housing, applicable wire's
insulation O. D. shall be 1.7 to 2.2mm(.067" to .087").
Housing –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
M type
B
A
Circuit No.1
Circuits
Model No.
Dimensions mm(in.)
Q'ty /
bag
N type
M type
Retainer
mountable
type
2
VHR-2N
VHR-2M
VHRR-2N
3.96( .156)
7.86( .309)
1,000
3
VHR-3N
VHR-3M
VHRR-3N
7.92( .312) 11.82( .465)
1,000
4
VHR-4N
VHR-4M
11.88( .468) 15.78( .621)
1,000
5
VHR-5N
VHR-5M
VHRR-5N 15.84( .624) 19.74( .777)
1,000
6
VHR-6N
VHR-6M
7
VHR-7N
8
9
A
5.7(.224)
Circuit No.1
13.3(.524)
13.3(.524)
Circuit No.1
6.2(.244)
10.6(.417)
5.7
(.224)
10.5(.413)
B
A
B
19.80( .780) 23.70( .933)
500
VHR-7M
VHRR-7N 23.76( .935) 27.66(1.089)
500
VHR- 8N
VHRR-8N 27.72(1.091) 31.62(1.245)
500
VHR- 9N
VHR-9M
VHRR-9N 31.68(1.247) 35.58(1.401)
500
10
VHR-10N
35.64(1.403) 39.54(1.557)
500
11
VHR-11N
39.60(1.559) 43.50(1.713)
500
10.5(.413)
B
A
Retainer mountable type
14.8(.583)
N type
Note: 1. Models identified as VHR-( ) M incorporate measures to prevent
electric shock and are thus safer in regard to high voltages.
2. The applicable housing for 2-circuits shrouded header is "VHR-2N"
only. "VHRR-2N" is not applicable.
¨ V approved.
3. Models VHR-11N and VHRR-(
)N are not TU
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
VHR-2N-oo(blank)…natural (white)
BK…black R…red BL…blue M…green D…orange Y…yellow
PK…pink H…gray
Material
Nylon 6, UL94V-0, natural (white)
191
VH
CONNECTOR
Retainer –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Model No.
A
Q'ty / bag
2
VHS-2V
3.70(1.146)
1,000
3
VHS-3V
7.52(1.296)
1,000
5
VHS-5V
15.44(1.608)
1,000
7
VHS-7V
23.36(1.920)
1,000
8
VHS-8V
27.32(1.076)
1,000
9
VHS-9V
31.28(1.231)
1,000
A
2 circuits : 2.6(.102)
3 to 9 circuits : 4.2(.165)
Circuits
Material
Glass-filled nylon 66, UL94V-0, natural (ivory)
¨ V approved.
Note: Not TU
7.1(.280)
Locking header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Model No.
[9.4(.370)]
8.5(.335)
Circuit No.1
1.14(.045)
2.0(.079)
Top entry type
7.7
3.2
(.303) (.126)
14.6(.575)
A
B
Circuits
Q’ty / box
Dimensions mm(in.)
Top
entry
type
Side
entry
type
Top entry
type
Side entry
type
2
B 2P-VH
B 2PS-VH
3.96( .156)
7.86( .309)
1,000
1,000
3
B 3P-VH
B 3PS-VH
7.92( .312)
11.82( .465)
1,000
500
4
B 4P-VH
B 4PS-VH
11.88( .468)
15.78( .621)
500
500
5
B 5P-VH
B 5PS-VH
15.84( .624)
19.74( .777)
500
250
6
B 6P-VH
B 6PS-VH
19.80( .780)
23.70( .933)
250
250
7
B 7P-VH
B 7PS-VH
23.76( .935)
27.66(1.089)
250
250
8
B 8P-VH
B 8PS-VH
27.72(1.091)
31.62(1.245)
200
200
9
B 9P-VH
B 9PS-VH
31.68(1.247)
35.58(1.401)
200
200
10
B10P-VH
B10PS-VH
35.64(1.403)
39.54(1.557)
200
200
A
B
Material and Finish
2.0(.079)
Side entry type
[9.4(.370)]
8.5(.335)
Circuit No.1
Post: Brass, copper-undercoated, tin/lead-plated
Wafer: Nylon 66, UL94V-0, natural (white)
Note: Headers with a reduced number of posts are also available.
ex.
1.14 3.96
(.045) (.156)
A
B
192
7.7
3.2
(.303) (.126)
14.9(.587)
B2P(S)-VH-oo(blank)…natural (white)
BK…black R…red TR…tomato red BL…blue M…green
O…orange Y…yellow PK…pink H…gray
VH
CONNECTOR
Model No.
Top entry type of PBT
Circuits
B
A
1.14(.045)
Circuit No.1
[9.4(.370)]
7.7
3.2
(.303) (.126)
[14.6(.575)]
Side entry type with PCB stabilizer
Side
entry
type
3.96( .156)
7.86( .309)
1,000
1,000
7.92( .312)
11.82( .465)
500
500
S4P-VH
11.88( .468)
15.78( .621)
500
500
B 5P-VH-B
S5P-VH
15.84( .624)
19.74( .777)
250
250
6
B 6P-VH-B
19.80( .780)
23.70( .933)
250
7
B 7P-VH-B
S7P-VH
23.76( .935)
27.66(1.089)
250
250
8
B 8P-VH-B
27.72(1.091)
31.62(1.245)
200
2
B 2P-VH-B
S2P-VH
3
B 3P-VH-B
S3P-VH
4
B 4P-VH-B
5
A
9
B 9P-VH-B
31.68(1.247)
35.58(1.401)
200
10
B10P-VH-B
35.64(1.403)
39.54(1.557)
200
11
B11P-VH-B
39.60(1.559)
43.50(1.713)
Material and Finish
7.7
(.303)
13.4(.528)
3.6
(.142)
Wafer: Top entry type of PBT: Glass-filled PBT, UL94V-0, natural (ivory)
Side entry type with PCB stabilizer: Nylon 66, UL94V-0, natural (white)
1.14
(.045)
4.8(.189)
A
Circuit No.1
Top
entry
type
Side entry
type with
PCB stabilizer
4.5
[9.4(.370)] (.177)
B
Q'ty / box
B
Top entry
type of
PBT
[1.95
(.077)]
6.8
1.7
(.268) (.067)
8.5(.335)
[1.95
(.077)]
Dimensions mm(in.)
¨ V approved.
Note : B11P-VH-B is not TU
ex.
B2P-VH-B-oo(blank)…natural (ivory)
C…black R…red E…blue M…green Y…yellow
ex.
S2P-VH-oo(blank)…natural (white)
BK…black R…red BL…blue Y…yellow M…green
Shrouded header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––
(2 , 3 circuits)
9.7(.382)
B
Circuits
Model No.
2
B 2P-VH-FB-B
B 3P-VH-FB-B
B 4P-VH-FB-B
B 5P-VH-FB-B
B 6P-VH-FB-B
B 7P-VH-FB-B
B 8P-VH-FB-B
B 9P-VH-FB-B
B10P-VH-FB-B
3
4
6
7
8
3.7
(.146)
1.5(.059)
11.0(.433)
5
1.14(.045)
A
9
10
Circuit No.1
Dimensions mm(in.)
A
B
Q'ty / box
3.96( .156)
9.80( .386)
250
7.92( .312)
13.76( .542)
200
11.88( .468)
17.72( .698)
150
15.84( .624)
21.68( .854)
200
19.80( .780)
25.64(1.009)
200
23.76( .935)
29.60(1.165)
100
27.72(1.091)
33.56(1.321)
100
31.68(1.247)
37.52(1.477)
100
35.64(1.403)
41.48(1.633)
125
Material and Finish
Wafer: Glass-filled PBT, UL94V-0, natural (white)
(4 to 10 circuits)
Note : The applicable housing for 2-circuits shrouded header is "VHR-2N" only.
9.7(.382)
11.0(.433)
ex.
3.7
(.146)
1.5(.059)
B
3.96
(.156)
1.14(.045)
A
B2P-VH-FB-B-oo(blank)…natural (white)
R…red C…black E…blue M…green Y…yellow O…orange
H…gray PK…pink
Circuit No.1
193
VH
CONNECTOR
PC board layout (viewed from soldering side) and Assembly layout –––––––––––––––––––
Locking header
Top entry type
Locking header
Side entry type
3.96 ± 0.05
(.156 ± .002)
1.65 + 00.1
(.065 + 0.004)dia.
16.5(.650)
1.65 + 00.1
(.065 + 0.004)dia.
20.5(.807)
10.5
(.413)
*7.2
(.283) min.
10.5(.413)
8.0
(.315)
3.96 ± 0.05
(.156 ± .002)
*7.2
(.283) min.
*11.0(.433) max. when used with the VR connector receptacle.
Locking header
3.96 ± 0.05
(.156 ± .002)
Shrouded header
3.96 ± 0.05
(.156 ± .002) 1.5(.059)
21.0(.827)
1.4 + 00.1
(.055 + .004
0 )dia.
10.5(.413)
1.65 + 00.1
(.065 + 0.004 )dia.
16.5(.650)
3.4±0.05
(.134.002)
10.5
(.413)
Circuit No.1
1.65 + 0.1
0 )dia.
19.0(.748)
Note:
1. Tolerances are non-cumulative: ±0.05mm(±.002) for all centers.
2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
Applicator for the semi-automatic press AP-K2N –––––––––––––––––––––––––––––––
Contact
SVH-21T-P1.1
SVT-41T-P1.1
194
Crimp applicator MKS-L
with safety cover
without safety cover
Compact crimp applicator MKS-LS
with safety cover
Strip-crimp applicator MKS-SC
with safety cover
APLMK SVH21-11
APLNC SVH21-11
APLSC SVH21-11
APLMK SVT41-11
APLNC SVT41-11
