DF13E-10DP-1.25V(25) 数据手册
Applicable standard
Operating
temperature range
Rating
-35C to +85C(Note 1)
20 % to 80 % (Note 2)
Operating
humidity range
-10C to +60C(Note 3)
40 % to 70 %(Note 3)
Storage
humidity range
150 V AC (DC)
Current
DF13-*DS-1.25C
Applicable
Contact
Voltage
Applicable
Connector
Storage
temperature range
1
A
DF13(G)-2630SCF
DF13-3032SCF
Specifications
Nov.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case that the application demands a high level of reliability, such as automotive,
please contact a company representative for further information.
Item
Construction
Powered by TCPDF (www.tcpdf.org)
Test method
General examination
Visually and by measuring instrument.
Marking
Confirmed visually.
Requirements
QT AT
According to drawing.
X
X
X
X
Electric characteristics
Contact resistance
100 m A (DC or 1000 Hz).
30 m MAX.
X
Insulation resistance
100 V DC.
500 M MIN.
X
Voltage proof
500 V AC for 1 min.
No flashover or breakdown.
X
X
X
X
X
X
X
X
Mechanical characteristics
Mechanical operation
30 times insertions and extractions.
Vibration
Frequency 10 to 55 Hz, single amplitude
0.75 mm, at 2 h, for 3 directions.
490 m/s2 duration of pulse 11 ms at 3 times for 3
directions.
Shock
①
②
①
②
Contact resistance: 30 m MAX.
No damage, crack or looseness of parts.
No electrical discontinuity of 1s.
Environmental characteristics
Temperature -55→ 15 to 35→+85→ 15 to 35 c
Time
30→ 2 to 3 → 30→ 2 to 3 min.
Under 5 cycles.
Exposed at 40 ± 2 c, 90 to 95 , 96 h.
① Contact resistance:
30m MAX.
② Insulation resistance: 500 M MIN.
③ No damage, crack or looseness of parts.
Resistance to soldering
heat
1) Reflow soldering
No deformation of case of excessive looseness
of the terminals.
Solderability
Soldered at solder temperature,
245c for insertion duration, 3sec.
Rapid change of
temperature
Damp heat
(Steady state)
≪Reflow area≫
250℃ MAX
10 sec MAX
230℃ MIN
60 sec MAX
≪Preheating area≫
170℃ to 190℃ 60 sec to 120 sec
Put through in reflow furnace twice,
leave in ambient temperature and
humidity for 1 hour.
2) Manual soldering
Soldering iron temperature :300℃,
Soldering time : 3sec.
No strength on contact.
Solder shall cover a minimum of
95 of the surface being immersed.
Remarks
Note 1:Include the temperature rising by current.
Note 2:No condensing
Note 3:Apply to the condition of long term storage for unused products before pcb on board,
after pcb on board, operating temperature and humidity range is applied for interim storage during transportation.
Count
Description of revisions
Unless otherwise specifid , refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
Designed
Checked
Date
Approved
KI.AKIYAMA
16.04.04
Checked
TS.FUKUSHIMA
16.04.04
Designed
YK.YAMAGUCHI
16.04.04
Drawn
MI.SAKIMURA
16.04.01
Drawing no.
Specification sheet
Part no.
Hirose electric co., ltd.
Code no.
ELC-367983-25-00
DF13E-*DP-1.25V(25)
CL536
DF13E-10DP-1.25V(25) 价格&库存
很抱歉,暂时无法提供与“DF13E-10DP-1.25V(25)”相匹配的价格&库存,您可以联系我们找货
