FGG.2B.306.CLAD62Z
FGG.2B.306.CLAD62Z
    LEMO(雷莫)
    FGG.2B.306.CLAD62Z
FGG.2B.306.CLAD62Z 数据手册
FGG.2B.306.CLAD62Z www.lemo.com SUMMARY # Wires Low voltage 6 Image is for illustrative purpose only Series 2B Termination type Male solder IP rating 50 AWG wire size 28.00 - 20.00 Catalog Cable Ø 5.30 - 6.20 mm See video assembly instructions Status active Matching parts EGG.2B.306.CLL Download Request a quote Eplan PHG.2B.306.CLLD62Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 30.02 g Performance Configuration 2B.306 : 6 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 12 Amps Specifications Contact Type: Solder Contact Dia.: 1.3 mm (0.051in) Bucket Dia.: 1 mm (0.039in) Max. Solid Conductor: 0.5 mm^2 (AWG 20) Max. Stranded Conductor: 0.5 mm^2 (AWG 20) R (max): 3.6 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1450 V (AC), 2050 V (DC) Vtest (contact-contact): 1350 V (AC), 1910 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 15 49 37 13 12 in. 0,59 1,93 1,46 0,51 0,47 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.2B.025.PA120 Caps: BFG.2B.100.PCSG Cables CMN.06.T20.062PGZE Grey CMN.06.T20.062PNZE CMN.06.T20.062QGZE TPR (medical) Grey 106220 PVC Black 12080 PVC Grey 160240 PVC Black 260250 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.306.CLAD62Z 价格&库存
很抱歉,暂时无法提供与“FGG.2B.306.CLAD62Z”相匹配的价格&库存,您可以联系我们找货
