UTS710D6S
UTS710D6S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT FMALE 6POS GOLD SOLDER
UTS710D6S 数据手册
17,93+0,15 -0,10 FEMALE CONNECTOR MALE CONNECTOR C 8 3.2 MAX (Panel thickness) SHELL A B (without marking) B C D E F G H f ; 1 ; RL 19,2+0,35 -0,10 8 I marking thickness 0.2 SOCKET PIN 7 A Ø0.6 ±0.05 for contact #20 Ø1 ±0.05 for contact #16 marking thickness 0.2 6 THREAD 1"20 UNEF CLASS 2A 7 NUT (see tightening torque) J 6 F PANEL CUT OUT INSERT O' RING A ±0.15 B ±0.20 (without marking) C ±0.37 specif. 30 C ±0.20 D E F ± 0.3 Tightening torque (Nut) Thread 11.90 24.00 19.05 19.05 ±0.37 13.75 ± 0.20 14.60 ± 0.20 3.1 2 Nm 3 Nm 14.90 26.90 22.15 22.20 16.40 0/+0.2 17.30 0/+0.25 3.1 12 18.95 31.75 27.15 26.97 20.85 0/+0.3 22.10 0/+0.3 3.1 7/8 20 UNEF CLASS 2A 4 Nm 14 22.15 34.90 30.20 30.15 24.00 0/+0.3 25.40 0/+0.3 3 ± 0.1 1"20 UNEF CLASS 2A 5 Nm 4 10 11/16 24 UNEF CLASS 2A SHELL 10/12/14 2,3 B 2 1 Contact area of receptacle on PCB H G C F 14 4.8/7 5.3/7 E . 5 XX Perçage 1 Perçage 2 A B C D T10 3.98 9.85 5.31 9.20 T12 4.92 12.17 6.56 11.37 T14 5.29 13.10 7.06 12.23 D 4 Orientations Normal (no digit), W,X,Y,Z = different orientations 3 Specification CUSTOMER DRAWING DRILLING PATTERN: Modification of view and cotation f 05/12/13 ISS DATE Designed by: TITLE -- -Latest modification - by: SORIN V. Date:23/10/08 LANDAIS.P MOD N° 2 CUSTOMER DRAWING JAM NUT RECEPTACLE WITH DIPSOLDER CONTACTS UTS HI SEAL Scale TAILLE 7,5 5.2/7 3.85/5.9 for layout 12-14 Insert arrangement (See table) P = Male contact S = Female contact D 4 4.8/7 3.85/5.9 for layout 12-14 D= Dipsolder contacts NOTE : - Insert arrangements : refer to C144-UTS1-A 8,57 12 Shell size ØE - Sealing in mated and unmated conditions: -IP68 : 1 bar during 1 week : immersion under 10 of water (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) 10 4.9/7 Jam nut receptacle UTS PERFORMANCE CHARACTERISTICS : - Operating temperature:-40°C up to 105°C - Insulation resistance:5000 M min - Test potential:2000 Vrms for #16 layout and 1500Vrms for #20 layout - Corrosion salt spray:500 hours - Durability:250 matings and unmatings A 2,3 8,57 3 SHELL 8 4.9/7 UTS7 14 D 19 P MATERIAL : - Shell:Polyamid UL94 V-0 - Insert:Polychloropren (CR) - Seal gasket : Sealing IP68/69K : Silicone - O'ring:nitril - Nut:Aluminium alloy black anodized - Contact: Brass + gold plated DRILLING PATTERN 10 D 5 08 9/16 24 UNEF CLASS 2A J (female connector) 3.8/6 for layout 8-2/8-3/8-4 3.75/5.8 for layout 8-2/8-3/8-4 4.7/7.25 for layout 8-3A/8-98/8-33 4.8/6.9 for layout 8-3A/8-98/8-33 8 SHELL SIZE I (male connector) Shell size 3/1 General linear Tolerances: ± 0.2 WWW.SOURIAU.COM FORMAT C A2 NPRDS / PROJECT UTS This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° C061-UTS1-A B SHEET 1/1 A 1
UTS710D6S 价格&库存
很抱歉,暂时无法提供与“UTS710D6S”相匹配的价格&库存,您可以联系我们找货
