XLR CHASSIS CONNECTORS
5 PIN JLX SERIES
Locking 3 pin connectors with
rugged metal shells for audio and
lighting control.
IO-XLR5-M-JLX
IO-XLR5-F-JLX
SPECIFICATIONS
PRODUCT
MECHANICAL
Gender: Male (IO-XLR5-M-JLX)
Lifetime: > 1000 Mating Cycles
Female (IO-XLR5-F-JLX)
Wiresize: 1.0mm Max O.D.
Contacts: 5
Wiring: Solder Contacts
ELECTRICAL
Locking Device: Latch Lock
Capacitance Between Contacts: ≤ 2.6 pF
Mounting Direction: Front
Capacitance Between Contact and Ground: ≤ 2.8 pF
Solderability: Complies with IEC
60068-2-20
Contact Resistance: < 7 mΩ
Insulation Resistance: ≥ 5000 MΩ
MATERIAL
Dielectric Strength: 1500V @ 60s
Pins: Brass (IO-XLR5-M-JLX)
Current Rating: 7.5 A / 125 V AC
Phosphor Bronze (IO-XLR5-F-JLX)
Grounding: Separate ground contact shell, mating
connector shell, and front panel
Pin Plating: Silver
ENVIRONMENTAL
Grounding Terminal Plating: Tin
Standard Compliance: IEC 61076-2-103
Shell: Die Cast Zinc
UL Flammability: Meets UL 94 HB
Shell Finish: Nickel
Temperature Range: -40°C ~ +70° C (-40°F ~ +158°F)
Push Button: Die Cast Zinc
Grounding Terminal: Brass
Push Button Finish: Nickel
Product specifications may change without prior notification
Io Audio Technologies® is a registered trademark of Knight Electronics, Inc.
10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 |
www.ioaudiotechnologies.com
DRAWINGS
IO-XLR5-F-JLX
IO-XLR5-M-JLX
FEATURES & APPLICATIONS
Panel Cutout
JLX Series XLR chassis connectors offer a sleek and robust
connection in a standard "J" Size shell. This series is perfect for
permanent installations or design-in applications where the
termination method is solder cups. The connectors feature
“metal on metal” housing which provides improved RF and EMI
protection, making these connectors perfect for use in high
noise environments or where cell phone or radio frequencies
are most offensive. They have precision machined, one piece,
silver plated contacts and a separate tin plated ground pin
which grounds to the connector housing and panel. Available
in 3 or 5 pin variations. The JLX Series XLR chassis connectors
help prevent local RF interference from assisted listening,
WiFi, and other radio transmitters close to the connectors.
When coupled with quality shielded cables, a robust system
for preventing the intrusion of unwanted noises is created.
PART NUMBER BREAKDOWN:
STANDARDS & CLASSIFICATIONS
IO-XLR5-M-JLX
Series Identifier
IO-XLR5-M-JLX
Number of Pins
IO-XLR5-M-JLX
Gender
IO-XLR5-M-JLX
Series Identifier
很抱歉,暂时无法提供与“IO-XLR5-F-JLX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+78.860831+10.20186
- 10+66.9841310+8.66542
- 30+61.9861630+8.01886
- 50+59.7914150+7.73494
- 100+56.93683100+7.36565
- 250+53.37325250+6.90465
- 500+50.82774500+6.57535
- 1000+48.404231000+6.26183
