HR34B-12WLPB-10S(71) 数据手册
Push-on Bayonet Lock Miniature Waterproof Connectors
HR34B Series
Mating : Just inserting plug unit will complete mating
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Un-mating : Rotating sleeve to unlock mating
fig.1
■Features
Cable exit directions
1. Water and dust protection
• IP67 or more (IP68) water and dust protection rating when
fully mated.
• Resistant to industrial grade oils.
• 4-position receptacles are sealed against water penetration
when mounted on the panel - no protective cap is required.
2. Easy and precise mating
• Mating: Just inserting plug unit completes mating
Unmating: Rotating sleeve counterclockwise unlocks
connectors (fig.1)
• Marking helps align plug with receptacle when mating.
• 3 guide keys make blind mating possible.
(Receptacle structure prevents plug from damaging
receptacle terminals)
fig.2
3. Multi-directional cable exit
Right angle plugs allow the cable to exit in 8 directions, in
45˚ increments.(fig.2)
4. Safty standards
The 4-position connectors meet requirements of TUV
standard.
5. Wide variation
Item
Number of positions
Connector type
Terminations(plug)
Terminations(receptacle)
Conduit material
Applicable cable size(Reference)
4,10
straight plug,right angle plug,receptacle
solder,crimp
wire solder
plastic,metal
(Ø5.7~6.5), (Ø6.5~7.3), (Ø8.0~9.0)
2020.96
1
HR34B Series●Push-on Bayonet Lock Miniature Waterproof Connectors
■Product Specifications
Current rating
10 pos. : 3A
4 pos. : 5A
Operating temperature range
-20°C to 125°C
Voltage rating
10 pos. : 200V AC, 250V DC
4 pos. : 200V AC, 200V DC (Pollution degree 3)
400V AC, 400V DC (Pollution degree 2)
Storage temperature range
-10°C to 60°C
Ratings
Item
1.Contact resistance
2.Insulation resistance
20mø max.
1,000Mø min.
Specification
Conditions
1A DC
500V DC
10 pos. : 900V AC / 1 minute
4 pos. : 2,000V AC / 1 minute
3.Withstanding voltage
No flashover or insulation breakdown
4.Vibration
No electrical discontinuity of 10μs or longer
Frequency : 10 to 500 Hz/cycle, total amplitude of 0.75
mm, 98m/s2 each, 3 hours in 3 axis.
5.Shock
Acceleration of 490 m/s2, 11 ms duration,
3 axis, each for 3 hours
6.Durability
(Mating / un-mating)
Contact resistance : 30mø max.
500 cycles
7.Temperature cycle
Insulation resistance : 500Mø min.
Temperature : -55°C / +15° to +35°C / +85°C / +15° to +35°C
Time
:-30 min. / 2 to 3 min.
/ 30 min. / 2 to 3 min.
5 cycles
8.Humidity
Insulation resistance : 50Mø min. (at high humidity)
Insulation resistance : 500Mø min. (when dry)
336 hours at 71°C, and humidity of 95%
9.Water protection
No water penetration inside connector
At the depth of 1meters for 0.5 hours.
■Materials / Finish
●Plugs
Part
Outer shell
Insulator
Female contacts
10 pos.
4 pos.
O-ring
Gasket
Material
Finish
Remarks
Zinc alloy, aluminum alloy, and
polyamide resin (black)
Black chrome plating, black chromate
finish (Trivalent Chromium)
Color : Black
Gold plated
Silver plated
UL94V-0
PPS
Phosphor bronze
Copper alloy
Fluororubber,
Nitrile hydride rubber
●Receptacles
Part
Material
Outer shell
Zinc alloy
Insulator
Male contacts
Ground contact
O-ring
2
10 pos.
4 pos.
4 pos.
PPS
Copper alloy
Brass
Brass
Fluororubber
Finish
Black chromate finish
Color : Black
Gold plated
Silver plated
Silver plated
Remarks
--------------UL94V-0
■Product Number Structure
●Plugs
HR34B - 12 WP A - 10 S - X ( ** )
1
2
3
4
5
6
8
5 Number of contacts.
1 Series name
2 Shell size
3 Shell style
: HR34B Series
: Diameter(mm) of the mating interface of the plug
WP : Straight plug
WLP : Right-angle plug
4 Conduit material and Applicable cable size
A : Conduit material metal, Applicable cable (Reference) : (Ø5.7~6.5)
B : Conduit material metal, Applicable cable (Reference) : (Ø6.5~7.3)
D : Conduit material plastic, Applicable cable (Reference) : (Ø5.7~6.5)
E : Conduit material plastic, Applicable cable (Reference) : (Ø6.5~7.3)
K : Conduit material metal, Applicable cable (Reference) : (Ø8.0~9.0)
7
(Excluding ground contacts)
6 Contact type
S : Female, wire solder
SC : Female, crimp
7 Keying
Blank : Standard
X
: X key position
Other
specifications
: 2 numerical digits wil be added when
8
there is a specifications change other
than shown in positions q to u
●Receptacles
HR34B - 12 WR A - 10 P - X ( ** )
1
1
2
3
4
2
3
4
5
Series name : HR34B Series
Shell size
Shell style
WR : Receptacle
Shell type
A : Square flange for 10 positions
B : Square flange for 4 positions
6
7
8
6 Contact type
P : Male,wire solder
7 Keying
Blank : Standard
X
: X key position
8 Other specifications : 2 numerical digits wil be added when
there is a specification change other
●Crimp contacts
HR34B - SC1 - 2 1 1
1
2
1 Series name : HR34B Series
2 Contact style : SC1 : Female contact
3 Contact type
3
4
5
4 Conductor size : 20 to 25AWG
5 Plating
1 : Gold plated
1 : 100pcs/pack
2 : 10,000pcs/reel
3
■Straight plugs
●Standard type (Conduit material :Plastic)
A
Ø19
49
◆Wire solder
All dimensions : mm
Part No.
HRS No.
A
Applicable cable diameter range(Reference)
HR34B-12WPD-10S
134-0026-0 00
Ø7.4
(Ø5.7~6.5)
HR34B-12WPE-10S
134-0027-2 00
Ø8.5
(Ø6.5~7.3)
HR34B-12WPD-4S
134-0020-3 00
Ø7.4
(Ø5.7~6.5)
HR34B-12WPD-4S-X
134-0023-1 00
HR34B-12WPE-4S
134-0025-7 00
Ø8.5
(Ø6.5~7.3)
HR34B-12WPE-4S-X
134-0031-0 00
HRS No.
A
HR34B-12WPD-10SC
134-0037-6 00
Ø7.4
(Ø5.7~6.5)
HR34B-12WPE-10SC
134-0038-9 00
Ø8.5
(Ø6.5~7.3)
HRS No.
A
HR34B-12WPA-10S(71)
134-0004-7 71
Ø7.4
(Ø5.7~6.5)
HR34B-12WPB-10S(71)
134-0007-5 71
Ø8.5
(Ø6.5~7.3)
HR34B-12WPK-10S
134-0052-0 00
Ø9.5
(Ø8.0~9.0)
HRS No.
A
HR34B-12WPA-10SC
134-0017-9 00
Ø7.4
(Ø5.7~6.5)
HR34B-12WPB-10SC
134-0028-5 00
Ø8.5
(Ø6.5~7.3)
HR34B-12WPK-10SC
134-0053-2 00
Ø9.5
(Ø8.0~9.0)
Solder cup inner diameter
Ø1
Ø1.7
◆Crimp (separate contacts required)
Part No.
●Robust type(Conduit material :Metal)
◆Wire solder
All dimensions : mm
Part No.
Ø1
Part No.
Not all cables of applicable dia. range can be easily assembled.
Please kindly check with factory before use.
BIllustrations of mated connectors.
Straight plug Mating combinations
B
4
B
10 pos.plug + receptacle wire solder
50.1
4 pos.plug + receptacle wire solder
49.6
■Right angle plugs
●Standard type (Conduit material : Plastic)
B
33.5
A
Ø19
◆Wire solder
All dimensions : mm
HRS No.
A
HR34B-12WLPD-10S
Part No.
134-0039-1 00
Ø7.4
(Ø5.7~6.5)
HR34B-12WLPE-10S
134-0040-0 00
Ø8.5
(Ø6.5~7.3)
HR34B-12WLPD-4S
134-0030-7 00
HR34B-12WLPD-4S-X
134-0034-8 00
HR34B-12WLPE-4S
134-0035-0 00
HR34B-12WLPE-4S-X
134-0036-3 00
Ø7.4
B
30.85
Ø1
(Ø5.7~6.5)
Ø1.7
Ø8.5
(Ø6.5~7.3)
Part No.
HRS No.
A
HR34B-12WLPD-10SC
134-0041-3 00
Ø7.4
HR34B-12WLPE-10SC
134-0042-6 00
Ø8.5
B
(Ø5.7~6.5)
30.85
(Ø6.5~7.3)
●Robust type (Conduit material :Metal)
◆Wire solder
All dimensions : mm
Part No.
HRS No.
A
B
HR34B-12WLPA-10S(71)
134-0005-0 71
Ø7.4
134-0008-8 71
Ø8.5
HR34B-12WLPK-10S
134-0054-5 00
Ø9.5
31.5
(Ø8.0~9.0)
HRS No.
A
B
HR34B-12WLPA-10SC
134-0018-1 00
Ø7.4
HR34B-12WLPB-10SC
134-0029-8 00
Ø8.5
HR34B-12WLPK-10SC
134-0055-8 00
Ø9.5
(Ø5.7~6.5)
30.5
(Ø6.5~7.3)
Ø1
Part No.
30.5
31.5
(Ø5.7~6.5)
(Ø6.5~7.3)
(Ø8.0~9.0)
Right-angle plug Mating Combinations
A
(33.5)
10 pos. plug shell A,B type.
Plug + receptacle wire solder
31.0
10 pos. plug shell D,E type.
31.3
10 pos. plug shell K type.
32.0
4 pos. plug + receptacle wire solder
31.3
A
5
■Receptacles
◆Wire solder
48)
2.
(R
3.2
4-Ø
1
3
8
10
B
A
4
7
A
B
All dimensions : mm
Part No.
HRS No.
A
B
HR34B-12WRA-10P
134-0016-6 00
17.26
23.4
Ø1
HR34B-12WRB-4P
134-0021-6 00
18.26
25.4
Ø1.4
HR34B-12WRB-4P-X
134-0024-4 00
O ring for water proof is not attached. Please find appropriate one from the market.
BRecommended panel cutouts
●Receptacle - wire solder
All dimensions : mm
4-B
HR34B-12WRA-10P
HR34B-12WRB-4P
HR34B-12WRB-4P-X
17.26±0.05
18.26±0.05
A
A
B
A
M3∞0.5
C
1 0/-0.1
1.1 0/-0.1
D
12.5 +0.1/0
16.3 +0.1/0
E
17 +0.1/0
20.8 +0.1/0
C
Recommended O ring dia.
Part No.
HR34B-12WRA-10P
ØD
HR34B-12WRB-4P
ØE
HR34B-12WRB-4P-X
Thickness
Inner diameter
Ø1.5
Ø11.5
Ø1.5
Ø15.5
BReceptacle Contact Arrangement
4 pos.wire solder
10 pos.wire solder
note.1 View direction : Mating surface
note.2
mark is ground terminal.
1
2
1
4
3
8
BCrimp contacts
2
5
3
6
9
7
10
15
1.2
◆Female
Part No.
HRS No.
Applicable conductor
20 to 25AWG
(Stranded wire)
HR34B-SC1-111
134-0051-7 00
100 pcs/pack
HR34B-SC1-211
134-0050-4 00
10,000 pcs/reel
Note : Use wire with a jacket diameter of 1.7mm max.
6
Packaging
BConnector Mating Combinations
10 pos. Plugs
10 pos. Receptacles
Straight, Wire Solder or Crimp
HR34B-12WPA-10S(71),10SC HR34B-12WPB-10S(71),10SC
HR34B-12WPD-10S,10SC HR34B-12WPE-10S,10SC
HR34B-12WPK-10S,10SC
Wire Solder
HR34B-12WRA-10P
Right angle, Wire Solder or Crimp
HR34B-12WLPA-10S(71),10SC HR34B-12WLPB-10S(71),10SC
HR34B-12WLPD-10S,10SC HR34B-12WLPE-10S,10SC
HR34B-12WLPK-10S,10SC
4 pos. Plugs
4 pos. Receptacles
Straight, Wire Solder (Standard key position)
HR34B-12WPD-4S
HR34B-12WPE-4S
Standard
key position
Wire solder (Standard key position)
HR34B-12WRB-4P
Right angle, Wire Solder (Standard key position)
HR34B-12WLPD-4S
HR34B-12WLPE-4S
Straight, Wire Solder (X key position)
HR34B-12WPD-4S-X
HR34B-12WPE-4S-X
Wire solder (X key position)
HR34B-12WRB-4P-X
Right angle, Wire Solder (X key position)
HR34B-12WLPD-4S-X
HR34B-12WLPE-4S-X
X key position
X key position
7
BApplicable tools
Type
Automatic Crimping Machine Body
Automatic Crimping Machine Applicator
Part No.
CM-105C
AP105-HR34B-1
HRS No.
901-0001-0
901-2051-2
Applicable Cable
Manual Crimp Tool
HT304/HR34B-1
150-0107-9
UL20276
20 AWG,23 AWG,25 AWG
HR34B-SC1-111
Terminal Extraction Tool
RP6-SC-TP
150-0039-0
HR34B-SC1-111
HR34B-SC1-211
20 AWG to 25 AWG
Applicable Contact
HR34B-SC1-211
Note 1 : Perform crimping based on the "Crimping Quality Standards" and "Crimping Conditions Table"
Note 2 : Problems that occur when using tools not designated by Hirose are outside the scope of warranty.
Note 3 : The applicable cables and applicable contacts are limited to those listed in the above table. For inquiries on cables not listed
contact a Hirose representative.
◆Manual contact crimping tool ◆Press CM-105C (Applicator ◆Contact extraction tool
ordered separate)
BHandling
1. Mating
2. Un-mating
Plug
Receptacle
B
A
Rotate counter-clockwise
Mating position alignment marks
Holding the plug by the outer shell (A) align the arrow on the plug
with the alignment mark on the receptacle and push straight in.
BPrecautions
Rotate the sleeve (B) counter-clockwise to a full stop and un-mate
the plug from the receptacle.
Center line of the connector
Alignment mark
When completely mated and locked the alignment
arrow on the plug must line-up with the center line of
the connector (alignment mark on the receptacle).
If the alignment arrow and the center line of the
connectors are not aligned (1mm max.) re-insert the
plug until they are aligned.
1 mm max.
1. When disconnecting or inserting the connector, be sure to do so after turning off the power.
2. To insert the connector, push it in until the arrow tip of the plug mating mark indicates the specified position of the diagram below
(i.e., the mating mark of the receptacle).
3. Note that the display method of the mating mark will differ depending on the receptacle.
4. To maintain the waterproof quality and cable clamp force, use a cable that is within the range of the applicable cable diameter.
5. Please consult Hirose Electric Sales for harness assembly procedure (ETAD-C0116-00).
6. Please note that the white label on the connector may come off due to solvents such as alcohol.
8
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 09/2020. Contents are subject to change without notice for the purpose of improvements.
