FGG.1B.310.CLAD52Z
FGG.1B.310.CLAD52Z
    LEMO(雷莫)
    FGG.1B.310.CLAD52Z
FGG.1B.310.CLAD52Z 数据手册
FGG.1B.310.CLAD52Z www.lemo.com SUMMARY # Wires Low voltage 10 Image is for illustrative purpose only Series 1B Termination type Male solder IP rating 50 AWG wire size 34.00 - 28.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.1B.310.CLL Download Request a quote Eplan PHG.1B.310.CLLD52Z TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet and nut for fitting a bend relief Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 15.88 g Performance Configuration 1B.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.7 mOhm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-shell): 1500 V (AC), 2120 V (DC) Vtest (contact-contact): 900 V (AC), 1270 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 12 42 31 10 9 in. 0,47 1,65 1,22 0,39 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1B.015.PA090 Caps: BFG.1B.100.PCSG Cables CMN.10.T28.052PGZE Grey CMN.10.T28.052PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.310.CLAD52Z
物料型号:FGG.1B.310.CLAD52Z
器件简介: - 系列:1B - 线数:10根低压线 - 端接类型:焊接 - IP等级:50 - 电缆直径:4.30 - 5.20 mm - 状态:活跃 - 匹配部件:EGG.1B.310.CLL 和 PHG.1B.310.CLLD52Z
引脚分配:1B.310,10根低压线
参数特性: - 壳体样式/型号:FG:直插头,电缆卡环和螺母用于安装弯曲缓解 - 键槽:1个键(alpha=0,插头:男性接触,插座:女性接触) - 壳体材料:黄铜(镀铬[SAE AMS 2460])壳体和卡环螺母,镀镍[SAE AMS QQ N 290]黄铜锁套和中间件 - 变体:Z:用于安装弯曲缓解的螺母 - 重量:15.88克 - 额定电流:2.5安培 - 接触类型:焊接 - 接触直径:0.5毫米(0.02英寸) - 桶直径:0.45毫米(0.018英寸) - 最大实心导体:0.09 mm²(AWG 28) - 最大绞合导体:0.09 mm²(AWG 28) - 最大电阻:8.7毫欧姆 - 绝缘体:L:PEEK(UL 94 / V-0/1.5)
功能详解: - 接触-壳体电压测试:1500 V(交流),2120 V(直流) - 接触-接触电压测试:900 V(交流),1270 V(直流) - 耐久性(壳体):5000次 - 温度范围:-55°C / +250°C - 湿度:≤95% [在60°C / 140°F] - 振动:15 g [10 Hz - 2000 Hz] - 抗冲击性:100 g [6 ms] - 气候类别:50/175/21 - 屏蔽(最小):75 dB(10 MHz),40 dB(1 GHz) - 盐雾腐蚀:>1000小时
应用信息: - 推荐工具:扳手(DCD.1B.015.PA090),保护帽(BFG.1B.100.PCSG) - 推荐电缆:CMN.10.T28.052PGZE(灰色),CMN.10.T28.052PNZE
封装信息: - 尺寸:A 12 mm,L 42 mm,M 31 mm,S1 10 mm,S2 9 mm
FGG.1B.310.CLAD52Z 价格&库存
很抱歉,暂时无法提供与“FGG.1B.310.CLAD52Z”相匹配的价格&库存,您可以联系我们找货
