2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KPPX-3P
Part Number Builder
KPPX
3
P
Series
No. of
Contacts
Contact
Type
DC POWER CONNECTORS: KPPX Series
Snap and Lock Plug
Series
KPPX - Snap and Lock DC Power Plug Cable Mount
Product Features
Laptop Computers, Power Supplies and Other Portable
Digital Equipment Applications
Snap & Lock Feature Helps to Prevent Accidental
Disconnects
3 or 4 Pins Transmit Power, or One Pin Can Be Used For
Signal Transmission
For Signal and DC Power Applications
Plugs Supplied in Kits Ready for Assembly
Number of Contacts
3 Pin
4 Pin
Contact Type
P - Plug
Mates with:
KPJX, KPJX-PM, and KPJX-CM Series Jacks
Contact Kycon for Other Options
Performance Specifications:
Materials and Finish
Body: ABS, UL 94HB Rated
Insert: Nylon, UL 94V-2 Rated
Inner Shield: Copper Alloy, Nickel Plated
Contacts: Brass, Silver Plated
KPPX Series
Dimensions in mm
Electrical Characteristics:
Contact Rating
3 Position: Pin 1 and 2, 48V DC at 7.5A Max.,
Pin 3, 48V DC 1.0A Max.
4 Position: 48V DC 7.5A Max. For All Pins
Insulation Resistance: 50 Megohms Min. at 250V DC
Dielectric Withstanding Voltage: 500V AC For 1 Minute
Contact Resistance: 30 milliohms Max.
Mechanical Characteristics:
Durability: 1000 Cycles
Suggested Wire Awg.: #18 For Power Wires, #24 for
Signal Wire
Click here for our assembly videos
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0918
很抱歉,暂时无法提供与“KPPX-4P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+28.673151+3.58636
- 10+24.3580510+3.04664
- 25+22.8302625+2.85555
- 50+21.7392150+2.71908
- 200+19.71268200+2.46561
- 400+18.77162400+2.34790
- 600+18.24236600+2.28171
- 1000+17.596941000+2.20098
- 2600+16.450562600+2.05759
