EXG.0B.307.HLN
www.lemo.com
SUMMARY
# Wires
Low voltage
7
Image is for illustrative purpose only
Series
0B
Termination type
Female print PCB
IP rating
50
AWG wire size
34.00 - 28.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.0B.307.CLAD32
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EX*: Elbow receptacle for printed circuit with two nuts (solder or screw fixing, back panel
mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
PPS (Polyphenylene) shell, other pieces nickel plated [SAE AMS QQ N 290] brass
Weight
11.07 g
Performance
Configuration
0B.307/EXG : 7 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
2 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.5 mm (0.02in)
R (max): 8.7 mOhm
Test voltage contact-contact : 1 kV rms
Test voltage contact-body shell : 1 kV rms
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
12NC part number: 4022.438.73511
DRAWINGS
Dimensions
A
B
D
E
H
I
K
L
M
N
S3
e
mm.
12
12.4
14.6
4.5
6.7
12.6
13.3
25
2.5
11.7
11
M9x0.6
in.
0,47
0,49
0,57
0,18
0,26
0,50
0,52
0,98
0,10
0,46
0,43
RECOMMENDED BY LEMO
Tools
2/3
3/3
很抱歉,暂时无法提供与“EXG.0B.307.HLN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+631.113331+81.97842
- 10+536.4575410+69.68312
- 30+496.4671430+64.48857
- 50+478.9082650+62.20776
- 100+456.07997100+59.24248
