FGG.1B.306.CLAD52
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
1B
Termination type
Male solder
IP rating
50
AWG wire size
30.00 - 22.00
Catalog
Cable Ø
4.30 - 5.20 mm
See video assembly instructions
Status
active
Matching parts
EGG.1B.306.CLL
Download
Request a quote
Eplan
PHG.1B.306.CLLD52
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FG*: Straight plug, cable collet
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
15.29 g
Performance
Configuration
1B.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
7 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
Max. Conductor: 0.34 mm^2 (AWG 22)
R (max): 6.1 mOhm
Vtest (contact-shell): 1200 V (AC), 1700 V (DC)
Vtest (contact-contact): 1050 V (AC), 1490 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S1
S2
mm.
12
43
32
10
9
in.
0,47
1,69
1,26
0,39
0,35
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.1B.015.PA090
Caps:
BFG.1B.100.PCSG
2/3
Cables
CMN.06.T28.044PGZE
Grey
CMN.06.T28.044PNZE
106240
PTFE
White
160140
PVC
Grey
160260
PVC
Black
6280
PVC
Black
3/3
很抱歉,暂时无法提供与“FGG.1B.306.CLAD52”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+323.19344
- 5+316.09120
- 25+305.75026
- 50+295.12815
