MD-60SV
MD-60SV
    CUIDEVICES
    CONN RCPT FMALE MINI DIN 6P SLDR
MD-60SV 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date page 10/08/2019 1 of 4 SERIES: MD-SV │ DESCRIPTION: MINI DIN CONNECTOR FEATURES • PCB mount • vertical mount • 3~8 pins PART NUMBER KEY MD - XX SV Base Number Pin Options 30 = 3 pins 40 = 4 pins 50 = 5 pins 60 = 6 pins 70 = 7 pins 80 = 8 pins SPECIFICATIONS parameter conditions/description min rated input voltage typ max 12 units Vdc rated input current 2 A contact resistance 30 mΩ 250 Vac 45 N 30 N insulation resistance at 250 Vdc voltage withstand for 1 minute 50 MΩ insertion force withdrawal force 9 operating temperature -20 life 85 1,000 flammability rating UL94V-0 RoHS yes cuidevices.com °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: MD-SV │ DESCRIPTION: MINI DIN CONNECTOR date 10/08/2019 │ page 2 of 4 MECHANICAL DRAWINGS (MD-30SV, MD-40SV, MD-50SV) units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm X.XXX ±0.030 mm MD-30SV   PLATING/COLOR housing PBT (UL94V-0) black contacts phosphor bronze tin shell brass nickel MD-40SV   MATERIAL    MD-50SV      Recommended PCB Layout Bottom View Recommended PCB Layout Bottom View cuidevices.com Recommended PCB Layout Bottom View Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: MD-SV │ DESCRIPTION: MINI DIN CONNECTOR | PCB Footprint date 10/08/2019 │ page 3 of 4 MECHANICAL DRAWINGS (MD-60SV, MD-70SV, MD-80SV) MD-60SV       Recommended PCB Layout Bottom View MD-70SV        Recommended PCB Layout Bottom View cuidevices.com MD-80SV        Recommended PCB Layout Bottom View Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: MD-SV │ DESCRIPTION: MINI DIN CONNECTOR date 10/08/2019 │ page 4 of 4 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 03/07/2012 1.02 updated datasheet 08/25/2017 updated housing, added 7 pin version, brand update 10/08/2019 1.03 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
MD-60SV 价格&库存
很抱歉,暂时无法提供与“MD-60SV”相匹配的价格&库存,您可以联系我们找货
